MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2012 Désiré Nuentsa-Wakam <[email protected]> 00005 // Copyright (C) 2012 Gael Guennebaud <[email protected]> 00006 // 00007 // This Source Code Form is subject to the terms of the Mozilla 00008 // Public License v. 2.0. If a copy of the MPL was not distributed 00009 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00010 00011 /* 00012 00013 * NOTE: This file is the modified version of [s,d,c,z]panel_bmod.c file in SuperLU 00014 00015 * -- SuperLU routine (version 3.0) -- 00016 * Univ. of California Berkeley, Xerox Palo Alto Research Center, 00017 * and Lawrence Berkeley National Lab. 00018 * October 15, 2003 00019 * 00020 * Copyright (c) 1994 by Xerox Corporation. All rights reserved. 00021 * 00022 * THIS MATERIAL IS PROVIDED AS IS, WITH ABSOLUTELY NO WARRANTY 00023 * EXPRESSED OR IMPLIED. ANY USE IS AT YOUR OWN RISK. 00024 * 00025 * Permission is hereby granted to use or copy this program for any 00026 * purpose, provided the above notices are retained on all copies. 00027 * Permission to modify the code and to distribute modified code is 00028 * granted, provided the above notices are retained, and a notice that 00029 * the code was modified is included with the above copyright notice. 00030 */ 00031 #ifndef SPARSELU_PANEL_BMOD_H 00032 #define SPARSELU_PANEL_BMOD_H 00033 00034 namespace Eigen { 00035 namespace internal { 00036 00055 template <typename Scalar, typename StorageIndex> 00056 void SparseLUImpl<Scalar,StorageIndex>::panel_bmod(const Index m, const Index w, const Index jcol, 00057 const Index nseg, ScalarVector& dense, ScalarVector& tempv, 00058 IndexVector& segrep, IndexVector& repfnz, GlobalLU_t& glu) 00059 { 00060 00061 Index ksub,jj,nextl_col; 00062 Index fsupc, nsupc, nsupr, nrow; 00063 Index krep, kfnz; 00064 Index lptr; // points to the row subscripts of a supernode 00065 Index luptr; // ... 00066 Index segsize,no_zeros ; 00067 // For each nonz supernode segment of U[*,j] in topological order 00068 Index k = nseg - 1; 00069 const Index PacketSize = internal::packet_traits<Scalar>::size; 00070 00071 for (ksub = 0; ksub < nseg; ksub++) 00072 { // For each updating supernode 00073 /* krep = representative of current k-th supernode 00074 * fsupc = first supernodal column 00075 * nsupc = number of columns in a supernode 00076 * nsupr = number of rows in a supernode 00077 */ 00078 krep = segrep(k); k--; 00079 fsupc = glu.xsup(glu.supno(krep)); 00080 nsupc = krep - fsupc + 1; 00081 nsupr = glu.xlsub(fsupc+1) - glu.xlsub(fsupc); 00082 nrow = nsupr - nsupc; 00083 lptr = glu.xlsub(fsupc); 00084 00085 // loop over the panel columns to detect the actual number of columns and rows 00086 Index u_rows = 0; 00087 Index u_cols = 0; 00088 for (jj = jcol; jj < jcol + w; jj++) 00089 { 00090 nextl_col = (jj-jcol) * m; 00091 VectorBlock<IndexVector> repfnz_col(repfnz, nextl_col, m); // First nonzero column index for each row 00092 00093 kfnz = repfnz_col(krep); 00094 if ( kfnz == emptyIdxLU ) 00095 continue; // skip any zero segment 00096 00097 segsize = krep - kfnz + 1; 00098 u_cols++; 00099 u_rows = (std::max)(segsize,u_rows); 00100 } 00101 00102 if(nsupc >= 2) 00103 { 00104 Index ldu = internal::first_multiple<Index>(u_rows, PacketSize); 00105 Map<ScalarMatrix, Aligned, OuterStride<> > U(tempv.data(), u_rows, u_cols, OuterStride<>(ldu)); 00106 00107 // gather U 00108 Index u_col = 0; 00109 for (jj = jcol; jj < jcol + w; jj++) 00110 { 00111 nextl_col = (jj-jcol) * m; 00112 VectorBlock<IndexVector> repfnz_col(repfnz, nextl_col, m); // First nonzero column index for each row 00113 VectorBlock<ScalarVector> dense_col(dense, nextl_col, m); // Scatter/gather entire matrix column from/to here 00114 00115 kfnz = repfnz_col(krep); 00116 if ( kfnz == emptyIdxLU ) 00117 continue; // skip any zero segment 00118 00119 segsize = krep - kfnz + 1; 00120 