MOAB: Mesh Oriented datABase
(version 5.3.1)
Lagrange shape function for 9-node quadrilateral elements. More...
#include <QuadLagrangeShape.hpp>
Public Member Functions | |
virtual EntityTopology | element_topology () const |
Get MBMesquite::EntityTopology handled by this mapping function. | |
virtual int | num_nodes () const |
Get number of nodes in the element type. | |
virtual void | coefficients (Sample location, NodeSet nodeset, double *coeff_out, size_t *indices_out, size_t &num_coeff_out, MsqError &err) const |
Mapping Function Coefficients. | |
virtual void | derivatives (Sample location, NodeSet nodeset, size_t *vertex_indices_out, MsqVector< 2 > *d_coeff_d_xi_out, size_t &num_vtx, MsqError &err) const |
Mapping Function Derivatives. | |
virtual void | ideal (Sample location, MsqMatrix< 3, 2 > &jacobian_out, MsqError &err) const |
Get ideal Jacobian matrix. |
This class implements the MappingFunction interface, providing a Lagrange shape function for quadrilateral elements.
\(\vec{x}(\xi,\eta) = \sum_{i=0}^{n-1} N_i(\xi,\eta) \vec{x_i}\)
\(N_a = l^2_b(\xi) l^2_c(\eta)\)
\(l^2_1(\xi) = (\xi - 1) (2 \xi - 1)\)
\(l^2_2(\xi) = 4 \xi (1 - \xi)\)
\(l^2_3(\xi) = \xi (2 \xi - 1)\)
\(\begin{array}{ccc} a & b & c \\ \hline 0 & 1 & 1 \\ 1 & 3 & 1 \\ 2 & 3 & 3 \\ 3 & 1 & 3 \\ 4 & 2 & 1 \\ 5 & 3 & 2 \\ 6 & 2 & 3 \\ 7 & 1 & 2 \\ 8 & 2 & 2 \end{array}\)
Definition at line 68 of file QuadLagrangeShape.hpp.
void MBMesquite::QuadLagrangeShape::coefficients | ( | Sample | location, |
NodeSet | nodeset, | ||
double * | coeff_out, | ||
size_t * | indices_out, | ||
size_t & | num_coeff_out, | ||
MsqError & | err | ||
) | const [virtual] |
This function returns the list of scalar values ( \(N_i\)'s) resulting from the evaluation of the mapping function coefficient terms \(N_1(\vec{\xi}), N_2(\vec{\xi}), \ldots, N_n(\vec{\xi})\) for a given \(\vec{\xi}\).
location | Where within the element at which to evaluate the coefficients. |
nodeset | List of which nodes are present in the element. |
coefficients_out | The coefficients ( \(N_i(\vec{\xi})\)) for each vertex in the element. |
indices_out | The index ($i$ in $N_i$) for each term in 'coeffs_out'. The assumption is that mapping function implementations will not return zero coefficients. This is not required, but for element types with large numbers of nodes it may have a significant impact on performance. |
Implements MBMesquite::MappingFunction.
Definition at line 47 of file QuadLagrangeShape.cpp.
