cgma
PartitionCurve.cpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : PartitionCurve-new.cpp
00003 //
00004 // Purpose       :
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Jason Kraftcheck
00009 //
00010 // Creation Date : 04/10/02
00011 //-------------------------------------------------------------------------
00012
00013 #include "PartitionCurve.hpp"
00014 #include "PartitionPoint.hpp"
00015 #include "PartitionCoEdge.hpp"
00016 #include "PartitionSurface.hpp"
00017 #include "VirtualQueryEngine.hpp"
00018 #include "PartSurfFacetTool.hpp"
00019
00020 #include "TDVGFacetOwner.hpp"
00021 #include "CubitFacetEdgeData.hpp"
00022 #include "CubitPointData.hpp"
00023 #include "CubitFacetData.hpp"
00024 #include "CubitTransformMatrix.hpp"
00025 #include "Surface.hpp"
00026
00027 #include "GfxDebug.hpp"
00028 #include "GMem.hpp"
00029
00030 /*
00031 void print_point_list( PartitionPoint* point )
00032 {
00033   PRINT_INFO("  Point %p: (%d curves)\n", point, point ? point->num_curves() : 0 );
00034   if(!point) { PRINT_INFO("\n\n"); return; }
00035
00036   PartitionCurve* curve = 0;
00037   while( curve = point->next_curve(curve) )
00038     PRINT_INFO("%10p",curve);
00039   PRINT_INFO("\n");
00040   curve = 0;
00041
00042   while( curve = point->next_curve(curve) )
00043     PRINT_INFO("%10s",
00044       curve->start_point() == point && curve->end_point() == point ? "(both)" :
00045       curve->start_point() == point ? "(start)" :
00046       curve->end_point() == point ? "(end)" : "(none)" );
00047   PRINT_INFO("\n");
00048 }
00049 */
00050
00051 PartitionCurve::PartitionCurve( )
00052   : firstCoEdge(0),
00053     startPoint(0),
00054     endPoint(0),
00055     startNext(0),
00056     endNext(0)
00057 {
00058 }
00059
00060 PartitionCurve::~PartitionCurve()
00061 {
00062   start_point(0);
00063   end_point(0);
00064
00065   remove_all_coedges();
00066   remove_facet_data();
00067 }
00068
00069 CubitStatus PartitionCurve::add( PartitionCoEdge* coedge )
00070 {
00071   if( coedge->myCurve )
00072     return CUBIT_FAILURE;
00073
00074   coedge->curveNext = firstCoEdge;
00075   firstCoEdge = coedge;
00076   coedge->myCurve = this;
00077   return CUBIT_SUCCESS;
00078 }
00079
00080 CubitStatus PartitionCurve::remove( PartitionCoEdge* coedge )
00081 {
00082   if( coedge->myCurve != this )
00083     return CUBIT_FAILURE;
00084
00085   if( firstCoEdge == coedge )
00086   {
00087     firstCoEdge = coedge->curveNext;
00088   }
00089   else
00090   {
00091     PartitionCoEdge* prev = firstCoEdge;
00092     while( prev && prev->curveNext != coedge )
00093       prev = prev->curveNext;
00094
00095     if( !prev )
00096     {
00097       assert(0);
00098       return CUBIT_FAILURE;
00099     }
00100
00101     prev->curveNext = coedge->curveNext;
00102   }
00103
00104   coedge->curveNext = 0;
00105   coedge->myCurve = 0;
00106   return CUBIT_SUCCESS;
00107 }
00108
00109 int PartitionCurve::num_coedges() const
00110 {
00111   int count = 0;
00112   for( PartitionCoEdge* coe = firstCoEdge; coe; coe = coe->curveNext )
00113     count++;
00114   return count;
00115 }
00116
00117 void PartitionCurve::remove_all_coedges( )
00118 {
00119   while( firstCoEdge && remove(firstCoEdge) ) {;}
00120   assert( !firstCoEdge );
00121 }
00122
00123 CubitStatus PartitionCurve::start_point( PartitionPoint* point )
