cgma
00001 00002 #ifdef INLINE_TEMPLATES 00003 #define MY_INLINE inline 00004 #else 00005 #define MY_INLINE 00006 #endif 00007 00008 #include "FacetorUtil.hpp" 00009 #include "TDDelaunay.hpp" 00010 #include "FacetEvalTool.hpp" 00011 #include "CubitPoint.hpp" 00012 #include "CubitPointData.hpp" 00013 #include "CubitFacet.hpp" 00014 #include "CubitFacetData.hpp" 00015 #include "ParamTool.hpp" 00016 #include "CubitMessage.hpp" 00017 00018 #define DETERM(p1,q1,p2,q2,p3,q3)\ 00019 ((q3)*((p2)-(p1)) + (q2)*((p1)-(p3)) + (q1)*((p3)-(p2))) 00020 #define FT_INSIDE_TOL 1.0e-6 00021 #define SQR(x) ((x) * (x)) 00022 #define ALPHA 0.70228615 00023 00024 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00025 CubitStatus 00026 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::locate_point( 00027 CubitVector& the_point, 00028 DLIList<TRI*>& facet_list, 00029 TRI* starting_tri, 00030 SURF* owning_surface, 00031 TRI*& tri_ptr) 00032 { 00033 CubitStatus rv = CUBIT_SUCCESS; 00034 00035 // start with the last one found 00036 00037 if (starting_tri != NULL) 00038 tri_ptr = starting_tri; 00039 00040 // otherwise use the first one on the list 00041 00042 else 00043 { 00044 tri_ptr = facet_list.get(); 00045 } 00046 00047 00048 // loop until we find something 00049 00050 NODE *n0, *n1, *n2; 00051 double aa, bb, cc; 00052 CubitBoolean found = CUBIT_FALSE; 00053 00054 //avoiding infinite loop 00055 int counter = 0; 00056 int max_count = facet_list.size(); 00057 00058 while(!found && rv == CUBIT_SUCCESS) 00059 { 00060 tri_ptr->tri_nodes( n0, n1, n2 ); 00061 aa = DETERM(the_point.x(), the_point.y(), 00062 n1->coordinates().x(), n1->coordinates().y(), 00063 n2->coordinates().x(), n2->coordinates().y()); 00064 bb = DETERM(n0->coordinates().x(), n0->coordinates().y(), 00065 the_point.x(), the_point.y(), 00066 n2->coordinates().x(), n2->coordinates().y()); 00067 cc = DETERM(n0->coordinates().x(), n0->coordinates().y(), 00068 n1->coordinates().x(), n1->coordinates().y(), 00069 the_point.x(), the_point.y()); 00070 if (aa > -FT_INSIDE_TOL && 00071 bb > -FT_INSIDE_TOL && 00072 cc > -FT_INSIDE_TOL) 00073 { 00074 found = CUBIT_TRUE; // this is the one 00075 } 00076 else 00077 { 00078 // set up to check the next logical neighbor 00079 if (aa <= bb && aa <= cc) 00080 { 00081 int edge_index = 1; 00082 tri_ptr = tri_ptr->adjacent( edge_index, owning_surface ); 00083 } 00084 else if (bb <= aa && bb <= cc) 00085 { 00086 int edge_index = 2; 00087 tri_ptr = tri_ptr->adjacent( edge_index, owning_surface ); 00088 } 00089 else 00090 { 00091 int edge_index = 0; 00092 tri_ptr = tri_ptr->adjacent( edge_index, owning_surface ); 00093 } 00094 // check to see if we've left the triangulation 00095 // also make sure that we are not stuck in a cycle 00096 if (tri_ptr == NULL || counter > max_count) 00097 { 00098 if(counter>max_count){ 00099 PRINT_WARNING("Encountered problem locating a triangle; going to exhaustive search.\n"); 00100 } 00101 00102 rv = exhaustive_locate_point( the_point, facet_list, tri_ptr ); 00103 found = CUBIT_TRUE; 00104 } 00105 } 00106 ++counter; 00107 } 00108 00109 return rv; 00110 } 00111 00112 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00113 CubitStatus 00114 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::exhaustive_locate_point( 00115 CubitVector& the_point, 00116 DLIList<TRI*>& facet_list, 00117 TRI*& tri_ptr) 00118 { 00119 CubitStatus rv = CUBIT_SUCCESS; 00120 00121 // loop until we find something 00122 00123 int ii; 00124 NODE *n0, *n1, *n2; 00125 double aa, bb, cc; 00126 CubitBoolean found = CUBIT_FALSE; 00127 for (ii=0; ii<facet_list.size() && !found; ii++) 00128 { 00129 tri_ptr = facet_list.get_and_step(); 00130 tri_ptr->tri_nodes( n0, n1, n2 ); 00131 aa = DETERM(the_point.x(), the_point.y(), 00132 n1->coordinates().x(), n1->coordinates().y(), 00133 n2->coordinates().x(), n2->coordinates().y()); 00134 bb = DETERM(n0->coordinates().x(), n0->coordinates().y(), 00135 the_point.x(), the_point.y(), 00136 n2->coordinates().x(), n2->coordinates().y()); 00137 cc = DETERM(n0->coordinates().x(), n0->coordinates().y(), 00138 n1->coordinates().x(), n1->coordinates().y(), 00139 the_point.x(), the_point.y()); 00140 if (aa > -FT_INSIDE_TOL && 00141 bb > -FT_INSIDE_TOL && 00142 cc > -FT_INSIDE_TOL) 00143 { 00144 found = CUBIT_TRUE; // this is the one 00145 } 00146 } 00147 if (!found) 00148 { 00149 rv = CUBIT_FAILURE; 00150 tri_ptr = NULL; 00151 } 00152 00153 return rv; 00154 } 00155 00156 //------------------------------------------------------------------------- 00157 // Function: are_nodes_colinear 00158 // Description: determine if the TRI is valid 00159 // Author: mbrewer 00160 // Date: 6/3/2002 00161 //------------------------------------------------------------------------- 00162 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00163 CubitBoolean 00164 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::are_nodes_colinear(TRI* tri_ptr) 00165 { 00166 NODE *nodes[3]; 00167 tri_ptr->tri_nodes( nodes[0], nodes[1], nodes[2] ); 00168 double det = DETERM( nodes[0]->coordinates().x(), 00169 nodes[0]->coordinates().y(), 00170 nodes[1]->coordinates().x(), 00171 nodes[1]->coordinates().y(), 00172 nodes[2]->coordinates().x(), 00173 nodes[2]->coordinates().y()); 00174 //PRINT_INFO("Det = %f\n",det); 00175 00176 if(fabs(det) > CUBIT_DBL_MIN){ 00177 return CUBIT_TRUE; 00178 } 00179 return CUBIT_FALSE; 00180 } 00181 00182 //------------------------------------------------------------------------- 00183 // Function: circumcenter 00184 // Description: get the circumcenter of the triangle 00185 // Author: chynes 00186 // Date: 6/6/2002 00187 //------------------------------------------------------------------------- 00188 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00189 CubitVector& 00190 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::circumcenter(TRI* tri_ptr) 00191 { 00192 ToolData *td = tri_ptr->get_TD( TDDelaunay<TRI,NODE>::is_delaunay ); 00193 TDDelaunay< TRI, NODE > *td_del = dynamic_cast<TDDelaunay< TRI, NODE >*> (td); 00194 if(td_del == NULL) { 00195 td_del = new TDDelaunay<TRI, NODE>(); 00196 tri_ptr->add_TD( td_del ); 00197 } 00198 return td_del->circumcenter2d( tri_ptr ); 00199 } 00200 00201 //------------------------------------------------------------------------- 00202 // Function: tri_visited 00203 // Description: set the tri_visited flag 00204 // Author: chynes 00205 // Date: 6/6/2002 00206 //------------------------------------------------------------------------- 00207 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00208 CubitBoolean 00209 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::tri_visited( 00210 TRI *tri_ptr, 00211 int curr_visit_flag) 00212 { 00213 ToolData *td = tri_ptr->get_TD( TDDelaunay< TRI, NODE >::is_delaunay ); 00214 TDDelaunay< TRI, NODE > *td_del = dynamic_cast<TDDelaunay< TRI, NODE >*> (td); 00215 if (td_del == NULL) 00216 { 00217 td_del = new TDDelaunay< TRI, NODE >(); 00218 tri_ptr->add_TD( td_del ); 00219 } 00220 return (td_del->visit_flag() == curr_visit_flag); 00221 } 00222 00223 //------------------------------------------------------------------------- 00224 // Function: tri_visited 00225 // Description: set the tri_visited flag 00226 // Author: chynes 00227 // Date: 6/3/2002 00228 //------------------------------------------------------------------------- 00229 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00230 void 00231 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::tri_visited( 00232 TRI *facet_ptr, 00233 CubitBoolean visited, 00234 int curr_visit_flag) 00235 { 00236 ToolData *td = facet_ptr->get_TD( TDDelaunay< TRI, NODE >::is_delaunay ); 00237 TDDelaunay< TRI, NODE > *td_del = dynamic_cast<TDDelaunay< TRI, NODE >*> (td); 00238 if (td_del == NULL) 00239 { 00240 td_del = new TDDelaunay< TRI, NODE >(); 00241 facet_ptr->add_TD( td_del ); 00242 } 00243 if (visited) 00244 td_del->visit_flag(curr_visit_flag); 00245 else 00246 td_del->visit_flag(INT_MIN); 00247 } 00248 00249 //------------------------------------------------------------------------- 00250 // Function: radius 00251 // Description: get the radius squared of the triangle circumcircle 00252 // Author: chynes 00253 // Date: 6/6/2002 00254 //------------------------------------------------------------------------- 00255 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00256 double 00257 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::radius(TRI* tri_ptr) 00258 { 00259 ToolData *td = tri_ptr->get_TD( TDDelaunay< TRI, NODE >::is_delaunay ); 00260 TDDelaunay< TRI, NODE > *td_del = dynamic_cast<TDDelaunay< TRI, NODE >*> (td); 00261 if (td_del == NULL) 00262 { 00263 td_del = new TDDelaunay< TRI, NODE >(); 00264 tri_ptr->add_TD( td_del ); 00265 } 00266 return td_del->radius2d( tri_ptr ); 00267 } 00268 00269 //------------------------------------------------------------------------- 00270 // Function: point_in_circumcircle 00271 // Description: determine if the point is inside the circumcircle of the 00272 // triangle and recurse to the adjacent triangles 00273 // Author: chynes 00274 // Date: 6/3/2002 00275 //------------------------------------------------------------------------- 00276 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00277 CubitStatus 00278 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::point_in_circumcircle( 00279 CubitVector& the_point, 00280 TRI* tri_ptr, 00281 DLIList<TRI*>& tri_list, 00282 SURF* surface_ptr, 00283 int curr_visit_flag) 00284 { 00285 CubitStatus rv = CUBIT_SUCCESS; 00286 00287 // check this triangle. If the nodes are colinear do not try to calculate 00288 //the circumcenter. 00289 if(!are_nodes_colinear(tri_ptr)) 00290 { 00291 PRINT_ERROR("Can't evaluate center of circumcircle\n"); 00292 return CUBIT_FAILURE; 00293 } 00294 00295 CubitVector cc = circumcenter( tri_ptr ); 00296 tri_visited( tri_ptr, CUBIT_TRUE, curr_visit_flag ); 00297 double dist2 = SQR(the_point.x() - cc.x()) + SQR(the_point.y() - cc.y()); 00298 double r2 = radius( tri_ptr ); 00299 double tol_factor = CUBIT_MAX(CUBIT_MAX(tri_ptr->edge(0)->length(), 00300 tri_ptr->edge(1)->length()), 00301 tri_ptr->edge(2)->length()); 00302 //PRINT_INFO("Tolerance factor = %f\n", tol_factor); 00303 00304 00305 00306 if (r2-dist2 > -(tol_factor*FT_INSIDE_TOL*FT_INSIDE_TOL))// inside or on circle 00307 { 00308 tri_list.append( tri_ptr ); 00309 00310 // go to its neighbors 00311 00312 int iedge; 00313 TRI *adjtri_ptr; 00314 for (iedge=0; iedge<3 && rv == CUBIT_SUCCESS; iedge++){ 00315 00316 int ii = iedge; 00317 adjtri_ptr = tri_ptr->adjacent( ii, surface_ptr ); 00318 if (adjtri_ptr != NULL && !tri_visited( adjtri_ptr, curr_visit_flag )) 00319 { 00320 rv = point_in_circumcircle( the_point, adjtri_ptr, tri_list, 00321 surface_ptr, curr_visit_flag ); 00322 } 00323 } 00324 } 00325 return rv; 00326 } 00327 00328 //------------------------------------------------------------------------- 00329 // Function: natural_neighbor_tris 00330 // Description: get a list of all triangles whose circumcircle contain 00331 // the point 00332 // Author: chynes 00333 // Date: 6/3/2002 00334 //------------------------------------------------------------------------- 00335 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00336 CubitStatus 00337 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::natural_neighbor_tris( 00338 CubitVector& the_point, 00339 DLIList<TRI*>& facet_list, 00340 TRI*& start_tri, 00341 SURF* surface_ptr, 00342 int& curr_visit_flag, 00343 DLIList<TRI*>& tri_list) 00344 { 00345 CubitStatus rv = CUBIT_SUCCESS; 00346 00347 // find the triangle the point is contained in 00348 00349 //CubitVector areacoord; 00350 TRI *tri_ptr; 