MBMesquite::TTau Class Reference
det(T) More...
#include <TTau.hpp>
+ Inheritance diagram for MBMesquite::TTau:
+ Collaboration diagram for MBMesquite::TTau:
Public Member Functions
virtual MESQUITE_EXPORT ~TTau ()
virtual MESQUITE_EXPORT std::string get_name () const
virtual MESQUITE_EXPORT bool evaluate (const MsqMatrix< 2, 2 > &T, double &result, MsqError &err)
 Evaluate \(\mu(T)\).
virtual MESQUITE_EXPORT bool evaluate (const MsqMatrix< 3, 3 > &T, double &result, MsqError &err)
Detailed Description
det(T)
Intended for use in QualityAssessment only. If used elsewhere, analytical derivatives should probably be implemented.
Definition at line 46 of file TTau.hpp.
MBMesquite::TTau::~TTau ( ) [virtual]
Definition at line 39 of file TTau.cpp.
Member Function Documentation
bool MBMesquite::TTau::evaluate ( const MsqMatrix< 2, 2 > &  T,
double &  result,
MsqError err
) [virtual]
Parameters:
T2x2 relative measure matrix (typically A W^-1)
resultOutput: value of function
Returns:
false if function cannot be evaluated for given T (e.g. division by zero, etc.), true otherwise.
Reimplemented from MBMesquite::TMetric.
Definition at line 46 of file TTau.cpp.
References MBMesquite::det().
    result = det( T );
    return true;
bool MBMesquite::TTau::evaluate ( const MsqMatrix< 3, 3 > &  T,
double &  result,
MsqError err
) [virtual]
Parameters:
T3x3 relative measure matrix (typically A W^-1)
Returns:
Definition at line 52 of file TTau.cpp.
    result = det( T );
    return true;
std::string MBMesquite::TTau::get_name ( ) const [virtual]
Implements MBMesquite::TMetric.
Definition at line 41 of file TTau.cpp.
    return "Tau";
List of all members.
