MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include <cmath>
#include <algorithm>
Functions | |
void | test_read_ascii () |
void | test_write_ascii () |
void | test_type_option () |
void | test_detect_type () |
void | test_endian_option () |
void | test_big_endian () |
void | test_little_endian () |
void | test_detect_byte_order () |
void | read_file (Interface &moab, const char *input_file, const char *options="") |
void | convert_file (const char *source_file, const char *dest_file, const char *options="") |
void | check_mesh_is_tet (Interface &moab) |
int | main () |
ErrorCode | read_file_ (Interface &moab, const char *input_file, const char *options="") |
Variables | |
static const char | sample [] = "sample.stl" |
static const char * | tmp_file = "test.stl" |
void check_mesh_is_tet | ( | Interface & | moab | ) |
Definition at line 166 of file stl_test.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, conn, dl, moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), MBENTITYSET, MBTRI, MBVERTEX, moab::Range::size(), and moab::subtract().
Referenced by test_big_endian(), test_little_endian(), test_read_ascii(), and test_write_ascii().
{ ErrorCode rval; Range verts, tris, other; rval = moab.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); rval = moab.get_entities_by_type( 0, MBTRI, tris );CHECK_ERR( rval ); rval = moab.get_entities_by_handle( 0, other );CHECK_ERR( rval ); CHECK_EQUAL( 4, (int)verts.size() ); CHECK_EQUAL( 4, (int)tris.size() ); other = subtract( other, verts ); other = subtract( other, tris ); CHECK( other.all_of_type( MBENTITYSET ) ); const double expt_coords[4][3] = { { 0, 0, 0 }, { 1, 0, 0 }, { 0, 1, 0 }, { 0, 0, 1 } }; EntityHandle vert_handles[4] = { 0, 0, 0, 0 }; for( Range::iterator i = verts.begin(); i != verts.end(); ++i ) { double coords[3]; rval = moab.get_coords( &*i, 1, coords );CHECK_ERR( rval ); bool found = false; for( int j = 0; j < 4; ++j ) { double ds = 0; for( int d = 0; d < 3; ++d ) { double dl = expt_coords[j][d] - coords[d]; ds += dl * dl; } if( ds < 1e-6 ) { CHECK_EQUAL( (EntityHandle)0, vert_handles[j] ); vert_handles[j] = *i; found = true; break; } } CHECK( found ); } const int expt_conn[4][3] = { { 0, 1, 3 }, { 0, 2, 1 }, { 0, 3, 2 }, { 1, 2, 3 } }; EntityHandle tri_handles[4] = { 0, 0, 0, 0 }; for( Range::iterator i = tris.begin(); i != tris.end(); ++i ) { const EntityHandle* conn = 0; int len = 0; rval = moab.get_connectivity( *i, conn, len );CHECK_ERR( rval ); CHECK_EQUAL( 3, len ); int conn_idx[3] = { static_cast< int >( std::find( vert_handles, vert_handles + 4, conn[0] ) - vert_handles ), static_cast< int >( std::find( vert_handles, vert_handles + 4, conn[1] ) - vert_handles ), static_cast< int >( std::find( vert_handles, vert_handles + 4, conn[2] ) - vert_handles ) }; CHECK( conn_idx[0] != 4 ); CHECK( conn_idx[1] != 4 ); CHECK( conn_idx[2] != 4 ); bool found = false; for( int j = 0; j < 4; ++j ) { int k = std::find( expt_conn[j], expt_conn[j] + 3, conn_idx[0] ) - expt_conn[j]; if( k == 3 ) continue; if( expt_conn[j][( k + 1 ) % 3] == conn_idx[1] && expt_conn[j][( k + 2 ) % 3] == conn_idx[2] ) { CHECK_EQUAL( (EntityHandle)0, tri_handles[j] ); tri_handles[j] = *i; found = true; break; } } CHECK( found ); } }
void convert_file | ( | const char * | source_file, |
const char * | dest_file, | ||
const char * | options = "" |
Definition at line 66 of file stl_test.cpp.
References CHECK_ERR, ErrorCode, moab::Core::load_file(), and moab::Core::write_file().
Referenced by test_big_endian(), test_detect_byte_order(), test_detect_type(), test_endian_option(), test_little_endian(), test_type_option(), and test_write_ascii().
{ ErrorCode rval; Core moab; rval = moab.load_file( input_file );CHECK_ERR( rval ); rval = moab.write_file( output_file, "STL", options );CHECK_ERR( rval ); }
int main | ( | ) |
Definition at line 38 of file stl_test.cpp.
References RUN_TEST, test_big_endian(), test_detect_byte_order(), test_detect_type(), test_endian_option(), test_little_endian(), test_read_ascii(), test_type_option(), test_write_ascii(), and tmp_file.
