MOAB: Mesh Oriented datABase
(version 5.2.1)
#include <MeshImplData.hpp>
Classes | |
struct | Element |
struct | Vertex |
Public Member Functions | |
MeshImplData () | |
void | clear () |
size_t | num_vertices () const |
size_t | num_elements () const |
size_t | num_vertex_uses () const |
size_t | max_vertex_index () const |
size_t | max_element_index () const |
void | copy_mesh (size_t *vertex_handle_array, size_t *element_hanlde_array, size_t *element_conn_offsets, size_t *element_conn_indices) |
void | all_vertices (std::vector< size_t > &list, MsqError &err) const |
void | all_elements (std::vector< size_t > &list, MsqError &err) const |
bool | is_vertex_valid (size_t index) const |
bool | is_element_valid (size_t index) const |
bool | is_mid_node (size_t index) const |
bool | is_corner_node (size_t index) const |
const Vector3D & | get_vertex_coords (size_t index, MsqError &err) const |
void | set_vertex_coords (size_t index, const Vector3D &coords, MsqError &err) |
bool | vertex_is_fixed (size_t index, MsqError &err) const |
bool | vertex_is_slaved (size_t index, MsqError &err) const |
void | fix_vertex (size_t index, bool flag, MsqError &err) |
void | slave_vertex (size_t index, bool flag, MsqError &err) |
unsigned char | get_vertex_byte (size_t index, MsqError &err) const |
void | set_vertex_byte (size_t index, unsigned char value, MsqError &err) |
EntityTopology | element_topology (size_t index, MsqError &err) const |
void | element_topology (size_t index, EntityTopology type, MsqError &err) |
const std::vector< size_t > & | element_connectivity (size_t index, MsqError &err) const |
const std::vector< size_t > & | vertex_adjacencies (size_t index, MsqError &err) const |
void | allocate_vertices (size_t count, MsqError &err) |
void | allocate_elements (size_t count, MsqError &err) |
void | reset_vertex (size_t index, const Vector3D &coords, bool fixed, MsqError &err) |
void | reset_element (size_t index, const std::vector< long > &vertices, EntityTopology topology, MsqError &err) |
void | reset_element (size_t index, const std::vector< size_t > &vertices, EntityTopology topology, MsqError &err) |
size_t | add_vertex (const Vector3D &coords, bool fixed, MsqError &err) |
size_t | add_element (const std::vector< long > &vertices, EntityTopology topology, MsqError &err) |
size_t | add_element (const std::vector< size_t > &vertices, EntityTopology topology, MsqError &err) |
void | delete_vertex (size_t index, MsqError &err) |
void | delete_element (size_t index, MsqError &err) |
void | copy_higher_order (std::vector< size_t > &mid_nodes, std::vector< size_t > &vertices, std::vector< size_t > &vertex_indices, std::vector< size_t > &index_offsets, MsqError &err) |
void | get_adjacent_elements (std::vector< size_t >::const_iterator nodes, std::vector< size_t >::const_iterator nodes_end, std::vector< size_t > &elems_out, MsqError &err) |
Get elements adjacent to ALL of the passed nodes. | |
void | skin (std::vector< size_t > &sides, MsqError &err) |
Skin mesh. | |
bool | have_slaved_flags () const |
Private Member Functions | |
bool | has_adjacent_elements (size_t elem, const std::vector< size_t > &nodes, MsqError &err) |
helper function for skinning | |
void | clear_element (size_t index, MsqError &err) |
void | set_element (size_t index, const std::vector< long > &vertices, EntityTopology topology, MsqError &err) |
void | set_element (size_t index, const std::vector< size_t > &vertices, EntityTopology topology, MsqError &err) |
Private Attributes | |
std::vector< Vertex > | vertexList |
std::vector< Element > | elementList |
std::vector< size_t > | deletedVertexList |
std::vector< size_t > | deletedElementList |
bool | haveSlavedFlags |
Class to store mesh representation for MeshImpl
Definition at line 43 of file MeshImplData.hpp.
MBMesquite::MeshImplData::MeshImplData | ( | ) | [inline] |
Definition at line 47 of file MeshImplData.hpp.
: haveSlavedFlags( false ) {}
size_t MBMesquite::MeshImplData::add_element | ( | const std::vector< long > & | vertices, |
EntityTopology | topology, | ||
MsqError & | err | ||
Add a new element
Definition at line 385 of file MeshImplData.cpp.
References deletedElementList, elementList, MSQ_ERRZERO, and set_element().
{ size_t index; if( !deletedElementList.empty() ) { index = deletedElementList[deletedElementList.size() - 1]; deletedElementList.pop_back(); } else { index = elementList.size(); elementList.resize( elementList.size() + 1 ); } set_element( index, vertices, topology, err ); MSQ_ERRZERO( err ); return index; }
size_t MBMesquite::MeshImplData::add_element | ( | const std::vector< size_t > & | vertices, |
Definition at line 404 of file MeshImplData.cpp.
size_t MBMesquite::MeshImplData::add_vertex | ( | const Vector3D & | coords, |
bool | fixed, | ||
Add a new vertex
Definition at line 365 of file MeshImplData.cpp.
