MOAB
4.9.3pre
#include <PaStiXSupport.h>
Public Types | |
| enum | { ColsAtCompileTime = MatrixType::ColsAtCompileTime, MaxColsAtCompileTime = MatrixType::MaxColsAtCompileTime } |
| typedef internal::pastix_traits < Derived >::MatrixType | _MatrixType |
| typedef _MatrixType | MatrixType |
| typedef MatrixType::Scalar | Scalar |
| typedef MatrixType::RealScalar | RealScalar |
| typedef MatrixType::StorageIndex | StorageIndex |
| typedef Matrix< Scalar, Dynamic, 1 > | Vector |
| typedef SparseMatrix< Scalar, ColMajor > | ColSpMatrix |
Public Member Functions | |
| PastixBase () | |
| ~PastixBase () | |
| template<typename Rhs , typename Dest > | |
| bool | _solve_impl (const MatrixBase< Rhs > &b, MatrixBase< Dest > &x) const |
| Array< StorageIndex, IPARM_SIZE, 1 > & | iparm () |
| int & | iparm (int idxparam) |
| Array< double, DPARM_SIZE, 1 > & | dparm () |
| double & | dparm (int idxparam) |
| Index | cols () const |
| Index | rows () const |
| ComputationInfo | info () const |
| Reports whether previous computation was successful. | |
Protected Types | |
| typedef SparseSolverBase< Derived > | Base |
Protected Member Functions | |
| void | init () |
| void | analyzePattern (ColSpMatrix &mat) |
| void | factorize (ColSpMatrix &mat) |
| void | clean () |
| void | compute (ColSpMatrix &mat) |
Protected Attributes | |
| int | m_initisOk |
| int | m_analysisIsOk |
| int | m_factorizationIsOk |
| ComputationInfo | m_info |
| pastix_data_t * | m_pastixdata |
| int | m_comm |
| Array< int, IPARM_SIZE, 1 > | m_iparm |
| Array< double, DPARM_SIZE, 1 > | m_dparm |
| Matrix< StorageIndex, Dynamic, 1 > | m_perm |
| Matrix< StorageIndex, Dynamic, 1 > | m_invp |
| int | m_size |
Definition at line 128 of file PaStiXSupport.h.
| typedef internal::pastix_traits<Derived>::MatrixType Eigen::PastixBase< Derived >::_MatrixType |
Definition at line 137 of file PaStiXSupport.h.
typedef SparseSolverBase<Derived> Eigen::PastixBase< Derived >::Base [protected] |
Reimplemented in Eigen::PastixLDLT< _MatrixType, _UpLo >, Eigen::PastixLLT< _MatrixType, _UpLo >, and Eigen::PastixLU< _MatrixType, IsStrSym >.
Definition at line 131 of file PaStiXSupport.h.
| typedef SparseMatrix<Scalar, ColMajor> Eigen::PastixBase< Derived >::ColSpMatrix |
Definition at line 143 of file PaStiXSupport.h.
| typedef _MatrixType Eigen::PastixBase< Derived >::MatrixType |
Definition at line 138 of file PaStiXSupport.h.
| typedef MatrixType::RealScalar Eigen::PastixBase< Derived >::RealScalar |
Definition at line 140 of file PaStiXSupport.h.
| typedef MatrixType::Scalar Eigen::PastixBase< Derived >::Scalar |
Definition at line 139 of file PaStiXSupport.h.
| typedef MatrixType::StorageIndex Eigen::PastixBase< Derived >::StorageIndex |
Reimplemented in Eigen::PastixLU< _MatrixType, IsStrSym >.
Definition at line 141 of file PaStiXSupport.h.
| typedef Matrix<Scalar,Dynamic,1> Eigen::PastixBase< Derived >::Vector |
Definition at line 142 of file PaStiXSupport.h.
| anonymous enum |
Definition at line 144 of file PaStiXSupport.h.
| Eigen::PastixBase< Derived >::PastixBase | ( | ) | [inline] |
Definition at line 151 of file PaStiXSupport.h.
