ExtractLand.cpp File Reference
#include "moab/ProgOptions.hpp"
#include "moab/Core.hpp"
#include <cmath>
#include <sstream>
+ Include dependency graph for ExtractLand.cpp:
Functions
int main (int argc, char *argv[])
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 22 of file ExtractLand.cpp.
References moab::Core::add_entities(), ProgOptions::addOpt(), moab::Range::begin(), moab::Core::create_meshset(), moab::Core::delete_entities(), moab::Range::end(), ErrorCode, moab::Core::get_entities_by_dimension(), moab::Core::globalId_tag(), moab::Range::insert(), moab::Core::load_file(), mb, MB_CHK_SET_ERR, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MESHSET_SET, ProgOptions::parseCommandLine(), ProgOptions::printHelp(), moab::Range::size(), moab::Core::tag_get_data(), moab::Core::tag_get_handle(), moab::Core::tag_set_data(), and moab::Core::write_file().
    ProgOptions opts;
    std::string  pg2file, lndfile, outfile;
    opts.addOpt< std::string >( "land,l", "phys grid filename", &lndfile );
    opts.addOpt< std::string >( "pg2file,p", "pg2 mesh file", &pg2file );
    opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile );
    opts.parseCommandLine( argc, argv );
    std::cout << " land file " << lndfile << "\n";
    std::cout << "pg2 mesh file: " << pg2file << "\n";
    std::cout << "output file: " << outfile << "\n";
    if( lndfile.empty() || pg2file.empty() || outfile.empty() )
        opts.printHelp();
        return 0;
    ErrorCode rval;
    Core* mb = new Core();
    rval = mb->load_file( lndfile.c_str() );MB_CHK_SET_ERR( rval, "can't load land pc file" );
    Core* mb2 = new Core();
    rval      = mb2->load_file( pg2file.c_str() );MB_CHK_SET_ERR( rval, "can't load pg2 mesh file" );
    Tag globalIDTag1 = mb->globalId_tag();
    Tag globalIDTag2 = mb2->globalId_tag();
    Range verts1;
    rval = mb->get_entities_by_dimension( 0, 0, verts1 );MB_CHK_SET_ERR( rval, "can't get vertices " );
    Range cells;
    rval = mb2->get_entities_by_dimension( 0, 2, cells );MB_CHK_SET_ERR( rval, "can't get 2d cells " );
    std::vector< int > globalIdsCells;
    globalIdsCells.resize( cells.size() );
    rval = mb2->tag_get_data( globalIDTag2, cells, &globalIdsCells[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " );
    std::vector< int > globalIdsVerts;
    globalIdsVerts.resize( verts1.size() );
    rval = mb->tag_get_data( globalIDTag1, verts1, &globalIdsVerts[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " );
    // now, every cell will be put into one set, by looking at the global id of cell
    std::map< int, EntityHandle > gidToCell;
    int i = 0;
    for( Range::iterator it = cells.begin(); it != cells.end(); ++it, i++ )
        gidToCell[globalIdsCells[i]] = *it;
    // create a new file set with land cells
    EntityHandle fileSet;
    rval = mb2->create_meshset( MESHSET_SET, fileSet );MB_CHK_SET_ERR( rval, "Error creating file set" );
    // empty all sets
    Range landCells;
    // look now at gid values for vertices
    for( i = 0; i < (int)verts1.size(); i++ )
        int gid           = globalIdsVerts[i];
        landCells.insert(gidToCell[gid]);
    rval = mb2->add_entities(fileSet, landCells);;MB_CHK_SET_ERR( rval, "can't add land cells" );
    rval = mb2->write_file( outfile.c_str(), 0, 0, &fileSet, 1 );MB_CHK_SET_ERR( rval, "can't write file" );
    // write the original with mask 0/1, default -1
    Tag mask;
    double def_val=-1.;
    rval = mb2->tag_get_handle( "mask", 1, MB_TYPE_DOUBLE, mask, MB_TAG_CREAT | MB_TAG_DENSE, &def_val );MB_CHK_SET_ERR( rval, "can't create mask tag" );
        EntityHandle cell = *it;
        // set to 0
        double val = 0.;
        rval = mb2->tag_set_data(mask, &cell, 1, &val); MB_CHK_SET_ERR( rval, "can't set mask tag" );
    for( Range::iterator it = landCells.begin(); it != landCells.end(); ++it, i++ )
        // set to 0
        double val = 1.;
    rval = mb2->delete_entities(&fileSet, 1); MB_CHK_SET_ERR( rval, "can't delete set" );
    rval = mb2->write_file( "AtmWithLandMask.h5m" );MB_CHK_SET_ERR( rval, "can't write file" );
    delete mb;
    delete mb2;
    return 0;