References deletedVertexList, MSQ_ERRZERO, reset_vertex(), and vertexList.
{ size_t index; if( !deletedVertexList.empty() ) { index = deletedVertexList[deletedVertexList.size() - 1]; deletedVertexList.pop_back(); reset_vertex( index, coords, fixed, err ); MSQ_ERRZERO( err ); } else { index = vertexList.size(); vertexList.push_back( Vertex( coords, fixed ) ); } return index; }
void MBMesquite::MeshImplData::all_elements | ( | std::vector< size_t > & | list, |
) | const |
Get all elements
Definition at line 593 of file MeshImplData.cpp.
References elementList.
Referenced by MBMesquite::MeshImpl::get_all_elements(), and MBMesquite::MeshImpl::vtk_store_cell_data().
{ list.clear(); for( size_t idx = 0; idx < elementList.size(); ++idx ) if( !elementList[idx].connectivity.empty() ) list.push_back( idx ); }
void MBMesquite::MeshImplData::all_vertices | ( | std::vector< size_t > & | list, |
) | const |
Get all vertices, including mid-nodes
Definition at line 586 of file MeshImplData.cpp.
References vertexList.
Referenced by MBMesquite::MeshImpl::get_all_vertices(), and MBMesquite::MeshImpl::vtk_store_point_data().
{ list.clear(); for( size_t idx = 0; idx < vertexList.size(); ++idx ) if( vertexList[idx].valid ) list.push_back( idx ); }
void MBMesquite::MeshImplData::allocate_elements | ( | size_t | count, |
Allocate space for specified number of elements
Definition at line 233 of file MeshImplData.cpp.
References elementList, MBMesquite::MsqError::INVALID_STATE, and MSQ_SETERR.
Referenced by MBMesquite::MeshImpl::MeshImpl(), MBMesquite::MeshImpl::read_exodus(), MBMesquite::MeshImpl::vtk_create_structured_elems(), MBMesquite::MeshImpl::vtk_read_polygons(), and MBMesquite::MeshImpl::vtk_read_unstructured_grid().
{ if( elementList.size() ) { MSQ_SETERR( err )( MsqError::INVALID_STATE ); return; } elementList.resize( count ); }
void MBMesquite::MeshImplData::allocate_vertices | ( | size_t | count, |
Allocate space for specified number of vertices
Definition at line 222 of file MeshImplData.cpp.
References MBMesquite::MsqError::INVALID_STATE, MSQ_SETERR, and vertexList.
Referenced by MBMesquite::MeshImpl::MeshImpl(), MBMesquite::MeshImpl::read_exodus(), MBMesquite::MeshImpl::vtk_read_polydata(), MBMesquite::MeshImpl::vtk_read_rectilinear_grid(), MBMesquite::MeshImpl::vtk_read_structured_grid(), MBMesquite::MeshImpl::vtk_read_structured_points(), and MBMesquite::MeshImpl::vtk_read_unstructured_grid().
{ if( vertexList.size() ) { MSQ_SETERR( err )( MsqError::INVALID_STATE ); return; } vertexList.resize( count ); }
void MBMesquite::MeshImplData::clear | ( | ) |
Clear all data
Definition at line 213 of file MeshImplData.cpp.
References deletedElementList, deletedVertexList, elementList, haveSlavedFlags, and vertexList.
Referenced by MBMesquite::MeshImpl::clear().
{ vertexList.clear(); elementList.clear(); deletedVertexList.clear(); deletedElementList.clear(); haveSlavedFlags = false; }
void MBMesquite::MeshImplData::clear_element | ( | size_t | index, |
) | [private] |
Clear existing element data
Definition at line 290 of file MeshImplData.cpp.
References MBMesquite::adj(), conn, corners, elementList, MBMesquite::MsqError::INVALID_ARG, MSQ_SETERR, and vertexList.
Referenced by delete_element(), and reset_element().
{ if( index >= elementList.size() ) { MSQ_SETERR( err )( "Invalid element handle", MsqError::INVALID_ARG ); return; } unsigned numvert = TopologyInfo::corners( elementList[index].topology ); if( numvert ) for( unsigned i = numvert; i < elementList[index].connectivity.size(); ++i ) --vertexList[elementList[index].connectivity[i]].midcount; std::vector< size_t >& conn = elementList[index].connectivity; for( std::vector< size_t >::iterator iter = conn.begin(); iter != conn.end(); ++iter ) { std::vector< size_t >& adj = vertexList[*iter].adjacencies; for( std::vector< size_t >::iterator iter2 = adj.begin(); iter2 != adj.end(); ++iter2 ) { if( *iter2 == index ) { adj.erase( iter2 ); break; } } } conn.clear(); }
void MBMesquite::MeshImplData::copy_higher_order | ( | std::vector< size_t > & | mid_nodes, |
std::vector< size_t > & | vertices, | ||
std::vector< size_t > & | vertex_indices, | ||
std::vector< size_t > & | index_offsets, | ||
Get all mid-nodes and their adjacent corner vertices
Definition at line 496 of file MeshImplData.cpp.
