MeshKit
1.0
00001 00002 #include "meshkit/MKCore.hpp" 00003 #include "meshkit/CurveFacetMeshReader.hpp" 00004 #include "meshkit/ModelEnt.hpp" 00005 #include <iostream> 00006 #include <iGeom.h> 00007 #include <cmath> 00008 #include "MBTagConventions.hpp" 00009 #include "moab/Core.hpp" 00010 #include "moab/GeomTopoTool.hpp" 00011 00012 namespace MeshKit 00013 { 00014 // Construction Function for CurveFacetMeshReader 00015 00016 moab::EntityType CurveFacetMeshReader_types[] = {moab::MBVERTEX, moab::MBEDGE, moab::MBMAXTYPE}; 00017 const moab::EntityType* CurveFacetMeshReader::output_types() 00018 { return CurveFacetMeshReader_types; } 00019 00020 00021 CurveFacetMeshReader::CurveFacetMeshReader(MKCore *mk_core, const MEntVector &ments) 00022 : MeshScheme(mk_core, ments) 00023 { 00024 mk = mk_core; 00025 } 00026 00027 // Destructor Function for CurveFacetMeshReader 00028 CurveFacetMeshReader::~CurveFacetMeshReader() 00029 { 00030 } 00031 00032 void CurveFacetMeshReader::setup_this() 00033 { 00034 00035 //create a vertex mesher 00036 int meshop_dim = 0; 00037 MeshOp *vm = (MeshOp*) mk_core()->construct_meshop(meshop_dim); 00038 00039 for (MEntSelection::iterator mit = mentSelection.begin(); mit != mentSelection.end(); mit++) 00040 { 00041 ModelEnt *me = mit->first; 00042 //do an initial check that the model entity is of the correct dimension 00043 if(me->dimension() != 1) 00044 { 00045 std::cout << "Found an entity that is of an incorrect dimension" << std::endl; 00046 mentSelection.erase(mit); 00047 continue; 00048 } 00049 00050 00051 //make sure that its children (vertices) have been meshed 00052 MEntVector children; 00053 me->get_adjacencies(0, children); 00054 00055 for(MEntVector::iterator j = children.begin(); j != children.end(); j++) 00056 { 00057 ModelEnt *child = *j; 00058 if(child->is_meshops_list_empty()) vm->add_modelent(child); 00059 } 00060 00061 } 00062 00063 //make sure we're meshing the veritces first 00064 mk_core()->insert_node(vm, this, mk_core()->root_node()); 00065 00066 //set faceting parameters to default values if the are not already set. 00067 00068 //set the faceting_tolerance 00069 if(!facet_tol) facet_tol = 1e-4; 00070 00071 //set the geom_reabs value 00072 if(!geom_res) geom_res = 1e-6; 00073 00074 } 00075 00076 void CurveFacetMeshReader::execute_this() 00077 { 00078 00079 for(MEntSelection::iterator mit = mentSelection.begin(); mit != mentSelection.end(); mit++) 00080 { 00081 00082 ModelEnt *me = mit->first; 00083 00084 00085 //---------------------------------// 00086 // FACET // 00087 //---------------------------------// 00088 facet(me); 00089 00090 // Not sure if this needs to be done yet 00091 //set_senses(me); 00092 00093 me->set_meshed_state(COMPLETE_MESH); 00094 } 00095 } 00096 00097 void CurveFacetMeshReader::facet(ModelEnt *curve) 00098 { 00099 iGeom::EntityHandle h = curve->geom_handle(); 00100 iMesh::EntitySetHandle sh = IBSH(curve->mesh_handle()); 00101 00102 //get the facets for this curve/ref_edge 00103 std::vector<double> pnts; 00104 std::vector<int> conn; 00105 iGeom::Error errval = mk_core()->igeom_instance()->getFacets(h,facet_tol,pnts,conn); 00106 if (errval != iBase_SUCCESS) throw Error(MK_FAILURE, "Unable get the facets of the curve."); 00107 //create vector for keeping track of the vertices 00108 std::vector<iBase_EntityHandle> verts; 