00124 {
00125   if( point == startPoint )
00126     return CUBIT_SUCCESS;
00127
00128   if( !remove_start_point() )
00129     { assert(0); return CUBIT_FAILURE; }
00130
00131   if( !point )
00132     return CUBIT_SUCCESS;
00133
00134   startPoint = point;
00135   if( point == endPoint )
00136   {
00137     startNext = endNext;
00138     endNext = 0;
00139   }
00140   else
00141   {
00142     startNext = point->firstCurve;
00143     point->firstCurve = this;
00144     point->curveCount++;
00145   }
00146
00147   return CUBIT_SUCCESS;
00148 }
00149
00150 CubitStatus PartitionCurve::end_point( PartitionPoint* point )
00151 {
00152   if( point == endPoint )
00153     return CUBIT_SUCCESS;
00154
00155   if( !remove_end_point() )
00156     { assert(0); return CUBIT_FAILURE; }
00157
00158   if( !point )
00159     return CUBIT_SUCCESS;
00160
00161   endPoint = point;
00162   if( point != startPoint )
00163   {
00164     endNext = point->firstCurve;
00165     point->firstCurve = this;
00166     point->curveCount++;
00167   }
00168
00169   return CUBIT_SUCCESS;
00170 }
00171
00172 CubitStatus PartitionCurve::remove_start_point()
00173 {
00174   if( startPoint == endPoint )
00175     endNext = startNext;
00176   else if( startPoint && !remove_from_point( startPoint, startNext ) )
00177     return CUBIT_FAILURE;
00178
00179   startPoint = 0;
00180   startNext = 0;
00181
00182   return CUBIT_SUCCESS;
00183 }
00184
00185 CubitStatus PartitionCurve::remove_end_point()
00186 {
00187   assert( startPoint != endPoint || !endNext );
00188     // endNext should be null if points are the same
00189
00190   if( endPoint && endPoint != startPoint &&
00191       !remove_from_point( endPoint, endNext ) )
00192     return CUBIT_FAILURE;
00193
00194   endPoint = 0;
00195   endNext = 0;
00196
00197   return CUBIT_SUCCESS;
00198 }
00199
00200 CubitStatus PartitionCurve::remove_from_point( PartitionPoint* point,
00201                                                PartitionCurve* next )
00202 {
00203   point->curveCount--;
00204   if( point->firstCurve == this )
00205   {
00206     point->firstCurve = next;
00207   }
00208   else
00209   {
00210     PartitionCurve* prev = point->firstCurve;
00211     while( prev )
00212     {
00213       PartitionCurve* temp = prev->next_curve(point);
00214       if( temp == this )
00215         break;
00216       prev = temp;
00217     }
00218
00219     if( !prev )
00220     {
00221       assert(0);
00222       return CUBIT_FAILURE;
00223     }
00224
00225     if( prev->startPoint == point )
00226       prev->startNext = next;
00227     else if( prev->endPoint == point )
00228       prev->endNext = next;
00229     else
00230       assert(0);
00231   }
00232
00233   return CUBIT_SUCCESS;
00234 }
00235
00236
00237
00238
00239 bool PartitionCurve::is_nonmanifold( const PartitionSurface* surf ) const
00240 {
00241   int count = 0;
00242   PartitionCoEdge* coedge = 0;
00243   while ( (coedge = next_coedge(coedge)) )
00244     if ( coedge->get_loop() && coedge->get_loop()->get_surface() == surf )
00245       count++;
00246   return count > 1;
00247 }
00248
00249 bool PartitionCurve::is_in_surface( const PartitionSurface* surf,
00250                                     bool manifold_only ) const
00251 {
00252   int count = 0;
00253   PartitionCoEdge* coedge = 0;
00254   while ( (coedge = next_coedge(coedge)) )
