Mesh Oriented datABase
(version 5.4.1)
Collaboration diagram for Tags:Functions | |
| void | iMesh_createTag (iMesh_Instance instance, const char *tag_name, const int tag_size, const int tag_type, iBase_TagHandle *tag_handle, int *err, const int tag_name_len) |
| Create a tag with specified name, size, and type. | |
| void | iMesh_destroyTag (iMesh_Instance instance, iBase_TagHandle tag_handle, const int forced, int *err) |
| Destroy a tag. | |
| void | iMesh_getTagName (iMesh_Instance instance, const iBase_TagHandle tag_handle, char *name, int *err, int name_len) |
| Get the name for a given tag handle. | |
| void | iMesh_getTagSizeValues (iMesh_Instance instance, const iBase_TagHandle tag_handle, int *tag_size, int *err) |
| Get size of a tag in units of numbers of tag data type. | |
| void | iMesh_getTagSizeBytes (iMesh_Instance instance, const iBase_TagHandle tag_handle, int *tag_size, int *err) |
| Get size of a tag in units of bytes. | |
| void | iMesh_getTagHandle (iMesh_Instance instance, const char *tag_name, iBase_TagHandle *tag_handle, int *err, int tag_name_len) |
| Get a the handle of an existing tag with the specified name. | |
| void | iMesh_getTagType (iMesh_Instance instance, const iBase_TagHandle tag_handle, int *tag_type, int *err) |
| Get the data type of the specified tag handle. | |
| void | iMesh_getAllEntSetTags (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, iBase_TagHandle **tag_handles, int *tag_handles_allocated, int *tag_handles_size, int *err) |
| Get all the tags associated with a specified entity set. | |
| void | iMesh_rmvEntSetTag (iMesh_Instance instance, iBase_EntitySetHandle entity_set_handle, const iBase_TagHandle tag_handle, int *err) |
| Remove a tag value from an entity set. | |
| void | iMesh_rmvArrTag (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, const iBase_TagHandle tag_handle, int *err) |
| Remove a tag value from an array of entities. | |
| void | iMesh_getAllTags (iMesh_Instance instance, const iBase_EntityHandle entity_handle, iBase_TagHandle **tag_handles, int *tag_handles_allocated, int *tag_handles_size, int *err) |
| Get all the tags associated with a specified entity handle. | |
| void | iMesh_rmvTag (iMesh_Instance instance, iBase_EntityHandle entity_handle, const iBase_TagHandle tag_handle, int *err) |
| Remove a tag value from an entity. | |
| void | iMesh_getAllIfaceTags (iMesh_Instance instance, iBase_TagHandle **tag_handles, int *tag_handles_allocated, int *tag_handles_size, int *err) |
| Get all the tags associated with the entire interface. | |
| void | iMesh_createTagWithOptions (iMesh_Instance instance, const char *tag_name, const char *tmp_tag_options, const int tag_size, const int tag_type, iBase_TagHandle *tag_handle, int *err, const int tag_name_len, const int tag_options_len) |
| Create a tag with options. | |
| void iMesh_createTag | ( | iMesh_Instance | instance, |
| const char * | tag_name, | ||
| const int | tag_size, | ||
| const int | tag_type, | ||
| iBase_TagHandle * | tag_handle, | ||
| int * | err, | ||
| const int | tag_name_len | ||
Create a tag with specified name, size, and type. Tag size is in units of size of tag_type data types. Value input for tag type must be value in iBase_TagType enumeration.
| [in] | instance | iMesh instance handle |
| [in] | tag_name | Character string indicating tag name |
| [in] | tag_size | Size of each tag value, in units of number of tag_type datums. |
| [in] | tag_type | Data type for data stored in this tag |
| [out] | tag_handle | Pointer to tag handle returned from function |
| [out] | err | Returned Error status (see iBase_ErrorType) |
| [in] | tag_name_len | Length of tag name string (String Length Arguments) |
Definition at line 1483 of file iMesh_MOAB.cpp.
