MOAB
4.9.3pre
A matrix or vector expression mapping an existing expression. More...
#include <Ref.h>
Public Types | |
| typedef RefBase< Ref > | Base |
Public Member Functions | |
| template<typename Derived > | |
| EIGEN_DEVICE_FUNC | Ref (PlainObjectBase< Derived > &expr, typename internal::enable_if< bool(Traits::template match< Derived >::MatchAtCompileTime), Derived >::type *=0) |
| EIGEN_DEVICE_FUNC | Ref (const DenseBase< Derived > &expr, typename internal::enable_if< bool(Traits::template match< Derived >::MatchAtCompileTime), Derived >::type *=0) |
Private Types | |
| typedef internal::traits< Ref > | Traits |
Private Member Functions | |
| EIGEN_DEVICE_FUNC | Ref (const PlainObjectBase< Derived > &expr, typename internal::enable_if< bool(Traits::template match< Derived >::MatchAtCompileTime), Derived >::type *=0) |
| PlainObjectType | the equivalent matrix type of the mapped data |
| Options | specifies the pointer alignment in bytes. It can be: Aligned128, , Aligned64, Aligned32, Aligned16, Aligned8 or Unaligned. The default is Unaligned. |
| StrideType | optionally specifies strides. By default, Ref implies a contiguous storage along the inner dimension (inner stride==1), but accepts a variable outer stride (leading dimension). This can be overridden by specifying strides. The type passed here must be a specialization of the Stride template, see examples below. |
This class provides a way to write non-template functions taking Eigen objects as parameters while limiting the number of copies. A Ref<> object can represent either a const expression or a l-value:
// in-out argument: void foo1(Ref<VectorXf> x); // read-only const argument: void foo2(const Ref<const VectorXf>& x);
In the in-out case, the input argument must satisfy the constraints of the actual Ref<> type, otherwise a compilation issue will be triggered. By default, a Ref<VectorXf> can reference any dense vector expression of float having a contiguous memory layout. Likewise, a Ref<MatrixXf> can reference any column-major dense matrix expression of float whose column's elements are contiguously stored with the possibility to have a constant space in-between each column, i.e. the inner stride must be equal to 1, but the outer stride (or leading dimension) can be greater than the number of rows.
In the const case, if the input expression does not match the above requirement, then it is evaluated into a temporary before being passed to the function. Here are some examples:
MatrixXf A; VectorXf a; foo1(a.head()); // OK foo1(A.col()); // OK foo1(A.row()); // Compilation error because here innerstride!=1 foo2(A.row()); // Compilation error because A.row() is a 1xN object while foo2 is expecting a Nx1 object foo2(A.row().transpose()); // The row is copied into a contiguous temporary foo2(2*a); // The expression is evaluated into a temporary foo2(A.col().segment(2,4)); // No temporary
The range of inputs that can be referenced without temporary can be enlarged using the last two template parameters. Here is an example accepting an innerstride!=1:
// in-out argument: void foo3(Ref<VectorXf,0,InnerStride<> > x); foo3(A.row()); // OK
The downside here is that the function foo3 might be significantly slower than foo1 because it won't be able to exploit vectorization, and will involve more expensive address computations even if the input is contiguously stored in memory. To overcome this issue, one might propose to overload internally calling a template function, e.g.:
// in the .h: void foo(const Ref<MatrixXf>& A); void foo(const Ref<MatrixXf,0,Stride<> >& A); // in the .cpp: template<typename TypeOfA> void foo_impl(const TypeOfA& A) { ... // crazy code goes here } void foo(const Ref<MatrixXf>& A) { foo_impl(A); } void foo(const Ref<MatrixXf,0,Stride<> >& A) { foo_impl(A); }
| typedef RefBase<Ref> Eigen::Ref< PlainObjectType, Options, StrideType >::Base |
Reimplemented from Eigen::RefBase< Ref< PlainObjectType, Options, StrideType > >.
typedef internal::traits<Ref> Eigen::Ref< PlainObjectType, Options, StrideType >::Traits [private] |
| EIGEN_DEVICE_FUNC Eigen::Ref< PlainObjectType, Options, StrideType >::Ref | ( | const PlainObjectBase< Derived > & | expr, |
| typename internal::enable_if< bool(Traits::template match< Derived >::MatchAtCompileTime), Derived >::type * | = 0 |
| ) | [inline, private] |
| EIGEN_DEVICE_FUNC Eigen::Ref< PlainObjectType, Options, StrideType >::Ref | ( | PlainObjectBase< Derived > & | expr, |
| ) | [inline] |
Definition at line 200 of file Ref.h.
EIGEN_STATIC_ASSERT(bool(Traits::template match<Derived>::MatchAtCompileTime), STORAGE_LAYOUT_DOES_NOT_MATCH);
Base::construct(expr.derived());
| EIGEN_DEVICE_FUNC Eigen::Ref< PlainObjectType, Options, StrideType >::Ref | ( | const DenseBase< Derived > & | expr, |
| ) | [inline] |
Definition at line 207 of file Ref.h.
EIGEN_STATIC_ASSERT(bool(internal::is_lvalue<Derived>::value), THIS_EXPRESSION_IS_NOT_A_LVALUE__IT_IS_READ_ONLY);
EIGEN_STATIC_ASSERT(!Derived::IsPlainObjectBase,THIS_EXPRESSION_IS_NOT_A_LVALUE__IT_IS_READ_ONLY);
Base::construct(expr.const_cast_derived());