00351 rv = locate_point( the_point, facet_list, start_tri, surface_ptr, tri_ptr ); 00352 start_tri = tri_ptr; 00353 00354 // keep track of visitation to triangles by incrementing curr_visit_flag 00355 // and comparing with the visit flag stored with the triangle 00356 00357 curr_visit_flag++; 00358 00359 // Recursively search, (starting with the tri the point is in) 00360 // search for all tris whose circumcircle contain the point and place 00361 // in the tri_list 00362 00363 if (rv == CUBIT_SUCCESS) 00364 { 00365 tri_list.append( tri_ptr ); 00366 tri_visited( tri_ptr, CUBIT_TRUE, curr_visit_flag ); 00367 int iedge; 00368 TRI *adjtri_ptr; 00369 for (iedge=0; iedge<3 && rv == CUBIT_SUCCESS; iedge++) 00370 { 00371 int ii = iedge; 00372 adjtri_ptr = tri_ptr->adjacent( ii, surface_ptr ); 00373 if (adjtri_ptr != NULL && !tri_visited( adjtri_ptr, curr_visit_flag )){ 00374 rv = point_in_circumcircle( the_point, adjtri_ptr, 00375 tri_list, surface_ptr, 00376 curr_visit_flag); 00377 } 00378 } 00379 } 00380 return rv; 00381 } 00382 00383 /************************************************************/ 00384 //author: mbrewer 00385 //This function performs tests on the void created by a point's 00386 //insertion to make sure that invalid connectivities are not 00387 //being created. 00388 /************************************************************/ 00389 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00390 CubitStatus 00391 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::valid_void( 00392 NODE * /*point_ptr*/, 00393 DLIList<TRI *> &tri_list, 00394 SURF* surface_ptr, 00395 int curr_visit_flag) 00396 { 00397 int temp_i, temp_j; 00398 DLIList<EDGE*> boundary_edge_list; 00399 DLIList<NODE*> boundary_node_list; 00400 TRI *adjtri_ptr; 00401 TRI *tri_ptr; 00402 EDGE *edge_ptr; 00403 DLIList<EDGE *> edge_list; 00404 //loop over the tri's in tri_list and find all of the curves 00405 //on the boundary of the set (ie, on the boundary of the void). 00406 for (temp_i=0; temp_i<tri_list.size(); temp_i++) 00407 { 00408 tri_ptr = tri_list.get_and_step(); 00409 //check each edge to see whether it is a boundary edge or not 00410 for (temp_j=0; temp_j<3; temp_j++){ 00411 00412 int kk = temp_j; 00413 // - if TRI == CubitFacet 00414 // - kk will be corrected in adjacent() to 00415 // - give the correct EDGE index 00416 adjtri_ptr = tri_ptr->adjacent( kk, surface_ptr ); 00417 if (!adjtri_ptr || !tri_visited( adjtri_ptr, curr_visit_flag )) 00418 { 00419 edge_ptr = tri_ptr->edge(kk); 00420 boundary_edge_list.append(edge_ptr); 00421 } 00422 } 00423 } 00424 int list_size = boundary_edge_list.size(); 00425 //uniquify the boundary edge list 00426 boundary_edge_list.uniquify_ordered(); 00427 //the list shouldn't have changed size during the uniquify. 00428 //if it did, there is a problem. 00429 if(list_size != boundary_edge_list.size()){ 00430 PRINT_WARNING("Unexpected result. Edge was duplicated on boundary.\n"); 00431 return CUBIT_FAILURE; 00432 } 00433 //loop over the boundary edges and get the nodes in the boundary loop 00434 for(temp_i=0; temp_i<list_size; ++temp_i){ 00435 edge_ptr=boundary_edge_list.get_and_step(); 00436 boundary_node_list.append(edge_ptr->end_node()); 00437 boundary_node_list.append(edge_ptr->start_node()); 00438 } 00439 list_size = boundary_node_list.size(); 00440 //each node should be in exactly two edges. First make sure that there 00441 //are the correct number of nodes. 00442 if(list_size%2){ 00443 PRINT_WARNING("Unexpected result. Node not listed twice.\n"); 00444 return CUBIT_FAILURE; 00445 } 00446 //now uniquify to make sure that the nodes were listed the correct number 00447 //of times. 00448 boundary_node_list.uniquify_ordered(); 00449 if( (list_size/2) != boundary_node_list.size()){ 00450 PRINT_WARNING("Unexpected result. Node was listed an incorrect number of times.