MOAB
4.9.3pre
Robust Cholesky decomposition of a matrix with pivoting. More...
#include <LDLT.h>
Public Types | |
| enum | { RowsAtCompileTime = MatrixType::RowsAtCompileTime, ColsAtCompileTime = MatrixType::ColsAtCompileTime, Options = MatrixType::Options & ~RowMajorBit, MaxRowsAtCompileTime = MatrixType::MaxRowsAtCompileTime, MaxColsAtCompileTime = MatrixType::MaxColsAtCompileTime, UpLo = _UpLo } |
| typedef _MatrixType | MatrixType |
| typedef MatrixType::Scalar | Scalar |
| typedef NumTraits< typename MatrixType::Scalar >::Real | RealScalar |
| typedef Eigen::Index | Index |
| typedef MatrixType::StorageIndex | StorageIndex |
| typedef Matrix< Scalar, RowsAtCompileTime, 1, Options, MaxRowsAtCompileTime, 1 > | TmpMatrixType |
| typedef Transpositions < RowsAtCompileTime, MaxRowsAtCompileTime > | TranspositionType |
| typedef PermutationMatrix < RowsAtCompileTime, MaxRowsAtCompileTime > | PermutationType |
| typedef internal::LDLT_Traits < MatrixType, UpLo > | Traits |
Public Member Functions | |
| LDLT () | |
| Default Constructor. | |
| LDLT (Index size) | |
| Default Constructor with memory preallocation. | |
| template<typename InputType > | |
| LDLT (const EigenBase< InputType > &matrix) | |
| Constructor with decomposition. | |
| void | setZero () |
| Traits::MatrixU | matrixU () const |
| Traits::MatrixL | matrixL () const |
| const TranspositionType & | transpositionsP () const |
| Diagonal< const MatrixType > | vectorD () const |
| bool | isPositive () const |
| bool | isNegative (void) const |
| template<typename Rhs > | |
| const Solve< LDLT, Rhs > | solve (const MatrixBase< Rhs > &b) const |
| template<typename Derived > | |
| bool | solveInPlace (MatrixBase< Derived > &bAndX) const |
| LDLT & | compute (const EigenBase< InputType > &matrix) |
| LDLT & | rankUpdate (const MatrixBase< Derived > &w, const RealScalar &alpha=1) |
| const MatrixType & | matrixLDLT () const |
| MatrixType | reconstructedMatrix () const |
| Index | rows () const |
| Index | cols () const |
| ComputationInfo | info () const |
| Reports whether previous computation was successful. | |
| template<typename RhsType , typename DstType > | |
| EIGEN_DEVICE_FUNC void | _solve_impl (const RhsType &rhs, DstType &dst) const |
| LDLT< MatrixType, _UpLo > & | rankUpdate (const MatrixBase< Derived > &w, const typename LDLT< MatrixType, _UpLo >::RealScalar &sigma) |
Static Protected Member Functions | |
| static void | check_template_parameters () |
Protected Attributes | |
| MatrixType | m_matrix |
| TranspositionType | m_transpositions |
| TmpMatrixType | m_temporary |
| internal::SignMatrix | m_sign |
| bool | m_isInitialized |
| _MatrixType | the type of the matrix of which to compute the LDL^T Cholesky decomposition |
| _UpLo | the triangular part that will be used for the decompositon: Lower (default) or Upper. The other triangular part won't be read. |
Perform a robust Cholesky decomposition of a positive semidefinite or negative semidefinite matrix
such that
, where P is a permutation matrix, L is lower triangular with a unit diagonal and D is a diagonal matrix.
The decomposition uses pivoting to ensure stability, so that L will have zeros in the bottom right rank(A) - n submatrix. Avoiding the square root on D also stabilizes the computation.