00255     if ( coedge->get_loop() && coedge->get_loop()->get_surface() == surf )
00256       count++;
00257
00258   if (manifold_only)
00259     return count == 1;
00260   else
00261     return count > 0;
00262 }
00263
00264
00265 CubitStatus PartitionCurve::move_to_geometry( CubitVector& position )
00266 {
00267   const CubitVector copy(position);
00268   return closest_point( copy, position );
00269 }
00270
00271 void PartitionCurve::get_parents_virt( DLIList<TopologyBridge*>& result )
00272 {
00273   for( PartitionCoEdge* coe = firstCoEdge; coe; coe = coe->curveNext )
00274     result.append( coe );
00275 }
00276
00277 void PartitionCurve::get_children_virt( DLIList<TopologyBridge*>& result )
00278 {
00279   result.append( startPoint );
00280   if( startPoint != endPoint )
00281     result.append( endPoint );
00282 }
00283
00284 GeometryQueryEngine* PartitionCurve::get_geometry_query_engine() const
00285 {
00286   return VirtualQueryEngine::instance();
00287 }
00288
00289 void PartitionCurve::print_debug_info( const char* prefix,
00290                                        bool entset ) const
00291 {
00292   const bool print_children = true;
00293
00294   if( prefix == 0 ) prefix = "";
00295   char* new_prefix = new char[strlen(prefix)+3];
00296   strcpy( new_prefix, prefix );
00297   strcat( new_prefix, "  ");
00298   PRINT_INFO("%sPartitionCurve %p\n", prefix, (void*)this );
00299
00300   if(entset)
00301     sub_entity_set().print_debug_info( new_prefix );
00302   else
00303     print_partitioned_entity();
00304
00305   PartitionCoEdge* coedge = 0;
00306   DLIList<Surface*> surface_list(1);
00307   while( (coedge = next_coedge(coedge)) )
00308   {
00309     surface_list.clean_out();
00310     coedge->surfaces(surface_list);
00311     Surface* surf_ptr = surface_list.size() == 1 ? surface_list.get() : 0;
00312     PRINT_INFO("%s  %s on Surface %p\n", prefix,
00313       coedge->sense() == CUBIT_FORWARD ? "FORWARD" :
00314       coedge->sense() == CUBIT_REVERSED ? "REVERSE" : "UNKNOWN",
00315       (void*)surf_ptr );
00316   }
00317
00318   PRINT_INFO("%s  start point: %p\n", prefix, (void*)start_point() );
00319   if( start_point() && print_children )
00320     start_point()->print_debug_info( new_prefix, false );
00321
00322   if( end_point() && end_point() == start_point() )
00323     PRINT_INFO("%s  end point SAME as start point\n", prefix );
00324   else
00325     PRINT_INFO("%s  end point: %p\n", prefix, (void*)end_point() );
00326   if( end_point() && end_point() != start_point() && print_children )
00327     end_point()->print_debug_info( new_prefix, false );
00328
00329   delete [] new_prefix;
00330 }
00331
00332 void PartitionCurve::append_simple_attribute_virt(const CubitSimpleAttrib& csa)
00333   { sub_entity_set().add_attribute( this, csa ); }
00334 void PartitionCurve::remove_simple_attribute_virt(const CubitSimpleAttrib& csa)
00335   { sub_entity_set().rem_attribute( this, csa ); }
00336 void PartitionCurve::remove_all_simple_attribute_virt()
00337   { sub_entity_set().rem_all_attrib( this ); }
00338 CubitStatus PartitionCurve::get_simple_attribute(DLIList<CubitSimpleAttrib>& list)
00339 {
00340   sub_entity_set().get_attributes( this, list );
00341   return CUBIT_SUCCESS;
00342 }
00343 CubitStatus PartitionCurve::get_simple_attribute(const CubitString& name,