\n"); 00451 return CUBIT_FAILURE; 00452 } 00453 return CUBIT_SUCCESS; 00454 00455 } 00456 00457 //------------------------------------------------------------------------- 00458 // Function: bowyer_watson_insert 00459 // Description: Bowyer-Watson insertion into an existing Delaunay Mesh 00460 // Author: chynes 00461 // Date: 6/3/2002 00462 //------------------------------------------------------------------------- 00463 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00464 CubitStatus 00465 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::bowyer_watson_insert( 00466 NODE* point_ptr, 00467 DLIList<TRI*>& tri_list, 00468 DLIList<TRI*>& facet_list, 00469 int& curr_visit_flag, 00470 SURF* surface_ptr, 00471 TRI*& last_tri) 00472 { 00473 CubitStatus rv = CUBIT_SUCCESS; 00474 00475 // mark the tris in the list so we can distinguish them from their 00476 // neighbors 00477 00478 curr_visit_flag++; 00479 int ii, jj; 00480 TRI *tri_ptr; 00481 for (ii=0; ii<tri_list.size(); ii++) 00482 { 00483 tri_ptr = tri_list.get_and_step(); 00484 tri_visited( tri_ptr, CUBIT_TRUE, curr_visit_flag ); 00485 } 00486 //MBREWER: This is not an optimal test. But, we need need to 00487 //do some tests to try to ensure that the void is valid for what 00488 //we need. This is attempting to avoid crashes by not allowing nodes 00489 //to be inserted when the mesh starts diverging from the Delaunay 00490 //criteria. 00491 rv = valid_void( point_ptr, tri_list, surface_ptr, curr_visit_flag ); 00492 if(!rv) 00493 return rv; 00494 00495 // find all edges at the boundary of the visited triangles and create 00496 // new triangles with them 00497 00498 // create a new triangle with this edge and the node 00499 TRI *adjtri_ptr; 00500 TRI *new_tri = NULL; 00501 EDGE *edge_ptr; 00502 DLIList<EDGE *> edge_list; 00503 for (ii=0; ii<tri_list.size(); ii++) 00504 { 00505 tri_ptr = tri_list.get_and_step(); 00506 for (jj=0; jj<3; jj++){ 00507 00508 int kk = jj; 00509 // - if TRI == CubitFacet 00510 // - kk will be corrected in adjacent() to 00511 // - give the correct EDGE index 00512 adjtri_ptr = tri_ptr->adjacent( kk, surface_ptr ); 00513 if (!adjtri_ptr || !tri_visited( adjtri_ptr, curr_visit_flag )) 00514 { 00515 edge_ptr = tri_ptr->edge(kk); 00516 assert(edge_list.append_unique( edge_ptr )); 00517 if(tri_ptr->sense(kk) == CUBIT_FORWARD) 00518 new_tri = (TRI *) new TRICHILD( edge_ptr->start_node(), edge_ptr->end_node(), point_ptr, surface_ptr); 00519 else 00520 new_tri = (TRI *) new TRICHILD( edge_ptr->end_node(), edge_ptr->start_node(), point_ptr, surface_ptr); 00521 facet_list.append(new_tri); 00522 } 00523 } 00524 } 00525 last_tri = new_tri; 00526 00527 // delete the triangles in the original triangle list 00528 00529 EDGE *del_edge_ptr; 00530 DLIList<EDGE *> del_edge_list; 00531 for (ii=0; ii<tri_list.size(); ii++) 00532 { 00533 tri_ptr = tri_list.get_and_step(); 00534 del_edge_list.clean_out(); 00535 facet_list.move_to(tri_ptr); 00536 facet_list.extract(); 00537 tri_ptr->edges( del_edge_list ); 00538 delete tri_ptr; 00539 00540 // delete the unused edges 00541 for (jj=0; jj<del_edge_list.size(); jj++) 00542 { 00543 del_edge_ptr = del_edge_list.get_and_step(); 00544 if (del_edge_ptr->number_tris() == 0 && del_edge_ptr->number_faces() == 0 ) 00545 delete del_edge_ptr; 00546 } 00547 } 00548 00549 return rv; 00550 } 00551 00552 //------------------------------------------------------------------------- 00553 // Function: insert_node 00554 // Description: insert one node into Delaunay mesh 00555 // Author: chynes 00556 // Date: 6/3/2002 00557 //------------------------------------------------------------------------- 00558 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00559 CubitStatus 00560 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::insert_node( 00561 NODE *node_ptr, 00562 DLIList<TRI*>& facet_list, 00563 SURF* surface_ptr, 00564 int& curr_visit_flag, 00565 TRI*& last_tri) 00566 { 00567 