MOAB
4.9.3pre
A sparse direct supernodal Cholesky (LLT) factorization and solver based on the PaStiX library. More...
#include <PaStiXSupport.h>
Public Types | |
| enum | { UpLo = _UpLo } |
| typedef _MatrixType | MatrixType |
| typedef PastixBase< PastixLLT < MatrixType, _UpLo > > | Base |
| typedef Base::ColSpMatrix | ColSpMatrix |
Public Member Functions | |
| PastixLLT () | |
| PastixLLT (const MatrixType &matrix) | |
| void | compute (const MatrixType &matrix) |
| void | analyzePattern (const MatrixType &matrix) |
| void | factorize (const MatrixType &matrix) |
Protected Member Functions | |
| void | init () |
| void | grabMatrix (const MatrixType &matrix, ColSpMatrix &out) |
This class is used to solve the linear systems A.X = B via a LL^T supernodal Cholesky factorization available in the PaStiX library. The matrix A should be symmetric and positive definite WARNING Selfadjoint complex matrices are not supported in the current version of PaStiX The vectors or matrices X and B can be either dense or sparse
| MatrixType | the type of the sparse matrix A, it must be a SparseMatrix<> |
| UpLo | The part of the matrix to use : Lower or Upper. The default is Lower as required by PaStiX |
Definition at line 524 of file PaStiXSupport.h.
| typedef PastixBase<PastixLLT<MatrixType, _UpLo> > Eigen::PastixLLT< _MatrixType, _UpLo >::Base |
Reimplemented from Eigen::PastixBase< PastixLLT< _MatrixType, _UpLo > >.
Definition at line 528 of file PaStiXSupport.h.
| typedef Base::ColSpMatrix Eigen::PastixLLT< _MatrixType, _UpLo >::ColSpMatrix |
Definition at line 529 of file PaStiXSupport.h.
| typedef _MatrixType Eigen::PastixLLT< _MatrixType, _UpLo >::MatrixType |
Definition at line 527 of file PaStiXSupport.h.
| anonymous enum |
| Eigen::PastixLLT< _MatrixType, _UpLo >::PastixLLT | ( | ) | [inline] |
Definition at line 533 of file PaStiXSupport.h.
| Eigen::PastixLLT< _MatrixType, _UpLo >::PastixLLT | ( | const MatrixType & | matrix | ) | [inline, explicit] |
Definition at line 538 of file PaStiXSupport.h.
| void Eigen::PastixLLT< _MatrixType, _UpLo >::analyzePattern | ( | const MatrixType & | matrix | ) | [inline] |
Compute the LL^T symbolic factorization of matrix using its sparsity pattern The result of this operation can be used with successive matrices having the same pattern as matrix
Definition at line 558 of file PaStiXSupport.h.
ColSpMatrix temp;
grabMatrix(matrix, temp);
Base::analyzePattern(temp);
| void Eigen::PastixLLT< _MatrixType, _UpLo >::compute | ( | const MatrixType & | matrix | ) | [inline] |
Compute the L factor of the LL^T supernodal factorization of matrix
Definition at line 547 of file PaStiXSupport.h.
ColSpMatrix temp;
Base::compute(temp);
| void Eigen::PastixLLT< _MatrixType, _UpLo >::factorize | ( | const MatrixType & | matrix | ) | [inline] |
Compute the LL^T supernodal numerical factorization of matrix
Definition at line 567 of file PaStiXSupport.h.
ColSpMatrix temp;
Base::factorize(temp);
| void Eigen::PastixLLT< _MatrixType, _UpLo >::grabMatrix | ( | const MatrixType & | matrix, |
| ColSpMatrix & | out | ||
| ) | [inline, protected] |
Definition at line 582 of file PaStiXSupport.h.
out.resize(matrix.rows(), matrix.cols());
// Pastix supports only lower, column-major matrices
out.template selfadjointView<Lower>() = matrix.template selfadjointView<UpLo>();
internal::c_to_fortran_numbering(out);
| void Eigen::PastixLLT< _MatrixType, _UpLo >::init | ( | ) | [inline, protected] |
Definition at line 576 of file PaStiXSupport.h.
