MeshKit
1.0
00001 #include "meshkit/PostBL.hpp" 00002 00003 namespace MeshKit 00004 { 00005 00006 // static registration of this mesh scheme 00007 moab::EntityType PostBL_tps[] = {moab::MBHEX, 00008 moab::MBMAXTYPE}; 00009 const moab::EntityType* PostBL::output_types() 00010 { return PostBL_tps; } 00011 00012 PostBL::PostBL( MKCore *mk, const MEntVector &me_vec) 00013 : MeshScheme( mk, me_vec), 00014 igeom(mk->igeom_instance()), imesh(mk->imesh_instance()), 00015 mb (mk->moab_instance()) 00016 // --------------------------------------------------------------------------- 00020 // --------------------------------------------------------------------------- 00021 { 00022 tri_sch = 2; 00023 m_Conn = 0; 00024 m_BElemNodes = 0; 00025 m_SurfId = -1; 00026 check_bl_edge_length = false; 00027 debug = false; 00028 hybrid = false; 00029 m_NeumannSet = -1; 00030 m_Material = 999999; 00031 m_nLineNumber = 0; 00032 szComment = "!"; 00033 MAXCHARS = 300; 00034 m_JacCalls = 0; 00035 m_JLo = 0.0; 00036 m_JHi = 0.0; 00037 err = 0; 00038 fixmat = -1; 00039 hex27 = 0; 00040 // hex = NULL; 00041 // hex1 = NULL; 00042 // hex2 = NULL; 00043 } 00044 00045 PostBL::~PostBL() 00046 // --------------------------------------------------------------------------- 00050 // --------------------------------------------------------------------------- 00051 {} 00052 00053 bool PostBL::add_modelent(ModelEnt *model_ent) 00054 // --------------------------------------------------------------------------- 00058 // --------------------------------------------------------------------------- 00059 { 00060 return MeshOp::add_modelent(model_ent); 00061 } 00062 00063 void PostBL::setup_this() 00064 // --------------------------------------------------------------------------- 00068 // --------------------------------------------------------------------------- 00069 { 00070 if (debug) { 00071 m_LogFile << "\nIn setup this : " << std::endl; 00072 } 00073 00074 } 00075 00076 void PostBL::execute_this() 00077 // --------------------------------------------------------------------------- 00081 // --------------------------------------------------------------------------- 00082 { 00083 m_LogFile << "\nIn execute this : creating boundary layer elements.." << std::endl; 00084 // start the timer 00085 CClock Timer; 00086 clock_t sTime = clock(); 00087 std::string szDateTime; 00088 Timer.GetDateTime (szDateTime); 00089 VerdictWrapper vw(mb); 00090 00091 m_LogFile << "\nStarting out at : " << szDateTime << std::endl; 00092 m_LogFile << "\n Loading meshfile: " << m_MeshFile << std::endl; 00093 00094 // load specified mesh file 00095 IBERRCHK(imesh->load(0, m_MeshFile.c_str(),0), *imesh); 00096 00097 //check if intervals is read from input file 00098 if(m_Intervals == 0){ 00099 m_LogFile << "Please specify desired number of intervals using 'Intervals' keyword" << std::endl; 00100 exit(0); 00101 } 00102 // if no NS specified, take all d-1 elements as BL input 00103 if (m_NeumannSet == -1 && m_SurfId == -1) { 00104 // create a neumann set with id 99999 in the model and set it for BL generation 00105 moab::Range neuEnts; 00106 moab::EntityHandle neuEntSet; 00107 moab::Tag neuTag; 00108 mb->create_meshset(moab::MESHSET_SET, neuEntSet); 