MOAB
4.9.3pre
General-purpose arrays with easy API for coefficient-wise operations. More...
#include <Array.h>
Public Types | |
| enum | { Options = _Options } |
| typedef PlainObjectBase< Array > | Base |
| typedef Base::PlainObject | PlainObject |
Public Member Functions | |
| template<typename OtherDerived > | |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Array & | operator= (const EigenBase< OtherDerived > &other) |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Array & | operator= (const Scalar &value) |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Array & | operator= (const DenseBase< OtherDerived > &other) |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Array & | operator= (const Array &other) |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Array () |
| EIGEN_DEVICE_FUNC | Array (internal::constructor_without_unaligned_array_assert) |
| template<typename T > | |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Array (const T &x) |
| template<typename T0 , typename T1 > | |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Array (const T0 &val0, const T1 &val1) |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Array (const Scalar &val0, const Scalar &val1, const Scalar &val2) |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Array (const Scalar &val0, const Scalar &val1, const Scalar &val2, const Scalar &val3) |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Array (const Array &other) |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Array (const EigenBase< OtherDerived > &other) |
| EIGEN_DEVICE_FUNC Index | innerStride () const |
| EIGEN_DEVICE_FUNC Index | outerStride () const |
Friends | |
| struct | internal::conservative_resize_like_impl |
| struct | internal::matrix_swap_impl |
The Array class is very similar to the Matrix class. It provides general-purpose one- and two-dimensional arrays. The difference between the Array and the Matrix class is primarily in the API: the API for the Array class provides easy access to coefficient-wise operations, while the API for the Matrix class provides easy access to linear-algebra operations.
See documentation of class Matrix for detailed information on the template parameters storage layout.
This class can be extended with the help of the plugin mechanism described on the page TopicCustomizingEigen by defining the preprocessor symbol EIGEN_ARRAY_PLUGIN.
| typedef PlainObjectBase<Array> Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Base |
| typedef Base::PlainObject Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::PlainObject |
| anonymous enum |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Array | ( | ) | [inline] |
Default constructor.
For fixed-size matrices, does nothing.
For dynamic-size matrices, creates an empty matrix of size 0. Does not allocate any array. Such a matrix is called a null matrix. This constructor is the unique way to create null matrices: resizing a matrix to 0 is not supported.
| EIGEN_DEVICE_FUNC Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Array | ( | internal::constructor_without_unaligned_array_assert | ) | [inline] |
Definition at line 142 of file Array.h.
: Base(internal::constructor_without_unaligned_array_assert()) { Base::_check_template_params(); EIGEN_INITIALIZE_COEFFS_IF_THAT_OPTION_IS_ENABLED }
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Array | ( | const T & | x | ) | [inline, explicit] |
Definition at line 170 of file Array.h.
Base::template _init1<T>(x);
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Array | ( | const T0 & | val0, |
| const T1 & | val1 | ||
| ) | [inline] |
Definition at line 178 of file Array.h.
this->template _init2<T0,T1>(val0, val1);
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Array | ( | const Scalar & | val0, |
| const Scalar & | val1, | ||
| const Scalar & | val2 | ||
| ) | [inline] |
| const Scalar & | val2, | ||
| const Scalar & | val3 | ||
| ) | [inline] |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Array | ( | const Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols > & | other | ) | [inline] |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Array | ( | const EigenBase< OtherDerived > & | other | ) | [inline] |
| EIGEN_DEVICE_FUNC Index Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::innerStride | ( | ) | const [inline] |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Array& Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::operator= | ( | const EigenBase< OtherDerived > & | other | ) | [inline] |
The usage of using Base::operator=; fails on MSVC. Since the code below is working with GCC and MSVC, we skipped the usage of 'using'. This should be done only for operator=.
Reimplemented from Eigen::PlainObjectBase< Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols > >.
Definition at line 76 of file Array.h.
return Base::operator=(other);
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Array& Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::operator= | ( | const Scalar & | value | ) | [inline] |
Set all the entries to value.
Definition at line 90 of file Array.h.
Base::setConstant(value);
return *this;
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Array& Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::operator= | ( | const DenseBase< OtherDerived > & | other | ) | [inline] |
Copies the value of the expression other into *this with automatic resizing.
*this might be resized to match the dimensions of other. If *this was a null matrix (not already initialized), it will be initialized.
Note that copying a row-vector into a vector (and conversely) is allowed. The resizing, if any, is then done in the appropriate way so that row-vectors remain row-vectors and vectors remain vectors.
Definition at line 107 of file Array.h.
return Base::_set(other);
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Array& Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::operator= | ( | const Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols > & | other | ) | [inline] |
This is a special case of the templated operator=. Its purpose is to prevent a default operator= from hiding the templated operator=.
Definition at line 116 of file Array.h.
| EIGEN_DEVICE_FUNC Index Eigen::Array< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::outerStride | ( | ) | const [inline] |
friend struct internal::conservative_resize_like_impl [friend] |
friend struct internal::matrix_swap_impl [friend] |
