MOAB
4.9.3pre
Expression of a fixed-size or dynamic-size sub-vector. More...
#include <VectorBlock.h>
Public Member Functions | |
| EIGEN_DEVICE_FUNC | VectorBlock (VectorType &vector, Index start, Index size) |
| EIGEN_DEVICE_FUNC | VectorBlock (VectorType &vector, Index start) |
Private Types | |
| enum | { IsColVector = !(internal::traits<VectorType>::Flags & RowMajorBit) } |
| typedef Block< VectorType, internal::traits< VectorType > ::Flags &RowMajorBit?1:Size, internal::traits< VectorType > ::Flags &RowMajorBit?Size:1 > | Base |
| VectorType | the type of the object in which we are taking a sub-vector |
| Size | size of the sub-vector we are taking at compile time (optional) |
This class represents an expression of either a fixed-size or dynamic-size sub-vector. It is the return type of DenseBase::segment(Index,Index) and DenseBase::segment<int>(Index) and most of the time this is the only way it is used.
However, if you want to directly maniputate sub-vector expressions, for instance if you want to write a function returning such an expression, you will need to use this class.
Here is an example illustrating the dynamic case:
Output:
Here is an example illustrating the fixed-size case:
Output:
Definition at line 56 of file VectorBlock.h.
typedef Block<VectorType, internal::traits<VectorType>::Flags & RowMajorBit ? 1 : Size, internal::traits<VectorType>::Flags & RowMajorBit ? Size : 1> Eigen::VectorBlock< VectorType, Size >::Base [private] |
Reimplemented from Eigen::Block< VectorType, internal::traits< VectorType >::Flags &RowMajorBit?1:Size, internal::traits< VectorType >::Flags &RowMajorBit?Size:1 >.
Definition at line 63 of file VectorBlock.h.
anonymous enum [private] |
Definition at line 64 of file VectorBlock.h.
| EIGEN_DEVICE_FUNC Eigen::VectorBlock< VectorType, Size >::VectorBlock | ( | VectorType & | vector, |
| Index | start, | ||
| Index | size | ||
| ) | [inline] |
Dynamic-size constructor
Definition at line 75 of file VectorBlock.h.
: Base(vector, IsColVector ? start : 0, IsColVector ? 0 : start, IsColVector ? size : 1, IsColVector ? 1 : size) { EIGEN_STATIC_ASSERT_VECTOR_ONLY(VectorBlock); }
| Index | start | ||
| ) | [inline] |
Fixed-size constructor
Definition at line 86 of file VectorBlock.h.
: Base(vector, IsColVector ? start : 0, IsColVector ? 0 : start) { EIGEN_STATIC_ASSERT_VECTOR_ONLY(VectorBlock); }
