MOAB
4.9.3pre
#include <GeneralMatrixMatrixTriangular.h>
Public Types | |
| enum | { BlockSize = meta_least_common_multiple<EIGEN_PLAIN_ENUM_MAX(mr,nr),EIGEN_PLAIN_ENUM_MIN(mr,nr)>::ret } |
| typedef gebp_traits< LhsScalar, RhsScalar, ConjLhs, ConjRhs > | Traits |
| typedef Traits::ResScalar | ResScalar |
Public Member Functions | |
| void | operator() (ResScalar *_res, Index resStride, const LhsScalar *blockA, const RhsScalar *blockB, Index size, Index depth, const ResScalar &alpha) |
Definition at line 137 of file GeneralMatrixMatrixTriangular.h.
| typedef Traits::ResScalar Eigen::internal::tribb_kernel< LhsScalar, RhsScalar, Index, mr, nr, ConjLhs, ConjRhs, UpLo >::ResScalar |
Definition at line 140 of file GeneralMatrixMatrixTriangular.h.
| typedef gebp_traits<LhsScalar,RhsScalar,ConjLhs,ConjRhs> Eigen::internal::tribb_kernel< LhsScalar, RhsScalar, Index, mr, nr, ConjLhs, ConjRhs, UpLo >::Traits |
Definition at line 139 of file GeneralMatrixMatrixTriangular.h.
| anonymous enum |
Definition at line 142 of file GeneralMatrixMatrixTriangular.h.
| void Eigen::internal::tribb_kernel< LhsScalar, RhsScalar, Index, mr, nr, ConjLhs, ConjRhs, UpLo >::operator() | ( | ResScalar * | _res, |
| Index | resStride, | ||
| const LhsScalar * | blockA, | ||
| const RhsScalar * | blockB, | ||
| Index | size, | ||
| Index | depth, | ||
| const ResScalar & | alpha | ||
| ) | [inline] |
Definition at line 145 of file GeneralMatrixMatrixTriangular.h.
typedef blas_data_mapper<ResScalar, Index, ColMajor> ResMapper;
ResMapper res(_res, resStride);
gebp_kernel<LhsScalar, RhsScalar, Index, ResMapper, mr, nr, ConjLhs, ConjRhs> gebp_kernel;
Matrix<ResScalar,BlockSize,BlockSize,ColMajor> buffer;
// let's process the block per panel of actual_mc x BlockSize,
// again, each is split into three parts, etc.
for (Index j=0; j<size; j+=BlockSize)
Index actualBlockSize = std::min<Index>(BlockSize,size - j);
const RhsScalar* actual_b = blockB+j*depth;
if(UpLo==Upper)
gebp_kernel(res.getSubMapper(0, j), blockA, actual_b, j, depth, actualBlockSize, alpha,
-1, -1, 0, 0);
// selfadjoint micro block
Index i = j;
buffer.setZero();
// 1 - apply the kernel on the temporary buffer
gebp_kernel(ResMapper(buffer.data(), BlockSize), blockA+depth*i, actual_b, actualBlockSize, depth, actualBlockSize, alpha,
-1, -1, 0, 0);
// 2 - triangular accumulation
for(Index j1=0; j1<actualBlockSize; ++j1)
ResScalar* r = &res(i, j + j1);
for(Index i1=UpLo==Lower ? j1 : 0;
UpLo==Lower ? i1<actualBlockSize : i1<=j1; ++i1)
r[i1] += buffer(i1,j1);
if(UpLo==Lower)
Index i = j+actualBlockSize;
gebp_kernel(res.getSubMapper(i, j), blockA+depth*i, actual_b, size-i,
depth, actualBlockSize, alpha, -1, -1, 0, 0);