00109 mb->get_entities_by_dimension(mb->get_root_set(), 2, neuEnts, true); 00110 mb->add_entities(neuEntSet, neuEnts); 00111 mb->tag_get_handle("NEUMANN_SET", neuTag); 00112 m_NeumannSet = 999999; 00113 mb->tag_set_data(neuTag, &neuEntSet, 1, (void*) &m_NeumannSet); 00114 } 00115 00116 moab::Range all_elems, all_verts; 00117 MBERRCHK(mb->get_entities_by_dimension(0, 3, all_elems,true),mb); 00118 if (all_elems.size() == 0) 00119 m_GD = 2; 00120 else if (all_elems.size() > 0) 00121 m_GD = 3; 00122 else 00123 exit(0); 00124 all_elems.clear(); 00125 m_LogFile << "Geometric dimension of meshfile = "<< m_GD <<std::endl; 00126 00127 // obtain existing tag handles 00128 MBERRCHK(mb->tag_get_handle("GEOM_DIMENSION", 1, moab::MB_TYPE_INTEGER, GDTag),mb); 00129 MBERRCHK(mb->tag_get_handle("NEUMANN_SET", 1, moab::MB_TYPE_INTEGER, NTag),mb); 00130 MBERRCHK(mb->tag_get_handle("MATERIAL_SET", 1, moab::MB_TYPE_INTEGER, MTag),mb); 00131 MBERRCHK(mb->tag_get_handle("GLOBAL_ID", 1, moab::MB_TYPE_INTEGER, GIDTag),mb); 00132 // create smoothset and fixed tag for mesquite 00133 MBERRCHK(mb->tag_get_handle("SMOOTHSET", 1, moab::MB_TYPE_INTEGER, STag, 00134 moab::MB_TAG_SPARSE|moab::MB_TAG_CREAT),mb); 00135 MBERRCHK(mb->tag_get_handle("fixed", 1, moab::MB_TYPE_INTEGER, FTag, 00136 moab::MB_TAG_SPARSE|moab::MB_TAG_CREAT),mb); 00137 MBERRCHK(mb->tag_get_handle("mnode", 1, moab::MB_TYPE_INTEGER, MNTag, 00138 moab::MB_TAG_SPARSE|moab::MB_TAG_CREAT),mb); 00139 MBERRCHK(mb->tag_get_handle("matid", 1, moab::MB_TYPE_INTEGER, MatIDTag, 00140 moab::MB_TAG_SPARSE|moab::MB_TAG_CREAT),mb); 00141 MBERRCHK(mb->tag_get_handle("BLNODEID", 1, moab::MB_TYPE_INTEGER, BLNodeIDTag, 00142 moab::MB_TAG_SPARSE|moab::MB_TAG_CREAT),mb); 00143 00144 // get all the entity sets with boundary layer geom dimension, neumann sets and material sets 00145 m_BLDim = m_GD - 1; 00146 00147 const void* gdim[] = {&m_BLDim}; 00148 00149 MBERRCHK(mb->get_entities_by_type_and_tag(0, moab::MBENTITYSET, &GDTag, 00150 gdim, 1 , sets, moab::Interface::INTERSECT, false), mb); 00151 MBERRCHK(mb->get_entities_by_type_and_tag(0, moab::MBENTITYSET, &NTag, 0, 1 , n_sets),mb); 00152 MBERRCHK(mb->get_entities_by_type_and_tag(0, moab::MBENTITYSET, &MTag, 0, 1 , m_sets),mb); 00153 00154 // Handling NeumannSets (if BL surf in input via NS) 00155 moab::EntityHandle this_set = 0; 00156 for (set_it = n_sets.begin(); set_it != n_sets.end(); set_it++) { 00157 00158 this_set = *set_it; 00159 00160 // get entity handle of NS specified in the input file 00161 int set_id; 00162 MBERRCHK(mb->tag_get_data(NTag, &this_set, 1, &set_id), mb); 00163 if(set_id == m_NeumannSet) 00164 break; 00165 this_set = 0; 00166 } 00167 if (debug && m_NeumannSet != -1 && this_set != 0){ 00168 m_LogFile << "Looking for NS with id " << m_NeumannSet << 00169 ". Total NS found are: "<< n_sets.size() << std::endl; 00170 } 00171 00172 // For specified surface: get the all the quads and nodes in a range 00173 moab::EntityHandle s1; 00174 // variable to store global id of boundary layer specified in the input file 00175 int dims; 00176 00177 // Method 1: INPUT by NeumannSet 00178 if(m_NeumannSet != -1 && this_set != 0){ 00179 