References iMesh_createTagWithOptions.
iMesh_createTagWithOptions( instance, tag_name, NULL, tag_size, tag_type, tag_handle, err, tag_name_size, 0 );
| void iMesh_createTagWithOptions | ( | iMesh_Instance | instance, |
| const char * | tmp_tag_options, | ||
| int * | err, | ||
| const int | tag_name_len, | ||
| const int | tag_options_len | ||
Create a tag with options; allows creation of Dense and Bit tags through iMesh Allowable options are: TAG_STORAGE_TYPE={DENSE | SPARSE | BIT | MESH} TAG_DEFAULT_VALUE=
(data type of value should match tag data type) [in] length of options string
| [in] | tag_name | tag name |
| [in] | tmp_tag_options | options string |
| [in] | tag_size | tag size, in number of values |
| [in] | tag_type | tag data type (int, double, etc.) |
| [out] | tag_handle | handle of new tag |
| [out] | err | error |
| [in] | tag_name_len | length of tag name string |
Definition at line 3042 of file iMesh_MOAB.cpp.
References CHKENUM, eatwhitespace(), ERROR, ErrorCode, filter_options(), iBase_BYTES, iBase_DOUBLE, iBase_ENTITY_HANDLE, iBase_ENTITY_SET_HANDLE, iBase_INTEGER, iBase_INVALID_ARGUMENT, iBase_SUCCESS, MB_ALREADY_ALLOCATED, mb_data_type_table, MB_SUCCESS, MB_TAG_BIT, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_MESH, MB_TAG_SPARSE, MBIMESHI, MOABI, RETURN, and TagType.
if( tag_size < 0 ) ERROR( iBase_INVALID_ARGUMENT, "iMesh_createTag: invalid tag size" );
CHKENUM( tag_type, iBase_TagValueType, iBase_INVALID_ARGUMENT );
std::string tmp_tagname( tag_name, tag_name_len );
eatwhitespace( tmp_tagname );
moab::TagType storage = MB_TAG_SPARSE;
ErrorCode result;
// declared here 'cuz might have to hold destination of a default value ptr
std::string storage_type;
const void* def_val = NULL;
std::vector< int > def_int;
std::vector< double > def_dbl;
std::vector< moab::EntityHandle > def_handles;
int dum_int;
double dum_dbl;
if( 0 != tag_options_len )
std::string tag_options = filter_options( tmp_tag_options, tmp_tag_options + tag_options_len );
FileOptions opts( tag_options.c_str() );
const char* option_vals[] = { "SPARSE", "DENSE", "BIT", "MESH" };
const moab::TagType opt_types[] = { moab::MB_TAG_SPARSE, moab::MB_TAG_DENSE, moab::MB_TAG_BIT,
moab::MB_TAG_MESH };
int opt_num = -1;
result = opts.match_option( "TAG_STORAGE_TYPE", option_vals, opt_num );
if( MB_FAILURE == result )
ERROR( result, "iMesh_createTagWithOptions: option string not recognized." );
else if( MB_SUCCESS == result )
assert( opt_num >= 0 && opt_num <= 3 );
storage = opt_types[opt_num];
// now look for default value option; reuse storage_type
storage_type.clear();
result = opts.get_option( "TAG_DEFAULT_VALUE", storage_type );
// ok, need to parse the string into a proper default value
switch( tag_type )
case iBase_INTEGER:
result = opts.get_int_option( "TAG_DEFAULT_VALUE", dum_int );
def_int.resize( tag_size );
std::fill( def_int.begin(), def_int.end(), dum_int );
def_val = &def_int[0];
break;
case iBase_DOUBLE:
result = opts.get_real_option( "TAG_DEFAULT_VALUE", dum_dbl );
def_dbl.resize( tag_size );
std::fill( def_dbl.begin(), def_dbl.end(), dum_dbl );
def_val = &def_dbl[0];
break;
case iBase_ENTITY_HANDLE:
// for default handle, will have to use int
if( 0 > dum_int )
ERROR( result, "iMesh_createTagWithOptions: for default handle-type tag, "
"must use non-negative int on input." );
def_handles.resize( tag_size );
std::fill( def_handles.begin(), def_handles.end(), (moab::EntityHandle)dum_int );
def_val = &def_handles[0];
break;
case iBase_BYTES:
if( (int)storage_type.length() < tag_size )
ERROR( result, "iMesh_createTagWithOptions: default value for byte-type "
"tag must be large enough to store tag value." );
def_val = storage_type.c_str();
break;