References MBMesquite::MeshImplData::Vertex::adjacencies, MBMesquite::MeshImplData::Element::connectivity, elementList, INTERNAL_ERROR, MBMesquite::MsqError::INVALID_STATE, is_vertex_valid(), MBMesquite::MeshImplData::Vertex::midcount, MSQ_ERRRTN, MSQ_SETERR, moab::side_number(), MBMesquite::MeshImplData::Element::topology, MBMesquite::MeshImplData::Vertex::valid, and vertexList.
{ mid_nodes.clear(); vertices.clear(); vertex_indices.clear(); index_offsets.clear(); // Create a map of from vertex handle to index in "vertices" // Use vertexList.size() to mean uninitialized. size_t v; std::vector< size_t > vert_map( vertexList.size() ); for( v = 0; v < vertexList.size(); ++v ) vert_map[v] = vertexList.size(); // Loop over all mid-side vertices for( v = 0; v < vertexList.size(); ++v ) { const Vertex& vert = vertexList[v]; // Not a mid-side vertex, skip it if( !vert.valid || !vert.midcount ) continue; // Populate "verts" with the handles of all adjacent corner vertices assert( vert.adjacencies.size() ); // shouldn't be able to fail if vert.midcount > 0 int elem_indx = vert.adjacencies[0]; Element& elem = elementList[elem_indx]; // Find index of node in elem's connectivity list unsigned index; for( index = 0; index < elem.connectivity.size(); ++index ) if( elem.connectivity[index] == v ) break; if( index == elem.connectivity.size() ) { MSQ_SETERR( err )( "Inconsistent data.", MsqError::INTERNAL_ERROR ); return; } // Given the index in the element's connectivity list, // get the side of the element containing the mid-node. unsigned side_dim, side_num; TopologyInfo::side_number( elem.topology, elem.connectivity.size(), index, side_dim, side_num, err );MSQ_ERRRTN( err ); if( !side_dim ) // Not a mid-side node { MSQ_SETERR( err )( MsqError::INVALID_STATE, "Improperly connected mesh." ); return; } // Get the adjacent corner vertices from the element side. unsigned num_corners; const unsigned* corner_indices = TopologyInfo::side_vertices( elem.topology, side_dim, side_num, num_corners, err );MSQ_ERRRTN( err ); // Add the mid-side node to the output list mid_nodes.push_back( v ); // Store offset at which the indices of the corner // vertices adjacent to this mid-side node will be // stored in "vertex_indices". index_offsets.push_back( vertex_indices.size() ); // For each adjacent corner vertex, if the vertex is not // already in "vertices" add it, and add the index to // the adjacency list for this mid-side node. for( unsigned i = 0; i < num_corners; ++i ) { size_t vert_idx = elem.connectivity[corner_indices[i]]; assert( is_vertex_valid( vert_idx ) ); if( vert_map[vert_idx] == vertexList.size() ) { vert_map[vert_idx] = vertices.size(); vertices.push_back( vert_idx ); } vertex_indices.push_back( vert_map[vert_idx] ); } } index_offsets.push_back( vertex_indices.size() ); }
void MBMesquite::MeshImplData::copy_mesh | ( | size_t * | vertex_handle_array, |
size_t * | element_hanlde_array, | ||
size_t * | element_conn_offsets, | ||
size_t * | element_conn_indices | ||
Copy internal representation into CSR rep Does not include mid-nodes.
Definition at line 441 of file MeshImplData.cpp.
References conn, MBMesquite::MeshImplData::Element::connectivity, corners, elementList, MBMesquite::MeshImplData::Element::topology, and vertexList.
{ std::vector< size_t > vertex_map( vertexList.size() ); size_t vh_index = 0; for( size_t v = 0; v < vertexList.size(); ++v ) { if( vertexList[v].valid #ifdef SEPARATE_MID_NODES && vertexList[v].midcount < vertexList[v].adjacencies.size() #endif ) { vertex_handle_array[vh_index] = v; vertex_map[v] = vh_index; ++vh_index; } else { vertex_map[v] = vertexList.size(); } } size_t offset = 0; for( size_t e = 0; e < elementList.size(); ++e ) { Element& elem = elementList[e]; size_t cl; #ifdef SEPARATE_MID_NODES cl = TopologyInfo::corners( elem.topology ); if( !cl ) #endif cl = elem.connectivity.size(); if( cl ) { *element_handle_array = e; ++element_handle_array; *element_conn_offsets = offset; ++element_conn_offsets; offset += cl; std::vector< size_t >::iterator conn = elem.connectivity.begin(); std::vector< size_t >::iterator end = conn + cl; while( conn != end ) { *element_conn_indices = vertex_map[*conn]; ++element_conn_indices; ++conn; } } } *element_conn_offsets = offset; }
void MBMesquite::MeshImplData::delete_element | ( | size_t | index, |
Delete an element
Definition at line 435 of file MeshImplData.cpp.
References clear_element(), deletedElementList, and MSQ_ERRRTN.
