MOAB
4.9.3pre
Standard Cholesky decomposition (LL^T) of a matrix and associated features. More...
#include <LLT.h>
Public Types | |
| enum | { RowsAtCompileTime = MatrixType::RowsAtCompileTime, ColsAtCompileTime = MatrixType::ColsAtCompileTime, Options = MatrixType::Options, MaxColsAtCompileTime = MatrixType::MaxColsAtCompileTime } |
| enum | { PacketSize = internal::packet_traits<Scalar>::size, AlignmentMask = int(PacketSize)-1, UpLo = _UpLo } |
| typedef _MatrixType | MatrixType |
| typedef MatrixType::Scalar | Scalar |
| typedef NumTraits< typename MatrixType::Scalar >::Real | RealScalar |
| typedef Eigen::Index | Index |
| typedef MatrixType::StorageIndex | StorageIndex |
| typedef internal::LLT_Traits < MatrixType, UpLo > | Traits |
Public Member Functions | |
| LLT () | |
| Default Constructor. | |
| LLT (Index size) | |
| Default Constructor with memory preallocation. | |
| template<typename InputType > | |
| LLT (const EigenBase< InputType > &matrix) | |
| Traits::MatrixU | matrixU () const |
| Traits::MatrixL | matrixL () const |
| template<typename Rhs > | |
| const Solve< LLT, Rhs > | solve (const MatrixBase< Rhs > &b) const |
| template<typename Derived > | |
| void | solveInPlace (MatrixBase< Derived > &bAndX) const |
| LLT & | compute (const EigenBase< InputType > &matrix) |
| const MatrixType & | matrixLLT () const |
| MatrixType | reconstructedMatrix () const |
| ComputationInfo | info () const |
| Reports whether previous computation was successful. | |
| Index | rows () const |
| Index | cols () const |
| template<typename VectorType > | |
| LLT | rankUpdate (const VectorType &vec, const RealScalar &sigma=1) |
| template<typename RhsType , typename DstType > | |
| EIGEN_DEVICE_FUNC void | _solve_impl (const RhsType &rhs, DstType &dst) const |
Static Protected Member Functions | |
| static void | check_template_parameters () |
Protected Attributes | |
| MatrixType | m_matrix |
| bool | m_isInitialized |
| ComputationInfo | m_info |
| _MatrixType | the type of the matrix of which we are computing the LL^T Cholesky decomposition |
| _UpLo | the triangular part that will be used for the decompositon: Lower (default) or Upper. The other triangular part won't be read. |
This class performs a LL^T Cholesky decomposition of a symmetric, positive definite matrix A such that A = LL^* = U^*U, where L is lower triangular.
While the Cholesky decomposition is particularly useful to solve selfadjoint problems like D^*D x = b, for that purpose, we recommend the Cholesky decomposition without square root which is more stable and even faster. Nevertheless, this standard Cholesky decomposition remains useful in many other situations like generalised eigen problems with hermitian matrices.
Remember that Cholesky decompositions are not rank-revealing. This LLT decomposition is only stable on positive definite matrices, use LDLT instead for the semidefinite case. Also, do not use a Cholesky decomposition to determine whether a system of equations has a solution.
Example:
Output:
| typedef Eigen::Index Eigen::LLT< _MatrixType, _UpLo >::Index |
| typedef _MatrixType Eigen::LLT< _MatrixType, _UpLo >::MatrixType |
| typedef NumTraits<typename MatrixType::Scalar>::Real Eigen::LLT< _MatrixType, _UpLo >::RealScalar |
| typedef MatrixType::Scalar Eigen::LLT< _MatrixType, _UpLo >::Scalar |
| typedef MatrixType::StorageIndex Eigen::LLT< _MatrixType, _UpLo >::StorageIndex |
| typedef internal::LLT_Traits<MatrixType,UpLo> Eigen::LLT< _MatrixType, _UpLo >::Traits |
| anonymous enum |
Definition at line 54 of file LLT.h.
| anonymous enum |
Definition at line 65 of file LLT.h.
UpLo = _UpLo
| Eigen::LLT< _MatrixType, _UpLo >::LLT | ( | ) | [inline] |
The default constructor is useful in cases in which the user intends to perform decompositions via LLT::compute(const MatrixType&).
Definition at line 79 of file LLT.h.
: m_matrix(), m_isInitialized(false) {}
| Eigen::LLT< _MatrixType, _UpLo >::LLT | ( | Index | size | ) | [inline, explicit] |
| Eigen::LLT< _MatrixType, _UpLo >::LLT | ( | const EigenBase< InputType > & | matrix | ) | [inline, explicit] |
Definition at line 91 of file LLT.h.
