MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2015 Gael Guennebaud <[email protected]> 00005 // 00006 // This Source Code Form is subject to the terms of the Mozilla 00007 // Public License v. 2.0. If a copy of the MPL was not distributed 00008 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00009 00010 #ifndef EIGEN_SPARSE_COMPRESSED_BASE_H 00011 #define EIGEN_SPARSE_COMPRESSED_BASE_H 00012 00013 namespace Eigen { 00014 00015 template<typename Derived> class SparseCompressedBase; 00016 00017 namespace internal { 00018 00019 template<typename Derived> 00020 struct traits<SparseCompressedBase<Derived> > : traits<Derived> 00021 {}; 00022 00023 } // end namespace internal 00024 00035 template<typename Derived> 00036 class SparseCompressedBase 00037 : public SparseMatrixBase<Derived> 00038 { 00039 public: 00040 typedef SparseMatrixBase<Derived> Base; 00041 EIGEN_SPARSE_PUBLIC_INTERFACE(SparseCompressedBase) 00042 using Base::operator=; 00043 using Base::IsRowMajor; 00044 00045 class InnerIterator; 00046 class ReverseInnerIterator; 00047 00048 protected: 00049 typedef typename Base::IndexVector IndexVector; 00050 Eigen::Map<IndexVector> innerNonZeros() { return Eigen::Map<IndexVector>(innerNonZeroPtr(), isCompressed()?0:derived().outerSize()); } 00051 const Eigen::Map<const IndexVector> innerNonZeros() const { return Eigen::Map<const IndexVector>(innerNonZeroPtr(), isCompressed()?0:derived().outerSize()); } 00052 00053 public: 00054 00056 inline Index nonZeros() const 00057 { 00058 if(Derived::IsVectorAtCompileTime && outerIndexPtr()==0) 00059 return derived().nonZeros(); 00060 else if(isCompressed()) 00061 return outerIndexPtr()[derived().outerSize()]-outerIndexPtr()[0]; 00062 else if(derived().outerSize()==0) 00063 return 0; 00064 else 00065 return innerNonZeros().sum(); 00066 } 00067 00071 inline const Scalar* valuePtr() const { return derived().valuePtr(); } 00075 inline Scalar* valuePtr() { return derived().valuePtr(); } 00076 00080 inline const StorageIndex* innerIndexPtr() const { return derived().innerIndexPtr(); } 00084 inline StorageIndex* innerIndexPtr() { return derived().innerIndexPtr(); } 00085 00090 inline const StorageIndex* outerIndexPtr() const { return derived().outerIndexPtr(); } 00095 inline StorageIndex* outerIndexPtr() { return derived().outerIndexPtr(); } 00096 00100 inline const StorageIndex* innerNonZeroPtr() const { return derived().innerNonZeroPtr(); } 00104 inline StorageIndex* innerNonZeroPtr() { return derived().innerNonZeroPtr(); } 00105 00107 inline bool isCompressed() const { return innerNonZeroPtr()==0; } 00108 00109 protected: 00111 SparseCompressedBase() {} 00112 private: 00113 template<typename OtherDerived> explicit SparseCompressedBase(const SparseCompressedBase<OtherDerived>&); 00114 }; 00115 00116 template<typename Derived> 00117 class SparseCompressedBase<Derived>::InnerIterator 00118 { 00119 public: 00120 InnerIterator() 00121 : m_values(0), m_indices(0), m_outer(0), m_id(0), m_end(0) 00122 {} 00123 00124 InnerIterator(const InnerIterator& other) 00125 : m_values(other.m_values), m_indices(other.m_indices), m_outer(other.m_outer), m_id(other.m_id), m_end(other.m_end) 00126 {} 00127 00128 InnerIterator& operator=(const InnerIterator& other) 00129 { 00130 m_values = other.m_values; 00131 m_indices = other.m_indices; 00132 const_cast<OuterType&>(m_outer).setValue(other.m_outer.value()); 00133 m_id = other.m_id; 00134 m_end = other.m_end; 00135 return *this; 00136 } 00137 00138 InnerIterator(const SparseCompressedBase& mat, Index outer) 00139 : m_values(mat.valuePtr()), m_indices(mat.innerIndexPtr()), m_outer(outer) 00140 { 00141 if(Derived::IsVectorAtCompileTime && mat.outerIndexPtr()==0) 00142 { 00143 m_id = 0; 00144 m_end = mat.nonZeros(); 00145 } 00146 else 00147 { 00148 m_id = mat.outerIndexPtr()[outer]; 00149 if(mat.isCompressed()) 00150 m_end = mat.outerIndexPtr()[outer+1]; 00151 else 00152 m_end = m_id + mat.innerNonZeroPtr()[outer]; 00153 } 00154 } 00155 00156 explicit InnerIterator(const SparseCompressedBase& mat) 00157 : m_values(mat.valuePtr()), m_indices(mat.innerIndexPtr()), m_outer(0), m_id(0), m_end(mat.nonZeros()) 00158 { 00159 EIGEN_STATIC_ASSERT_VECTOR_ONLY(Derived); 00160 } 00161 00162 explicit InnerIterator(const internal::CompressedStorage<Scalar,StorageIndex>& data) 00163 : m_values(data.valuePtr()), m_indices(data.indexPtr()), m_outer(0), m_id(0), m_end(data.size()) 00164 { 00165 EIGEN_STATIC_ASSERT_VECTOR_ONLY(Derived); 00166 } 00167 00168 inline InnerIterator& operator++() { m_id++; return *this; } 00169 00170 inline const Scalar& value() const { return m_values[m_id]; } 00171 inline Scalar& valueRef() { return const_cast<Scalar&>(m_values[m_id]); } 00172 00173 inline StorageIndex index() const { return m_indices[m_id]; } 00174 inline Index outer() const { return m_outer.value(); } 00175 inline Index row() const { return IsRowMajor ? m_outer.value() : index(); } 00176 inline Index col() const { return IsRowMajor ? index() : m_outer.value(); } 00177 00178 inline operator bool() const { return (m_id < m_end); } 00179 00180 protected: 00181 const Scalar* m_values; 00182 const StorageIndex* m_indices; 00183 typedef internal::variable_if_dynamic<Index,Derived::IsVectorAtCompileTime?0:Dynamic> OuterType; 00184 const OuterType m_outer; 00185 Index m_id; 00186 Index m_end; 00187 private: 00188 // If you get here, then you're not using the right InnerIterator type, e.g.: 00189 // SparseMatrix<double,RowMajor> A; 00190 // SparseMatrix<double>::InnerIterator it(A,0); 00191 template<typename T> InnerIterator(const SparseMatrixBase<T>&, Index outer); 00192 }; 00193 00194 template<typename Derived> 00195 class SparseCompressedBase<Derived>::ReverseInnerIterator 00196 { 00197 public: 00198 ReverseInnerIterator(const SparseCompressedBase& mat, Index outer) 00199 : m_values(mat.valuePtr()), m_indices(mat.innerIndexPtr()), m_outer(outer) 00200 { 00201 if(Derived::IsVectorAtCompileTime && mat.outerIndexPtr()==0) 00202 { 00203 m_start = 0; 00204 m_id = mat.nonZeros(); 00205 } 00206 else 00207 { 00208 m_start.value() = mat.outerIndexPtr()[outer]; 00209 if(mat.isCompressed()) 00210 m_id = mat.outerIndexPtr()[outer+1]; 00211 else 00212 m_id = m_start.value() + mat.innerNonZeroPtr()[outer]; 00213 } 00214 } 00215 00216 explicit ReverseInnerIterator(const SparseCompressedBase& mat) 00217 : m_values(mat.valuePtr()), m_indices(mat.innerIndexPtr()), m_outer(0), m_start(0), m_id(mat.nonZeros()) 00218 { 00219 EIGEN_STATIC_ASSERT_VECTOR_ONLY(Derived); 00220 } 00221 00222 explicit ReverseInnerIterator(const internal::CompressedStorage<Scalar,StorageIndex>& data) 