MOAB
4.9.3pre
A direct sparse LLT Cholesky factorizations. More...
#include <SimplicialCholesky.h>
Public Types | |
| enum | { UpLo = _UpLo } |
| typedef _MatrixType | MatrixType |
| typedef SimplicialCholeskyBase < SimplicialLLT > | Base |
| typedef MatrixType::Scalar | Scalar |
| typedef MatrixType::RealScalar | RealScalar |
| typedef MatrixType::StorageIndex | StorageIndex |
| typedef SparseMatrix< Scalar, ColMajor, Index > | CholMatrixType |
| typedef Matrix< Scalar, Dynamic, 1 > | VectorType |
| typedef internal::traits < SimplicialLLT > | Traits |
| typedef Traits::MatrixL | MatrixL |
| typedef Traits::MatrixU | MatrixU |
Public Member Functions | |
| SimplicialLLT () | |
| SimplicialLLT (const MatrixType &matrix) | |
| const MatrixL | matrixL () const |
| const MatrixU | matrixU () const |
| SimplicialLLT & | compute (const MatrixType &matrix) |
| void | analyzePattern (const MatrixType &a) |
| void | factorize (const MatrixType &a) |
| Scalar | determinant () const |
This class provides a LL^T Cholesky factorizations of sparse matrices that are selfadjoint and positive definite. The factorization allows for solving A.X = B where X and B can be either dense or sparse.
In order to reduce the fill-in, a symmetric permutation P is applied prior to the factorization such that the factorized matrix is P A P^-1.
| _MatrixType | the type of the sparse matrix A, it must be a SparseMatrix<> |
| _UpLo | the triangular part that will be used for the computations. It can be Lower or Upper. Default is Lower. |
| _Ordering | The ordering method to use, either AMDOrdering<> or NaturalOrdering<>. Default is AMDOrdering<> |
Definition at line 330 of file SimplicialCholesky.h.
| typedef SimplicialCholeskyBase<SimplicialLLT> Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::Base |
Reimplemented from Eigen::SimplicialCholeskyBase< SimplicialLLT< _MatrixType, _UpLo, _Ordering > >.
Definition at line 335 of file SimplicialCholesky.h.
| typedef SparseMatrix<Scalar,ColMajor,Index> Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::CholMatrixType |
Definition at line 339 of file SimplicialCholesky.h.
| typedef Traits::MatrixL Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::MatrixL |
Definition at line 342 of file SimplicialCholesky.h.
| typedef _MatrixType Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::MatrixType |
Definition at line 333 of file SimplicialCholesky.h.
| typedef Traits::MatrixU Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::MatrixU |
Definition at line 343 of file SimplicialCholesky.h.
| typedef MatrixType::RealScalar Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::RealScalar |
Definition at line 337 of file SimplicialCholesky.h.
| typedef MatrixType::Scalar Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::Scalar |
Definition at line 336 of file SimplicialCholesky.h.
| typedef MatrixType::StorageIndex Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::StorageIndex |
Definition at line 338 of file SimplicialCholesky.h.
| typedef internal::traits<SimplicialLLT> Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::Traits |
Definition at line 341 of file SimplicialCholesky.h.
| typedef Matrix<Scalar,Dynamic,1> Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::VectorType |
Definition at line 340 of file SimplicialCholesky.h.
| anonymous enum |
| Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::SimplicialLLT | ( | ) | [inline] |
| Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::SimplicialLLT | ( | const MatrixType & | matrix | ) | [inline, explicit] |
Constructs and performs the LLT factorization of matrix
Definition at line 348 of file SimplicialCholesky.h.
: Base(matrix) {}
| void Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::analyzePattern | ( | const MatrixType & | a | ) | [inline] |
Performs a symbolic decomposition on the sparcity of matrix.
This function is particularly useful when solving for several problems having the same structure.
Definition at line 376 of file SimplicialCholesky.h.
Base::analyzePattern(a, false);
| SimplicialLLT& Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::compute | ( | const MatrixType & | matrix | ) | [inline] |
Computes the sparse Cholesky decomposition of matrix
Definition at line 364 of file SimplicialCholesky.h.
Base::template compute<false>(matrix);
return *this;
| Scalar Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::determinant | ( | ) | const [inline] |
Definition at line 393 of file SimplicialCholesky.h.
Scalar detL = Base::m_matrix.diagonal().prod();
return numext::abs2(detL);
| void Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::factorize | ( | const MatrixType & | a | ) | [inline] |
Performs a numeric decomposition of matrix
The given matrix must has the same sparcity than the matrix on which the symbolic decomposition has been performed.
Definition at line 387 of file SimplicialCholesky.h.
Base::template factorize<false>(a);
| const MatrixL Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::matrixL | ( | ) | const [inline] |
Definition at line 352 of file SimplicialCholesky.h.
eigen_assert(Base::m_factorizationIsOk && "Simplicial LLT not factorized");
return Traits::getL(Base::m_matrix);
| const MatrixU Eigen::SimplicialLLT< _MatrixType, _UpLo, _Ordering >::matrixU | ( | ) | const [inline] |
Definition at line 358 of file SimplicialCholesky.h.
return Traits::getU(Base::m_matrix);