Remember that Cholesky decompositions are not rank-revealing. Also, do not use a Cholesky decomposition to determine whether a system of equations has a solution.
| typedef Eigen::Index Eigen::LDLT< _MatrixType, _UpLo >::Index |
| typedef _MatrixType Eigen::LDLT< _MatrixType, _UpLo >::MatrixType |
| typedef PermutationMatrix<RowsAtCompileTime, MaxRowsAtCompileTime> Eigen::LDLT< _MatrixType, _UpLo >::PermutationType |
| typedef NumTraits<typename MatrixType::Scalar>::Real Eigen::LDLT< _MatrixType, _UpLo >::RealScalar |
| typedef MatrixType::Scalar Eigen::LDLT< _MatrixType, _UpLo >::Scalar |
| typedef MatrixType::StorageIndex Eigen::LDLT< _MatrixType, _UpLo >::StorageIndex |
| typedef Matrix<Scalar, RowsAtCompileTime, 1, Options, MaxRowsAtCompileTime, 1> Eigen::LDLT< _MatrixType, _UpLo >::TmpMatrixType |
| typedef internal::LDLT_Traits<MatrixType,UpLo> Eigen::LDLT< _MatrixType, _UpLo >::Traits |
| typedef Transpositions<RowsAtCompileTime, MaxRowsAtCompileTime> Eigen::LDLT< _MatrixType, _UpLo >::TranspositionType |
| anonymous enum |
| RowsAtCompileTime | |
| ColsAtCompileTime | |
| Options | |
| MaxRowsAtCompileTime | |
| MaxColsAtCompileTime | |
| UpLo |
Definition at line 52 of file LDLT.h.
Options = MatrixType::Options & ~RowMajorBit, // these are the options for the TmpMatrixType, we need a ColMajor matrix here!
UpLo = _UpLo
| Eigen::LDLT< _MatrixType, _UpLo >::LDLT | ( | ) | [inline] |
The default constructor is useful in cases in which the user intends to perform decompositions via LDLT::compute(const MatrixType&).
Definition at line 76 of file LDLT.h.
: m_matrix(), m_transpositions(), m_sign(internal::ZeroSign), m_isInitialized(false) {}
| Eigen::LDLT< _MatrixType, _UpLo >::LDLT | ( | Index | size | ) | [inline, explicit] |
Like the default constructor but with preallocation of the internal data according to the specified problem size.
Definition at line 89 of file LDLT.h.
: m_matrix(size, size), m_transpositions(size), m_temporary(size), m_sign(internal::ZeroSign), m_isInitialized(false) {}
| Eigen::LDLT< _MatrixType, _UpLo >::LDLT | ( | const EigenBase< InputType > & | matrix | ) | [inline, explicit] |
This calculates the decomposition for the input matrix.
Definition at line 103 of file LDLT.h.
: m_matrix(matrix.rows(), matrix.cols()), m_transpositions(matrix.rows()), m_temporary(matrix.rows()), m_sign(internal::ZeroSign), m_isInitialized(false) { compute(matrix.derived()); }
| void Eigen::LDLT< _MatrixType, _UpLo >::_solve_impl | ( | const RhsType & | rhs, |
| DstType & | dst | ||
| ) | const |
Definition at line 488 of file LDLT.h.
eigen_assert(rhs.rows() == rows());
// dst = P b
dst = m_transpositions * rhs;
// dst = L^-1 (P b)
matrixL().solveInPlace(dst);
// dst = D^-1 (L^-1 P b)
// more precisely, use pseudo-inverse of D (see bug 241)
using std::abs;
const typename Diagonal<const MatrixType>::RealReturnType vecD(vectorD());
// In some previous versions, tolerance was set to the max of 1/highest and the maximal diagonal entry * epsilon
// as motivated by LAPACK's xGELSS:
// RealScalar tolerance = numext::maxi(vecD.array().abs().maxCoeff() * NumTraits<RealScalar>::epsilon(),RealScalar(1) / NumTraits<RealScalar>::highest());
// However, LDLT is not rank revealing, and so adjusting the tolerance wrt to the highest
// diagonal element is not well justified and leads to numerical issues in some cases.
