VarLenDenseTag.hpp
00001 /** \file   VarLenDenseTag.hpp
00002  *  \author Jason Kraftcheck
00003  *  \date   2010-12-14
00004  */
00005
00006 #ifndef VAR_LEN_DENSE_TAG_HPP
00007 #define VAR_LEN_DENSE_TAG_HPP
00008
00009 #include "TagInfo.hpp"
00010 #include "VarLenTag.hpp"
00011
00012 namespace moab
00013 {
00014
00015 class VarLenTag;
00016
00017 /**\brief Dense storage of variable-length tag data
00018  *
00019  * Implement variable-length dense tag.
00020  */
00021 class VarLenDenseTag : public TagInfo
00022 {
00023   private:
00024     int mySequenceArray;  //!< Array index in SequenceManager used to store tag data.
00025
00026     VarLenTag meshValue;
00027
00028     VarLenDenseTag( int array_index,
00029                     const char* name,
00030                     DataType type,
00031                     const void* default_value,
00032                     int default_value_len );
00033
00034   public:
00035     static VarLenDenseTag* create_tag( SequenceManager* seqman,
00036                                        Error* error_handler,
00037                                        const char* name,
00038                                        DataType type,
00039                                        const void* default_value,
00040                                        int default_value_len );
00041
00042     virtual ~VarLenDenseTag();
00043
00044     virtual TagType get_storage_type() const;
00045
00046     /**\brief Remove/clear tag data for all entities
00047      *
00048      * Remove tag values from entities.
00049      *
00050      *\param delete_pending  If true, then release any global
00051      *          data associated with the tag in preparation for deleting
00052      *          the tag itself.
00053      *
00054      *\Note Invalidates tag if \c tag_delete_pending is true.  The only
00055      *        valid method that can be invoked that is is the destructor.
00056      *
00057      *\param seqman    Pointer to mesh entity database
00058      */
00059     virtual ErrorCode release_all_data( SequenceManager* seqman, Error* error_handler, bool delete_pending );
00060
00061     /**\brief Get tag value for passed entities
00062      *
00063      * Get tag values for specified entities.
00064      *
00065      *\Note Will fail for variable-length data.
00066      *\param seqman Pointer to mesh entity database
00067      *\param entities Entity handles for which to retrieve tag data
00068      *\param num_entities Length of \c entities array
00069      *\param data Pointer to memory in which to store consecutive tag values,
00070      *            one for each passed entity.
00071      */
00072     virtual ErrorCode get_data( const SequenceManager* seqman,
00073                                 Error* error_handler,
00074                                 const EntityHandle* entities,
00075                                 size_t num_entities,
00076                                 void* data ) const;
00077
00078     /**\brief Get tag value for passed entities
00079      *
00080      * Get tag values for specified entities.
00081      *
00082      *\Note Will fail for variable-length data.
00083      *\param seqman Pointer to mesh entity database
00084      *\param entities Entity handles for which to retrieve tag data
00085      *\param data Pointer to memory in which to store consecutive tag values,
00086      *            one for each passed entity.
00087      */
00088     virtual ErrorCode get_data( const SequenceManager* seqman,
00089                                 Error* error_handler,
00090                                 const Range& entities,
00091                                 void* data ) const;
00092
00093     /**\brief Get tag value for passed entities
00094      *
00095      * Get tag values for specified entities.
00096      *
00097      *\param seqman    Pointer to mesh entity database
00098      *\param entities  Entity handles for which to retrieve tag data
00099      *\param num_entities Length of \c entities array
00100      *\param data_ptrs Array of pointers to tag values, one pointer
00101      *                 for each passed entity.
00102      *\param data_lengths One value for each entity specifying the
00103      *                length of the tag value for the corresponding
00104      *                entity.
00105      */
00106     virtual ErrorCode get_data( const SequenceManager* seqman,
00107                                 Error* error_handler,
00108                                 const EntityHandle* entities,
00109                                 size_t num_entities,
00110                                 const void** data_ptrs,
00111                                 int* data_lengths ) const;
00112
00113     /**\brief Get tag value for passed entities
00114      *
00115      * Get tag values for specified entities.
00116      *
00117      *\param seqman    Pointer to mesh entity database
00118      *\param entities  Entity handles for which to retrieve tag data
00119      *\param data_ptrs Array of pointers to tag values, one pointer
00120      *                 for each passed entity.