MBERRCHK(mb->get_entities_by_dimension(this_set, m_BLDim, quads,true),mb); 00180 if (quads.size() <=0){ 00181 m_LogFile << " No quads found, aborting.. " << std::endl; 00182 exit(0); 00183 } 00184 00185 MBERRCHK(mb->get_adjacencies(quads, 0, false, nodes, moab::Interface::UNION),mb); 00186 if(m_GD == 3) 00187 MBERRCHK(mb->get_adjacencies(quads, 1, true, edges, moab::Interface::UNION),mb); 00188 00189 if (debug) { 00190 m_LogFile << "Found NeumannSet with id : " << m_NeumannSet << std::endl; 00191 m_LogFile << "#Quads in this surface: " << quads.size() << std::endl; 00192 m_LogFile << "#Nodes in this surface: " << nodes.size() << std::endl; 00193 m_LogFile << "#New nodes to be created:" << m_Intervals*nodes.size() << std::endl; 00194 } 00195 } 00196 // Method 2: INPUT by surface id (geom dimension) 00197 else if (m_SurfId !=-1){ 00198 for(moab::Range::iterator rit=sets.begin(); rit != sets.end(); ++rit){ 00199 s1 = *rit; 00200 MBERRCHK(mb->tag_get_data(GIDTag, &s1, 1, &dims),mb); 00201 00202 if(dims == m_SurfId && m_SurfId != -1){ 00203 MBERRCHK(mb->get_entities_by_dimension(s1, m_BLDim, quads,true),mb); 00204 if (quads.size() <=0){ 00205 m_LogFile << " No quads found, aborting.. " << std::endl; 00206 exit(0); 00207 } 00208 00209 MBERRCHK(mb->get_adjacencies(quads, 0, false, nodes, moab::Interface::UNION),mb); 00210 if(m_GD == 3) 00211 MBERRCHK(mb->get_adjacencies(edges, 0, false, nodes, moab::Interface::UNION),mb); 00212 if (debug) { 00213 m_LogFile << "Found surface with id : " << m_SurfId << std::endl; 00214 m_LogFile << "#Quads in this surface: " << quads.size() << std::endl; 00215 m_LogFile << "#Nodes in this surface: " << nodes.size() << std::endl; 00216 m_LogFile << "#New nodes to be created:" << m_Intervals*nodes.size() << std::endl; 00217 } 00218 } 00219 } 00220 } 00221 00222 if (quads.size() == 0 || nodes.size() == 0) { 00223 m_LogFile << "Invalid boundary layer specification, aborting.." << std::endl; 00224 exit(0); 00225 } 00226 00227 // placeholder for storing smoothing entities 00228 moab::EntityHandle smooth_set; 00229 int s_id = 100; 00230 MBERRCHK(mb->create_meshset(moab::MESHSET_SET, smooth_set, 1), mb); 00231 MBERRCHK(mb->tag_set_data(STag, &smooth_set, 1, &s_id), mb); 00232 00233 // placeholder for storing gd on new entities 00234 MBERRCHK(mb->create_meshset(moab::MESHSET_SET, geom_set, 1), mb); 00235 MBERRCHK(mb->tag_set_data(GDTag, &geom_set, 1, &m_GD), mb); 00236 00237 // declare variables before starting BL creation 00238 std::vector <bool> node_status(false); // size of verts of bl surface 00239 node_status.resize(nodes.size()); 00240 blmaterial_id.resize(quads.size()); 00241 00242 //size of the following is based on element type 00243 new_vert.resize(m_Intervals*nodes.size()); 00244 // element on the boundary 00245 Range::iterator kter = quads.begin(); 00246 00247 MBERRCHK(mb->get_adjacencies(&(*kter), 1, m_GD, false, old_hex),mb); 00248 std::cout << "old_hex size is - before filtering fixmat - " << old_hex.size() << std::endl; 00249 if((int) old_hex.size() == 0){ 00250 m_LogFile << "unable to find adjacent hex for BL quad, aborting..."; 00251 exit(0); 00252 } 00253 00254 // allocate space for connectivity/adjacency during the first pass of this loop 00255 