00109 00110 00111 // loop over the facet points 00112 for(unsigned int j = 0; j < pnts.size(); j+=3) 00113 { 00114 //create a new vertex handle 00115 iBase_EntityHandle v; 00116 mk_core()->imesh_instance()->createVtx(pnts[j],pnts[j+1],pnts[j+2],v); 00117 verts.push_back(v); 00118 } 00119 00120 //--------------------------------------------------// 00121 //check that the start and end vertices are within // 00122 //the geom resabs of the facet verts // 00123 //--------------------------------------------------// 00124 00125 //get the curve vertices 00126 MEntVector end_verts; 00127 curve->get_adjacencies(0, end_verts); 00128 00129 //get the entity handle of the start vertex 00130 std::vector<moab::EntityHandle> dum_handles; 00131 end_verts.front()->get_mesh(0,dum_handles); 00132 assert( 1 == dum_handles.size() ); // should only be one vertex in a vertex entity set 00133 iMesh::EntityHandle start_vtx = IBEH(dum_handles.front()); 00134 00135 dum_handles.clear(); 00136 00137 // do the same for the end vertex 00138 end_verts.back()->get_mesh(0, dum_handles); 00139 assert( 1 == dum_handles.size() ); // should only be one vertex in a vertex entity set 00140 iMesh::EntityHandle end_vtx = IBEH(dum_handles.front()); 00141 00142 dum_handles.clear(); 00143 00144 //std::cout << "Number of end_verts: " << end_verts.size() << std::endl; 00145 00146 //special case for a point curve 00147 if(verts.size() < 2) 00148 { 00149 if( start_vtx != end_vtx || curve->measure() > geom_res) 00150 { 00151 std::cout << "Warning: no facetting for curve " << curve->id() << std::endl; 00152 return; 00153 } 00154 else 00155 { 00156 mk_core()->imesh_instance()->addEntToSet(start_vtx, sh); 00157 return; 00158 } 00159 } 00160 00161 //check for a closed curve 00162 bool closed = (mvtx2mvtx_dist(verts.front(),verts.back()) < geom_res); 00163 00164 // check that geometry and facetting agree that the curve is closed 00165 if ( closed != (start_vtx == end_vtx)) 00166 std::cout << "Warning: topology and geometry inconsistent for possibly closed curve " 00167 << curve->id() << std::endl; 00168 00169 //check the proximity of the front and end vertices to the start and end points, respectively 00170 if(vtx2vtx_dist(end_verts.front()->geom_handle(), verts.front()) > geom_res || 00171 vtx2vtx_dist(end_verts.back()->geom_handle(), verts.back()) > geom_res) 00172 { 00173 //try reversing the points 00174 //std::reverse(verts.begin(), verts.end()); 00175 00176 //check again, if this time it fails, give a warning 00177 if(vtx2vtx_dist(end_verts.front()->geom_handle(), verts.front()) > geom_res || 00178 vtx2vtx_dist(end_verts.back()->geom_handle(), verts.back()) > geom_res) 00179 { 00180 std::cerr << "Warning: vertices not at the ends of the curve " << curve->id() << std::endl; 00181 } 00182 } 00183 00184 00185 //now replace start and end facet points with the curve's child vert(s) 00186 00187 //capture the beginning and end vertex handles for deletion 00188 iMesh::EntityHandle front_vert_to_del = verts.front(); 00189 iMesh::EntityHandle back_vert_to_del = verts.back(); 00190 00191 verts.front() = start_vtx; 00192 verts.back() = end_vtx; 00193 00194 //delete the old vertices 00195 mk_core()->imesh_instance()->deleteEnt(front_vert_to_del); 00196 mk_core()->imesh_instance()->deleteEnt(back_vert_to_del); 00197 00198 //now