cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : Body.cpp 00003 // 00004 // Purpose : This file contains the implementation of the class 00005 // Body. 00006 // 00007 // Special Notes : 00008 // 00009 // Creator : 00010 // 00011 // Creation Date : 00012 // 00013 // Owner : 00014 //------------------------------------------------------------------------- 00015 00016 #include <assert.h> 00017 #include "CubitDefines.h" 00018 #include "CubitMessage.hpp" 00019 #include "CubitBox.hpp" 00020 00021 #include "BodySM.hpp" 00022 #include "Body.hpp" 00023 00024 #include "CoVolume.hpp" 00025 #include "CoEdge.hpp" 00026 00027 #include "RefVolume.hpp" 00028 #include "RefFace.hpp" 00029 #include "RefEdge.hpp" 00030 #include "DLIList.hpp" 00031 #include "RefEntityFactory.hpp" 00032 #include "GeometryQueryTool.hpp" 00033 #include "GeometryQueryEngine.hpp" 00034 #include "CastTo.hpp" 00035 00036 00037 //------------------------------------------------------------------------- 00038 // Purpose : Default constructor. 00039 // 00040 // Special Notes : 00041 // 00042 // Creator : Xuechen Liu 00043 // 00044 // Creation Date : 08/06/96 00045 //------------------------------------------------------------------------- 00046 Body::Body() 00047 { 00048 } 00049 00050 //------------------------------------------------------------------------- 00051 // Purpose : A constructor with a pointer to an TopologyBridge 00052 // as input. 00053 // 00054 // Special Notes : 00055 // 00056 // Creator : Xuechen Liu 00057 // 00058 // Creation Date : 08/06/96 00059 //------------------------------------------------------------------------- 00060 Body::Body(BodySM* OSMEPtr) 00061 { 00062 // Set the new Body's OSME pointer 00063 if (OSMEPtr != NULL) 00064 { 00065 set_topology_bridge(OSMEPtr) ; 00066 } 00067 else 00068 { 00069 PRINT_ERROR("In the Body(OSME*) constructor\n"); 00070 PRINT_ERROR(" Input OSME pointer is NULL\n"); 00071 assert(OSMEPtr != NULL); 00072 } 00073 00074 // Set the Entity ID for this new Body 00075 entityId = RefEntityFactory::instance()->next_body_id(); 00076 00077 // read and initialize attributes 00078 auto_read_cubit_attrib(); 00079 auto_actuate_cubit_attrib(); 00080 00081 // Assign a default entity name 00082 assign_default_name(); 00083 } 00084 00085 //------------------------------------------------------------------------- 00086 // Purpose : The destructor 00087 // 00088 // Special Notes : 00089 // 00090 // Creator : Raikanta Sahu 00091 // 00092 // Creation Date : 10/22/96 00093 //------------------------------------------------------------------------- 00094 Body::~Body() 00095 { 00096 } 00097 00098 00099 //------------------------------------------------------------------------- 00100 // Purpose : Get BodySM ptr 00101 // 00102 // Special Notes : 00103 // 00104 // Creator : Jason Kraftcheck 00105 // 00106 // Creation Date : 07/23/03 00107 //------------------------------------------------------------------------- 00108 BodySM* Body::get_body_sm_ptr() const 00109 { 00110 TopologyBridge* bridge = bridge_manager()->topology_bridge(); 00111 return dynamic_cast<BodySM*>(bridge); 00112 } 00113 00114 //------------------------------------------------------------------------- 00115 // Purpose : Check if this body contains only sheet volumes. 