MOAB: Mesh Oriented datABase
(version 5.2.1)
Multiplies quality metric value by a number (a double). More...
#include <ScalarMultiplyQualityMetric.hpp>
Public Member Functions | |
ScalarMultiplyQualityMetric (QualityMetric *metric, double scale) | |
~ScalarMultiplyQualityMetric () | |
MetricType | get_metric_type () const |
std::string | get_name () const |
int | get_negate_flag () const |
1 if metric should be minimized, -1 if metric should be maximized. | |
void | get_evaluations (PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err) |
Get locations at which metric can be evaluated. | |
bool | evaluate (PatchData &pd, size_t handle, double &value, MsqError &err) |
Get metric value at a logical location in the patch. | |
bool | evaluate_with_indices (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, MsqError &err) |
bool | evaluate_with_gradient (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, MsqError &err) |
Get metric value and gradient at a logical location in the patch. | |
bool | evaluate_with_Hessian (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, std::vector< Matrix3D > &Hessian, MsqError &err) |
Get metric value and deravitives at a logical location in the patch. | |
Private Attributes | |
QualityMetric * | mMetric |
double | mScale |
Definition at line 49 of file ScalarMultiplyQualityMetric.hpp.
MBMesquite::ScalarMultiplyQualityMetric::ScalarMultiplyQualityMetric | ( | QualityMetric * | metric, |
double | scale | ||
) | [inline] |
Definition at line 52 of file ScalarMultiplyQualityMetric.hpp.
Definition at line 54 of file ScalarMultiplyQualityMetric.hpp.
bool ScalarMultiplyQualityMetric::evaluate | ( | PatchData & | pd, |
size_t | handle, | ||
double & | value, | ||
MsqError & | err | ||
) | [virtual] |
Evaluate the metric at one location in the PatchData.
pd | The patch. |
handle | The location in the patch (as passed back from get_evaluations). |
value | The output metric value. |
Implements MBMesquite::QualityMetric.
Definition at line 53 of file ScalarMultiplyQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate(), mMetric, and mScale.
bool ScalarMultiplyQualityMetric::evaluate_with_gradient | ( | PatchData & | pd, |
std::vector< size_t > & | indices, | ||
std::vector< Vector3D > & | gradient, | ||
) | [virtual] |
pd | The patch. |
indices | The free vertices that the evaluation is a function of, specified as vertex indices in the PatchData. |
gradient | The gradient of the metric as a function of the coordinates of the free vertices passed back in the indices list. |
Reimplemented from MBMesquite::QualityMetric.
Definition at line 68 of file ScalarMultiplyQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate_with_gradient(), mMetric, mScale, and MSQ_CHKERR.
{ bool rval = mMetric->evaluate_with_gradient( pd, handle, value, indices, gradient, err ); value *= mScale; for( std::vector< Vector3D >::iterator i = gradient.begin(); i != gradient.end(); ++i ) *i *= mScale; return !MSQ_CHKERR( err ) && rval; }
bool ScalarMultiplyQualityMetric::evaluate_with_Hessian | ( | PatchData & | pd, |
std::vector< Matrix3D > & | Hessian, | ||
) | [virtual] |
pd | The patch. |
Hessian | The Hessian of the metric as a function of the coordinates. The Hessian is passed back as the upper-triangular portion of the matrix in row-major order, where each Matrix3D is the portion of the Hessian with respect to the vertices at the corresponding positions in the indices list. |
Definition at line 79 of file ScalarMultiplyQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate_with_Hessian(), mMetric, mScale, and MSQ_CHKERR.
{ bool rval = mMetric->evaluate_with_Hessian( pd, handle, value, indices, gradient, Hessian, err ); value *= mScale; for( std::vector< Vector3D >::iterator i = gradient.begin(); i != gradient.end(); ++i ) *i *= mScale; for( std::vector< Matrix3D >::iterator j = Hessian.begin(); j != Hessian.end(); ++j ) *j *= mScale; return !MSQ_CHKERR( err ) && rval; }
bool ScalarMultiplyQualityMetric::evaluate_with_indices | ( | PatchData & | pd, |
) | [virtual] |
pd | The patch. |
Definition at line 60 of file ScalarMultiplyQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate_with_indices(), mMetric, mScale, and MSQ_CHKERR.
{ bool rval = mMetric->evaluate_with_indices( pd, handle, value, indices, err ); value *= mScale; return !MSQ_CHKERR( err ) && rval; }
void ScalarMultiplyQualityMetric::get_evaluations | ( | PatchData & | pd, |
std::vector< size_t > & | handles, | ||
bool | free_vertices_only, | ||
) | [virtual] |
Different metrics are evaluated for different things within a patch. For example, an element-based metric will be evaluated once for each element in patch, a vertex-based metric once for each veretx, and a target/sample-point based metric will be evaluated once for each samle point in each element. This method returns a list of handles, one for each location in the patch at which the metric can be evaluated. The handle values are used as input to the evaluate methods.
pd | The patch |
handles | Output list of handles |
free_vertices_only | If true, only pass back evaluation points that depend on at least one free vertex. |
Definition at line 47 of file ScalarMultiplyQualityMetric.cpp.
References MBMesquite::QualityMetric::get_evaluations(), mMetric, and MSQ_CHKERR.
{ mMetric->get_evaluations( pd, handles, free_vertices_only, err );MSQ_CHKERR( err ); }
MetricType MBMesquite::ScalarMultiplyQualityMetric::get_metric_type | ( | ) | const [inline, virtual] |
Definition at line 56 of file ScalarMultiplyQualityMetric.hpp.
References MBMesquite::QualityMetric::get_metric_type(), and mMetric.
{ return mMetric->get_metric_type(); }
std::string ScalarMultiplyQualityMetric::get_name | ( | ) | const [virtual] |
Definition at line 42 of file ScalarMultiplyQualityMetric.cpp.
References MBMesquite::QualityMetric::get_name(), and mMetric.
int MBMesquite::ScalarMultiplyQualityMetric::get_negate_flag | ( | ) | const [inline, virtual] |
Definition at line 63 of file ScalarMultiplyQualityMetric.hpp.
References MBMesquite::QualityMetric::get_negate_flag(), and mMetric.
{ return mMetric->get_negate_flag(); }
Definition at line 82 of file ScalarMultiplyQualityMetric.hpp.
Referenced by evaluate(), evaluate_with_gradient(), evaluate_with_Hessian(), evaluate_with_indices(), get_evaluations(), get_metric_type(), get_name(), and get_negate_flag().
double MBMesquite::ScalarMultiplyQualityMetric::mScale [private] |
Definition at line 83 of file ScalarMultiplyQualityMetric.hpp.
Referenced by evaluate(), evaluate_with_gradient(), evaluate_with_Hessian(), and evaluate_with_indices().