// Moreover, Lapack's xSYTRS routines use 0 for the tolerance.
RealScalar tolerance = RealScalar(1) / NumTraits<RealScalar>::highest();
for (Index i = 0; i < vecD.size(); ++i)
if(abs(vecD(i)) > tolerance)
dst.row(i) /= vecD(i);
else
dst.row(i).setZero();
// dst = L^-T (D^-1 L^-1 P b)
matrixU().solveInPlace(dst);
// dst = P^-1 (L^-T D^-1 L^-1 P b) = A^-1 b
dst = m_transpositions.transpose() * dst;
| static void Eigen::LDLT< _MatrixType, _UpLo >::check_template_parameters | ( | ) | [inline, static, protected] |
| Index Eigen::LDLT< _MatrixType, _UpLo >::cols | ( | ) | const [inline] |
| LDLT< MatrixType, _UpLo > & Eigen::LDLT< MatrixType, _UpLo >::compute | ( | const EigenBase< InputType > & | a | ) |
Compute / recompute the LDLT decomposition A = L D L^* = U^* D U of matrix
Definition at line 433 of file LDLT.h.
check_template_parameters();
eigen_assert(a.rows()==a.cols());
const Index size = a.rows();
m_matrix = a.derived();
m_transpositions.resize(size);
m_isInitialized = false;
m_temporary.resize(size);
m_sign = internal::ZeroSign;
internal::ldlt_inplace<UpLo>::unblocked(m_matrix, m_transpositions, m_temporary, m_sign);
m_isInitialized = true;
return *this;
| ComputationInfo Eigen::LDLT< _MatrixType, _UpLo >::info | ( | ) | const [inline] |
Success if computation was succesful, NumericalIssue if the matrix.appears to be negative. Definition at line 218 of file LDLT.h.
eigen_assert(m_isInitialized && "LDLT is not initialized.");
return Success;
| bool Eigen::LDLT< _MatrixType, _UpLo >::isNegative | ( | void | ) | const [inline] |
Definition at line 158 of file LDLT.h.
return m_sign == internal::NegativeSemiDef || m_sign == internal::ZeroSign;
| bool Eigen::LDLT< _MatrixType, _UpLo >::isPositive | ( | ) | const [inline] |
Definition at line 151 of file LDLT.h.
return m_sign == internal::PositiveSemiDef || m_sign == internal::ZeroSign;
| Traits::MatrixL Eigen::LDLT< _MatrixType, _UpLo >::matrixL | ( | ) | const [inline] |
Definition at line 129 of file LDLT.h.
return Traits::getL(m_matrix);
| const MatrixType& Eigen::LDLT< _MatrixType, _UpLo >::matrixLDLT | ( | ) | const [inline] |
TODO: document the storage layout
Definition at line 202 of file LDLT.h.
return m_matrix;
| Traits::MatrixU Eigen::LDLT< _MatrixType, _UpLo >::matrixU | ( | ) | const [inline] |
Definition at line 122 of file LDLT.h.
return Traits::getU(m_matrix);
| LDLT& Eigen::LDLT< _MatrixType, _UpLo >::rankUpdate | ( | const MatrixBase< Derived > & | w, |
| const RealScalar & | alpha = 1 |
| LDLT<MatrixType,_UpLo>& Eigen::LDLT< _MatrixType, _UpLo >::rankUpdate | ( | const MatrixBase< Derived > & | w, |
| const typename LDLT< MatrixType, _UpLo >::RealScalar & | sigma | ||
Update the LDLT decomposition: given A = L D L^T, efficiently compute the decomposition of A + sigma w w^T.
| w | a vector to be incorporated into the decomposition. |
| sigma | a scalar, +1 for updates and -1 for "downdates," which correspond to removing previously-added column vectors. Optional; default value is +1. |
Definition at line 460 of file LDLT.h.