{ clear_element( index, err );MSQ_ERRRTN( err ); deletedElementList.push_back( index ); }
void MBMesquite::MeshImplData::delete_vertex | ( | size_t | index, |
Delete a vertex - may not be referenced by any element
Definition at line 423 of file MeshImplData.cpp.
References deletedVertexList, MBMesquite::MsqError::INVALID_ARG, is_vertex_valid(), MSQ_SETERR, and vertexList.
{ if( !is_vertex_valid( index ) ) { MSQ_SETERR( err )( "Invalid vertex handle", MsqError::INVALID_ARG ); return; } vertexList[index].valid = false; deletedVertexList.push_back( index ); }
const std::vector< size_t > & MBMesquite::MeshImplData::element_connectivity | ( | size_t | index, |
) | const |
Get element connectivity list, including mid-nodes
Definition at line 191 of file MeshImplData.cpp.
References MBMesquite::dummy_list, elementList, MBMesquite::MsqError::INVALID_ARG, is_element_valid(), and MSQ_SETERR.
Referenced by MBMesquite::MeshImpl::elements_get_attached_vertices(), MBMesquite::is_side_boundary(), MBMesquite::MeshImpl::set_all_slaved_flags(), MBMesquite::MeshImpl::set_skin_flags(), MBMesquite::MeshImpl::vtk_read_unstructured_grid(), MBMesquite::MeshImpl::write_exodus(), and MBMesquite::MeshImpl::write_vtk().
{ if( !is_element_valid( index ) ) { MSQ_SETERR( err )( "Invalid element handle", MsqError::INVALID_ARG ); return dummy_list; } return elementList[index].connectivity; }
EntityTopology MBMesquite::MeshImplData::element_topology | ( | size_t | index, |
) | const |
Get element type
Definition at line 157 of file MeshImplData.cpp.
References elementList, MBMesquite::MsqError::INVALID_ARG, is_element_valid(), MBMesquite::MIXED, and MSQ_SETERR.
Referenced by MBMesquite::MeshImpl::elements_get_topologies(), MBMesquite::is_side_boundary(), MBMesquite::MeshImpl::set_all_slaved_flags(), MBMesquite::MeshImpl::set_skin_flags(), MBMesquite::MeshImpl::vtk_read_unstructured_grid(), MBMesquite::MeshImpl::write_exodus(), and MBMesquite::MeshImpl::write_vtk().
{ if( !is_element_valid( index ) ) { MSQ_SETERR( err )( "Invalid element handle", MsqError::INVALID_ARG ); return MIXED; } return elementList[index].topology; }
void MBMesquite::MeshImplData::element_topology | ( | size_t | index, |
EntityTopology | type, | ||
Set element type
Definition at line 168 of file MeshImplData.cpp.
References corners, elementList, MBMesquite::MsqError::INVALID_ARG, is_element_valid(), MSQ_SETERR, and vertexList.
{ if( !is_element_valid( index ) ) { MSQ_SETERR( err )( "Invalid element handle", MsqError::INVALID_ARG ); return; } unsigned i, numvert; numvert = TopologyInfo::corners( elementList[index].topology ); if( numvert ) for( i = numvert; i < elementList[index].connectivity.size(); ++i ) --vertexList[elementList[index].connectivity[i]].midcount; elementList[index].topology = type; numvert = TopologyInfo::corners( elementList[index].topology ); if( numvert ) for( i = numvert; i < elementList[index].connectivity.size(); ++i ) ++vertexList[elementList[index].connectivity[i]].midcount; }
void MBMesquite::MeshImplData::fix_vertex | ( | size_t | index, |
bool | flag, | ||
Set vertex fixed flag
Definition at line 112 of file MeshImplData.cpp.
References MBMesquite::MsqError::INVALID_ARG, is_vertex_valid(), MSQ_SETERR, and vertexList.
Referenced by MBMesquite::MeshImpl::read_exodus(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::MeshImpl::set_all_fixed_flags(), MBMesquite::MeshImpl::set_skin_flags(), and MBMesquite::MeshImpl::vertices_set_fixed_flag().
{ if( !is_vertex_valid( index ) ) { MSQ_SETERR( err )( "Invalid vertex handle", MsqError::INVALID_ARG ); return; } vertexList[index].fixed = flag; }
void MBMesquite::MeshImplData::get_adjacent_elements | ( | std::vector< size_t >::const_iterator | nodes, |
std::vector< size_t >::const_iterator | nodes_end, | ||
std::vector< size_t > & | elems_out, | ||
Return the list of elements that is the intersection of the adjacency lists of the specified vertices.
Definition at line 600 of file MeshImplData.cpp.
Referenced by has_adjacent_elements().
