MOAB: Mesh Oriented datABase
(version 5.2.1)
Definition at line 39 of file IdealWeightInverseMeanRatioTest.cpp.
Definition at line 71 of file IdealWeightInverseMeanRatioTest.cpp.
IdealWeightInverseMeanRatioTest::CPPUNIT_TEST_SUITE_END | ( | ) | [private] |
void IdealWeightInverseMeanRatioTest::test_degenerate_elements | ( | ) | [inline] |
Definition at line 127 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
{ tester.test_evaluate_degenerate_element( &mMetric, false ); }
void IdealWeightInverseMeanRatioTest::test_domain_deviation | ( | ) | [inline] |
Definition at line 116 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
void IdealWeightInverseMeanRatioTest::test_eval_with_gradient | ( | ) | [inline] |
Definition at line 152 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
void IdealWeightInverseMeanRatioTest::test_eval_with_hessian | ( | ) | [inline] |
Definition at line 158 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
void IdealWeightInverseMeanRatioTest::test_eval_with_hessian_diagonal | ( | ) | [inline] |
Definition at line 165 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
void IdealWeightInverseMeanRatioTest::test_eval_with_indices | ( | ) | [inline] |
Definition at line 147 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
void IdealWeightInverseMeanRatioTest::test_get_element_indices | ( | ) | [inline] |
Definition at line 137 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
{ tester.test_get_element_indices( &mMetric ); }
void IdealWeightInverseMeanRatioTest::test_get_evaluations | ( | ) | [inline] |
Definition at line 132 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
{ tester.test_get_element_evaluations( &mMetric ); }
void IdealWeightInverseMeanRatioTest::test_get_fixed_indices | ( | ) | [inline] |
Definition at line 142 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
{ tester.test_get_indices_fixed( &mMetric ); }
void IdealWeightInverseMeanRatioTest::test_gradient_reflects_quality | ( | ) | [inline] |
Definition at line 111 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
{ tester.test_gradient_reflects_quality( &mMetric ); }
void IdealWeightInverseMeanRatioTest::test_ideal_element_eval | ( | ) | [inline] |
Definition at line 81 of file IdealWeightInverseMeanRatioTest.cpp.
References MBMesquite::HEXAHEDRON, mMetric, MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::TETRAHEDRON, and MBMesquite::TRIANGLE.
{ tester.test_evaluate_unit_edge_element( &mMetric, TRIANGLE, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, QUADRILATERAL, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, TETRAHEDRON, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, HEXAHEDRON, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, PRISM, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, PYRAMID, 1.0 ); }
void IdealWeightInverseMeanRatioTest::test_ideal_element_grad | ( | ) | [inline] |
Definition at line 91 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
{ tester.test_ideal_element_zero_gradient( &mMetric, false ); }
void IdealWeightInverseMeanRatioTest::test_ideal_element_hess | ( | ) | [inline] |
Definition at line 96 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
{ tester.test_ideal_element_positive_definite_Hessian( &mMetric, false ); }
void IdealWeightInverseMeanRatioTest::test_inverted_elements | ( | ) | [inline] |
Definition at line 122 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
{ tester.test_evaluate_inverted_element( &mMetric, false ); }
void IdealWeightInverseMeanRatioTest::test_location_invariant | ( | ) | [inline] |
Definition at line 170 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
void IdealWeightInverseMeanRatioTest::test_measures_quality | ( | ) | [inline] |
Definition at line 106 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
{ tester.test_measures_quality( &mMetric ); }
void IdealWeightInverseMeanRatioTest::test_orient_invariant | ( | ) | [inline] |
Definition at line 182 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
{ tester.test_orient_invariant( &mMetric ); tester.test_grad_orient_invariant( &mMetric ); }
void IdealWeightInverseMeanRatioTest::test_scale_invariant | ( | ) | [inline] |
Definition at line 177 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
{ tester.test_scale_invariant( &mMetric ); }
void IdealWeightInverseMeanRatioTest::test_supported_types | ( | ) | [inline] |
Definition at line 76 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
{ tester.test_supported_element_types( &mMetric ); }
void IdealWeightInverseMeanRatioTest::test_valid_hessian | ( | ) | [inline] |
Definition at line 101 of file IdealWeightInverseMeanRatioTest.cpp.
References mMetric.
Definition at line 67 of file IdealWeightInverseMeanRatioTest.cpp.
Definition at line 68 of file IdealWeightInverseMeanRatioTest.cpp.