{ int result = 0; result += RUN_TEST( test_read_ascii ); result += RUN_TEST( test_write_ascii ); result += RUN_TEST( test_type_option ); result += RUN_TEST( test_detect_type ); result += RUN_TEST( test_endian_option ); result += RUN_TEST( test_big_endian ); result += RUN_TEST( test_little_endian ); result += RUN_TEST( test_detect_byte_order ); remove( tmp_file ); return result; }
Definition at line 61 of file stl_test.cpp.
References CHECK_ERR, ErrorCode, and read_file_().
{ ErrorCode rval = read_file_( moab, input_file, options );CHECK_ERR( rval ); }
ErrorCode read_file_ | ( | Interface & | moab, |
const char * | input_file, | ||
Definition at line 55 of file stl_test.cpp.
References ErrorCode, and moab::Interface::load_file().
Referenced by read_file(), test_detect_type(), test_endian_option(), and test_type_option().
{ ErrorCode rval = moab.load_file( input_file, 0, options ); return rval; }
void test_big_endian | ( | ) |
Definition at line 135 of file stl_test.cpp.
References check_mesh_is_tet(), convert_file(), read_file(), sample, and tmp_file.
Referenced by main().
{ Core moab; convert_file( sample, tmp_file, "BINARY;BIG_ENDIAN" ); read_file( moab, tmp_file, "BINARY;BIG_ENDIAN" ); check_mesh_is_tet( moab ); remove( tmp_file ); }
void test_detect_byte_order | ( | ) |
Definition at line 153 of file stl_test.cpp.
References convert_file(), read_file(), sample, and tmp_file.
void test_detect_type | ( | ) |
Definition at line 107 of file stl_test.cpp.
References convert_file(), read_file(), read_file_(), sample, and tmp_file.
{ Core moab; read_file( moab, sample ); convert_file( sample, tmp_file, "BINARY" ); read_file_( moab, tmp_file ); remove( tmp_file ); }
void test_endian_option | ( | ) |
Definition at line 119 of file stl_test.cpp.
References CHECK, convert_file(), ErrorCode, MB_SUCCESS, read_file_(), sample, and tmp_file.
{ ErrorCode rval; Core moab; convert_file( sample, tmp_file, "BINARY;BIG_ENDIAN" ); rval = read_file_( moab, tmp_file, "BINARY;LITTLE_ENDIAN" ); CHECK( MB_SUCCESS != rval ); convert_file( sample, tmp_file, "BINARY;LITTLE_ENDIAN" ); rval = read_file_( moab, tmp_file, "BINARY;BIG_ENDIAN" ); CHECK( MB_SUCCESS != rval ); remove( tmp_file ); }
void test_little_endian | ( | ) |
Definition at line 144 of file stl_test.cpp.
{ Core moab; convert_file( sample, tmp_file, "BINARY;LITTLE_ENDIAN" ); read_file( moab, tmp_file, "BINARY;LITTLE_ENDIAN" ); check_mesh_is_tet( moab ); remove( tmp_file ); }
void test_read_ascii | ( | ) |
Definition at line 76 of file stl_test.cpp.
References check_mesh_is_tet(), read_file(), and sample.
{ Core moab; read_file( moab, sample, "ASCII" ); check_mesh_is_tet( moab ); }
void test_type_option | ( | ) |
Definition at line 92 of file stl_test.cpp.
{ ErrorCode rval; Core moab; rval = read_file_( moab, sample, "BINARY" ); CHECK( MB_SUCCESS != rval ); convert_file( sample, tmp_file, "BINARY" ); rval = read_file_( moab, tmp_file, "ASCII" ); CHECK( MB_SUCCESS != rval ); remove( tmp_file ); }
void test_write_ascii | ( | ) |
Definition at line 83 of file stl_test.cpp.
{ convert_file( sample, tmp_file, "ASCII" ); Core moab; read_file( moab, tmp_file, "ASCII" ); remove( tmp_file ); check_mesh_is_tet( moab ); }
const char sample[] = "sample.stl" [static] |
Definition at line 17 of file stl_test.cpp.
Referenced by MBMesquite::MsqMeshEntity::check_element_orientation(), MBMesquite::IdealShapeTarget::get_2D_target(), FakeTargetCalc::get_2D_target(), MBMesquite::IdealShapeTarget::get_3D_target(), FakeTargetCalc::get_3D_target(), FakeTargetCalc::get_surface_target(), FakeTargetCalc::get_weight(), MBMesquite::MsqMeshEntity::inverted_jacobian_2d(), MBMesquite::MsqMeshEntity::inverted_jacobian_3d(), MBMesquite::MeshUtil::lambda_distribution(), test_big_endian(), test_detect_byte_order(), test_detect_type(), test_endian_option(), test_little_endian(), test_read_ascii(), test_type_option(), and test_write_ascii().
const char* tmp_file = "test.stl" [static] |
Definition at line 21 of file stl_test.cpp.
Referenced by main(), mb_skin_verts_common(), test_big_endian(), test_detect_byte_order(), test_detect_type(), test_endian_option(), test_little_endian(), test_type_option(), test_write_ascii(), and write_and_read().
