addPCdata.cpp File Reference
#include "moab/ProgOptions.hpp"
#include "moab/Core.hpp"
#include <cmath>
#include <sstream>
+ Include dependency graph for addPCdata.cpp:
Functions
int main (int argc, char *argv[])
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 28 of file addPCdata.cpp.
References ProgOptions::addOpt(), moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Core::get_entities_by_dimension(), moab::Core::load_file(), mb, MB_CHK_SET_ERR, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, ProgOptions::parseCommandLine(), ProgOptions::printHelp(), moab::Range::size(), moab::Core::tag_get_bytes(), moab::Core::tag_get_data(), moab::Core::tag_get_data_type(), moab::Core::tag_get_handle(), moab::Core::tag_get_length(), moab::Core::tag_set_data(), and moab::Core::write_file().
    ProgOptions opts;
    std::string inputfile, outfile( "out.h5m" ), sourcefile, variable_name;
    int dual_mesh = 0;
    opts.addOpt< std::string >( "input,i", "input mesh filename", &inputfile );
    opts.addOpt< std::string >( "source,s", "h5m file aligned with the mesh input file", &sourcefile );
    opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile );
    opts.addOpt< std::string >( "var,v", "variable to extract and add to output file", &variable_name );
    opts.addOpt< int >( "pentagon,p", "switch for dual mesh ", &dual_mesh );
    opts.parseCommandLine( argc, argv );
    std::cout << "input file: " << inputfile << "\n";
    std::cout << "source file: " << sourcefile << "\n";
    std::cout << "variable to copy: " << variable_name << "\n";
    std::cout << "output file: " << outfile << "\n";
    if( inputfile.empty() )
        opts.printHelp();
        return 0;
    ErrorCode rval;
    Core* mb = new Core();
    rval = mb->load_file( inputfile.c_str() );MB_CHK_SET_ERR( rval, "can't load input file" );
    Core* mb2 = new Core();
    rval      = mb2->load_file( sourcefile.c_str() );MB_CHK_SET_ERR( rval, "can't load source file" );
    Tag sourceTag;
    rval = mb2->tag_get_handle( variable_name.c_str(), sourceTag );MB_CHK_SET_ERR( rval, "can't get tag from file" );
    int sizeTag = 0;
    rval        = mb2->tag_get_length( sourceTag, sizeTag );MB_CHK_SET_ERR( rval, "can't get size of tag " );
    DataType type;
    rval = mb2->tag_get_data_type( sourceTag, type );MB_CHK_SET_ERR( rval, "can't get type of tag " );
    int sizeInBytes = 0;
    rval            = mb2->tag_get_bytes( sourceTag, sizeInBytes );MB_CHK_SET_ERR( rval, "can't get size in bytes of tag " );
    Tag newTag;
     *  ErrorCode tag_get_handle( const char* name,
                                      int size,
                                      DataType type,
                                      Tag& tag_handle,
                                      unsigned flags = 0,
                                      const void* default_value = 0 )
    void* defVal;
    int defInt       = -100000;
    double defDouble = -1.e10;
    if( type == MB_TYPE_INTEGER )
        defVal = (void*)( &defInt );
    else if( type == MB_TYPE_DOUBLE )
        defVal = (void*)( &defDouble );
    rval = mb->tag_get_handle( variable_name.c_str(), sizeTag, type, newTag, MB_TAG_DENSE | MB_TAG_CREAT, defVal );MB_CHK_SET_ERR( rval, "can't create new tag " );
    // get vertices on ini mesh; get global id on ini mesh
    // get global id on source mesh
    Tag gid;
    Tag gid2;
    rval = mb->tag_get_handle( "GLOBAL_ID", gid );MB_CHK_SET_ERR( rval, "can't get GLOBAL_ID tag on ini mesh " );
    rval = mb2->tag_get_handle( "GLOBAL_ID", gid2 );MB_CHK_SET_ERR( rval, "can't get GLOBAL_ID tag on source mesh " );
    // get vertices on ini mesh; build
    Range iniVerts;
    rval = mb->get_entities_by_dimension( 0, 0, iniVerts );MB_CHK_SET_ERR( rval, "can't get verts on initial mesh " );
    if( 0 != dual_mesh )
        // verts will be polygons
        rval = mb->get_entities_by_dimension( 0, 2, iniVerts );MB_CHK_SET_ERR( rval, "can't get polygons on initial mesh " );
    std::vector< int > gids;
    gids.resize( iniVerts.size() );
    rval = mb->tag_get_data( gid, iniVerts, &( gids[0] ) );MB_CHK_SET_ERR( rval, "can't get gid on initial verts " );
    // build now the map
    std::map< int, EntityHandle > fromGidToEh;
    int i = 0;
    for( Range::iterator vit = iniVerts.begin(); vit != iniVerts.end(); vit++, i++ )
        fromGidToEh[gids[i]] = *vit;
    // now get the source verts, and tags, and set it on new mesh
    char* valTag = new char[sizeInBytes];
    std::cout << " size of tag in bytes:" << sizeInBytes << "\n";
    Range sourceVerts;
    rval = mb2->get_entities_by_dimension( 0, 0, sourceVerts );MB_CHK_SET_ERR( rval, "can't get verts on source mesh " );
    for( Range::iterator sit = sourceVerts.begin(); sit != sourceVerts.end(); sit++ )
        int globalId              = 0;
        EntityHandle sourceHandle = *sit;
        rval                      = mb2->tag_get_data( gid2, &sourceHandle, 1, &globalId );MB_CHK_SET_ERR( rval, "can't get id on source mesh " );
        // iniVert could be a polygon, actually
        EntityHandle iniVert = fromGidToEh[globalId];
        // find the value of source tag
        rval = mb2->tag_get_data( sourceTag, &sourceHandle, 1, (void*)valTag );MB_CHK_SET_ERR( rval, "can't get value on source tag " );
        rval = mb->tag_set_data( newTag, &iniVert, 1, (void*)valTag );MB_CHK_SET_ERR( rval, "can't set value on initial mesh, new tag " );
    // save file
    rval = mb->write_file( outfile.c_str() );MB_CHK_SET_ERR( rval, "can't write file" );
    delete[] valTag;
    delete mb;
    delete mb2;
    return 0;
