MOAB: Mesh Oriented datABase
(version 5.2.1)
Computes the lengths of the edges connected to given a vertex.. More...
#include <EdgeLengthQualityMetric.hpp>
Public Member Functions | |
MESQUITE_EXPORT | EdgeLengthQualityMetric () |
virtual MESQUITE_EXPORT | ~EdgeLengthQualityMetric () |
virtual MESQUITE_EXPORT std::string | get_name () const |
virtual MESQUITE_EXPORT int | get_negate_flag () const |
1 if metric should be minimized, -1 if metric should be maximized. | |
virtual MESQUITE_EXPORT bool | evaluate (PatchData &pd, size_t vertex, double &value, MsqError &err) |
Get metric value at a logical location in the patch. | |
virtual MESQUITE_EXPORT bool | evaluate_with_indices (PatchData &pd, size_t vertex, double &value, std::vector< size_t > &indices, MsqError &err) |
Private Member Functions | |
bool | evaluate_common (PatchData &pd, size_t vertex, double &value, std::vector< size_t > &vertices, MsqError &err) |
EdgeLengthQualityMetric is a vertex based metric which computes the lengths of the edges connected to a given vertex and then averages those together, using the specified averaging method The metric uses SUM as the default averaging method.
Definition at line 55 of file EdgeLengthQualityMetric.hpp.
Definition at line 58 of file EdgeLengthQualityMetric.hpp.
: AveragingQM( SUM ) {}
virtual MESQUITE_EXPORT MBMesquite::EdgeLengthQualityMetric::~EdgeLengthQualityMetric | ( | ) | [inline, virtual] |
Definition at line 61 of file EdgeLengthQualityMetric.hpp.
bool EdgeLengthQualityMetric::evaluate | ( | PatchData & | pd, |
size_t | handle, | ||
double & | value, | ||
MsqError & | err | ||
) | [virtual] |
Evaluate the metric at one location in the PatchData.
pd | The patch. |
handle | The location in the patch (as passed back from get_evaluations). |
value | The output metric value. |
Implements MBMesquite::QualityMetric.
Definition at line 72 of file EdgeLengthQualityMetric.cpp.
References evaluate_common(), and MSQ_CHKERR.
{ std::vector< size_t > verts; bool rval = evaluate_common( pd, vertex, value, verts, err ); return !MSQ_CHKERR( err ) && rval; }
bool EdgeLengthQualityMetric::evaluate_common | ( | PatchData & | pd, |
size_t | vertex, | ||
std::vector< size_t > & | vertices, | ||
) | [private] |
Definition at line 55 of file EdgeLengthQualityMetric.cpp.
References MBMesquite::AveragingQM::average_metrics(), MBMesquite::PatchData::get_adjacent_vertex_indices(), MBMesquite::PatchData::get_vertex_array(), MSQ_CHKERR, and MSQ_ERRZERO.
Referenced by evaluate(), and evaluate_with_indices().
{ fval = 0.0; pd.get_adjacent_vertex_indices( this_vert, adj_verts, err ); MSQ_ERRZERO( err ); const unsigned num_sample_points = adj_verts.size(); double* metric_values = new double[num_sample_points]; const MsqVertex* verts = pd.get_vertex_array( err ); MSQ_ERRZERO( err ); for( unsigned i = 0; i < num_sample_points; ++i ) metric_values[i] = ( verts[this_vert] - verts[adj_verts[i]] ).length(); fval = average_metrics( metric_values, num_sample_points, err ); delete[] metric_values; return !MSQ_CHKERR( err ); }
bool EdgeLengthQualityMetric::evaluate_with_indices | ( | PatchData & | pd, |
std::vector< size_t > & | indices, | ||
) | [virtual] |
pd | The patch. |
indices | The free vertices that the evaluation is a function of, specified as vertex indices in the PatchData. |
Definition at line 79 of file EdgeLengthQualityMetric.cpp.
References evaluate_common(), MSQ_CHKERR, and MBMesquite::PatchData::num_free_vertices().
{ indices.clear(); bool rval = evaluate_common( pd, vertex, value, indices, err ); std::vector< size_t >::iterator r, w; for( r = w = indices.begin(); r != indices.end(); ++r ) { if( *r < pd.num_free_vertices() ) { *w = *r; ++w; } } indices.erase( w, indices.end() ); if( vertex < pd.num_free_vertices() ) indices.push_back( vertex ); return !MSQ_CHKERR( err ) && rval; }
std::string EdgeLengthQualityMetric::get_name | ( | ) | const [virtual] |
Definition at line 45 of file EdgeLengthQualityMetric.cpp.
{ return "Edge Length"; }
int EdgeLengthQualityMetric::get_negate_flag | ( | ) | const [virtual] |
Definition at line 50 of file EdgeLengthQualityMetric.cpp.
return 1;