create the edges with the vertices we've chosen 00199 00200 //vector to contain the edges 00201 std::vector<iBase_EntityHandle> edges; 00202 //loop over vertices and create edges 00203 for (unsigned int j = 0; j < verts.size()-1; j++) 00204 { 00205 //create edges 00206 iBase_EntityHandle e; 00207 mk_core()->imesh_instance()->createEnt(iMesh_LINE_SEGMENT, &verts[j], 2, e); 00208 edges.push_back(e); 00209 } 00210 00211 //remove duplicate vertex if the curve is closed 00212 if(closed && start_vtx == end_vtx) verts.pop_back(); 00213 00214 //add vertices and edges to the entity set 00215 mk_core()->imesh_instance()->addEntArrToSet(&verts[0], verts.size(), sh); 00216 mk_core()->imesh_instance()->addEntArrToSet(&edges[0], edges.size(), sh); 00217 } 00218 00219 void CurveFacetMeshReader::set_senses(ModelEnt *curve) 00220 { 00221 00222 //get the geom_handle for this curve 00223 iGeom::EntityHandle gh = curve->geom_handle(); 00224 00225 //get all surfaces adjacent to this curve 00226 MEntVector adj_surfs; 00227 curve->get_adjacencies(2, adj_surfs); 00228 00229 MEntVector::iterator i; 00230 std::vector<int> senses; 00231 std::vector<moab::EntityHandle> meshsets; 00232 for(i = adj_surfs.begin(); i !=adj_surfs.end(); i++) 00233 { 00234 int sense; 00235 //create a model ent for the current adjacent surface 00236 ModelEnt *adj_ent = *i; 00237 //get the sense of the curve wrt the surface 00238 mk_core()->igeom_instance()->getEgFcSense(gh, adj_ent->geom_handle(),sense); 00239 //std::cout << "Sense: " << sense << std::endl; 00240 // add the sense and the entityhandle to the appropriate vectors 00241 senses.push_back(sense); 00242 meshsets.push_back(adj_ent->mesh_handle()); 00243 } 00244 00245 // use moab to set the senses of the entities 00246 // using moab to do this allows the use of variable length tags 00247 // which are not currently available in iGeom 00248 moab::GeomTopoTool gt(mk_core()->moab_instance()); 00249 moab::ErrorCode rval = gt.set_senses(curve->mesh_handle(),meshsets,senses); 00250 if(rval != moab::MB_SUCCESS) std::cout << "Error setting curve senses!" << std::endl; 00251 00252 } 00253 00254 // should I be using an iMesh entity to do this comparison?? 00255 double CurveFacetMeshReader::vtx2vtx_dist(iGeom::EntityHandle vtx1, iMesh::EntityHandle vtx2) 00256 { 00257 00258 double x1,y1,z1; 00259 double x2,y2,z2; 00260 00261 mk_core()->igeom_instance()->getVtxCoord(vtx1, x1, y1, z1); 00262 mk_core()->imesh_instance()->getVtxCoord(vtx2, x2, y2, z2); 00263 00264 double dist = pow((x1-x2),2) + pow((y1-y2),2) + pow((z1-z2),2); 00265 00266 return sqrt(dist); 00267 } 00268 00269 double CurveFacetMeshReader::mvtx2mvtx_dist(iMesh::EntityHandle vtx1, iMesh::EntityHandle vtx2) 00270 { 00271 00272 double x1,y1,z1; 00273 double x2,y2,z2; 00274 00275 mk_core()->imesh_instance()->getVtxCoord(vtx1, x1, y1, z1); 00276 mk_core()->imesh_instance()->getVtxCoord(vtx2, x2, y2, z2); 00277 00278 double dist = pow((x1-x2),2) + pow((y1-y2),2) + pow((z1-z2),2); 00279 00280 return sqrt(dist); 00281 } 00282 00283 void CurveFacetMeshReader::set_mesh_params(double faceting_tolerance, double geom_resabs) 00284 { 00285 //Assign the faceting values if they are passed into the function 00286 if(faceting_tolerance) facet_tol = faceting_tolerance; 00287 if(geom_resabs) geom_res = geom_resabs; 00288 } 00289 00290 }