00223 : m_values(data.valuePtr()), m_indices(data.indexPtr()), m_outer(0), m_start(0), m_id(data.size()) 00224 { 00225 EIGEN_STATIC_ASSERT_VECTOR_ONLY(Derived); 00226 } 00227 00228 inline ReverseInnerIterator& operator--() { --m_id; return *this; } 00229 00230 inline const Scalar& value() const { return m_values[m_id-1]; } 00231 inline Scalar& valueRef() { return const_cast<Scalar&>(m_values[m_id-1]); } 00232 00233 inline StorageIndex index() const { return m_indices[m_id-1]; } 00234 inline Index outer() const { return m_outer.value(); } 00235 inline Index row() const { return IsRowMajor ? m_outer.value() : index(); } 00236 inline Index col() const { return IsRowMajor ? index() : m_outer.value(); } 00237 00238 inline operator bool() const { return (m_id > m_start.value()); } 00239 00240 protected: 00241 const Scalar* m_values; 00242 const StorageIndex* m_indices; 00243 const internal::variable_if_dynamic<Index,Derived::IsVectorAtCompileTime?0:Dynamic> m_outer; 00244 Index m_id; 00245 const internal::variable_if_dynamic<Index,Derived::IsVectorAtCompileTime?0:Dynamic> m_start; 00246 }; 00247 00248 namespace internal { 00249 00250 template<typename Derived> 00251 struct evaluator<SparseCompressedBase<Derived> > 00252 : evaluator_base<Derived> 00253 { 00254 typedef typename Derived::Scalar Scalar; 00255 typedef typename Derived::InnerIterator InnerIterator; 00256 typedef typename Derived::ReverseInnerIterator ReverseInnerIterator; 00257 00258 enum { 00259 CoeffReadCost = NumTraits<Scalar>::ReadCost, 00260 Flags = Derived::Flags 00261 }; 00262 00263 evaluator() : m_matrix(0) 00264 { 00265 EIGEN_INTERNAL_CHECK_COST_VALUE(CoeffReadCost); 00266 } 00267 explicit evaluator(const Derived &mat) : m_matrix(&mat) 00268 { 00269 EIGEN_INTERNAL_CHECK_COST_VALUE(CoeffReadCost); 00270 } 00271 00272 inline Index nonZerosEstimate() const { 00273 return m_matrix->nonZeros(); 00274 } 00275 00276 operator Derived&() { return m_matrix->const_cast_derived(); } 00277 operator const Derived&() const { return *m_matrix; } 00278 00279 typedef typename DenseCoeffsBase<Derived,ReadOnlyAccessors>::CoeffReturnType CoeffReturnType; 00280 Scalar coeff(Index row, Index col) const 00281 { return m_matrix->coeff(row,col); } 00282 00283 Scalar& coeffRef(Index row, Index col) 00284 { 00285 eigen_internal_assert(row>=0 && row<m_matrix->rows() && col>=0 && col<m_matrix->cols()); 00286 00287 const Index outer = Derived::IsRowMajor ? row : col; 00288 const Index inner = Derived::IsRowMajor ? col : row; 00289 00290 Index start = m_matrix->outerIndexPtr()[outer]; 00291 Index end = m_matrix->isCompressed() ? m_matrix->outerIndexPtr()[outer+1] : m_matrix->outerIndexPtr()[outer] + m_matrix->innerNonZeroPtr()[outer]; 00292 eigen_assert(end>start && "you are using a non finalized sparse matrix or written coefficient does not exist"); 00293 const Index p = std::lower_bound(m_matrix->innerIndexPtr()+start, m_matrix->innerIndexPtr()+end,inner) 00294 - m_matrix->innerIndexPtr(); 00295 eigen_assert((p<end) && (m_matrix->innerIndexPtr()[p]==inner) && "written coefficient does not exist"); 00296 return m_matrix->const_cast_derived().valuePtr()[p]; 00297 } 00298 00299 const Derived *m_matrix; 00300 }; 00301 00302 } 00303 00304 } // end namespace Eigen 00305 00306 #endif // EIGEN_SPARSE_COMPRESSED_BASE_H