: m_matrix(matrix.rows(), matrix.cols()), m_isInitialized(false) { compute(matrix.derived()); }
| void Eigen::LLT< _MatrixType, _UpLo >::_solve_impl | ( | const RhsType & | rhs, |
| DstType & | dst | ||
| ) | const |
Definition at line 426 of file LLT.h.
dst = rhs;
solveInPlace(dst);
| static void Eigen::LLT< _MatrixType, _UpLo >::check_template_parameters | ( | ) | [inline, static, protected] |
| Index Eigen::LLT< _MatrixType, _UpLo >::cols | ( | ) | const [inline] |
| LLT< MatrixType, _UpLo > & Eigen::LLT< MatrixType, _UpLo >::compute | ( | const EigenBase< InputType > & | a | ) |
Computes / recomputes the Cholesky decomposition A = LL^* = U^*U of matrix
Example:
Output:
Definition at line 387 of file LLT.h.
check_template_parameters();
eigen_assert(a.rows()==a.cols());
const Index size = a.rows();
m_matrix.resize(size, size);
m_matrix = a.derived();
m_isInitialized = true;
bool ok = Traits::inplace_decomposition(m_matrix);
m_info = ok ? Success : NumericalIssue;
return *this;
| ComputationInfo Eigen::LLT< _MatrixType, _UpLo >::info | ( | ) | const [inline] |
Success if computation was succesful, NumericalIssue if the matrix.appears to be negative. Definition at line 156 of file LLT.h.
eigen_assert(m_isInitialized && "LLT is not initialized.");
return m_info;
| Traits::MatrixL Eigen::LLT< _MatrixType, _UpLo >::matrixL | ( | ) | const [inline] |
Definition at line 106 of file LLT.h.
return Traits::getL(m_matrix);
| const MatrixType& Eigen::LLT< _MatrixType, _UpLo >::matrixLLT | ( | ) | const [inline] |
TODO: document the storage layout
Definition at line 142 of file LLT.h.
return m_matrix;
| Traits::MatrixU Eigen::LLT< _MatrixType, _UpLo >::matrixU | ( | ) | const [inline] |
Definition at line 99 of file LLT.h.
return Traits::getU(m_matrix);
| LLT< _MatrixType, _UpLo > Eigen::LLT< _MatrixType, _UpLo >::rankUpdate | ( | const VectorType & | v, |
| const RealScalar & | sigma = 1 |
Performs a rank one update (or dowdate) of the current decomposition. If A = LL^* before the rank one update, then after it we have LL^* = A + sigma * v v^* where v must be a vector of same dimension.
Definition at line 410 of file LLT.h.
EIGEN_STATIC_ASSERT_VECTOR_ONLY(VectorType);
eigen_assert(v.size()==m_matrix.cols());
eigen_assert(m_isInitialized);
if(internal::llt_inplace<typename MatrixType::Scalar, UpLo>::rankUpdate(m_matrix,v,sigma)>=0)
m_info = NumericalIssue;
else
m_info = Success;
return *this;
| MatrixType Eigen::LLT< MatrixType, _UpLo >::reconstructedMatrix | ( | ) | const |
Definition at line 457 of file LLT.h.
return matrixL() * matrixL().adjoint().toDenseMatrix();
| Index Eigen::LLT< _MatrixType, _UpLo >::rows | ( | ) | const [inline] |
| const Solve<LLT, Rhs> Eigen::LLT< _MatrixType, _UpLo >::solve | ( | const MatrixBase< Rhs > & | b | ) | const [inline] |
using the current decomposition of A.Since this LLT class assumes anyway that the matrix A is invertible, the solution theoretically exists and is unique regardless of b.
Example:
Output:
Definition at line 124 of file LLT.h.
eigen_assert(m_matrix.rows()==b.rows()
&& "LLT::solve(): invalid number of rows of the right hand side matrix b");
return Solve<LLT, Rhs>(*this, b.derived());
| void Eigen::LLT< MatrixType, _UpLo >::solveInPlace | ( | MatrixBase< Derived > & | bAndX | ) | const |
use x = llt_object.solve(x);
This is the in-place version of solve().
| bAndX | represents both the right-hand side matrix b and result x. |
This version avoids a copy when the right hand side matrix b is not needed anymore.
Definition at line 445 of file LLT.h.
eigen_assert(m_matrix.rows()==bAndX.rows());
matrixL().solveInPlace(bAndX);
matrixU().solveInPlace(bAndX);
ComputationInfo Eigen::LLT< _MatrixType, _UpLo >::m_info [protected] |
bool Eigen::LLT< _MatrixType, _UpLo >::m_isInitialized [protected] |
MatrixType Eigen::LLT< _MatrixType, _UpLo >::m_matrix [protected] |