00121      *\param data_lengths One value for each entity specifying the
00122      *                length of the tag value for the corresponding
00123      *                entity.
00124      */
00125     virtual ErrorCode get_data( const SequenceManager* seqman,
00126                                 Error* error_handler,
00127                                 const Range& entities,
00128                                 const void** data_ptrs,
00129                                 int* data_lengths ) const;
00130
00131     /**\brief Set tag value for passed entities
00132      *
00133      * Store tag data or update stored tag values
00134      *\Note Will fail for variable-length data.
00135      *\param seqman Pointer to mesh entity database
00136      *\param entities Entity handles for which to store tag data
00137      *\param num_entities Length of \c entities array
00138      *\param data Pointer to memory holding consecutive tag values,
00139      *            one for each passed entity.
00140      */
00141     virtual ErrorCode set_data( SequenceManager* seqman,
00142                                 Error* error_handler,
00143                                 const EntityHandle* entities,
00144                                 size_t num_entities,
00145                                 const void* data );
00146
00147     /**\brief Set tag value for passed entities
00148      *
00149      * Store tag data or update stored tag values
00150      *\Note Will fail for variable-length data.
00151      *\param seqman Pointer to mesh entity database
00152      *\param entities Entity handles for which to store tag data
00153      *\param data Pointer to memory holding consecutive tag values,
00154      *            one for each passed entity.
00155      */
00156     virtual ErrorCode set_data( SequenceManager* seqman,
00157                                 Error* error_handler,
00158                                 const Range& entities,
00159                                 const void* data );
00160
00161     /**\brief Set tag value for passed entities
00162      *
00163      * Store tag data or update stored tag values
00164      *
00165      *\param seqman    Pointer to mesh entity database
00166      *\param entities  Entity handles for which to store tag data
00167      *\param num_entities Length of \c entities array
00168      *\param data_ptrs Array of pointers to tag values, one pointer
00169      *                 for each passed entity.
00170      *\param data_lengths One value for each entity specifying the
00171      *                length of the tag value for the corresponding
00172      *                entity.  Array is required for variable-length
00173      *                tags and is ignored for fixed-length tags.
00174      */
00175     virtual ErrorCode set_data( SequenceManager* seqman,
00176                                 Error* error_handler,
00177                                 const EntityHandle* entities,
00178                                 size_t num_entities,
00179                                 void const* const* data_ptrs,
00180                                 const int* data_lengths );
00181
00182     /**\brief Set tag value for passed entities
00183      *
00184      * Store tag data or update stored tag values
00185      *
00186      *\param seqman    Pointer to mesh entity database
00187      *\param entities  Entity handles for which to store tag data
00188      *\param data_ptrs Array of pointers to tag values, one pointer
00189      *                 for each passed entity.
00190      *\param data_lengths One value for each entity specifying the
00191      *                length of the tag value for the corresponding
00192      *                entity.  Array is required for variable-length
00193      *                tags and is ignored for fixed-length tags.
00194      */
00195     virtual ErrorCode set_data( SequenceManager* seqman,
00196                                 Error* error_handler,
00197                                 const Range& entities,
00198                                 void const* const* data_ptrs,
00199                                 const int* data_lengths );
00200
00201     /**\brief Set tag value for passed entities
00202      *
00203      * Store tag data or update stored tag values.
00204      *
00205      *\param seqman    Pointer to mesh entity database
00206      *\param entities  Entity handles for which to store tag data
00207      *\param num_entities Length of \c entities array
00208      *\param value_ptr Pointer to a single tag value which is to be
00209      *                 stored for each of the passed entities.
00210      *\param value_len Length of tag value in bytes.  Ignored for
00211      *                 fixed-length tags.  Required for variable-
00212      *                 length tags.
00213      */
00214     virtual ErrorCode clear_data( SequenceManager* seqman,
00215                                   Error* error_handler,
00216                                   const EntityHandle* entities,
00217                                   size_t num_entities,
00218                                   const void* value_ptr,
00219                                   int value_len = 0 );
00220
00221     /**\brief Set tag value for passed entities
00222      *
00223      * Store tag data or update stored tag values.
00224      *
00225      *\param seqman    Pointer to mesh entity database
00226      *\param entities  Entity handles for which to store tag data
00227      *\param value_ptr Pointer to a single tag value which is to be
00228      *                 stored for each of the passed entities.
00229      *\param value_len Length of tag value in bytes.  Ignored for
00230      *                 fixed-length tags.  Required for variable-
00231      *                 length tags.