References MBMesquite::Sample::dimension, MBMesquite::NodeSet::have_any_mid_node(), MBMesquite::NodeSet::mid_edge_node(), MBMesquite::NodeSet::mid_face_node(), MSQ_SETERR, MBMesquite::Sample::number, and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
{ if( !nodeset.have_any_mid_node() ) { LinearQuadrilateral::coefficients( loc, nodeset, coeff_out, indices_out, num_coeff ); return; } switch( loc.dimension ) { case 0: num_coeff = 1; indices_out[0] = loc.number; coeff_out[0] = 1.0; break; case 1: coeff_out[0] = coeff_out[1] = coeff_out[2] = coeff_out[3] = coeff_out[4] = coeff_out[5] = coeff_out[6] = coeff_out[7] = coeff_out[8] = 0.0; if( nodeset.mid_edge_node( loc.number ) ) { // if mid-edge node is present num_coeff = 1; indices_out[0] = loc.number + 4; coeff_out[0] = 1.0; } else { // If mid-edge node is not present, mapping function value // for linear edge is even weight of adjacent vertices. num_coeff = 2; indices_out[0] = loc.number; indices_out[1] = ( loc.number + 1 ) % 4; coeff_out[0] = 0.5; coeff_out[1] = 0.5; } break; case 2: if( nodeset.mid_face_node( 0 ) ) { // if quad center node is present num_coeff = 1; indices_out[0] = 8; coeff_out[0] = 1.0; } else { // for linear element, (no mid-edge nodes), all corners contribute 1/4. num_coeff = 4; indices_out[0] = 0; indices_out[1] = 1; indices_out[2] = 2; indices_out[3] = 3; coeff_out[0] = 0.25; coeff_out[1] = 0.25; coeff_out[2] = 0.25; coeff_out[3] = 0.25; // add in contribution for any mid-edge nodes present for( int i = 0; i < 4; ++i ) { // for each edge if( nodeset.mid_edge_node( i ) ) { indices_out[num_coeff] = i + 4; coeff_out[num_coeff] = 0.5; coeff_out[i] -= 0.25; coeff_out[( i + 1 ) % 4] -= 0.25; ++num_coeff; } } } break; default: MSQ_SETERR( err ) ( MsqError::UNSUPPORTED_ELEMENT, "Request for dimension %d mapping function value" "for a quadrilateral element", loc.dimension ); } }
void MBMesquite::QuadLagrangeShape::derivatives | ( | Sample | location, |
size_t * | vertex_indices_out, | ||
MsqVector< 2 > * | d_coeff_d_xi_out, | ||
size_t & | num_vtx, | ||
This function returns the partial derivatives of the mapping function coefficient terms \(\nabla N_1(\vec{\xi}), \nabla N_2(\vec{\xi}), \ldots, \nabla N_n(\vec{\xi})\) evaluated for a given \(\vec{\xi}\), where \(\vec{x_i}\) is a point in \(\mathbf{R}^3\) (i.e. \(x_i,y_i,z_i\)). \(\vec{\xi_i} = \left\{\begin{array}{c}\xi_i\\ \eta_i\\ \end{array}\right\}\) for surface elements and \(\vec{\xi_i} = \left\{\begin{array}{c}\xi_i\\ \eta_i\\ \zeta_i\\ \end{array}\right\}\) for volume elements.
The list of returned partial derivatives may be considered list of elements of a matrix \(\mathbf{D}\) in row major order. For surface elements, \(\mathbf{D}\) is a \(n\times 2\) matrix and for volume elements it is a \(n \times 3\) matrix. Each row of \(\mathbf{D}\) corresponds to one of the coefficient functions \(N_i(\vec{\xi})\) and each column corresponds to one of the components of \(\vec{\xi}\) that the corresponding coefficient function is differentiated with respect to.
\( \mathbf{D} = \left[ \begin{array}{ccc} \frac{\delta N_1}{\delta \xi} & \frac{\delta N_1}{\delta \eta} & \ldots \\ \frac{\delta N_2}{\delta \xi} & \frac{\delta N_2}{\delta \eta} & \ldots \\ \vdots & \vdots & \ddots \end{array} \right]\)
The Jacobian matrix ( \(\mathbf{J}\)) of the mapping function can be calculated as follows. Define a matrix \(\mathbf{X}\) such that each column contains the coordinates of the element nodes.
\( \mathbf{X} = \left[ \begin{array}{ccc} x_1 & x_2 & \ldots \\ y_1 & y_2 & \ldots \\ z_1 & z_2 & \ldots \end{array}\right]\)
The Jacobian matrix is then:
\(\mathbf{J} = \mathbf{X} \times \mathbf{D}\)
\(\mathbf{X}\) is always \(3\times n\), so \(\mathbf{J}\) is either \(3\times 2\) (surface elements) or \(3\times 3\) (volume elements) depending on the dimensions of \(\mathbf{D}\).
If the Jacobian matrix of the mapping function is considered as a function of the element vertex coordinates \(\mathbf{J}(\vec{x_1},\vec{x_2},\ldots)\) with \(\vec{\xi}\) constant, then the gradient of that Jacobian matrix function (with respect to the vertex coordinates) can be obtained from the same output list of partial deravitves.