00344                                        DLIList<CubitSimpleAttrib>& list)
00345 {
00346   sub_entity_set().get_attributes( this, name.c_str(), list );
00347   return CUBIT_SUCCESS;
00348 }
00349
00350 void PartitionCurve::reverse_point_order()
00351 {
00352   if( startPoint != endPoint )
00353   {
00354     PartitionPoint* tmp_pt = startPoint;
00355     startPoint = endPoint;
00356     endPoint = tmp_pt;
00357
00358     PartitionCurve* tmp_cv = startNext;
00359     startNext = endNext;
00360     endNext = tmp_cv;
00361   }
00362 }
00363
00364 void PartitionCurve::get_facet_data( DLIList<CubitFacetEdgeData*>& result_list ) const
00365   { result_list = facetEdges; }
00366
00367 void PartitionCurve::set_facet_data( const DLIList<CubitFacetEdgeData*>& new_list )
00368 {
00369   remove_facet_data();
00370   facetEdges = new_list;
00371   for( int i = facetEdges.size(); i--; )
00372     TDVGFacetOwner::set( facetEdges.step_and_get(), this );
00373 }
00374
00375 void PartitionCurve::remove_facet_data( )
00376 {
00377   while( facetEdges.size() )
00378     TDVGFacetOwner::remove( facetEdges.pop() );
00379 }
00380
00381
00382 void PartitionCurve::notify_split( FacetEntity* old_entity, FacetEntity* new_entity )
00383 {
00384   CubitFacetEdgeData* old_ptr = dynamic_cast<CubitFacetEdgeData*>(old_entity);
00385   CubitFacetEdgeData* new_ptr = dynamic_cast<CubitFacetEdgeData*>(new_entity);
00386   assert(TDVGFacetOwner::get(old_entity) == this);
00387   assert(TDVGFacetOwner::get(new_entity) == 0);
00388   assert(old_ptr && new_ptr);
00389
00390   facetEdges.reset();
00391   if (facetEdges.get() == old_ptr)
00392   {
00393     if (new_ptr->contains(start_point()->facet_point()))
00394       facetEdges.insert_first(new_ptr);
00395     else
00396       facetEdges.insert(new_ptr);
00397   }
00398   else if (facetEdges.move_to(old_ptr))
00399   {
00400     CubitFacetEdgeData* prev = facetEdges.prev();
00401     if (prev->shared_point(new_ptr))
00402       facetEdges.back();
00403     facetEdges.insert(new_ptr);
00404   }
00405   else
00406   {
00407     assert( 0 /*old_entity not in list*/);
00408   }
00409
00410   facetEdges.reset();
00411   TDVGFacetOwner::set( new_ptr, this );
00412 }
00413
00414
00415 CubitStatus PartitionCurve::fix_facet_data( PartitionCurve* new_curve )
00416 {
00417   if ( !facetEdges.size() )
00418     return CUBIT_SUCCESS;
00419
00420
00421   DLIList<CubitFacetEdgeData*> my_edges(facetEdges);
00422   assert( end_point() == new_curve->start_point() );
00423   CubitVector pos( end_point()->coordinates() );
00424
00425   double min_edge_len_sqr = CUBIT_DBL_MAX;
00426   double min_edge_dst_sqr = CUBIT_DBL_MAX;
00427   CubitFacetEdgeData* closest_edge = 0;
00428   CubitVector point, vect, edge_pos;
00429   int i;
00430
00431   for ( i = my_edges.size(); i--; ) {
00432     CubitFacetEdgeData* edge = my_edges.step_and_get();
00433     point = edge->point(0)->coordinates();
00434     vect = edge->point(1)->coordinates() - point;
00435
00436     double len_sqr = vect.length_squared();
00437     if ( len_sqr < min_edge_len_sqr )
00438       min_edge_len_sqr = len_sqr;
00439
00440     point -= pos;
00441     double t = (vect % -point) / len_sqr;
00442     if ( t < 0.0 ) t = 0.0;
00443     else if( t > 1.0 ) t = 1.0;
00444     double dst_sqr = (point + t * vect).length_squared();
00445