if(mb->type_from_handle(old_hex[0]) == moab::MBHEX){ 00256 m_Conn = 8; 00257 m_BElemNodes = 4; 00258 m_HConn = 8; 00259 //allocating based on element type 00260 conn.resize(m_Intervals*m_Conn), qconn.resize(m_BElemNodes), adj_qconn.resize(m_BElemNodes), 00261 old_hex_conn.resize(m_Conn), adj_hex_nodes1.resize(m_Conn); 00262 } 00263 else if(mb->type_from_handle(old_hex[0]) == MBTET){ 00264 m_Conn = 4; 00265 m_BElemNodes = 3; 00266 //allocating based on element type - thrice the number of elements 00267 if(hybrid){ 00268 m_HConn = 6; 00269 conn.resize(m_Intervals*6); 00270 } 00271 else{ 00272 m_HConn = 6; // we use the prism for making tets 00273 tet_conn.resize(3*m_Intervals*m_Conn); 00274 conn.resize(m_Intervals*6); 00275 } 00276 qconn.resize(m_BElemNodes), adj_qconn.resize(m_BElemNodes), 00277 old_hex_conn.resize(m_Conn), adj_hex_nodes1.resize(m_Conn); 00278 } 00279 else if(mb->type_from_handle(old_hex[0]) == MBQUAD){ 00280 m_Conn = 4; 00281 m_HConn = 4; 00282 m_BElemNodes = 2; 00283 //allocating based on element type 00284 conn.resize(m_Intervals*m_Conn), qconn.resize(m_BElemNodes), adj_qconn.resize(m_BElemNodes), 00285 old_hex_conn.resize(m_Conn), adj_hex_nodes1.resize(m_Conn); 00286 } 00287 else if(mb->type_from_handle(old_hex[0]) == MBTRI){ 00288 m_Conn = 3; 00289 m_HConn = 4; 00290 m_BElemNodes = 2; 00291 //allocating based on element type - twice the number of elements 00292 if(hybrid){ 00293 m_HConn = 4; 00294 conn.resize(m_Intervals*m_HConn); 00295 } 00296 else{ 00297 tri_conn.resize(2*m_Intervals*m_Conn); 00298 conn.resize(2*m_Intervals*m_Conn); 00299 } 00300 qconn.resize(m_BElemNodes), adj_qconn.resize(m_BElemNodes), 00301 old_hex_conn.resize(m_Conn), adj_hex_nodes1.resize(m_Conn); 00302 } 00303 else if(m_Conn == 0 || m_BElemNodes == 0){ 00304 m_LogFile << "This mesh type is not supported by this tool" << std::endl; 00305 exit(0); 00306 } 00307 00308 // Tag all nodes on outer boundary with a unique number 00309 int node_id = 0; 00310 std::vector<int> NId(nodes.size()); 00311 for(moab::Range::iterator nodes_iter = nodes.begin(); nodes_iter != nodes.end(); nodes_iter++){ 00312 NId[node_id] = node_id; 00313 MBERRCHK(mb->tag_set_data(BLNodeIDTag, &(*nodes_iter),1, &NId[node_id]), mb); 00314 ++node_id; 00315 } 00316 00317 // Handling MaterialSet 00318 int mset_id = 0, found = 0; 00319 for (mset_it = m_sets.begin(); mset_it != m_sets.end(); mset_it++) { 00320 00321 mthis_set = *mset_it; 00322 00323 // get entity handle of MS specified in the input file 00324 MBERRCHK(mb->tag_get_data(MTag, &mthis_set, 1, &mset_id), mb); 00325 00326 // if no material set is specified, we'll have to resolve else just set all the MNTag to 0 00327 if(mset_id == m_Material){ 00328 found = 1; 00329 break; 00330 } 00331 else if(mset_id == fixmat){ 00332 MBERRCHK(mb->get_entities_by_dimension(mthis_set, m_GD, fixmat_ents ,true),mb); 00333 } 00334 00335 // get all the nodes in the material and tag bl nodes 00336 moab::Range mat_nodes, mat_hexes; 00337 if(m_GD == 3){ 00338 if(m_Conn == 8) 00339 MBERRCHK(mb->get_entities_by_type(mthis_set, moab::MBHEX, mat_hexes, true), mb); 00340 else if(m_Conn ==4) 00341 MBERRCHK(mb->get_entities_by_type(mthis_set, moab::MBTET, mat_hexes, true), mb); 