\(\frac{\delta \mathbf{J}}{\delta x_i} = \left[ \begin{array}{ccc} \frac{\delta N_i}{\delta \xi} & \frac{\delta N_i}{\delta \eta} & \ldots \\ 0 & 0 & \ldots \\ 0 & 0 & \ldots \end{array} \right]\) \(\frac{\delta \mathbf{J}}{\delta y_i} = \left[ \begin{array}{ccc} 0 & 0 & \ldots \\ \frac{\delta N_i}{\delta \xi} & \frac{\delta N_i}{\delta \eta} & \ldots \\ 0 & 0 & \ldots \end{array} \right]\) \(\frac{\delta \mathbf{J}}{\delta z_i} = \left[ \begin{array}{ccc} 0 & 0 & \ldots \\ 0 & 0 & \ldots \\ \frac{\delta N_i}{\delta \xi} & \frac{\delta N_i}{\delta \eta} & \ldots \end{array} \right]\)
location | Where within the element at which to evaluate the derivatives. |
vertices_out | The list of vertices for which the corresponding coefficient in the mapping function is non-zero. The vertices are specified by their index in the canonical ordering for an element with all mid-nodes present (i.e. first all the corner nodes, then the mid-edge nodes, ...). |
d_coeff_d_xi_out | The mapping function is composed of a series of coefficient functions \(N_i(\vec{\xi})\), one correspoding to the position \(\vec{x_i}\) of each node in the element such that the mapping function is of the form: \(\vec{x}(\vec{\xi})=\sum_{i=1}^n N_i(\vec{\xi})\vec{x_i}\). For each vertex indicated in vertex_indices_out, this list contains the partial derivatives of the cooresponding coefficient function \(N_i\) with respect to each component of \(\vec{\xi}\) in the same order as the corresponding nodes in vertex_indices_out. |
num_vtx | Output: The number of vertex indices and derivitive tuples returned in vertices_out and d_coeff_d_xi_out, respectively. |
Implements MBMesquite::MappingFunction2D.
Definition at line 374 of file QuadLagrangeShape.cpp.
References MBMesquite::derivatives_at_corner(), MBMesquite::derivatives_at_mid_edge(), MBMesquite::derivatives_at_mid_elem(), MBMesquite::Sample::dimension, MBMesquite::NodeSet::have_any_mid_node(), MBMesquite::MsqError::INVALID_ARG, MSQ_SETERR, and MBMesquite::Sample::number.
{ if( !nodeset.have_any_mid_node() ) { LinearQuadrilateral::derivatives( loc, nodeset, vertex_indices_out, d_coeff_d_xi_out, num_vtx ); return; } switch( loc.dimension ) { case 0: derivatives_at_corner( loc.number, nodeset, vertex_indices_out, d_coeff_d_xi_out, num_vtx ); break; case 1: derivatives_at_mid_edge( loc.number, nodeset, vertex_indices_out, d_coeff_d_xi_out, num_vtx ); break; case 2: derivatives_at_mid_elem( nodeset, vertex_indices_out, d_coeff_d_xi_out, num_vtx ); break; default: MSQ_SETERR( err )( "Invalid/unsupported logical dimension", MsqError::INVALID_ARG ); } }
EntityTopology MBMesquite::QuadLagrangeShape::element_topology | ( | ) | const [virtual] |
Definition at line 37 of file QuadLagrangeShape.cpp.
References MBMesquite::QUADRILATERAL.
{ return QUADRILATERAL; }
void MBMesquite::QuadLagrangeShape::ideal | ( | Sample | location, |
MsqMatrix< 3, 2 > & | jacobian_out, | ||
Returns the Jacobian matrix of an ideal element. The orientation of element or corresponding matrix is arbitrary. The "ideal" element should be scaled such the Jacobian (determinant of the Jacobian matrix) is 1.0.
location | Where within the element at which to evaluate the Jacobian. Typically doesn't matter except for degenerate elements (e.g. pyramid as degenerate hex.) |
jacobian_out | The Jacobian of the mapping function at the specified logical location. |
Reimplemented from MBMesquite::MappingFunction2D.
Definition at line 399 of file QuadLagrangeShape.cpp.
{ J( 0, 0 ) = J( 1, 1 ) = 1.0; J( 0, 1 ) = J( 1, 0 ) = 0.0; J( 2, 0 ) = J( 2, 1 ) = 0.0; }
int MBMesquite::QuadLagrangeShape::num_nodes | ( | ) | const [virtual] |
Get the number of nodes in the element type that the mapping function implements. It is assumed that the result of this function, in combination with the element topology, is sufficient to determine the element type.
Definition at line 42 of file QuadLagrangeShape.cpp.
return 9;