00446     if ( dst_sqr < min_edge_dst_sqr ) {
00447       min_edge_dst_sqr = dst_sqr;
00448       closest_edge = edge;
00449       edge_pos = edge->point(0)->coordinates() + t * vect;
00450     }
00451   }
00452
00453   my_edges.reset();
00454   DLIList<CubitFacetEdgeData*> new_curve_edges;
00455   my_edges.last();
00456   while( my_edges.get() != closest_edge ) {
00457     new_curve_edges.append( my_edges.pop() );
00458     my_edges.last();
00459   }
00460
00461   min_edge_len_sqr *= 0.2;
00462   double dst_tol_sqr = CUBIT_MAX( min_edge_len_sqr, GEOMETRY_RESABS*GEOMETRY_RESABS );
00463
00464   bool edge_reversed = false;
00465   if ( my_edges.size() > 1 )
00466   {
00467     my_edges.last();
00468     CubitFacetEdgeData* other = my_edges.prev();
00469     edge_reversed = other->contains( closest_edge->point(1) );
00470   }
00471   else if( new_curve_edges.size() > 1 )
00472   {
00473     new_curve_edges.last();
00474     CubitFacetEdgeData* other = new_curve_edges.get();
00475     edge_reversed = other->contains( closest_edge->point(0) );
00476   }
00477   else
00478   {
00479     edge_reversed = (start_point()->facet_point() == closest_edge->point(1));
00480     assert(edge_reversed || start_point()->facet_point() == closest_edge->point(0));
00481   }
00482
00483
00484   CubitPoint* new_point = 0;
00485   double d1 = (pos - closest_edge->point(0)->coordinates()).length_squared();
00486   double d2 = (pos - closest_edge->point(1)->coordinates()).length_squared();
00487   if ( (!TDVGFacetOwner::get(closest_edge->point(0)) && d1 < dst_tol_sqr) ||
00488        (d1 < GEOMETRY_RESABS*GEOMETRY_RESABS) )
00489   {
00490     if ( !edge_reversed )
00491       new_curve_edges.append( my_edges.pop() );
00492     new_point = closest_edge->point(0);
00493   }
00494   else if( (!TDVGFacetOwner::get(closest_edge->point(1)) && d2 < dst_tol_sqr) ||
00495       (d2 < GEOMETRY_RESABS*GEOMETRY_RESABS) )
00496   {
00497     if( edge_reversed )
00498       new_curve_edges.append( my_edges.pop() );
00499     new_point = closest_edge->point(1);
00500   }
00501   else
00502   {
00503     CubitFacetEdge* new_edge;
00504     CubitFacet* new_facet;
00505     TDVGFacetOwner::remove(closest_edge);
00506     PartSurfFacetTool::split_edge(closest_edge, edge_pos, 0, new_point, new_edge, new_facet );
00507     TDVGFacetOwner::set(closest_edge, this);
00508
00509     if ( edge_reversed ) {
00510       new_curve_edges.append( my_edges.pop() );
00511       my_edges.append( dynamic_cast<CubitFacetEdgeData*>(new_edge) );
00512     } else {
00513       new_curve_edges.append( dynamic_cast<CubitFacetEdgeData*>(new_edge) );
00514       //TDVGFacetOwner::remove(new_edge);
00515     }
00516   }
00517
00518   CubitPointData* new_point_d = dynamic_cast<CubitPointData*>(new_point);
00519   new_point_d->set(end_point()->coordinates());
00520   end_point()->facet_point( new_point_d );
00521   set_facet_data(my_edges);
00522   new_curve_edges.reverse();
00523   new_curve->set_facet_data(new_curve_edges);
00524
00525   PartitionCoEdge* coedge = 0;
00526   while ((coedge = next_coedge(coedge)) != NULL )
00527   {
00528     PartitionLoop* loop = coedge->get_loop();
00529     if (!loop) continue;
00530
00531     PartitionSurface* surf = loop->get_surface();
00532     if (!surf->notify_moving_point( new_point, pos ))
00533       return CUBIT_FAILURE;