: m_initisOk(false), m_analysisIsOk(false), m_factorizationIsOk(false), m_pastixdata(0), m_size(0) { init(); }
| Eigen::PastixBase< Derived >::~PastixBase | ( | ) | [inline] |
Definition at line 156 of file PaStiXSupport.h.
clean();
| bool Eigen::PastixBase< Base >::_solve_impl | ( | const MatrixBase< Rhs > & | b, |
| MatrixBase< Dest > & | x | ||
| ) | const |
Definition at line 367 of file PaStiXSupport.h.
eigen_assert(m_isInitialized && "The matrix should be factorized first");
EIGEN_STATIC_ASSERT((Dest::Flags&RowMajorBit)==0,
THIS_METHOD_IS_ONLY_FOR_COLUMN_MAJOR_MATRICES);
int rhs = 1;
x = b; /* on return, x is overwritten by the computed solution */
for (int i = 0; i < b.cols(); i++){
m_iparm[IPARM_START_TASK] = API_TASK_SOLVE;
m_iparm[IPARM_END_TASK] = API_TASK_REFINE;
internal::eigen_pastix(&m_pastixdata, MPI_COMM_WORLD, internal::convert_index<int>(x.rows()), 0, 0, 0,
m_perm.data(), m_invp.data(), &x(0, i), rhs, m_iparm.data(), m_dparm.data());
// Check the returned error
m_info = m_iparm(IPARM_ERROR_NUMBER)==0 ? Success : NumericalIssue;
return m_iparm(IPARM_ERROR_NUMBER)==0;
| void Eigen::PastixBase< Derived >::analyzePattern | ( | ColSpMatrix & | mat | ) | [protected] |
Definition at line 307 of file PaStiXSupport.h.
eigen_assert(m_initisOk && "The initialization of PaSTiX failed");
// clean previous calls
if(m_size>0)
clean();
m_size = internal::convert_index<int>(mat.rows());
m_perm.resize(m_size);
m_invp.resize(m_size);
m_iparm(IPARM_START_TASK) = API_TASK_ORDERING;
m_iparm(IPARM_END_TASK) = API_TASK_ANALYSE;
internal::eigen_pastix(&m_pastixdata, MPI_COMM_WORLD, m_size, mat.outerIndexPtr(), mat.innerIndexPtr(),
mat.valuePtr(), m_perm.data(), m_invp.data(), 0, 0, m_iparm.data(), m_dparm.data());
if(m_iparm(IPARM_ERROR_NUMBER))
m_info = NumericalIssue;
m_analysisIsOk = false;
else
m_info = Success;
m_analysisIsOk = true;
| void Eigen::PastixBase< Derived >::clean | ( | ) | [inline, protected] |
Definition at line 230 of file PaStiXSupport.h.
eigen_assert(m_initisOk && "The Pastix structure should be allocated first");
m_iparm(IPARM_START_TASK) = API_TASK_CLEAN;
m_iparm(IPARM_END_TASK) = API_TASK_CLEAN;
internal::eigen_pastix(&m_pastixdata, MPI_COMM_WORLD, 0, 0, 0, (Scalar*)0,
| Index Eigen::PastixBase< Derived >::cols | ( | void | ) | const [inline] |
Definition at line 201 of file PaStiXSupport.h.
{ return m_size; }
| void Eigen::PastixBase< Derived >::compute | ( | ColSpMatrix & | mat | ) | [protected] |
Definition at line 295 of file PaStiXSupport.h.
eigen_assert(mat.rows() == mat.cols() && "The input matrix should be squared");
analyzePattern(mat);
factorize(mat);
m_iparm(IPARM_MATRIX_VERIFICATION) = API_NO;
| Array<double,DPARM_SIZE,1>& Eigen::PastixBase< Derived >::dparm | ( | ) | [inline] |
Returns a reference to the double vector DPARM of PaStiX parameters The statistics related to the different phases of factorization and solve are saved here as well
Definition at line 187 of file PaStiXSupport.h.
return m_dparm;
| double& Eigen::PastixBase< Derived >::dparm | ( | int | idxparam | ) | [inline] |
Return a reference to a particular index parameter of the DPARM vector
Definition at line 196 of file PaStiXSupport.h.
return m_dparm(idxparam);
| void Eigen::PastixBase< Derived >::factorize | ( | ColSpMatrix & | mat | ) | [protected] |
Definition at line 338 of file PaStiXSupport.h.
