MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** @example SetsNTags.cpp 00002 * Description: Get the sets representing materials and Dirichlet/Neumann boundary conditions and 00003 * list their contents.\n This example shows how to get entity sets, and tags on those sets. 00004 * 00005 * To run: ./SetsNTags [meshfile]\n 00006 * (default values can run if users don't specify a mesh file) 00007 */ 00008 00009 #include "moab/Core.hpp" 00010 #include "moab/Interface.hpp" 00011 #include "moab/Range.hpp" 00012 #include "MBTagConventions.hpp" 00013 00014 #include <iostream> 00015 00016 using namespace moab; 00017 using namespace std; 00018 00019 #ifndef MESH_DIR 00020 #define MESH_DIR "." 00021 #endif 00022 00023 string test_file_name = string( MESH_DIR ) + string( "/hex01.vtk" ); 00024 00025 // Tag names for these conventional tags come from MBTagConventions.hpp 00026 const char* tag_nms[] = { MATERIAL_SET_TAG_NAME, DIRICHLET_SET_TAG_NAME, NEUMANN_SET_TAG_NAME }; 00027 00028 int main( int argc, char** argv ) 00029 { 00030 // Get the material set tag handle 00031 Tag mtag; 00032 ErrorCode rval; 00033 Range sets, set_ents; 00034 00035 // Get MOAB instance 00036 Interface* mb = new( std::nothrow ) Core; 00037 if( NULL == mb ) return 1; 00038 00039 // Need option handling here for input filename 00040 if( argc > 1 ) 00041 { 00042 // User has input a mesh file 00043 test_file_name = argv[1]; 00044 } 00045 00046 // Load a file 00047 rval = mb->load_file( test_file_name.c_str() );MB_CHK_ERR( rval ); 00048 00049 // Loop over set types 00050 for( int i = 0; i < 3; i++ ) 00051 { 00052 // Get the tag handle for this tag name; tag should already exist (it was created during 00053 // file read) 00054 rval = mb->tag_get_handle( tag_nms[i], 1, MB_TYPE_INTEGER, mtag );MB_CHK_ERR( rval ); 00055 00056 // Get all the sets having that tag (with any value for that tag) 00057 sets.clear(); 00058 rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &mtag, NULL, 1, sets );MB_CHK_ERR( rval ); 00059 00060 // Iterate over each set, getting the entities and printing them 00061 Range::iterator set_it; 00062 for( set_it = sets.begin(); set_it != sets.end(); ++set_it ) 00063 { 00064 // Get the id for this set 00065 int set_id; 00066 rval = mb->tag_get_data( mtag, &( *set_it ), 1, &set_id );MB_CHK_ERR( rval ); 00067 00068 // Get the entities in the set, recursively 00069 rval = mb->get_entities_by_handle( *set_it, set_ents, true );MB_CHK_ERR( rval ); 00070 00071 cout << tag_nms[i] << " " << set_id << " has " << set_ents.size() << " entities:" << endl; 00072 set_ents.print( " " ); 00073 set_ents.clear(); 00074 } 00075 } 00076 00077 delete mb; 00078 00079 return 0; 00080 }
