GeomSetHierarchy.cpp File Reference
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "MBCN.hpp"
#include "MBTagConventions.hpp"
#include "moab/GeomTopoTool.hpp"
#include <iostream>
#include <cassert>
+ Include dependency graph for GeomSetHierarchy.cpp:
Functions
int main (int argc, char **argv)
Variables
const char * ent_names [] = { "Vertex", "Edge", "Face", "Region" }
Function Documentation
int main ( int  argc,
char **  argv
Definition at line 11 of file GeomSetHierarchy.cpp.
References moab::Range::begin(), moab::Range::clear(), dim, moab::Range::end(), ent_names, ErrorCode, GEOM_DIMENSION_TAG_NAME, moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_parent_meshsets(), moab::GeomTopoTool::get_sense(), moab::GeomTopoTool::get_senses(), moab::Interface::globalId_tag(), moab::Interface::load_file(), mb, MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
    if( 1 == argc )
        std::cout << "Usage: " << argv[0] << " <filename>" << std::endl;
        return 0;
    // instantiate & load a file
    moab::Interface* mb  = new moab::Core();
    moab::ErrorCode rval = mb->load_file( argv[1] );
    assert( moab::MB_SUCCESS == rval );
    // get the geometric topology tag handle
    moab::Tag geom_tag, gid_tag;
    rval = mb->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, moab::MB_TYPE_INTEGER, geom_tag );
    gid_tag = mb->globalId_tag();
    assert( NULL != gid_tag );
    // traverse the model, from dimension 3 downward
    moab::Range psets, chsets;
    std::vector< moab::EntityHandle > sense_ents;
    std::vector< int > senses;
    int dim, pgid, chgid;
    void* dim_ptr = &dim;
    int sense;
    moab::GeomTopoTool gt( mb, true );
    for( dim = 3; dim >= 0; dim-- )
        // get parents at this dimension
        chsets.clear();
        rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, &dim_ptr, 1, chsets, 1, false );
        // for each child, get parents and do something with them
        moab::Range::iterator ch_it, p_it;
        for( ch_it = chsets.begin(); ch_it != chsets.end(); ++ch_it )
            // get the children and put in child set list
            psets.clear();
            rval = mb->get_parent_meshsets( *ch_it, psets );
            rval = mb->tag_get_data( gid_tag, &( *ch_it ), 1, &chgid );
            // print # parents
            std::cout << ent_names[dim] << " " << chgid << " has " << psets.size() << " parents." << std::endl;
            if( 2 == dim )
                for( p_it = psets.begin(); p_it != psets.end(); ++p_it )
                    rval = mb->tag_get_data( gid_tag, &( *p_it ), 1, &pgid );
                    rval = gt.get_sense( *ch_it, *p_it, sense );
                    if( moab::MB_SUCCESS != rval ) continue;
                    std::cout << ent_names[dim + 1] << " " << pgid << ", " << ent_names[dim] << " " << chgid
                              << " sense is: ";
                    if( 1 == sense )
                        std::cout << "FORWARD" << std::endl;
                    else
                        std::cout << "REVERSE" << std::endl;
            else if( 1 == dim )
                sense_ents.clear();
                senses.clear();
                rval = gt.get_senses( *ch_it, sense_ents, senses );
                for( unsigned int i = 0; i < sense_ents.size(); i++ )
                    rval = mb->tag_get_data( gid_tag, &sense_ents[i], 1, &pgid );
                              << " sense is: ";
                    if( -1 == senses[i] )
                        std::cout << "REVERSED" << std::endl;
                    else if( 0 == senses[i] )
                        std::cout << "BOTH" << std::endl;
                    else if( 1 == senses[i] )
                    else
                        std::cout << "(invalid)" << std::endl;
    delete mb;
    return 0;
Variable Documentation
const char* ent_names[] = { "Vertex", "Edge", "Face", "Region" }
Definition at line 9 of file GeomSetHierarchy.cpp.
Referenced by main().
