MeshKit
1.0
00001 00007 #include "meshkit/MKCore.hpp" 00008 #include "meshkit/CAMALTriAdvance.hpp" 00009 #include "meshkit/SizingFunction.hpp" 00010 #include "meshkit/SizingFunctionVar.hpp" 00011 #include "meshkit/ModelEnt.hpp" 00012 00013 using namespace MeshKit; 00014 00015 #include "TestUtil.hpp" 00016 00017 MKCore *mk = NULL; 00018 bool save_mesh = false; 00019 00020 void holysurf_test(); 00021 void singleholesurf_test(); 00022 void singleholesurfimprinted_test(); 00023 void square_test(); 00024 void mesh_test(std::string filebase); 00025 void var_size_test(); 00026 00027 #ifdef HAVE_ACIS 00028 std::string extension = ".sat"; 00029 #elif HAVE_OCC 00030 std::string extension = ".stp"; 00031 #endif 00032 00033 int main(int argc, char **argv) 00034 { 00035 00036 // start up MK and load the geometry 00037 mk = new MKCore; 00038 int num_fail = 0; 00039 00040 if (argc == 2) save_mesh = true; 00041 00042 00043 num_fail += RUN_TEST(holysurf_test); 00044 num_fail += RUN_TEST(singleholesurf_test); 00045 num_fail += RUN_TEST(singleholesurfimprinted_test); 00046 num_fail += RUN_TEST(square_test); 00047 num_fail += RUN_TEST(var_size_test); 00048 return num_fail; 00049 } 00050 00051 void holysurf_test() 00052 { 00053 mesh_test("holysurf"); 00054 } 00055 00056 void singleholesurf_test() 00057 { 00058 mesh_test("singleholesurf"); 00059 } 00060 00061 void singleholesurfimprinted_test() 00062 { 00063 mesh_test("singleholesurfimprinted"); 00064 } 00065 00066 void square_test() 00067 { 00068 mesh_test("squaresurf"); 00069 } 00070 void mesh_test(std::string filebase) 00071 { 00072 std::string file_name = TestDir + "/" + filebase + extension; 00073 mk->load_geometry(file_name.c_str()); 00074 00075 // get the surface 00076 MEntVector dum, surfs; 00077 mk->get_entities_by_dimension(2, dum); 00078 surfs.push_back(*dum.rbegin()); 00079 mk->construct_meshop("CAMALTriAdvance", surfs); 00080 00081 // make a sizing function and set it on the surface 00082 SizingFunction esize(mk, -1, 0.25); 00083 surfs[0]->sizing_function_index(esize.core_index()); 00084 00085 // mesh the surface, by calling execute 00086 mk->setup_and_execute(); 00087 00088 // report the number of tris 00089 moab::Range tris; 00090 moab::ErrorCode rval = mk->moab_instance()->get_entities_by_dimension(0, 2, tris); 00091 CHECK_EQUAL(moab::MB_SUCCESS, rval); 00092 std::cout << tris.size() << " tris generated." << std::endl; 00093 00094 if (save_mesh) { 00095 // output mesh 00096 std::string outfile = filebase + std::string(".vtk"); 00097 moab::EntityHandle out_set = surfs[0]->mesh_handle(); 00098 rval = mk->moab_instance()->write_file(outfile.c_str(), NULL, NULL, &out_set, 1); 00099 MBERRCHK(rval, mk->moab_instance()); 00100 } 00101 00102 mk->clear_graph(); 00103 } 00104 00105 void var_size_test() 00106 { 00107 std::string file_name = TestDir + "/" + std::string("squaresurf") + extension; 00108 mk->load_geometry(file_name.c_str()); 00109 00110 // get the surface 00111 MEntVector dum, surfs; 00112 mk->get_entities_by_dimension(2, dum); 00113 surfs.push_back(*dum.rbegin()); 00114 mk->construct_meshop("CAMALTriAdvance", surfs); 00115 00116 // make a sizing function and set it on the surface 00117 // make a sizing function and set it on the surface 00118 SizingFunctionVar * svar = new SizingFunctionVar(mk, -1, 0.1); 00119 00120 // these could be read from a file, or something 00121 double point0[3] = {0, 0, 0}; 00122 double coeffs[4] = {0.05, 0.05, 0.05, 0.1}; 00123 svar->set_linear_coeff(point0, coeffs); 00124 00125 ModelEnt *this_surf = (*surfs.rbegin()); 00126 this_surf->sizing_function_index(svar->core_index()); 00127 // how to know if we use a var size during setup of the Edge Mesher? 00128 00129 // mesh the surface, by calling execute 00130 mk->setup_and_execute(); 00131 00132 // report the number of tris 00133 moab::Range tris; 00134 moab::ErrorCode rval = mk->moab_instance()->get_entities_by_dimension(0, 2, tris); 00135 CHECK_EQUAL(moab::MB_SUCCESS, rval); 00136 std::cout << tris.size() << " tris generated." << std::endl; 00137 00138 if (save_mesh) { 00139 // output mesh 00140 std::string outfile = std::string("squaresurf") + std::string(".vtk"); 00141 moab::EntityHandle out_set = surfs[0]->mesh_handle(); 00142 rval = mk->moab_instance()->write_file(outfile.c_str(), NULL, NULL, &out_set, 1); 00143 MBERRCHK(rval, mk->moab_instance()); 00144 } 00145 00146 mk->clear_graph(); 00147 }