00342 } 00343 else if(m_GD == 2){ 00344 if(m_Conn == 4) 00345 MBERRCHK(mb->get_entities_by_type(mthis_set, moab::MBQUAD, mat_hexes, true), mb); 00346 else if(m_Conn == 3) 00347 MBERRCHK(mb->get_entities_by_type(mthis_set, moab::MBTRI, mat_hexes, true), mb); 00348 } 00349 00350 // tag all the mat_hexes with matid 00351 std::vector<int> matID(mat_hexes.size(), mset_id); 00352 MBERRCHK(mb->tag_set_data(MatIDTag, mat_hexes, &matID[0]), mb); 00353 // 00354 MBERRCHK(mb->get_adjacencies(mat_hexes, 0, false, mat_nodes, Interface::UNION), mb); 00355 moab::Range mat_b_nodes = intersect(nodes, mat_nodes); 00356 00357 std::vector<int> bl_node_data(mat_b_nodes.size(), 0); 00358 std::vector<int> node_tag_data(mat_b_nodes.size(),-1); 00359 00360 // don't do error check, as it is supposed to give error when multiple material case is encountered 00361 mb->tag_get_data(MNTag, mat_b_nodes, &node_tag_data[0]); 00362 for(int i=0; i< (int)mat_b_nodes.size(); i++){ 00363 // already a part of some material 00364 if(node_tag_data[i] != -1){ 00365 bl_node_data[i] = node_tag_data[i]+1; 00366 } 00367 } 00368 00369 MBERRCHK(mb->tag_set_data(MNTag, mat_b_nodes, &bl_node_data[0]), mb); 00370 mat_hexes.clear(); 00371 mat_b_nodes.clear(); 00372 mat_nodes.clear(); 00373 mthis_set = 0; 00374 } // end handling material set 00375 00376 // if fixmat specified, filter old hex, we don't have to correct both sides of the boundary 00377 if (fixmat !=-1 && (int) old_hex.size() > 1){ 00378 moab::EntityHandle old_hex_set; 00379 MBERRCHK(mb->create_meshset(moab::MESHSET_SET, old_hex_set, 1), mb); 00380 MBERRCHK(mb->add_entities(old_hex_set,&old_hex[0], (int) old_hex.size()), mb); 00381 // TODO: Find a faster way of doing this 00382 MBERRCHK(mb->remove_entities(old_hex_set, fixmat_ents), mb); 00383 old_hex.clear(); 00384 old_hex.empty(); 00385 // the the old hex to be modified 00386 MBERRCHK(mb->get_entities_by_dimension(old_hex_set, m_GD, old_hex), mb); 00387 } 00388 else if(fixmat ==-1 && (int) old_hex.size()>1){ 00389 m_LogFile << "FIXMAT not defined, elements found on either side of specified BL surface, aborting..."; 00390 m_LogFile << "\n\n Define FIXMAT keyword with material id that remains fixed." << std::endl; 00391 exit(0); 00392 } 00393 00394 MBERRCHK(mb->get_connectivity(&(*kter), 1, qconn),mb); 00395 MBERRCHK(mb->get_connectivity(&old_hex[0], 1, old_hex_conn),mb); 00396 00397 // get the normal to the plane of the 2D mesh 00398 if(m_GD==2) 00399 get_normal_quad (old_hex_conn, surf_normal); 00400 if(found == 1 && m_Material !=999999){ 00401 m_LogFile << "Found material set with id " << m_Material << std::endl; 00402 } 00403 else if (m_Material !=999999 && found == 0){ 00404 // material set found, but non-existant. Now create this material set 00405 m_LogFile << "Creating material set with id " << m_Material << std::endl; 00406 MBERRCHK(mb->create_meshset(moab::MESHSET_SET, mthis_set, 1), mb); 00407 MBERRCHK(mb->tag_set_data(MTag, &mthis_set, 1, &m_Material), mb); 00408 } 00409 else if (m_Material == 999999 && found == 0){ 00410 m_LogFile << "Use old materials for new boundary layer elements. No material specified." << std::endl; 00411 00412 // If no material tag exists in the model create one now 00413 if((int)m_sets.size() == 0){ 00414 m_LogFile << "Creating material set with id " << m_Material << std::endl; 00415 MBERRCHK(mb->create_meshset(moab::MESHSET_SET, mthis_set, 1), mb); 00416 MBERRCHK(mb->tag_set_data(MTag, &mthis_set, 1, &m_Material), mb); 00417 } 00418 } 00419 else{ 00420 m_LogFile << "Unhandled case" << std::endl; 00421 exit(0); 00422 } 00423 00424 err = compute_normals(); 00425 if (err!