{ if( node_iter == node_end || !is_vertex_valid( *node_iter ) ) { MSQ_SETERR( err )( MsqError::INVALID_ARG ); return; } // Get list of elements adjacent to first node elems = vertexList[*node_iter].adjacencies; // For each aditional node, intersect elems with elements adjacent to node for( ++node_iter; node_iter != node_end; ++node_iter ) { std::vector< size_t >::iterator elem_iter = elems.begin(); while( elem_iter != elems.end() ) { std::vector< size_t >::const_iterator adj_iter = vertexList[*node_iter].adjacencies.begin(); const std::vector< size_t >::const_iterator adj_end = vertexList[*node_iter].adjacencies.end(); for( ; adj_iter != adj_end; ++adj_iter ) if( *elem_iter == *adj_iter ) break; if( adj_iter == adj_end ) { *elem_iter = elems[elems.size() - 1]; elems.pop_back(); } else { ++elem_iter; } } } }
unsigned char MBMesquite::MeshImplData::get_vertex_byte | ( | size_t | index, |
) | const |
Get vertex byte
Definition at line 135 of file MeshImplData.cpp.
Referenced by MBMesquite::MeshImpl::vertices_get_byte().
{ if( !is_vertex_valid( index ) ) { MSQ_SETERR( err )( "Invalid vertex handle", MsqError::INVALID_ARG ); return 0; } return vertexList[index].byte; }
const Vector3D & MBMesquite::MeshImplData::get_vertex_coords | ( | size_t | index, |
) | const |
Get vertex coordinates
Definition at line 74 of file MeshImplData.cpp.
References MBMesquite::dummy_vtx, MBMesquite::MsqError::INVALID_ARG, is_vertex_valid(), MSQ_SETERR, and vertexList.
Referenced by MBMesquite::MeshImpl::vertices_get_coordinates(), MBMesquite::MeshImpl::write_exodus(), and MBMesquite::MeshImpl::write_vtk().
{ if( !is_vertex_valid( index ) ) { MSQ_SETERR( err )( "Invalid vertex handle", MsqError::INVALID_ARG ); return dummy_vtx; } return vertexList[index].coords; }
bool MBMesquite::MeshImplData::has_adjacent_elements | ( | size_t | elem, |
const std::vector< size_t > & | nodes, | ||
) | [private] |
Check if any elements adjacent to a side of an element are of the same dimension as the input element.
elem | The element |
nodes | The nodes composing the side of the element |
Definition at line 637 of file MeshImplData.cpp.
References dim, elementList, and get_adjacent_elements().
Referenced by skin().
{ std::vector< size_t > adj_elems; const unsigned dim = TopologyInfo::dimension( elementList[elem].topology ); get_adjacent_elements( nodes.begin(), nodes.end(), adj_elems, err ); std::vector< size_t >::iterator iter; for( iter = adj_elems.begin(); iter != adj_elems.end(); ++iter ) if( *iter != elem && TopologyInfo::dimension( elementList[*iter].topology ) == dim ) break; return iter != adj_elems.end(); }
bool MBMesquite::MeshImplData::have_slaved_flags | ( | ) | const [inline] |
Definition at line 183 of file MeshImplData.hpp.
References haveSlavedFlags.
Referenced by vertex_is_slaved(), and MBMesquite::MeshImpl::write_vtk().
{ return haveSlavedFlags; }
bool MBMesquite::MeshImplData::is_corner_node | ( | size_t | index | ) | const |
Check if the specified node is used as a corner vertex on any element
Definition at line 581 of file MeshImplData.cpp.
References is_vertex_valid(), and vertexList.
Referenced by MBMesquite::MeshImplVertIter::operator++().
{ return is_vertex_valid( index ) && vertexList[index].midcount < vertexList[index].adjacencies.size(); }
bool MBMesquite::MeshImplData::is_element_valid | ( | size_t | index | ) | const [inline] |
Check if passed element index is valid
Definition at line 87 of file MeshImplData.hpp.
Referenced by element_connectivity(), element_topology(), MBMesquite::MeshImplElemIter::operator++(), MBMesquite::MeshImplElemIter::restart(), MBMesquite::MeshImpl::set_all_slaved_flags(), MBMesquite::MeshImpl::set_skin_flags(), skin(), MBMesquite::MeshImpl::write_exodus(), and MBMesquite::MeshImpl::write_vtk().
{ return index < elementList.size() && !elementList[index].connectivity.empty(); }
bool MBMesquite::MeshImplData::is_mid_node | ( | size_t | index | ) | const |
Check if the specified node is used as a mid-node on any element
Definition at line 576 of file MeshImplData.cpp.
{ return is_vertex_valid( index ) && vertexList[index].midcount > 0; }
bool MBMesquite::MeshImplData::is_vertex_valid | ( | size_t | index | ) | const [inline] |
Check if passed vertex index is valid
Definition at line 81 of file MeshImplData.hpp.
Referenced by copy_higher_order(), delete_vertex(), fix_vertex(), get_adjacent_elements(), get_vertex_byte(), get_vertex_coords(), is_corner_node(), is_mid_node(), MBMesquite::MeshImplVertIter::operator++(), MBMesquite::MeshImplVertIter::restart(), MBMesquite::MeshImpl::set_all_fixed_flags(), set_element(), set_vertex_byte(), set_vertex_coords(), slave_vertex(), vertex_adjacencies(), vertex_is_fixed(), vertex_is_slaved(), MBMesquite::MeshImpl::write_exodus(), and MBMesquite::MeshImpl::write_vtk().