00534   }
00535
00536   new_point->set(pos);
00537   return CUBIT_SUCCESS;
00538 }
00539
00540 void PartitionCurve::remove_dead_facet( CubitFacetEdgeData* edge )
00541 {
00542   facetEdges.remove(edge);
00543 }
00544
00545 CubitStatus PartitionCurve::get_save_topology( DLIList<int>& end_points )
00546 {
00547   for( int i = 0; i < 2; i++ )
00548   {
00549     PartitionPoint* point = i ? end_point() : start_point();
00550     int set_id, pt_id;
00551     if( &(point->sub_entity_set()) == &sub_entity_set() )
00552       set_id = 0;
00553     else
00554       set_id = point->sub_entity_set().get_unique_id();
00555     pt_id = point->sub_entity_set().get_id(point);
00556     end_points.append(set_id);
00557     end_points.append(pt_id);
00558   }
00559   return CUBIT_SUCCESS;
00560 }
00561
00562
00563
00564 void PartitionCurve::transform(const CubitTransformMatrix& xform)
00565 {
00566   int i;
00567
00568   DLIList<CubitPoint*> points(facetEdges.size());
00569   for ( i = facetEdges.size(); i--; )
00570   {
00571     CubitFacetEdgeData* edge = facetEdges.step_and_get();
00572     edge->point(0)->marked(1);
00573     edge->point(1)->marked(1);
00574   }
00575   for ( i = facetEdges.size(); i--; )
00576   {
00577     CubitFacetEdgeData* edge = facetEdges.step_and_get();
00578     for ( int j = 0; j < 2; j++ )
00579     {
00580       CubitPoint* pt = edge->point(j);
00581       if( pt->marked() )
00582       {
00583         pt->marked(0);
00584
00585         if( TDVGFacetOwner::get(pt) == 0 )
00586           points.append(pt);
00587       }
00588     }
00589   }
00590
00591   for( i = points.size(); i--; )
00592   {
00593     CubitPoint* pt = points.get_and_step();
00594     pt->set( xform * pt->coordinates() );
00595   }
00596 }
00597
00598 void PartitionCurve::replace_facet(CubitFacetEdgeData* dead_facet,
00599                                    DLIList<CubitFacetEdgeData*> &new_facets)
00600 {
00601   assert(new_facets.size() > 1); // doesn't make sense to replace 1 to 1
00602
00603   DLIList<CubitFacetEdgeData*> new_copy = new_facets;
00604
00605   new_facets.reset();
00606   facetEdges.reset();
00607   int dead_index = facetEdges.where_is_item(dead_facet);
00608   assert(-1 != dead_index);
00609
00610   // special case for a single facet on the edge
00611   // -  use curve endpoints to determine order
00612   if (facetEdges.size() == 1)
00613   {
00614     facetEdges.clean_out();
00615
00616     new_copy.last();
00617     if (new_copy.get()->contains(start_point()->facet_point()) )
00618       new_copy.reverse();
00619
00620     new_copy.reset();
00621     assert( new_copy.get()->contains(start_point()->facet_point()) );
00622     new_copy.last();
00623     assert( new_copy.get()->contains(end_point()->facet_point()) );
00624
00625     facetEdges = new_copy;
00626   }
00627   else
00628   {
00629     DLIList<CubitFacetEdgeData*> ordered_edges;
00630     int i;
00631
00632     // copy the edges before the dead edge into a new list
00633     for (i=0; i< dead_index; i++)
00634       ordered_edges.append(facetEdges.next(i));
00635
00636     // if there are edges before the new edges, find out whether the first or last
00637     // new edge is adjacent to the one before the dead edge
00638     CubitFacetEdgeData *prev = NULL;
00639     CubitFacetEdgeData *next = NULL;
00640     CubitPoint *new_start_pt = NULL;