CubitStatus rv = CUBIT_SUCCESS; 00568 00569 // get a list of all triangles whose circumcircle contain the point 00570 00571 DLIList<TRI *> tri_list; 00572 CubitVector the_point = node_ptr->coordinates(); 00573 rv = natural_neighbor_tris( the_point, facet_list, 00574 last_tri, surface_ptr, 00575 curr_visit_flag, tri_list ); 00576 00577 00578 // Use a Bowyer-Watson insertion 00579 00580 if (rv == CUBIT_SUCCESS) 00581 { 00582 rv = bowyer_watson_insert( node_ptr, tri_list, 00583 facet_list, curr_visit_flag, 00584 surface_ptr, last_tri); 00585 } 00586 00587 return rv; 00588 } 00589 00590 //------------------------------------------------------------------------- 00591 // Function: get_size 00592 // Description: get the distortion factor for point inside tri, if one exists 00593 // otherwise return 1; 00594 // Author: chynes 00595 // Date: 7/24/02 00596 //------------------------------------------------------------------------- 00597 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00598 double 00599 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::get_size(CubitVector &cc, TRI *tri_ptr) 00600 { 00601 //extract data 00602 NODE *n0,*n1,*n2; 00603 CubitVector area_coord; 00604 tri_ptr->tri_nodes(n0,n1,n2); 00605 00606 if (n0->coordinates().z() - 1.0 < fabs(FT_INSIDE_TOL) 00607 && n1->coordinates().z() - 1.0 < fabs(FT_INSIDE_TOL) 00608 && n2->coordinates().z() - 1.0 < fabs(FT_INSIDE_TOL) ) 00609 return 1.0; 00610 else 00611 { 00612 //get vectors 00613 CubitVector v0 = n0->coordinates(); 00614 CubitVector v1 = n1->coordinates(); 00615 CubitVector v2 = n2->coordinates(); 00616 00617 //set z direction 00618 v0.z(cc.z()); 00619 v1.z(cc.z()); 00620 v2.z(cc.z()); 00621 00622 //create points 00623 CubitPoint *p0 = (CubitPoint*) new CubitPointData(v0); 00624 CubitPoint *p1 = (CubitPoint*) new CubitPointData(v1); 00625 CubitPoint *p2 = (CubitPoint*) new CubitPointData(v2); 00626 00627 //create facet 00628 CubitFacet *temp_facet = (CubitFacet*) new CubitFacetData(p0,p1,p2); 00629 00630 FacetEvalTool::facet_area_coordinate(temp_facet, cc, area_coord); 00631 00632 delete p0; 00633 delete p1; 00634 delete p2; 00635 delete temp_facet; 00636 00637 return (area_coord.x()*n0->coordinates().z()) 00638 + (area_coord.y()*n1->coordinates().z()) 00639 + (area_coord.z()*n2->coordinates().z()); 00640 } 00641 } 00642 00643 //------------------------------------------------------------------------- 00644 // Function: tri_sort_list 00645 // Description: set the tri sort list index 00646 // Author: chynes 00647 // Date: 6/3/2002 00648 //------------------------------------------------------------------------- 00649 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00650 void 00651 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::tri_sort_list( 00652 TRI *facet_ptr, 00653 int sort_list_index ) 00654 { 00655 ToolData *td = facet_ptr->get_TD( TDDelaunay< TRI, NODE >::is_delaunay ); 00656 TDDelaunay< TRI, NODE > *td_del = dynamic_cast<TDDelaunay< TRI, NODE >*> (td); 00657 if (td_del == NULL) 00658 { 00659 td_del = new TDDelaunay<TRI, NODE>(); 00660 facet_ptr->add_TD( td_del ); 00661 } 00662 td_del->tri_sort_list(sort_list_index); 00663 } 00664 00665 00666 //------------------------------------------------------------------------- 00667 // Function: tri_sort_list 00668 // Description: get the tri sort list index 00669 // Author: chynes 00670 // Date: 6/3/2002 00671 //------------------------------------------------------------------------- 00672 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00673 int 00674 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::tri_sort_list( TRI *facet_ptr ) 00675 { 00676 ToolData *td = facet_ptr->get_TD( TDDelaunay< TRI, NODE >::is_delaunay ); 00677 TDDelaunay< TRI, NODE > *td_del = dynamic_cast<TDDelaunay< TRI, NODE >*> (td); 00678 if (td_del == NULL) 00679 { 00680 td_del = new TDDelaunay<TRI, NODE>(); 00681 