{ return index < vertexList.size() && vertexList[index].valid; }
size_t MBMesquite::MeshImplData::max_element_index | ( | ) | const [inline] |
Definition at line 64 of file MeshImplData.hpp.
Referenced by MBMesquite::MeshImplElemIter::is_at_end(), MBMesquite::MeshImpl::set_all_slaved_flags(), MBMesquite::MeshImpl::set_skin_flags(), MBMesquite::MeshImpl::write_exodus(), and MBMesquite::MeshImpl::write_vtk().
{ return elementList.size(); }
size_t MBMesquite::MeshImplData::max_vertex_index | ( | ) | const [inline] |
Definition at line 60 of file MeshImplData.hpp.
Referenced by MBMesquite::MeshImplVertIter::is_at_end(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::MeshImpl::set_all_fixed_flags(), MBMesquite::MeshImpl::tag_to_bool(), MBMesquite::MeshImpl::write_exodus(), and MBMesquite::MeshImpl::write_vtk().
{ return vertexList.size(); }
size_t MBMesquite::MeshImplData::num_elements | ( | ) | const |
Get number of elements
Definition at line 54 of file MeshImplData.cpp.
References deletedElementList, and elementList.
Referenced by MBMesquite::MeshImpl::read_vtk(), MBMesquite::MeshImpl::vtk_read_cell_data(), MBMesquite::MeshImpl::vtk_read_dataset(), MBMesquite::MeshImpl::write_exodus(), and MBMesquite::MeshImpl::write_vtk().
{ return elementList.size() - deletedElementList.size(); }
size_t MBMesquite::MeshImplData::num_vertex_uses | ( | ) | const |
Get number of vertex uses (sum of connectivity length for all elements) Does not count mid-nodes
Definition at line 59 of file MeshImplData.cpp.
References corners, and elementList.
Referenced by MBMesquite::MeshImpl::write_vtk().
{ size_t result = 0; for( std::vector< Element >::const_iterator iter = elementList.begin(); iter != elementList.end(); ++iter ) { #ifdef SEPARATE_MID_NODES unsigned from_topo = TopologyInfo::corners( iter->topology ); result += from_topo ? from_topo : iter->connectivity.size(); #else result += iter->connectivity.size(); #endif } return result; }
size_t MBMesquite::MeshImplData::num_vertices | ( | ) | const |
Get number of vertices, does not include mid-nodes
Definition at line 41 of file MeshImplData.cpp.
Referenced by MBMesquite::MeshImpl::vtk_read_dataset(), MBMesquite::MeshImpl::vtk_read_point_data(), MBMesquite::MeshImpl::write_exodus(), and MBMesquite::MeshImpl::write_vtk().
{ size_t count = 0; for( std::vector< Vertex >::const_iterator iter = vertexList.begin(); iter != vertexList.end(); ++iter ) #ifdef SEPARATE_MID_NODES if( iter->valid && iter->midcount < iter->adjacencies.size() ) #else if( iter->valid ) #endif ++count; return count; }
void MBMesquite::MeshImplData::reset_element | ( | size_t | index, |
const std::vector< long > & | vertices, | ||
Clear element at specified index (if any) including connectivity and adjacency data, and re-initialize with passed data.
Definition at line 276 of file MeshImplData.cpp.
References clear_element(), MSQ_ERRRTN, and set_element().
{ clear_element( index, err );MSQ_ERRRTN( err ); set_element( index, vertices, topology, err );MSQ_ERRRTN( err ); }
const std::vector< size_t > & | vertices, | ||
Definition at line 283 of file MeshImplData.cpp.
void MBMesquite::MeshImplData::reset_vertex | ( | size_t | index, |
const Vector3D & | coords, | ||
bool | fixed, | ||
Set allocated but unset veretx to specified values
Definition at line 255 of file MeshImplData.cpp.
References MBMesquite::MeshImplData::Vertex::adjacencies, MBMesquite::MeshImplData::Vertex::coords, fixed, MBMesquite::MeshImplData::Vertex::fixed, MBMesquite::MsqError::INVALID_ARG, MBMesquite::MsqError::INVALID_STATE, MSQ_SETERR, MBMesquite::MeshImplData::Vertex::valid, and vertexList.
Referenced by add_vertex(), MBMesquite::MeshImpl::MeshImpl(), MBMesquite::MeshImpl::read_exodus(), MBMesquite::MeshImpl::vtk_read_polydata(), MBMesquite::MeshImpl::vtk_read_rectilinear_grid(), MBMesquite::MeshImpl::vtk_read_structured_grid(), MBMesquite::MeshImpl::vtk_read_structured_points(), and MBMesquite::MeshImpl::vtk_read_unstructured_grid().