typedef typename TranspositionType::StorageIndex IndexType;
const Index size = w.rows();
if (m_isInitialized)
eigen_assert(m_matrix.rows()==size);
else
m_matrix.resize(size,size);
m_matrix.setZero();
for (Index i = 0; i < size; i++)
m_transpositions.coeffRef(i) = IndexType(i);
m_sign = sigma>=0 ? internal::PositiveSemiDef : internal::NegativeSemiDef;
internal::ldlt_inplace<UpLo>::update(m_matrix, m_transpositions, m_temporary, w, sigma);
return *this;
| MatrixType Eigen::LDLT< MatrixType, _UpLo >::reconstructedMatrix | ( | ) | const |
Definition at line 554 of file LDLT.h.
const Index size = m_matrix.rows();
MatrixType res(size,size);
// P
res.setIdentity();
res = transpositionsP() * res;
// L^* P
res = matrixU() * res;
// D(L^*P)
res = vectorD().real().asDiagonal() * res;
// L(DL^*P)
res = matrixL() * res;
// P^T (LDL^*P)
res = transpositionsP().transpose() * res;
return res;
| Index Eigen::LDLT< _MatrixType, _UpLo >::rows | ( | ) | const [inline] |
| void Eigen::LDLT< _MatrixType, _UpLo >::setZero | ( | ) | [inline] |
Clear any existing decomposition
Definition at line 116 of file LDLT.h.
| const Solve<LDLT, Rhs> Eigen::LDLT< _MatrixType, _UpLo >::solve | ( | const MatrixBase< Rhs > & | b | ) | const [inline] |
using the current decomposition of A.This function also supports in-place solves using the syntax x = decompositionObject.solve(x) .
More precisely, this method solves
using the decomposition
by solving the systems
and
in succession. If the matrix
is singular, then
will also be singular (all the other matrices are invertible). In that case, the least-square solution of
is computed. This does not mean that this function computes the least-square solution of
is
is singular.
Definition at line 181 of file LDLT.h.
eigen_assert(m_matrix.rows()==b.rows()
&& "LDLT::solve(): invalid number of rows of the right hand side matrix b");
return Solve<LDLT, Rhs>(*this, b.derived());
| bool Eigen::LDLT< MatrixType, _UpLo >::solveInPlace | ( | MatrixBase< Derived > & | bAndX | ) | const |
use x = ldlt_object.solve(x);
This is the in-place version of solve().
| bAndX | represents both the right-hand side matrix b and result x. |
This version avoids a copy when the right hand side matrix b is not needed anymore.
Definition at line 540 of file LDLT.h.
eigen_assert(m_matrix.rows() == bAndX.rows());
bAndX = this->solve(bAndX);
return true;
| const TranspositionType& Eigen::LDLT< _MatrixType, _UpLo >::transpositionsP | ( | ) | const [inline] |
Definition at line 137 of file LDLT.h.
return m_transpositions;
| Diagonal<const MatrixType> Eigen::LDLT< _MatrixType, _UpLo >::vectorD | ( | ) | const [inline] |
Definition at line 144 of file LDLT.h.
return m_matrix.diagonal();
bool Eigen::LDLT< _MatrixType, _UpLo >::m_isInitialized [protected] |
MatrixType Eigen::LDLT< _MatrixType, _UpLo >::m_matrix [protected] |
Used to compute and store the Cholesky decomposition A = L D L^* = U^* D U. The strict upper part is used during the decomposition, the strict lower part correspond to the coefficients of L (its diagonal is equal to 1 and is not stored), and the diagonal entries correspond to D.
internal::SignMatrix Eigen::LDLT< _MatrixType, _UpLo >::m_sign [protected] |
TmpMatrixType Eigen::LDLT< _MatrixType, _UpLo >::m_temporary [protected] |
TranspositionType Eigen::LDLT< _MatrixType, _UpLo >::m_transpositions [protected] |