facet_ptr->add_TD( td_del ); 00682 } 00683 return td_del->tri_sort_list(); 00684 } 00685 00686 //------------------------------------------------------------------------- 00687 // Function: classify_tri_by_angle 00688 // Description: compute the angles at the triangle vertices and classify 00689 // by its worst triangle 00690 // Author: chynes 00691 // Date: 6/3/2002 00692 //------------------------------------------------------------------------- 00693 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00694 CubitStatus 00695 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::classify_tri_by_angle( 00696 TRI* tri_ptr, 00697 DLIList<TRI*>* sorted_lists, 00698 const int num_lists, 00699 const double interval, 00700 const double quality_angle) 00701 { 00702 //CubitStatus rv = CUBIT_SUCCESS; 00703 00704 // Determine the minimum angle 00705 00706 NODE *nodes[3]; 00707 tri_ptr->tri_nodes( nodes[0], nodes[1], nodes[2] ); 00708 double x0 = nodes[0]->coordinates().x(); 00709 double y0 = nodes[0]->coordinates().y(); 00710 double x1 = nodes[1]->coordinates().x(); 00711 double y1 = nodes[1]->coordinates().y(); 00712 double x2 = nodes[2]->coordinates().x(); 00713 double y2 = nodes[2]->coordinates().y(); 00714 00715 double ax = x1 - x0; 00716 double ay = y1 - y0; 00717 double bx = x2 - x0; 00718 double by = y2 - y0; 00719 double dot = ax*bx + ay*by; 00720 double a_mag = sqrt( ax*ax + ay*ay ); 00721 double b_mag = sqrt( bx*bx + by*by ); 00722 double angle0 = dot / ( a_mag * b_mag ); 00723 angle0 = acos( angle0 ); 00724 00725 ax = -ax; 00726 ay = -ay; 00727 bx = x2 - x1; 00728 by = y2 - y1; 00729 dot = ax*bx + ay*by; 00730 b_mag = sqrt( bx*bx + by*by ); 00731 double angle1 = dot / ( a_mag * b_mag ); 00732 angle1 = acos( angle1 ); 00733 00734 double angle2 = CUBIT_PI - angle0 - angle1; 00735 00736 double min_angle = CUBIT_MIN( CUBIT_MIN(angle0,angle1), 00737 CUBIT_MIN(angle1,angle2) ); 00738 if (min_angle < 0.0) { 00739 assert(0); 00740 return CUBIT_FAILURE; 00741 } 00742 00743 // If it is greater than the QUALITY_ANGLE then place it in 00744 // the triSortArray[0], otherwise place it in one of the other deques 00745 // depending upon its minimum angle 00746 00747 // Determine which list 00748 00749 int index; 00750 if (min_angle >= quality_angle) { 00751 index = 0; 00752 } 00753 else { 00754 index = 1 + (int)(min_angle/interval); 00755 if (index < 1) index = 1; 00756 if (index > num_lists-1) index = num_lists-1; 00757 } 00758 00759 // Place it on a list 00760 00761 sorted_lists[index].append( tri_ptr ); 00762 tri_sort_list( tri_ptr, index ); 00763 00764 return CUBIT_SUCCESS; 00765 } 00766 00767 //------------------------------------------------------------------------- 00768 // Function: insert_at_circumcenter 00769 // Description: insert a node at the circumcenter of a tri 00770 // Author: chynes 00771 // Date: 6/3/2002 00772 //------------------------------------------------------------------------- 00773 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> MY_INLINE 00774 CubitStatus 00775 FacetorUtil<SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC>::insert_at_circumcenter( 00776 TRI* tri_ptr, 00777 DLIList<TRI*>& facet_list, 00778 TRI*& start_tri, 00779 int& curr_visit_flag, 00780 SURF* surface_ptr, 00781 DLIList<TRI*>* sorted_lists, 00782 const int num_lists, 00783 const double interval, 00784 const double quality_angle, 00785 SIZEFUNC* sizing_function, 00786 ParamTool* p_tool) 00787 { 00788 CubitStatus rv = CUBIT_SUCCESS; 00789 00790 // find the cicumcenter of the triangle and the target size there 00791 //if nodes are colinear do not try to find circumenter 00792 if(!are_nodes_colinear(tri_ptr)) 00793 { 00794 PRINT_ERROR("Can't evaluate center of circumcircle\n"); 00795 return CUBIT_FAILURE; 00796 } 00797 CubitVector cc = circumcenter( tri_ptr ); 00798 00799 //translate cc into 3D space 00800 CubitVector cc_xyz; 