00116 // 00117 // Special Notes : 00118 // 00119 // Creator : Jason Kraftcheck 00120 // 00121 // Creation Date : 01/15/04 00122 //------------------------------------------------------------------------- 00123 CubitBoolean Body::is_sheet_body() 00124 { 00125 DLIList<RefVolume*> volumes; 00126 ref_volumes(volumes); 00127 while (volumes.size()) 00128 if (!volumes.pop()->is_sheet()) 00129 return CUBIT_FALSE; 00130 return CUBIT_TRUE; 00131 } 00132 00133 CubitVector Body::center_point() 00134 { 00135 return bounding_box().center(); 00136 } 00137 00138 CubitPointContainment Body::point_containment( CubitVector &point ) 00139 { 00140 return get_body_sm_ptr()->point_containment( point ); 00141 } 00142 00143 CubitBoolean Body::get_mass_props(CubitVector &cofg) 00144 { 00145 double vol; 00146 CubitStatus result = get_body_sm_ptr()->mass_properties(cofg, vol); 00147 return result ? CUBIT_TRUE : CUBIT_FALSE; 00148 } 00149 00150 //------------------------------------------------------------------------- 00151 // Purpose : Get the bounding box of the object. 00152 // 00153 // Special Notes : This function assumes that a Body's spatial extent is 00154 // defined by the set of RefVolumes it "owns". 00155 // 00156 // Creator : Malcolm J. Panthaki 00157 // 00158 // Creation Date : 10/23/96 00159 //------------------------------------------------------------------------- 00160 CubitBox Body::bounding_box() 00161 { 00162 // Get the list of RefVolumes. Perform the union of the bounding 00163 // boxes of all the RefVolumes to obtain the bounding box of 00164 // the Body. 00165 DLIList<RefVolume*> ref_volume_list ; 00166 /*CubitStatus status = */ 00167 ref_volumes(ref_volume_list); 00168 00169 if ( ref_volume_list.size() == 0 ) 00170 { 00171 CubitVector vec(0.0, 0.0, 0.0); 00172 return CubitBox( vec, vec ); 00173 } 00174 RefVolume* ref_volume_ptr = NULL ; 00175 00176 ref_volume_list.reset() ; 00177 CubitBox result_box = ref_volume_list.get_and_step()->bounding_box(); 00178 for(int i = 1 ; i < ref_volume_list.size() ; i++) 00179 { 00180 ref_volume_ptr = ref_volume_list.get_and_step() ; 00181 result_box |= ref_volume_ptr->bounding_box() ; 00182 } 00183 00184 return result_box ; 00185 } 00186 00187 00188 double Body::measure() 00189 { 00190 DLIList<RefVolume*> volumes; 00191 ref_volumes(volumes); 00192 double volume = 0.0; 00193 for (int i = volumes.size(); i > 0; i--) 00194 { 00195 volume += volumes.get_and_step()->measure(); 00196 } 00197 00198 return volume; 00199 } 00200 00201 CubitString Body::measure_label() 00202 { 00203 return "volume"; 00204 } 00205 00206 int Body::validate() 00207 { 00208 int error = 0; 00209 00210 // Perform general RefEntity checks (measure > 0) 00211 error += RefEntity::validate(); 00212 00213 // check the body from acis 00214 BodySM* osme_ptr = get_body_sm_ptr(); 00215 DLIList <TopologyEntity*> bad_entities; 00216 if ( osme_ptr != NULL ) 00217 { 00218 00219 error += osme_ptr->validate( entity_name(), bad_entities); 00220 } 00221 else 00222 { 00223 PRINT_WARNING("\tWARNING: Null underlying solid modeling body for %s, (%s %d)\n", 00224 entity_name().c_str(), class_name(), id()); 00225 error++; 00226 } 00227 return error; 00228 } 00229 00230 void Body::color(int value) 00231 { 00232 int i; 00233 DLIList<RefVolume*> refVolumeList; 00234 ref_volumes ( refVolumeList ); 00235 00236 refVolumeList.reset(); 00237 for (i = refVolumeList.size(); i--; ) 00238 refVolumeList.get_and_step()->color(value); 00239 } 00240 00241 int Body::color() const 00242 { 00243 return RefEntity::color(); 00244 } 00245 00246
