MBMesquite::MeshImplVertIter Class Reference
VertexIterator for MeshImpl. More...
#include <MeshImplData.hpp>
+ Inheritance diagram for MBMesquite::MeshImplVertIter:
+ Collaboration diagram for MBMesquite::MeshImplVertIter:
Public Member Functions
 MeshImplVertIter (MeshImplData *data)
virtual ~MeshImplVertIter ()
virtual void restart ()
virtual void operator++ ()
 ++iterator
virtual Mesh::VertexHandle operator* () const
virtual bool is_at_end () const
Private Attributes
MeshImplDatamesh
size_t index
Detailed Description
Iterate over valid vertex indices
Definition at line 254 of file MeshImplData.hpp.
Definition at line 261 of file MeshImplData.hpp.
References restart().
                                           : mesh( data )
        restart();
Definition at line 740 of file MeshImplData.cpp.
Member Function Documentation
bool MBMesquite::MeshImplVertIter::is_at_end ( ) const [virtual]
Returns false until the iterator has been advanced PAST the last entity. Once is_at_end() returns true, *iterator returns 0.
Implements MBMesquite::EntityIterator.
Definition at line 760 of file MeshImplData.cpp.
References index, MBMesquite::MeshImplData::max_vertex_index(), and mesh.
    return index >= mesh->max_vertex_index();
Mesh::VertexHandle MBMesquite::MeshImplVertIter::operator* ( ) const [virtual]
*iterator. Return the handle currently being pointed at by the iterator.
Definition at line 755 of file MeshImplData.cpp.
References index.
    return reinterpret_cast< Mesh::VertexHandle >( index );
void MBMesquite::MeshImplVertIter::operator++ ( ) [virtual]
++iterator
Definition at line 748 of file MeshImplData.cpp.
References index, MBMesquite::MeshImplData::is_corner_node(), MBMesquite::MeshImplData::is_vertex_valid(), and mesh.
    ++index;
    while( index < mesh->max_vertex_index() && ( !mesh->is_vertex_valid( index ) || !mesh->is_corner_node( index ) ) )
        ++index;
Moves the iterator back to the first entity in the list.
Definition at line 742 of file MeshImplData.cpp.
References index, MBMesquite::MeshImplData::is_vertex_valid(), and mesh.
Referenced by MeshImplVertIter().
    index = 0;
    if( !mesh->is_vertex_valid( index ) ) operator++();
Member Data Documentation
Definition at line 258 of file MeshImplData.hpp.
Referenced by is_at_end(), operator*(), operator++(), and restart().
Definition at line 257 of file MeshImplData.hpp.
Referenced by is_at_end(), operator++(), and restart().
List of all members.