=0){ 00426 m_LogFile << "Failed to compute normals" << std::endl; 00427 exit(0); 00428 } 00429 00430 err = push_bulk_mesh(vw); 00431 if (err!=0){ 00432 m_LogFile << "Failed to push bulk mesh" << std::endl; 00433 exit(0); 00434 } 00435 err = create_bl_elements(vw); 00436 if (err!=0){ 00437 m_LogFile << "Failed to create boundary layer elements after pushing bulk mesh" << std::endl; 00438 exit(0); 00439 } 00440 00441 m_LogFile << "\nTotal Jacobian calls/Min/Max of penultimate hex elements:" << m_JacCalls << ", " << m_JLo << ", " << m_JHi << std::endl; 00442 00443 // convert the final mesh to hex27 for Nek5000 00444 if(hex27 == 1){ 00445 moab::Range entities; 00446 moab::EntityHandle meshset; 00447 mb->get_entities_by_type(0, MBHEX, entities); 00448 mb->create_meshset(MESHSET_SET, meshset); 00449 mb->add_entities(meshset, entities); 00450 // Add nodes along mid- edge, face and region 00451 mb->convert_entities(meshset, true, true, true); 00452 m_LogFile << "Mesh converted from hex 8 to hex 27 elements" << std::endl; 00453 } 00454 00455 // save the final mesh with boundary layer elements 00456 MBERRCHK(mb->write_mesh(m_OutFile.c_str()),mb); 00457 m_LogFile << "\n\nWrote Mesh File: " << m_OutFile << std::endl; 00458 // get the current date and time 00459 Timer.GetDateTime (szDateTime); 00460 m_LogFile << "Ending at : " << szDateTime; 00461 // report/compute the elapsed time 00462 m_LogFile << "Elapsed wall clock time: " << Timer.DiffTime () 00463 << " seconds or " << (Timer.DiffTime ())/60.0 << " mins\n"; 00464 m_LogFile << "Total CPU time used: " << (double) (clock() - sTime)/CLOCKS_PER_SEC \ 00465 << " seconds" << std::endl; 00466 } 00467 00468 void PostBL::PrepareIO (int argc, char *argv[], std::string TestDir) 00469 // --------------------------------------------------------------------------- 00473 // --------------------------------------------------------------------------- 00474 { 00475 // set and open input output files 00476 bool bDone = false; 00477 do{ 00478 if (2 == argc) { 00479 m_InputFile = argv[1]; 00480 m_LogName = m_InputFile + ".log"; 00481 } 00482 else if (1 == argc){ 00483 m_InputFile = TestDir + "/" + (char *)DEFAULT_TEST_POSTBL; 00484 m_LogName = (std::string)DEFAULT_TEST_POSTBL + ".log"; 00485 } 00486 00487 // open input file for reading 00488 m_FileInput.open (m_InputFile.c_str(), std::ios::in); 00489 if (!m_FileInput){ 00490 m_LogFile << "Usage: postbl <filename.inp> " << std::endl; 00491 m_LogFile << "Default test file can be found here <Meshkit/data>" << std::endl; 00492 m_LogFile << " Examples input and mesh files are located here <MeshKit/test/algs/postbl_examples>" << std::endl; 00493 m_FileInput.clear (); 00494 exit(1); 00495 } 00496 else 00497 bDone = true; // file opened successfully 00498 00499 // open the log file for