moab::Tag new_tag;
result = MOABI->tag_get_handle( tmp_tagname.c_str(), tag_size, mb_data_type_table[tag_type], new_tag,
storage | MB_TAG_EXCL, def_val );
if( MB_SUCCESS != result )
std::string msg( "iMesh_createTag: " );
if( MB_ALREADY_ALLOCATED == result )
msg += "Tag already exists with name: \"";
*tag_handle = (iBase_TagHandle)new_tag;
else
msg += "Failed to create tag with name: \"";
msg += tag_name;
msg += "\".";
ERROR( result, msg.c_str() );
if( tag_type == iBase_ENTITY_HANDLE )
MBIMESHI->note_ent_handle_tag( new_tag );
else if( tag_type == iBase_ENTITY_SET_HANDLE )
MBIMESHI->note_set_handle_tag( new_tag );
RETURN( iBase_SUCCESS );
/* old implementation:
Tag new_tag;
int this_size = tag_size;
ErrorCode result = MOABI->tag_get_handle(tmp_tagname.c_str(),
this_size,
new_tag,
MB_TAG_SPARSE|MB_TAG_EXCL);
if (MB_SUCCESS != result) {
std::string msg("iMesh_createTag: ");
if (MB_ALREADY_ALLOCATED == result) {
*tag_handle = (iBase_TagHandle) new_tag;
else
msg += tag_name;
msg += "\".";
ERROR(result,msg.c_str());
if (tag_type == iBase_ENTITY_HANDLE)
else if (tag_type == iBase_ENTITY_SET_HANDLE)
| void iMesh_destroyTag | ( | iMesh_Instance | instance, |
| iBase_TagHandle | tag_handle, | ||
| const int | forced, | ||
| int * | err | ||
Destroy a tag.
Destroy a tag. If forced is non-zero and entities still have values set for this tag, tag is deleted anyway and those values disappear, otherwise tag is not deleted.
| [in] | tag_handle | Handle of tag to be deleted |
| [in] | forced | If non-zero, delete the tag even if entities have values set for the tag. |
Definition at line 1494 of file iMesh_MOAB.cpp.
References CHKERR, moab::Range::empty(), ERROR, ErrorCode, iBase_ERROR_MAP, iBase_TAG_IN_USE, MB_SUCCESS, MB_TAG_NOT_FOUND, MBIMESHI, MBMAXTYPE, MBVERTEX, MOABI, RETURN, TAG_HANDLE, and smoab::UNION.
// might need to check if it's used first
if( false == forced )
Range ents;
ErrorCode result;
Tag this_tag = TAG_HANDLE( tag_handle );
for( EntityType this_type = MBVERTEX; this_type != MBMAXTYPE; this_type++ )
result = MOABI->get_entities_by_type_and_tag( 0, this_type, &this_tag, NULL, 1, ents, Interface::UNION );CHKERR( result, "iMesh_destroyTag: problem finding tag." );
if( !ents.empty() )
ERROR( iBase_TAG_IN_USE, "iMesh_destroyTag: forced=false and entities"
" are still assigned this tag." );
// check if tag value is set on mesh
const void* data_ptr;
EntityHandle root = 0;
result = MOABI->tag_get_by_ptr( this_tag, &root, 1, &data_ptr );
ERROR( iBase_TAG_IN_USE, "iMesh_destroyTag: forced=false and mesh"
" is still assigned this tag." );
// ok, good to go - either forced or no entities with this tag
ErrorCode result = MOABI->tag_delete( TAG_HANDLE( tag_handle ) );
if( MB_SUCCESS != result && MB_TAG_NOT_FOUND != result ) ERROR( result, "iMesh_destroyTag: problem deleting tag." );
if( MB_SUCCESS == result ) MBIMESHI->note_tag_destroyed( TAG_HANDLE( tag_handle ) );
RETURN( iBase_ERROR_MAP[result] );
| void iMesh_getAllEntSetTags | ( | iMesh_Instance | instance, |
| const iBase_EntitySetHandle | entity_set_handle, | ||
| iBase_TagHandle ** | tag_handles, | ||
| int * | tag_handles_allocated, | ||
| int * | tag_handles_size, | ||
| int * | err | ||
| [in] | entity_set_handle | Entity being queried |
| [in,out] | tag_handles | Pointer to array of tag_handles returned from Array pointer, allocated and occupied sizes argument trio) |
| [in,out] | tag_handles_allocated | Pointer to allocated size of tag_handles |
| [out] | tag_handles_size | Pointer to occupied size of tag_handles array |
Definition at line 1765 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, CHKERR, ENTITY_HANDLE, ErrorCode, iBase_SUCCESS, MOABI, remove_var_len_tags(), and RETURN.