00641     CubitPoint *new_end_pt = NULL;
00642     if (dead_index > 0)
00643     {
00644       prev = facetEdges.next(dead_index-1);
00645       new_start_pt = prev->shared_point(dead_facet);
00646       assert(new_start_pt != NULL);
00647     }
00648
00649     if (dead_index < (facetEdges.size() - 1) )
00650     {
00651       next = facetEdges.next(dead_index+1);
00652       new_end_pt = next->shared_point(dead_facet);
00653       assert(new_end_pt != NULL);
00654     }
00655
00656     if (prev)
00657     {
00658       new_copy.last();
00659       if (new_copy.get()->contains(new_start_pt))
00660         new_copy.reverse();
00661     }
00662     else
00663     {
00664       // use the edge after the dead edge to find out whether to reverse the new
00665       // edges or not
00666       assert(next != NULL);
00667       new_copy.reset();
00668       if (new_copy.get()->contains(new_end_pt))
00669         new_copy.reverse();
00670     }
00671
00672     if (prev)
00673     {
00674       new_copy.reset();
00675       assert( prev->shared_point(new_copy.get()) != NULL);
00676     }
00677     if (next)
00678     {
00679       new_copy.last();
00680       assert( next->shared_point(new_copy.get()) != NULL);
00681     }
00682
00683     // copy the new edges into place in the ordered list
00684     new_copy.reset();
00685     for (i=new_copy.size(); i>0; i--)
00686       ordered_edges.append(new_copy.get_and_step());
00687
00688     // add the rest of the edges to the list
00689     facetEdges.reset();
00690     for (i=dead_index+1; i<facetEdges.size(); i++)
00691       ordered_edges.append(facetEdges.next(i));
00692
00693
00694     facetEdges.clean_out();
00695     facetEdges = ordered_edges;
00696   }
00697
00698   TDVGFacetOwner::remove(dead_facet);
00699   for( int j = 0; j < new_facets.size(); j++ )
00700     TDVGFacetOwner::set(new_facets.step_and_get(),this);
00701
00702   // TODO - memory management - where should the facets get deleted
00703 }
00704
00705 void PartitionCurve::draw_facets( int color)
00706 {
00707   if( !facetEdges.size() )
00708   {
00709     PRINT_ERROR("No facet data.\n");
00710     return ;
00711   }
00712
00713   int i;
00714   GPoint* pts = new GPoint[facetEdges.size() + 1];
00715
00716   facetEdges.reset();
00717   CubitPoint* pt = 0;
00718   if( facetEdges.size() == 1 )
00719   {
00720     pt = facetEdges.get()->point(0);
00721   }
00722   else
00723   {
00724     pt = facetEdges.get()->shared_point(facetEdges.next());
00725     pt = facetEdges.get()->other_point(pt);
00726   }
00727
00728   CubitVector v = pt->coordinates();
00729   pts[0].x = (float)v.x();
00730   pts[0].y = (float)v.y();
00731   pts[0].z = (float)v.z();
00732
00733   for( i = 1; i <= facetEdges.size(); i++ )
00734   {
00735     pt = facetEdges.get_and_step()->other_point(pt);
00736     CubitVector v = pt->coordinates();
00737     pts[i].x = (float)v.x();
00738     pts[i].y = (float)v.y();
00739     pts[i].z = (float)v.z();
00740   }
00741
00742   GfxDebug::draw_polyline( pts, facetEdges.size() + 1, color );
00743   for ( i = 0; i <= facetEdges.size(); i++ )
00744   {
00745     GfxDebug::draw_point( pts[i].x, pts[i].y, pts[i].z, color );
00746   }
00747
00748   facetEdges.reset();
00749   for ( i = 0; i < facetEdges.size(); i++ )
00750   {
00751     CubitFacetEdge* edge = facetEdges.get_and_step();