dumping debug/output statements 00500 m_LogFile.coss.open (m_LogName.c_str(), std::ios::out); 00501 if (!m_LogFile.coss){ 00502 m_LogFile << "Unable to open file: " << m_LogName << std::endl; 00503 m_LogFile.coss.clear (); 00504 exit(1); 00505 } 00506 else 00507 bDone = true; // file opened successfully 00508 m_LogFile << '\n'; 00509 m_LogFile << "\t\t---------------------------------------------------------" << '\n'; 00510 m_LogFile << "\t\t Tool to generate Post-mesh Boundary Layers " << '\n'; 00511 m_LogFile << "\t\t\t\tArgonne National Laboratory" << '\n'; 00512 m_LogFile << "\t\t\t\t 2012 " << '\n'; 00513 m_LogFile << "\t\t---------------------------------------------------------" << '\n'; 00514 m_LogFile << "\nsee README file for using the program and details on various cards.\n"<< std::endl; 00515 00516 }while (!bDone); 00517 00518 // Get the meshfile name, surface(s), thickness, intervals and bias 00519 CParser Parse; 00520 int maxloop = 1000; 00521 // count the total number of cylinder commands in each pincellh 00522 for(;;){ 00523 if(m_nLineNumber > maxloop){ 00524 m_LogFile << "Warning: Didn't find End keyword, stopping after reading 1000 lines from input file" << std::endl; 00525 break; 00526 } 00527 if (!Parse.ReadNextLine (m_FileInput, m_nLineNumber, szInputString, 00528 MAXCHARS, szComment)) 00529 IOErrorHandler (INVALIDINPUT); 00530 00531 // Get tri scheme 00532 if (szInputString.substr(0,9) == "trischeme"){ 00533 std::istringstream szFormatString (szInputString); 00534 szFormatString >> m_Card >> tri_sch; 00535 if(szFormatString.fail()) 00536 IOErrorHandler(INVALIDINPUT); 00537 m_LogFile << m_Card << " name read: "<< tri_sch << std::endl; 00538 } 00539 // Get hybrid 00540 if (szInputString.substr(0,6) == "hybrid"){ 00541 std::istringstream szFormatString (szInputString); 00542 szFormatString >> m_Card >> hybrid; 00543 if(szFormatString.fail()) 00544 IOErrorHandler(INVALIDINPUT); 00545 m_LogFile << m_Card << " name read: "<< hybrid << std::endl; 00546 } 00547 // Get hybrid 00548 if (szInputString.substr(0,6) == "fixmat"){ 00549 std::istringstream szFormatString (szInputString); 00550 szFormatString >> m_Card >> fixmat; 00551 if(szFormatString.fail()) 00552 IOErrorHandler(INVALIDINPUT); 00553 m_LogFile << m_Card << " name read: "<< fixmat << std::endl; 00554 } 00555 // Get MeshFile name 00556 if (szInputString.substr(0,8) == "meshfile"){ 00557 std::istringstream szFormatString (szInputString); 00558 szFormatString >> m_Card >> m_MeshFile; 00559 if(szFormatString.fail()) 00560 IOErrorHandler(INVALIDINPUT); 00561 m_LogFile << m_Card << " name read: "<< m_MeshFile << std::endl; 00562 if (argc == 1){ 00563 m_MeshFile = TestDir + "/" + m_MeshFile; 00564 } 00565 } 00566 // Get BL surface 00567 if (szInputString.substr(0,8) == "surfaces"){ 00568 std::istringstream szFormatString (szInputString); 00569 szFormatString >> m_Card >> m_SurfId; 00570 if(m_SurfId < 0 || szFormatString.fail()) 00571 IOErrorHandler(INVALIDINPUT); 00572 m_LogFile << m_Card << " read: "<< m_SurfId <<std::endl; 00573 } 00574 // Get BL surface via neumann set or sideset 00575 if (szInputString.substr(0,10) == "neumannset"){ 00576 std::istringstream szFormatString (szInputString); 