EntityHandle eh = ENTITY_HANDLE( entity_set_handle );
std::vector< Tag > all_tags;
ErrorCode result = MOABI->tag_get_tags_on_entity( eh, all_tags );CHKERR( result, "iMesh_entitysetGetAllTagHandles failed." );
remove_var_len_tags( MOABI, all_tags );
// now put those tag handles into sidl array
ALLOC_CHECK_ARRAY_NOFAIL( tag_handles, all_tags.size() );
memcpy( *tag_handles, &all_tags[0], all_tags.size() * sizeof( Tag ) );
*tag_handles_size = (int)all_tags.size();
| void iMesh_getAllIfaceTags | ( | iMesh_Instance | instance, |
| int * | err | ||
Definition at line 1617 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, CHKERR, ErrorCode, iBase_SUCCESS, MOABI, remove_var_len_tags(), and RETURN.
ErrorCode result = MOABI->tag_get_tags( all_tags );CHKERR( result, "iMesh_getAllIfaceTags failed." );
*tag_handles_size = all_tags.size();
| void iMesh_getAllTags | ( | iMesh_Instance | instance, |
| const iBase_EntityHandle | entity_handle, | ||
| int * | err | ||
| [in] | entity_handle | Entity being queried |
Definition at line 2218 of file iMesh_MOAB.cpp.
ErrorCode result = MOABI->tag_get_tags_on_entity( ENTITY_HANDLE( entity_handle ), all_tags );CHKERR( result, "iMesh_getAllTags failed." );
| void iMesh_getTagHandle | ( | iMesh_Instance | instance, |
| int * | err, | ||
| [in] | tag_name | Name of tag being queried |
Definition at line 1591 of file iMesh_MOAB.cpp.
References eatwhitespace(), ERROR, ErrorCode, iBase_SUCCESS, iBase_TAG_NOT_FOUND, MB_SUCCESS, MB_TAG_ANY, MB_TYPE_OPAQUE, MOABI, RETURN, size, and TAG_HANDLE.
ErrorCode result = MOABI->tag_get_handle( tmp_tagname.c_str(), 0, MB_TYPE_OPAQUE, (Tag&)*tag_handle, MB_TAG_ANY );
std::string msg( "iMesh_getTagHandle: problem getting handle for tag named '" );
msg += std::string( tag_name ) + std::string( "'" );
*tag_handle = 0;
// do not return variable-length tags through ITAPS API
int size;
if( MB_SUCCESS != MOABI->tag_get_length( TAG_HANDLE( *tag_handle ), size ) ) RETURN( iBase_TAG_NOT_FOUND );
| void iMesh_getTagName | ( | iMesh_Instance | instance, |
| const iBase_TagHandle | tag_handle, | ||
| char * | name, | ||
| int * | err, | ||
| int | name_len | ||
| [in] | tag_handle | Tag handle being queried |
| [in,out] | name | Pointer to character string to store name returned from |
| [in] | name_len | Length of character string input to function (String Length Arguments) |
Definition at line 1532 of file iMesh_MOAB.cpp.
References CHKERR, ErrorCode, iBase_SUCCESS, MOABI, RETURN, and TAG_HANDLE.
static ::std::string name;
ErrorCode result = MOABI->tag_get_name( TAG_HANDLE( tag_handle ), name );CHKERR( result, "iMesh_getTagName: problem getting name." );
strncpy( out_data, name.c_str(), out_data_len );
| void iMesh_getTagSizeBytes | ( | iMesh_Instance | instance, |
| int * | tag_size, | ||
| int * | err | ||
| [in] | tag_handle | Handle of tag being queried |
| [out] | tag_size | Pointer to tag size returned from function |
Definition at line 1581 of file iMesh_MOAB.cpp.