00232      */
00233     virtual ErrorCode clear_data( SequenceManager* seqman,
00234                                   Error* error_handler,
00235                                   const Range& entities,
00236                                   const void* value_ptr,
00237                                   int value_len = 0 );
00238
00239     /**\brief Remove/clear tag data for entities
00240      *
00241      * Remove tag values from entities.
00242      *
00243      *\param seqman    Pointer to mesh entity database
00244      *\param entities  Entity handles for which to store tag data
00245      *\param num_entities Length of \c entities array
00246      */
00247     virtual ErrorCode remove_data( SequenceManager* seqman,
00248                                    Error* error_handler,
00249                                    const EntityHandle* entities,
00250                                    size_t num_entities );
00251
00252     /**\brief Remove/clear tag data for entities
00253      *
00254      * Remove tag values from entities.
00255      *
00256      *\param seqman    Pointer to mesh entity database
00257      *\param entities  Entity handles for which to store tag data
00258      */
00259     virtual ErrorCode remove_data( SequenceManager* seqman, Error* error_handler, const Range& entities );
00260
00261     /**\brief Access tag data via direct pointer into contiguous blocks
00262      *
00263      * Iteratively obtain direct access to contiguous blocks of tag
00264      * storage.  This function cannot be used with bit tags because
00265      * of the compressed bit storage.  This function cannot be used
00266      * with variable length tags because it does not provide a mechanism
00267      * to determine the length of the value for each entity.  This
00268      * function may be used with sparse tags, but if it is used, it
00269      * will return data for a single entity at a time.
00270      *
00271      *\param iter        As input, the first entity for which to return
00272      *                   data.  As output, one past the last entity for
00273      *                   which data was returned.
00274      *\param end         One past the last entity for which data is desired
00275      *\param data_ptr    Output: pointer to tag storage.
00276      *\param allocate    If true, space for this tag will be allocated, if not it wont
00277      *
00278      *\Note If this function is called for entities for which no tag value
00279      *      has been set, but for which a default value exists, it will
00280      *      force the allocation of explicit storage for each such entity
00281      *      even though MOAB would normally not explicitly store tag values
00282      *      for such entities.
00283      */
00284     virtual ErrorCode tag_iterate( SequenceManager* seqman,
00285                                    Error* error_handler,
00286                                    Range::iterator& iter,
00287                                    const Range::iterator& end,
00288                                    void*& data_ptr,
00289                                    bool allocate );
00290
00291     /**\brief Get all tagged entities
00292      *
00293      * Get the list of entities for which the a tag value has been set,
00294      * or a close approximation if the tag storage scheme cannot
00295      * accurately determine exactly which entities have explicit values.
00296      *
00297      *\param seqman   Pointer to entity storage database
00298      *\param output_entities Results *appended* to this range
00299      *\param type     Optional entity type.  If specified, search is
00300      *                limited to entities of specified type.
00301      *\param intersect Optional intersect list.  If specified,
00302      *                search is restricted to entities in this list.
00303      */
00304     virtual ErrorCode get_tagged_entities( const SequenceManager* seqman,
00305                                            Range& output_entities,
00306                                            EntityType type        = MBMAXTYPE,
00307                                            const Range* intersect = 0 ) const;
00308
00309     /**\brief Count all tagged entities
00310      *
00311      * Count the entities for which the a tag value has been set,
00312      * or a close approximation if the tag storage scheme cannot
00313      * accurately determine exactly which entities have explicit values.
00314      *
00315      *\param seqman   Pointer to entity storage database
00316      *\param output_count This is *incremented* for each detected entity.
00317      *\param type     Optional entity type.  If specified, search is
00318      *                limited to entities of specified type.
00319      *\param intersect Optional intersect list.  If specified,
00320      *                search is restricted to entities in this list.
00321      */
00322     virtual ErrorCode num_tagged_entities( const SequenceManager* seqman,
00323                                            size_t& output_count,
00324                                            EntityType type        = MBMAXTYPE,
00325                                            const Range* intersect = 0 ) const;
00326
00327     /**\brief Get all tagged entities with tag value
00328      *
00329      * Get the list of entities which have the specified tag value.
00330      *
00331      *\param seqman   Pointer to entity storage database
00332      *\param output_entities Results *appended* to this range
00333      *\param value    Pointer to tag value
00334      *\param value_bytes Size of tag value in bytes.
