MOAB: Mesh Oriented datABase
(version 5.4.1)
Functions | |
moab::ErrorCode | GenerateTestMatrixAndVectors (int nx, int ny, int nz, moab::HypreParMatrix &A, moab::HypreParVector &sol, moab::HypreParVector &rhs, moab::HypreParVector &exactsol) |
int | main (int argc, char *argv[]) |
moab::ErrorCode GenerateTestMatrixAndVectors | ( | int | nx, |
int | ny, | ||
int | nz, | ||
moab::HypreParMatrix & | A, | ||
moab::HypreParVector & | sol, | ||
moab::HypreParVector & | rhs, | ||
moab::HypreParVector & | exactsol | ||
Definition at line 199 of file hypre_test.cpp.
References moab::debug, MB_SUCCESS, MPI_COMM_WORLD, rank, and size.
Referenced by main().
{ #ifdef DEBUG int debug = 1; #else int debug = 0; #endif #ifdef MOAB_HAVE_MPI int size, rank; // Number of MPI processes, My process ID MPI_Comm_size( MPI_COMM_WORLD, &size ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); #else int size = 1; // Serial case (not using MPI) int rank = 0; #endif // Set this bool to true if you want a 7-pt stencil instead of a 27 pt stencil bool use_7pt_stencil = false; const int NNZPERROW = 27; int local_nrow = nx * ny * nz; // This is the size of our subblock assert( local_nrow > 0 ); // Must have something to work with int local_nnz = NNZPERROW * local_nrow; // Approximately 27 nonzeros per row (except for boundary nodes) int total_nrow = 0; MPI_Allreduce( &local_nrow, &total_nrow, 1, MPI_DOUBLE, MPI_SUM, MPI_COMM_WORLD ); // int total_nrow = local_nrow * size; // Total number of grid points in mesh long long total_nnz = NNZPERROW * (long long)total_nrow; // Approximately 27 nonzeros per row (except for boundary nodes) int start_row = local_nrow * rank; // Each processor gets a section of a chimney stack domain int stop_row = start_row + local_nrow - 1; // Allocate arrays that are of length local_nrow // Eigen::SparseMatrix<double, Eigen::RowMajor> diagMatrix(local_nrow, local_nrow); // diagMatrix.reserve(local_nnz); HYPRE_Int col[2] = { start_row, stop_row }; A.resize( total_nrow, col ); sol.resize( total_nrow, start_row, stop_row ); rhs.resize( total_nrow, start_row, stop_row ); exactsol.resize( total_nrow, start_row, stop_row ); long long nnzglobal = 0; for( int iz = 0; iz < nz; iz++ ) { for( int iy = 0; iy < ny; iy++ ) { for( int ix = 0; ix < nx; ix++ ) { const int curlocalrow = iz * nx * ny + iy * nx + ix; const int currow = start_row + curlocalrow; int nnzrow = 0; std::vector< double > colvals; std::vector< int > indices; for( int sz = -1; sz <= 1; sz++ ) { for( int sy = -1; sy <= 1; sy++ ) { for( int sx = -1; sx <= 1; sx++ ) { const int curlocalcol = sz * nx * ny + sy * nx + sx; const int curcol = currow + curlocalcol; // Since we have a stack of nx by ny by nz domains , stacking in the z // direction, we check to see if sx and sy are reaching outside of the // domain, while the check for the curcol being valid is sufficient to // check the z values if( ( ix + sx >= 0 ) && ( ix + sx < nx ) && ( iy + sy >= 0 ) && ( iy + sy < ny ) && ( curcol >= 0 && curcol < total_nrow ) ) { if( !use_7pt_stencil || ( sz * sz + sy * sy + sx * sx <= 1 ) ) { // This logic will skip over point that are not part of a 7-pt // stencil if( curcol == currow ) { colvals.push_back( 27.0 ); } else { colvals.push_back( -1.0 ); } indices.push_back( curcol ); nnzrow++; } } } // end sx loop } // end sy loop } // end sz loop int ncols = indices.size(); A.SetValues( 1, &ncols, &currow, indices.data(), colvals.data() ); // diagMatrix.set_row_values ( curlocalrow, indices.size(), indices.data(), // colvals.data() ); nnzglobal += nnzrow; sol.SetValue( currow, 0.0 ); rhs.SetValue( currow, 27.0 - ( (double)( nnzrow - 1 ) ) ); exactsol.SetValue( currow, 1.0 ); } // end ix loop } // end iy loop } // end iz loop if( debug ) cout << "Global size of the matrix: " << total_nrow << " and NNZ (estimate) = " << total_nnz << " NNZ (actual) = " << nnzglobal << endl; if( debug ) cout << "Process " << rank << " of " << size << " has " << local_nrow << endl; if( debug ) cout << " rows. Global rows " << start_row << " through " << stop_row << endl; if( debug ) cout << "Process " << rank << " of " << size << " has " << local_nnz << " nonzeros." << endl; A.FinalizeAssembly(); sol.FinalizeAssembly(); rhs.FinalizeAssembly(); exactsol.FinalizeAssembly(); // A.Print("matrix.out"); return moab::MB_SUCCESS; }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 19 of file hypre_test.cpp.
References b, GenerateTestMatrixAndVectors(), ierr, mb, MPI_COMM_WORLD, rank, size, and tolerance.
{ // double norm, d; int ierr = 0; double times[5]; int nx = 5, ny = 5, nz = 5; #ifdef MOAB_HAVE_MPI MPI_Init( &argc, &argv ); int size, rank; // Number of MPI processes, My process ID MPI_Comm_size( MPI_COMM_WORLD, &size ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); #else int size = 1; // Serial case (not using MPI) int rank = 0; #endif MPI_Comm comm = MPI_COMM_WORLD; moab::Core mbCore; moab::Interface& mb = mbCore; // rval = mb.load_file(example.c_str(), &euler_set, opts.c_str()); moab::ParallelComm* pcomm = new moab::ParallelComm( &mb, comm ); moab::HypreParMatrix A( pcomm ); moab::HypreParVector x( pcomm ), b( pcomm ), xexact( pcomm ); #ifdef DEBUG if( rank == 0 ) { int junk = 0; cout << "Press enter to continue" << endl; cin >> junk; } MPI_Barrier( MPI_COMM_WORLD ); #endif if( argc > 4 ) { if( rank == 0 ) cerr << "Usage:" << endl << "\t" << argv[0] << " nx ny nz" << endl << " where nx, ny and nz are the local sub-block dimensions, or" << endl; exit( 1 ); } else { if( rank == 0 ) cout << "Using command:" << "\t" << argv[0] << " nx ny nz" << endl; } times[0] = MPI_Wtime(); // Initialize it (if needed) if( argc == 4 ) { nx = atoi( argv[1] ); ny = atoi( argv[2] ); nz = atoi( argv[3] ); } GenerateTestMatrixAndVectors( nx, ny, nz, A, x, b, xexact ); times[1] = MPI_Wtime() - times[0]; // operator creation time const bool useCG = true; // TODO make into command line option const bool useAMG = false; // TODO make into command line option int niters = 0; double normr = 0; int max_iter = 150; double tolerance = 1e-15; // Set tolerance to zero to make all runs do max_iter iterations times[2] = MPI_Wtime(); // reset moab::HypreSolver *lsSolver, *psSolver; if( useCG ) { lsSolver = new moab::HyprePCG( A ); moab::HyprePCG* cgSolver = dynamic_cast< moab::HyprePCG* >( lsSolver ); cgSolver->SetTol( tolerance ); cgSolver->SetMaxIter( max_iter ); cgSolver->SetLogging( 1 ); cgSolver->Verbosity( 1 ); cgSolver->SetResidualConvergenceOptions( 3, 0.0 ); } else { lsSolver = new moab::HypreGMRES( A ); moab::HypreGMRES* gmresSolver = dynamic_cast< moab::HypreGMRES* >( lsSolver ); gmresSolver->SetTol( tolerance, normr ); gmresSolver->SetMaxIter( max_iter ); gmresSolver->SetLogging( 1 ); gmresSolver->Verbosity( 5 ); gmresSolver->SetKDim( 30 ); } if( useAMG ) { psSolver = new moab::HypreBoomerAMG( A ); dynamic_cast< moab::HypreBoomerAMG* >( psSolver )->SetSystemsOptions( 3 ); } else { psSolver = new moab::HypreParaSails( A ); dynamic_cast< moab::HypreParaSails* >( psSolver )->SetSymmetry( 1 ); } if( psSolver ) lsSolver->SetPreconditioner( *psSolver ); times[2] = MPI_Wtime() - times[2]; // solver setup time /* Now let us solve the linear system */ times[3] = MPI_Wtime(); // reset ierr = lsSolver->Solve( b, x ); if( ierr ) cerr << "Error in call to CG/GMRES HYPRE Solver: " << ierr << ".\n" << endl; times[3] = MPI_Wtime() - times[3]; // solver time lsSolver->GetNumIterations( niters ); lsSolver->GetFinalResidualNorm( normr ); times[4] = MPI_Wtime() - times[0]; // x.Print ( "solution.out" ); #ifdef MOAB_HAVE_MPI double t4 = times[3]; double t4min = 0.0; double t4max = 0.0; double t4avg = 0.0; MPI_Allreduce( &t4, &t4min, 1, MPI_DOUBLE, MPI_MIN, MPI_COMM_WORLD ); MPI_Allreduce( &t4, &t4max, 1, MPI_DOUBLE, MPI_MAX, MPI_COMM_WORLD ); MPI_Allreduce( &t4, &t4avg, 1, MPI_DOUBLE, MPI_SUM, MPI_COMM_WORLD ); t4avg = t4avg / ( (double)size ); #endif if( rank == 0 ) { // Only PE 0 needs to compute and report timing results // double fniters = niters; // double fnrow = A.NNZ(); // double fnnz = A.M(); // double fnops_ddot = fniters * 4 * fnrow; // double fnops_waxpby = fniters * 6 * fnrow; // double fnops_sparsemv = fniters * 2 * fnnz; // double fnops = fnops_ddot + fnops_waxpby + fnops_sparsemv; std::cout << "Testing Laplace problem solver with HYPRE interface\n"; { std::cout << "\tParallelism\n"; #ifdef MOAB_HAVE_MPI std::cout << "Number of MPI ranks: \t" << size << std::endl; #else std::cout << "MPI not enabled\n"; #endif } std::cout << "Dimensions (nx*ny*nz): \t(" << nx << "*" << ny << "*" << nz << ")\n"; std::cout << "Number of iterations: \t" << niters << std::endl; std::cout << "Final residual: \t" << normr << std::endl; std::cout << "************ Performance Summary (times in sec) *************" << std::endl; { std::cout << "\nTime Summary" << std::endl; std::cout << "Total \t" << times[4] << std::endl; std::cout << "Operator Creation \t" << times[1] << std::endl; std::cout << "Solver Setup \t" << times[2] << std::endl; std::cout << "HYPRE Solver \t" << times[3] << std::endl; std::cout << "Avg. Solver \t" << t4avg << std::endl; } } // Compute difference between known exact solution and computed solution // All processors are needed here. // double residual = 0; // if ((ierr = ComputeLinfError(x, xexact, &residual))) // cerr << "Error in call to ComputeLinfError: " << ierr << ".\n" << endl; // if (rank==0) // cout << "Difference between computed and exact = " // << residual << ".\n" << endl; delete lsSolver; // Finish up #ifdef MOAB_HAVE_MPI MPI_Finalize(); #endif return 0; }