00752     CubitVector mid = 0.5*(edge->point(0)->coordinates()+edge->point(1)->coordinates());
00753     GfxDebug::draw_label( i, (float)mid.x(), (float)mid.y(), (float)mid.z(), color );
00754   }
00755   GfxDebug::flush();
00756
00757   delete [] pts;
00758 }
00759
00760 void PartitionCurve::do_facet_cleanup()
00761 {
00762   int i;
00763   const double tol = 10.0 * GEOMETRY_RESABS;
00764   const double tol_sqr = tol * tol;
00765
00766   DLIList<CubitFacetEdgeData*> edge_list(facetEdges);
00767   CubitFacetEdgeData* prev_edge = 0;
00768   edge_list.reset();
00769
00770   for ( i = edge_list.size(); i--; )
00771   {
00772     CubitFacetEdgeData* edge = edge_list.get_and_step();
00773     PartitionEntity* start_pt = TDVGFacetOwner::get(edge->point(0));
00774     PartitionEntity* end_pt = TDVGFacetOwner::get(edge->point(1));
00775     if ( start_pt && end_pt )
00776     {
00777       prev_edge = edge;
00778       continue;
00779     }
00780
00781     CubitVector edge_vect(edge->point(1)->coordinates());
00782     edge_vect -= edge->point(0)->coordinates();
00783     if ( edge_vect.length_squared() > tol_sqr )
00784     {
00785       prev_edge = edge;
00786       continue;
00787     }
00788
00789     CubitPoint *keep, *dead;
00790     if ( start_pt )
00791     {
00792       keep = edge->point(0);
00793       dead = edge->point(1);
00794     }
00795     else if ( end_pt )
00796     {
00797       keep = edge->point(1);
00798       dead = edge->point(0);
00799     }
00800     else
00801     {
00802       double prev = (prev_edge->point(0)->coordinates() -
00803         prev_edge->point(1)->coordinates()).length_squared();
00804       double next = (edge_list.get()->point(0)->coordinates() -
00805         edge_list.get()->point(1)->coordinates()).length_squared();
00806       if ( prev < next )
00807       {
00808         dead = prev_edge->shared_point(edge);
00809         keep = edge_list.get()->shared_point(edge);
00810       }
00811       else
00812       {
00813         dead = edge_list.get()->shared_point(edge);
00814         keep = prev_edge->shared_point(edge);
00815       }
00816       assert( dead && keep );
00817     }
00818
00819     if ( PartSurfFacetTool::collapse_edge( keep, dead ) )
00820     {
00821       ;
00822     }
00823     else
00824     {
00825       prev_edge = edge;
00826     }
00827   }
00828 }
00829
00830
00831 CubitStatus PartitionCurve::move_to_geometry( CubitPoint* point )
00832 {
00833   CubitVector new_pos;
00834   if (!closest_point( point->coordinates(), new_pos ))
00835     return CUBIT_FAILURE;
00836
00837   point->set(new_pos);
00838
00839   DLIList<PartitionSurface*> surfaces;
00840   PartitionCoEdge* coedge = 0;
00841   while ((coedge = next_coedge(coedge)) != NULL )
00842   {
00843     PartitionLoop* loop = coedge->get_loop();
00844     if (!loop)
00845       continue;
00846
00847     PartitionSurface* surf = loop->get_surface();
00848     surfaces.append_unique(surf);
00849
00850     coedge = coedge->next();
00851   }
00852
00853   int i;
00854   surfaces.reset();
00855   for ( i = 0; i < surfaces.size(); i++ )
00856     if (!surfaces.get_and_step()->notify_moving_point( point, new_pos ))
00857       break;
00858
00859   if (i < surfaces.size())
00860     return CUBIT_FAILURE;
00861
00862   point->set(new_pos);
00863   return CUBIT_SUCCESS;
00864 }