// if(&m_cpyMat != &mat) m_cpyMat = mat;
eigen_assert(m_analysisIsOk && "The analysis phase should be called before the factorization phase");
m_iparm(IPARM_START_TASK) = API_TASK_NUMFACT;
m_iparm(IPARM_END_TASK) = API_TASK_NUMFACT;
m_factorizationIsOk = false;
m_isInitialized = false;
else
m_info = Success;
m_factorizationIsOk = true;
m_isInitialized = true;
| ComputationInfo Eigen::PastixBase< Derived >::info | ( | ) | const [inline] |
Success if computation was succesful, NumericalIssue if the PaStiX reports a problem InvalidInput if the input matrix is invalidDefinition at line 212 of file PaStiXSupport.h.
eigen_assert(m_isInitialized && "Decomposition is not initialized.");
return m_info;
| void Eigen::PastixBase< Derived >::init | ( | ) | [protected] |
Initialize the PaStiX data structure. A first call to this function fills iparm and dparm with the default PaStiX parameters
Definition at line 259 of file PaStiXSupport.h.
m_size = 0;
m_iparm.setZero(IPARM_SIZE);
m_dparm.setZero(DPARM_SIZE);
m_iparm(IPARM_MODIFY_PARAMETER) = API_NO;
0, 0, 0, 0,
0, 0, 0, 1, m_iparm.data(), m_dparm.data());
m_iparm[IPARM_MATRIX_VERIFICATION] = API_NO;
m_iparm[IPARM_VERBOSE] = API_VERBOSE_NOT;
m_iparm[IPARM_ORDERING] = API_ORDER_SCOTCH;
m_iparm[IPARM_INCOMPLETE] = API_NO;
m_iparm[IPARM_OOC_LIMIT] = 2000;
m_iparm[IPARM_RHS_MAKING] = API_RHS_B;
m_iparm(IPARM_START_TASK) = API_TASK_INIT;
m_iparm(IPARM_END_TASK) = API_TASK_INIT;
0, 0, 0, 0, m_iparm.data(), m_dparm.data());
if(m_iparm(IPARM_ERROR_NUMBER)) {
m_info = InvalidInput;
m_initisOk = false;
else {
m_info = Success;
m_initisOk = true;
| Array<StorageIndex,IPARM_SIZE,1>& Eigen::PastixBase< Derived >::iparm | ( | ) | [inline] |
Returns a reference to the integer vector IPARM of PaStiX parameters to modify the default parameters. The statistics related to the different phases of factorization and solve are saved here as well
Definition at line 169 of file PaStiXSupport.h.
return m_iparm;
| int& Eigen::PastixBase< Derived >::iparm | ( | int | idxparam | ) | [inline] |
Return a reference to a particular index parameter of the IPARM vector
Definition at line 178 of file PaStiXSupport.h.
return m_iparm(idxparam);
| Index Eigen::PastixBase< Derived >::rows | ( | void | ) | const [inline] |
Definition at line 202 of file PaStiXSupport.h.
{ return m_size; }
int Eigen::PastixBase< Derived >::m_analysisIsOk [protected] |
Definition at line 242 of file PaStiXSupport.h.
int Eigen::PastixBase< Derived >::m_comm [mutable, protected] |
Definition at line 246 of file PaStiXSupport.h.
Array<double,DPARM_SIZE,1> Eigen::PastixBase< Derived >::m_dparm [mutable, protected] |
Definition at line 248 of file PaStiXSupport.h.
int Eigen::PastixBase< Derived >::m_factorizationIsOk [protected] |
Definition at line 243 of file PaStiXSupport.h.
ComputationInfo Eigen::PastixBase< Derived >::m_info [mutable, protected] |
Definition at line 244 of file PaStiXSupport.h.
int Eigen::PastixBase< Derived >::m_initisOk [protected] |
Definition at line 241 of file PaStiXSupport.h.
Matrix<StorageIndex,Dynamic,1> Eigen::PastixBase< Derived >::m_invp [mutable, protected] |
Definition at line 250 of file PaStiXSupport.h.
Array<int,IPARM_SIZE,1> Eigen::PastixBase< Derived >::m_iparm [mutable, protected] |
Definition at line 247 of file PaStiXSupport.h.
pastix_data_t* Eigen::PastixBase< Derived >::m_pastixdata [mutable, protected] |
Definition at line 245 of file PaStiXSupport.h.
Matrix<StorageIndex,Dynamic,1> Eigen::PastixBase< Derived >::m_perm [mutable, protected] |
Definition at line 249 of file PaStiXSupport.h.
int Eigen::PastixBase< Derived >::m_size [mutable, protected] |
Definition at line 251 of file PaStiXSupport.h.
