MeshKit
1.0
00001 /* 00002 * MBGeomOp.cpp 00003 * 00004 * Created on: Sep 30, 2011 00005 */ 00006 00007 #include <iostream> 00008 00009 #include "meshkit/MBGeomOp.hpp" 00010 #include "meshkit/ModelEnt.hpp" 00011 00012 #include "moab/Core.hpp" 00013 #include "moab/GeomTopoTool.hpp" 00014 00015 namespace MeshKit { 00016 00017 //Entity Type initialization for geometrization; no mesh output 00018 moab::EntityType MBGeomOp_tps[] = { moab::MBMAXTYPE }; // no mesh, really 00019 const moab::EntityType* MBGeomOp::output_types() 00020 { 00021 return MBGeomOp_tps; 00022 } 00023 00024 MBGeomOp::MBGeomOp(MKCore *mk_core, const MEntVector &me_vec) : 00025 MeshScheme(mk_core, me_vec) 00026 { 00027 // TODO Auto-generated constructor stub 00028 00029 } 00030 00031 MBGeomOp::~MBGeomOp() 00032 { 00033 // TODO Auto-generated destructor stub 00034 } 00035 00036 //set up the geometrization of a model ent (face) for mesh-based geometry 00037 void MBGeomOp::setup_this() 00038 { 00039 00040 } 00041 00042 // construct the mesh: nothing to do, there is no mesh, really, only geometry 00043 // in the form of mesh-based geometry 00044 void MBGeomOp::execute_this() 00045 { 00046 if (mentSelection.empty()) 00047 return; 00048 ModelEnt * me = mentSelection.begin()->first; 00049 // get the one and only model entity, which should be of dimension 2, and geometrize it 00050 // this should be the model entity handle 00051 moab::EntityHandle mset = me->mesh_handle(); 00052 iGeom::EntityHandle gent = me->geom_handle(); 00053 if (gent != 0) { 00054 std::cout << "geometry exists on the model ent, do not geometrize\n"; 00055 return; // we do have something here, do not "geometrize" 00056 } 00057 moab::GeomTopoTool gtt(mk_core()->moab_instance()); 00058 moab::EntityHandle output; 00059 moab::ErrorCode rval = gtt.geometrize_surface_set(mset, output); 00060 MBERRCHK(rval, mk_core()->moab_instance()); 00061 // now, get all entity sets in here; the one with dimension 2, put it in mset, and 00062 // form other model ents with other sets; 00063 moab::Range geom_sets; 00064 moab::Tag geomTag = mk_core()->moab_geom_dim_tag(); 00065 00066 rval = mk_core()->moab_instance()->get_entities_by_type_and_tag(output, 00067 moab::MBENTITYSET, &geomTag, NULL, 1, geom_sets, moab::Interface::UNION); 00068 MBERRCHK(rval, mk_core()->moab_instance()); 00069 00070 std::vector<int> dims; 00071 dims.resize(geom_sets.size()); 00072 rval = mk_core()->moab_instance()->tag_get_data(geomTag, geom_sets, &dims[0]); 00073 MBERRCHK(rval, mk_core()->moab_instance()); 00074 00075 // find the one of dimension 2, it is the main one: 00076 // the rest should be of dimension 1 or 0, and for each we should have a ModelEnt 00077 // we should maybe repeat the process from populate mesh... 00078 // maybe we should create new model ents for these new gents; they will be meshable with 00079 // camal, if the geo handles are from FBiGeom 00080 // now, create additional model entities, with mesh based geometry 00081 // the index of this geometry is returned 00082 00083 // now, maybe we should not initialize new geometry 00084 // entities at this point are just moab sets 00085 00086 // at this moment, we have model entities with geom index indx, 00087 // for the mesh-based geometry 00088 mentSelection[me].insert(output); 00089 // the range (result) will have an rootModelSet appropriate for 00090 // a new instantiation of GeomTopoTool 00091 return; 00092 00093 // get dimensions 00094 } 00095 00096 }