{ if( index >= vertexList.size() ) { MSQ_SETERR( err )( "Invalid vertex handle", MsqError::INVALID_ARG ); return; } Vertex& vert = vertexList[index]; if( !vert.adjacencies.empty() ) { MSQ_SETERR( err )( "Cannot overwrite referenced vertex", MsqError::INVALID_STATE ); return; } vert.coords = coords; vert.fixed = fixed; vert.valid = true; }
void MBMesquite::MeshImplData::set_element | ( | size_t | index, |
) | [private] |
Set cleared element
Definition at line 319 of file MeshImplData.cpp.
References conn.
Referenced by add_element(), and reset_element().
{ if( sizeof( long ) == sizeof( size_t ) ) set_element( index, *reinterpret_cast< const std::vector< size_t >* >( &vertices ), topology, err ); else { std::vector< size_t > conn( vertices.size() ); std::copy( vertices.begin(), vertices.end(), conn.begin() ); set_element( index, conn, topology, err ); } }
) | [private] |
Set cleared element
Definition at line 332 of file MeshImplData.cpp.
References MBMesquite::adj(), corners, elementList, MBMesquite::MsqError::INVALID_ARG, is_vertex_valid(), MSQ_SETERR, and vertexList.
{ if( index >= elementList.size() ) { MSQ_SETERR( err )( "Invalid element handle", MsqError::INVALID_ARG ); return; } elementList[index].connectivity = vertices; elementList[index].topology = topology; for( std::vector< size_t >::const_iterator iter = vertices.begin(); iter != vertices.end(); ++iter ) { if( !is_vertex_valid( *iter ) ) { MSQ_SETERR( err )( "Invalid vertex handle", MsqError::INVALID_ARG ); return; } std::vector< size_t >& adj = vertexList[*iter].adjacencies; for( std::vector< size_t >::iterator iter2 = adj.begin(); iter2 != adj.end(); ++iter2 ) if( *iter2 == index ) return; adj.push_back( index ); } unsigned numvert = TopologyInfo::corners( elementList[index].topology ); if( numvert ) for( unsigned i = numvert; i < elementList[index].connectivity.size(); ++i ) ++vertexList[elementList[index].connectivity[i]].midcount; }
void MBMesquite::MeshImplData::set_vertex_byte | ( | size_t | index, |
unsigned char | value, | ||
Set vertex byte
Definition at line 146 of file MeshImplData.cpp.
References MBMesquite::MsqError::INVALID_ARG, is_vertex_valid(), MSQ_SETERR, value(), and vertexList.
Referenced by MBMesquite::MeshImpl::vertices_set_byte().
{ if( !is_vertex_valid( index ) ) { MSQ_SETERR( err )( "Invalid vertex handle", MsqError::INVALID_ARG ); return; } vertexList[index].byte = value; }
void MBMesquite::MeshImplData::set_vertex_coords | ( | size_t | index, |
Set vertex coordinates
Definition at line 244 of file MeshImplData.cpp.
Referenced by MBMesquite::MeshImpl::vertex_set_coordinates().
{ if( !is_vertex_valid( index ) ) { MSQ_SETERR( err )( "Invalid vertex handle", MsqError::INVALID_ARG ); return; } vertexList[index].coords = coords; }
void MBMesquite::MeshImplData::skin | ( | std::vector< size_t > & | sides, |
Skin mesh.
Get the boundary of a mesh as element sides
sides | Element sides as pairs of values : { elem_index, side_number } |
Definition at line 650 of file MeshImplData.cpp.
References MBMesquite::adj(), conn, dim, elementList, has_adjacent_elements(), is_element_valid(), MSQ_ERRRTN, MBMesquite::POLYGON, and MBMesquite::POLYHEDRON.
{ std::vector< size_t > side_nodes; // For each element in mesh for( size_t elem = 0; elem < elementList.size(); ++elem ) { if( !is_element_valid( elem ) ) continue; // For each side of the element, check if there // are any adjacent elements. const EntityTopology topo = elementList[elem].topology; std::vector< size_t >& conn = elementList[elem].connectivity; switch( topo ) { // For normal elements (not poly****) default: { unsigned num = TopologyInfo::sides( topo ); unsigned dim = TopologyInfo::dimension( topo ) - 1; // For each side for( unsigned side = 0; side < num; ++side ) { // Get list of vertices defining the side unsigned count; const unsigned* indices = TopologyInfo::side_vertices( topo, dim, side, count, err );MSQ_ERRRTN( err ); side_nodes.clear(); for( unsigned k = 0; k < count; ++k ) side_nodes.push_back( conn[indices[k]] ); // If no adjacent element, add side to output list bool adj = has_adjacent_elements( elem, side_nodes, err );MSQ_ERRRTN( err ); if( !adj ) { sides.push_back( elem ); sides.push_back( side ); } } } break; case POLYGON: { for( unsigned side = 0, next = 1; next < conn.size(); ++side, ++next ) { side_nodes.clear(); side_nodes.push_back( conn[side] ); side_nodes.push_back( conn[next] ); // If no adjacent element, add side to output list bool adj = has_adjacent_elements( elem, side_nodes, err );MSQ_ERRRTN( err ); if( !adj ) { sides.push_back( elem ); sides.push_back( side ); } } } break; case POLYHEDRON: { for( unsigned side = 0; side < conn.size(); ++side ) { side_nodes = elementList[conn[side]].connectivity; // If no adjacent element, add side to output list bool adj = has_adjacent_elements( elem, side_nodes, err );MSQ_ERRRTN( err ); if( !adj ) { sides.push_back( elem ); sides.push_back( side ); } } } break; } // switch(topo) } // for (elementList) }
void MBMesquite::MeshImplData::slave_vertex | ( | size_t | index, |
bool | flag, | ||
Set vertex slaved flag
Definition at line 123 of file MeshImplData.cpp.