00335      *\param type     Optional entity type.  If specified, search is
00336      *                limited to entities of specified type.
00337      *\param intersect_entities Optional intersect list.  If specified,
00338      *                search is restricted to entities in this list.
00339      */
00340     virtual ErrorCode find_entities_with_value( const SequenceManager* seqman,
00341                                                 Error* error,
00342                                                 Range& output_entities,
00343                                                 const void* value,
00344                                                 int value_bytes                 = 0,
00345                                                 EntityType type                 = MBMAXTYPE,
00346                                                 const Range* intersect_entities = 0 ) const;
00347
00348     /**\brief Check if entity is tagged */
00349     virtual bool is_tagged( const SequenceManager*, EntityHandle h ) const;
00350
00351     /**\brief Get memory use for tag data.
00352      *
00353      */
00354     virtual ErrorCode get_memory_use( const SequenceManager* seqman,
00355                                       unsigned long& total,
00356                                       unsigned long& per_entity ) const;
00357
00358   private:
00359     VarLenDenseTag( const VarLenDenseTag& );
00360     VarLenDenseTag& operator=( const VarLenDenseTag& );
00361
00362     /**\brief Get or allocated tag storage
00363      *
00364      *\param h       First entity for which to return storage.
00365      *\param ptr     Pointer to dag storage.  This pointer will be set
00366      *               to null and \c MB_SUCCESS will be returned if the handle
00367      *               is valid but no tag storage has been allocated.
00368      *\param count   Number of consecutive entities for which tag storage
00369      *               is returned.  This value will be valid even if null
00370      *               is returned for \c ptr and indicates the number of
00371      *               consecutive entities for which no tag storage has been
00372      *               allocated.
00373      *\param allocate If true storage will be allocated and initialized
00374      *               if it has not already been allocated.
00375      *\return        MB_SUCCESS if handle is valid (regardless of whether
00376      *               or not any tag storage is allocated).
00377      */
00378     inline ErrorCode get_array( SequenceManager* seqman,
00379                                 Error* error_handler,
00380                                 EntityHandle h,
00381                                 VarLenTag*& ptr,
00382                                 size_t& count,
00383                                 bool allocate );
00384
00385     /**\brief Get tag storage
00386      *
00387      *\param h       First entity for which to return storage.
00388      *\param ptr     Pointer to dag storage.  This pointer will be set
00389      *               to null and \c MB_SUCCESS will be returned if the handle
00390      *               is valid but no tag storage has been allocated.
00391      *\param count   Number of consecutive entities for which tag storage
00392      *               is returned.  This value will be valid even if null
00393      *               is returned for \c ptr and indicates the number of
00394      *               consecutive entities for which no tag storage has been
00395      *               allocated.
00396      *\return        MB_SUCCESS if handle is valid (regardless of whether
00397      *               or not any tag storage is allocated).
00398      */
00399     inline ErrorCode get_array( const SequenceManager* seqman,
00400                                 Error* error_handler,
00401                                 EntityHandle h,
00402                                 const VarLenTag*& ptr,
00403                                 size_t& count ) const;
00404
00405     /**\brief Common implementation of set_data, and clear_data
00406      *\param allocate  If false and no storage is currently allocated for
00407      *                 an entity then leave entity tag unallocated.
00408      *\param one_value If true,  pointers and lengths are assumed to be
00409      *                 arrays of length 1 and all entities are set to the
00410      *                 corresponding value
00411      */
00412     inline ErrorCode set_data( SequenceManager* seqman,
00413                                Error* error_handler,
00414                                const EntityHandle* entities,
00415                                size_t num_entities,
00416                                bool one_value,
00417                                void const* const* pointers,
00418                                const int* lengths );
00419
00420     /**\brief Common implementation of set_data, and clear_data
00421      *\param allocate  If false and no storage is currently allocated for
00422      *                 an entity then leave entity tag unallocated.
00423      *\param one_value If true,  pointers and lengths are assumed to be
00424      *                 arrays of length 1 and all entities are set to the
00425      *                 corresponding value
00426      */
00427     inline ErrorCode set_data( SequenceManager* seqman,
00428                                Error* error_handler,
00429                                const Range& entities,
00430                                bool one_value,
00431                                void const* const* pointers,
00432                                const int* lengths );
00433 };
00434
00435 }  // namespace moab
00436
00437 #endif  // VAR_LEN_DENSE_TAG_HPP