00801 p_tool->transform_to_xyz(cc_xyz, cc); 00802 // get target length in 3D space 00803 double target_length = sizing_function->size_at_point( cc_xyz ); 00804 // get new size 00805 double size = get_size(cc, tri_ptr); 00806 // update size 00807 cc.z(size); 00808 // update target_length 00809 target_length = target_length*size; 00810 00811 // Determine if we should now insert the point. Allow insertions 00812 // in the general case down to circumcircle size of ALPHA times the 00813 // interpolated target edge length size. For tris with small 00814 // angles, allow additional inserts to improve the quality down 00815 // to 1/2 the target size 00816 if(!are_nodes_colinear(tri_ptr)) 00817 { 00818 PRINT_ERROR("Can't evaluate radius of circumcircle\n"); 00819 return CUBIT_FAILURE; 00820 } 00821 00822 00823 double r2 = radius( tri_ptr ); 00824 CubitBoolean insert = CUBIT_FALSE; 00825 int tsindex = tri_sort_list( tri_ptr ); 00826 assert(tsindex > -1); 00827 if (tsindex == 0) 00828 { 00829 if (r2 > SQR(ALPHA*target_length)) 00830 { 00831 insert = CUBIT_TRUE; 00832 } 00833 } 00834 else 00835 { 00836 if (r2 > SQR(0.5*ALPHA*target_length)) 00837 { 00838 insert = CUBIT_TRUE; 00839 } 00840 } 00841 if (insert) 00842 { 00843 00844 // Determine the tris that will be affected by the insertion 00845 00846 start_tri = tri_ptr; 00847 DLIList <TRI *> tri_list; 00848 rv = natural_neighbor_tris( cc, facet_list, 00849 start_tri, surface_ptr, 00850 curr_visit_flag, tri_list ); 00851 // If it was outside, then we are done with it 00852 00853 if (tri_list.size() == 0) 00854 { 00855 return CUBIT_SUCCESS; 00856 } 00857 if (rv != CUBIT_SUCCESS) { 00858 return rv; 00859 } 00860 00861 // See if we are too close to a boundary 00862 00863 double x0, y0, x1, y1, cx, cy, edge_radius, dist; 00864 TRI *nntri_ptr; 00865 EDGE *edge_ptr; 00866 int ii, iedge; 00867 for (ii=0; ii<tri_list.size(); ii++) 00868 { 00869 nntri_ptr = tri_list.get_and_step(); 00870 for (iedge=0; iedge<3; iedge++) 00871 { 00872 edge_ptr = tri_ptr->edge( iedge ); 00873 00874 // An edge encroaches if the distance from the prospective 00875 // new point to the midpoint of the edge is less than 00876 // half the length of the edge 00877 00878 if (edge_ptr->marked()) // on the boundary? 00879 { 00880 x0 = (edge_ptr->start_node())->coordinates().x(); 00881 y0 = (edge_ptr->start_node())->coordinates().y(); 00882 x1 = (edge_ptr->end_node())->coordinates().x(); 00883 y1 = (edge_ptr->end_node())->coordinates().y(); 00884 cx = (x0 + x1) * 0.5; 00885 cy = (y0 + y1) * 0.5; 00886 edge_radius = sqrt(SQR(x1-x0) + SQR(y1-y0)) * 0.5; 00887 dist = sqrt( SQR(cx-cc.x()) + SQR(cy-cc.y()) ); 00888 00889 // Edge encroaches: don't insert, return now 00890 00891 if (dist - edge_radius < FT_INSIDE_TOL) 00892 { 00893 return CUBIT_SUCCESS; 00894 } 00895 } 00896 } 00897 } 00898 00899 // Before inserting, remove all the tris on the neighbor 00900 // tri_list from the lists 00901 00902 int index; 00903 for (ii=0; ii<tri_list.size(); ii++) 00904 { 00905 nntri_ptr = tri_list.get_and_step(); 00906 index = tri_sort_list( nntri_ptr ); 00907 assert(index >= 0); 00908 sorted_lists[index].remove( nntri_ptr ); 00909 } 00910 00911 // Create the new node 00912 00913 NODE *new_node_ptr = (NODE *)new NODECHILD( cc, surface_ptr ); 00914 00915 // Insert the new node into the mesh 00916 00917 rv = bowyer_watson_insert( new_node_ptr, tri_list, 00918 facet_list, curr_visit_flag, 00919 surface_ptr, start_tri); 00920 if (rv != CUBIT_SUCCESS) 00921 return rv; 00922 00923 // get the new tris at the node and classify them 00924 00925 tri_list.clean_out(); 00926 new_node_ptr->tris( tri_list ); 00927 for (ii=0; ii<tri_list.size() && rv == CUBIT_SUCCESS; ii++) 00928 { 00929 tri_ptr = tri_list.get_and_step(); 00930 rv = classify_tri_by_angle( tri_ptr, sorted_lists, num_lists, interval, quality_angle ); 00931 } 00932 } 00933 00934 return rv; 00935 }