References haveSlavedFlags, MBMesquite::MsqError::INVALID_ARG, is_vertex_valid(), MSQ_SETERR, and vertexList.
Referenced by MBMesquite::MeshImpl::read_vtk(), MBMesquite::MeshImpl::set_all_slaved_flags(), and MBMesquite::MeshImpl::set_skin_flags().
{ if( !is_vertex_valid( index ) ) { MSQ_SETERR( err )( "Invalid vertex handle", MsqError::INVALID_ARG ); return; } vertexList[index].slaved = flag; haveSlavedFlags = true; }
const std::vector< size_t > & MBMesquite::MeshImplData::vertex_adjacencies | ( | size_t | index, |
) | const |
Get vertex adjacency list
Definition at line 202 of file MeshImplData.cpp.
References MBMesquite::dummy_list, MBMesquite::MsqError::INVALID_ARG, is_vertex_valid(), MSQ_SETERR, and vertexList.
Referenced by MBMesquite::is_side_boundary(), and MBMesquite::MeshImpl::vertices_get_attached_elements().
{ if( !is_vertex_valid( index ) ) { MSQ_SETERR( err )( "Invalid vertex handle", MsqError::INVALID_ARG ); return dummy_list; } return vertexList[index].adjacencies; }
bool MBMesquite::MeshImplData::vertex_is_fixed | ( | size_t | index, |
) | const |
Get vertex fixed flag
Definition at line 85 of file MeshImplData.cpp.
Referenced by MBMesquite::MeshImpl::vertices_get_fixed_flag(), MBMesquite::MeshImpl::write_exodus(), and MBMesquite::MeshImpl::write_vtk().
{ if( !is_vertex_valid( index ) ) { MSQ_SETERR( err )( "Invalid vertex handle", MsqError::INVALID_ARG ); return false; } return vertexList[index].fixed; }
bool MBMesquite::MeshImplData::vertex_is_slaved | ( | size_t | index, |
) | const |
Get vertex slaved flag
Definition at line 96 of file MeshImplData.cpp.
References have_slaved_flags(), MBMesquite::MsqError::INVALID_ARG, MBMesquite::MsqError::INVALID_STATE, is_vertex_valid(), MSQ_SETERR, and vertexList.
Referenced by MBMesquite::MeshImpl::vertices_get_slaved_flag(), and MBMesquite::MeshImpl::write_vtk().
{ if( !is_vertex_valid( index ) ) { MSQ_SETERR( err )( "Invalid vertex handle", MsqError::INVALID_ARG ); return false; } if( !have_slaved_flags() ) { MSQ_SETERR( err )( "Slave flags not set", MsqError::INVALID_STATE ); return false; } return vertexList[index].slaved; }
std::vector< size_t > MBMesquite::MeshImplData::deletedElementList [private] |
List of unused indices in element list
Definition at line 240 of file MeshImplData.hpp.
Referenced by add_element(), clear(), delete_element(), and num_elements().
std::vector< size_t > MBMesquite::MeshImplData::deletedVertexList [private] |
List of unused indices in vertex list
Definition at line 238 of file MeshImplData.hpp.
Referenced by add_vertex(), clear(), and delete_vertex().
std::vector< Element > MBMesquite::MeshImplData::elementList [private] |
Array of elements
Definition at line 235 of file MeshImplData.hpp.
Referenced by add_element(), all_elements(), allocate_elements(), clear(), clear_element(), copy_higher_order(), copy_mesh(), element_connectivity(), element_topology(), has_adjacent_elements(), is_element_valid(), max_element_index(), num_elements(), num_vertex_uses(), set_element(), and skin().
bool MBMesquite::MeshImplData::haveSlavedFlags [private] |
Definition at line 242 of file MeshImplData.hpp.
Referenced by clear(), have_slaved_flags(), and slave_vertex().
std::vector< Vertex > MBMesquite::MeshImplData::vertexList [private] |
Array of vertices
Definition at line 234 of file MeshImplData.hpp.
Referenced by add_vertex(), all_vertices(), allocate_vertices(), clear(), clear_element(), copy_higher_order(), copy_mesh(), delete_vertex(), element_topology(), fix_vertex(), get_adjacent_elements(), get_vertex_byte(), get_vertex_coords(), is_corner_node(), is_mid_node(), is_vertex_valid(), max_vertex_index(), num_vertices(), reset_vertex(), set_element(), set_vertex_byte(), set_vertex_coords(), slave_vertex(), vertex_adjacencies(), vertex_is_fixed(), and vertex_is_slaved().