00577 szFormatString >> m_Card >> m_NeumannSet; 00578 if(m_NeumannSet < 0 || szFormatString.fail()) 00579 IOErrorHandler(INVALIDINPUT); 00580 m_LogFile << m_Card << " read: "<< m_NeumannSet <<std::endl; 00581 } 00582 // Get BL material (block) number 00583 if (szInputString.substr(0,8) == "material"){ 00584 std::istringstream szFormatString (szInputString); 00585 szFormatString >> m_Card >> m_Material; 00586 if(m_Material < 0 || szFormatString.fail()) 00587 IOErrorHandler(INVALIDINPUT); 00588 m_LogFile << m_Card << " read: "<< m_Material <<std::endl; 00589 } 00590 00591 // Get thickness 00592 if (szInputString.substr(0,9) == "thickness"){ 00593 std::istringstream szFormatString (szInputString); 00594 szFormatString >> m_Card >> m_Thickness; 00595 if(m_Thickness < 0 || szFormatString.fail()) 00596 IOErrorHandler(INVALIDINPUT); 00597 m_LogFile << m_Card << " read: "<< m_Thickness <<std::endl; 00598 } 00599 // Get intervals 00600 if (szInputString.substr(0,9) == "intervals"){ 00601 std::istringstream szFormatString (szInputString); 00602 szFormatString >> m_Card >> m_Intervals; 00603 if(m_Intervals < 0 || szFormatString.fail()) 00604 IOErrorHandler(INVALIDINPUT); 00605 m_LogFile << m_Card << " read: "<< m_Intervals <<std::endl; 00606 } 00607 // Get bias 00608 if (szInputString.substr(0,4) == "bias"){ 00609 std::istringstream szFormatString (szInputString); 00610 szFormatString >> m_Card >> m_Bias; 00611 if(m_Bias < 0 || szFormatString.fail()) 00612 IOErrorHandler(INVALIDINPUT); 00613 m_LogFile << m_Card << " read: "<< m_Bias <<std::endl; 00614 } 00615 // Output file name 00616 if (szInputString.substr(0,7) == "outfile"){ 00617 std::istringstream szFormatString (szInputString); 00618 szFormatString >> m_Card >> m_OutFile; 00619 if(szFormatString.fail()) 00620 IOErrorHandler(INVALIDINPUT); 00621 m_LogFile << m_Card << " name read: "<< m_OutFile <<std::endl; 00622 } 00623 // Output file name 00624 if (szInputString.substr(0,7) == "outfile"){ 00625 std::istringstream szFormatString (szInputString); 00626 szFormatString >> m_Card >> m_OutFile; 00627 if(szFormatString.fail()) 00628 IOErrorHandler(INVALIDINPUT); 00629 m_LogFile << m_Card << " name read: "<< m_OutFile <<std::endl; 00630 } 00631 // save hex27 mesh 00632 if (szInputString.substr(0,5) == "hex27"){ 00633 std::istringstream szFormatString (szInputString); 00634 szFormatString >> m_Card >> hex27; 00635 if(szFormatString.fail()) 00636 IOErrorHandler(INVALIDINPUT); 00637 m_LogFile << m_Card << " hex27 creation: "<< hex27 <<std::endl; 00638 } 00639 if (szInputString.substr(0,3) == "end"){ 00640 break; 00641 } 00642 } 00643 } 00644 00645 void PostBL::IOErrorHandler (ErrorStates ECode) const 00646 // --------------------------------------------------------------------------- 00650 // --------------------------------------------------------------------------- 00651 { 00652 std::cerr << '\n'; 00653 if (ECode == INVALIDINPUT) // invalid input 00654 std::cerr << "Invalid input."; 00655 else 00656 std::cerr << "Unknown error ...?"; 00657 00658 std::cerr << '\n' << "Error in input file line : " << m_nLineNumber; 00659 std::cerr << std::endl; 00660 exit (1); 00661 } 00662 00663 00664 } // namespace MeshKit 00665 00666