ErrorCode result = MOABI->tag_get_bytes( TAG_HANDLE( tag_handle ), *tag_size_bytes );CHKERR( result, "iMesh_getTagSize: problem getting size." );
| void iMesh_getTagSizeValues | ( | iMesh_Instance | instance, |
| int * | err | ||
Definition at line 1571 of file iMesh_MOAB.cpp.
ErrorCode result = MOABI->tag_get_length( TAG_HANDLE( tag_handle ), *tag_size_val );CHKERR( result, "iMesh_getTagSize: problem getting size." );
| void iMesh_getTagType | ( | iMesh_Instance | instance, |
| int * | tag_type, | ||
| int * | err | ||
Get the data type of the specified tag handle. Tag type is a value in the iBase_TagType enumeration.
| [in] | tag_handle | Handle for the tag being queried |
| [out] | tag_type | Pointer to tag type returned from function |
Definition at line 1545 of file iMesh_MOAB.cpp.
References check_handle_tag_type(), CHKERR, ErrorCode, iBase_ENTITY_HANDLE, iBase_ENTITY_SET_HANDLE, iBase_SUCCESS, MB_TYPE_HANDLE, MBIMESHI, MOABI, RETURN, TAG_HANDLE, and tstt_data_type_table.
DataType this_type;
ErrorCode result = MOABI->tag_get_data_type( TAG_HANDLE( tag_handle ), this_type );CHKERR( result, "iMesh_getTagType: problem getting type." );
if( this_type != MB_TYPE_HANDLE )
*value_type = tstt_data_type_table[this_type];
else if( MBIMESHI->is_set_handle_tag( TAG_HANDLE( tag_handle ) ) )
*value_type = iBase_ENTITY_SET_HANDLE;
else if( MBIMESHI->is_ent_handle_tag( TAG_HANDLE( tag_handle ) ) )
*value_type = iBase_ENTITY_HANDLE;
else
result = check_handle_tag_type( TAG_HANDLE( tag_handle ), MBIMESHI );CHKERR( result, "iMesh_getTagType: problem guessing handle tag subtype" );
else
| void iMesh_rmvArrTag | ( | iMesh_Instance | instance, |
| const iBase_EntityHandle * | entity_handles, | ||
| const int | entity_handles_size, | ||
| int * | err | ||
| [in] | entity_handles | Entity from which tag is being removed |
| [in] | entity_handles_size | Number of entities in entity array |
| [in] | tag_handle | Tag handle of tag being removed |
Definition at line 2085 of file iMesh_MOAB.cpp.
References CHKNONEMPTY, CONST_HANDLE_ARRAY_PTR, ErrorCode, iBase_ERROR_MAP, iBase_SUCCESS, MB_TAG_NOT_FOUND, MOABI, RETURN, and TAG_HANDLE.
if( 0 == entity_handles_size ) RETURN( iBase_SUCCESS );
CHKNONEMPTY();
ErrorCode result = MOABI->tag_delete_data( TAG_HANDLE( tag_handle ), CONST_HANDLE_ARRAY_PTR( entity_handles ),
entity_handles_size );
// don't return an error if the tag simply wasn't set on the entities
if( MB_TAG_NOT_FOUND == result )
else
| void iMesh_rmvEntSetTag | ( | iMesh_Instance | instance, |
| int * | err | ||
| [in] | entity_set_handle | Entity set from which tag is being removed |
Definition at line 1787 of file iMesh_MOAB.cpp.
References ENTITY_HANDLE, ErrorCode, iBase_ERROR_MAP, iBase_SUCCESS, MB_TAG_NOT_FOUND, MOABI, RETURN, and TAG_HANDLE.
EntityHandle set = ENTITY_HANDLE( entity_set_handle );
ErrorCode result = MOABI->tag_delete_data( TAG_HANDLE( tag_handle ), &set, 1 );
// don't return an error if the tag simply wasn't set on the ent set
else
| void iMesh_rmvTag | ( | iMesh_Instance | instance, |
| int * | err | ||
| [in] | entity_handle | Entity from which tag is being removed |
Definition at line 2239 of file iMesh_MOAB.cpp.
References iMesh_rmvArrTag.
iMesh_rmvArrTag( instance, &entity_handle, 1, tag_handle, err );