luptr = glu.xlusup(fsupc); 00121 no_zeros = kfnz - fsupc; 00122 00123 Index isub = lptr + no_zeros; 00124 Index off = u_rows-segsize; 00125 for (Index i = 0; i < off; i++) U(i,u_col) = 0; 00126 for (Index i = 0; i < segsize; i++) 00127 { 00128 Index irow = glu.lsub(isub); 00129 U(i+off,u_col) = dense_col(irow); 00130 ++isub; 00131 } 00132 u_col++; 00133 } 00134 // solve U = A^-1 U 00135 luptr = glu.xlusup(fsupc); 00136 Index lda = glu.xlusup(fsupc+1) - glu.xlusup(fsupc); 00137 no_zeros = (krep - u_rows + 1) - fsupc; 00138 luptr += lda * no_zeros + no_zeros; 00139 MappedMatrixBlock A(glu.lusup.data()+luptr, u_rows, u_rows, OuterStride<>(lda) ); 00140 U = A.template triangularView<UnitLower>().solve(U); 00141 00142 // update 00143 luptr += u_rows; 00144 MappedMatrixBlock B(glu.lusup.data()+luptr, nrow, u_rows, OuterStride<>(lda) ); 00145 eigen_assert(tempv.size()>w*ldu + nrow*w + 1); 00146 00147 Index ldl = internal::first_multiple<Index>(nrow, PacketSize); 00148 Index offset = (PacketSize-internal::first_default_aligned(B.data(), PacketSize)) % PacketSize; 00149 MappedMatrixBlock L(tempv.data()+w*ldu+offset, nrow, u_cols, OuterStride<>(ldl)); 00150 00151 L.setZero(); 00152 internal::sparselu_gemm<Scalar>(L.rows(), L.cols(), B.cols(), B.data(), B.outerStride(), U.data(), U.outerStride(), L.data(), L.outerStride()); 00153 00154 // scatter U and L 00155 u_col = 0; 00156 for (jj = jcol; jj < jcol + w; jj++) 00157 { 00158 nextl_col = (jj-jcol) * m; 00159 VectorBlock<IndexVector> repfnz_col(repfnz, nextl_col, m); // First nonzero column index for each row 00160 VectorBlock<ScalarVector> dense_col(dense, nextl_col, m); // Scatter/gather entire matrix column from/to here 00161 00162 kfnz = repfnz_col(krep); 00163 if ( kfnz == emptyIdxLU ) 00164 continue; // skip any zero segment 00165 00166 segsize = krep - kfnz + 1; 00167 no_zeros = kfnz - fsupc; 00168 Index isub = lptr + no_zeros; 00169 00170 Index off = u_rows-segsize; 00171 for (Index i = 0; i < segsize; i++) 00172 { 00173 Index irow = glu.lsub(isub++); 00174 dense_col(irow) = U.coeff(i+off,u_col); 00175 U.coeffRef(i+off,u_col) = 0; 00176 } 00177 00178 // Scatter l into SPA dense[] 00179 for (Index i = 0; i < nrow; i++) 00180 { 00181 Index irow = glu.lsub(isub++); 00182 dense_col(irow) -= L.coeff(i,u_col); 00183 L.coeffRef(i,u_col) = 0; 00184 } 00185 u_col++; 00186 } 00187 } 00188 else // level 2 only 00189 { 00190 // Sequence through each column in the panel 00191 for (jj = jcol; jj < jcol + w; jj++) 00192 { 00193 nextl_col = (jj-jcol) * m; 00194 VectorBlock<IndexVector> repfnz_col(repfnz, nextl_col, m); // First nonzero column index for each row 00195 VectorBlock<ScalarVector> dense_col(dense, nextl_col, m); // Scatter/gather entire matrix column from/to here 00196 00197 kfnz = repfnz_col(krep); 00198 if ( kfnz == emptyIdxLU ) 00199 continue; // skip any zero segment 00200 00201 segsize = krep - kfnz + 1; 00202 luptr = glu.xlusup(fsupc); 00203 00204 Index lda = glu.xlusup(fsupc+1)-glu.xlusup(fsupc);// nsupr 00205 00206 // Perform a trianglar solve and block update, 00207 // then scatter the result of sup-col update to dense[] 00208 no_zeros = kfnz - fsupc; 00209 if(segsize==1) LU_kernel_bmod<1>::run(segsize, dense_col, tempv, glu.lusup, luptr, lda, nrow, glu.lsub, lptr, no_zeros); 00210 else if(segsize==2) LU_kernel_bmod<2>::run(segsize, dense_col, tempv, glu.lusup, luptr, lda, nrow, glu.lsub, lptr, no_zeros); 00211 else if(segsize==3) LU_kernel_bmod<3>::run(segsize, dense_col, tempv, glu.lusup, luptr, lda, nrow, glu.lsub, lptr, no_zeros); 00212 else LU_kernel_bmod<Dynamic>::run(segsize, dense_col, tempv, glu.lusup, luptr, lda, nrow, glu.lsub, lptr, no_zeros); 00213 } // End for each column in the panel 00214 } 00215 00216 } // End for each updating supernode 00217 } // end panel bmod 00218 00219 } // end namespace internal 00220 00221 } // end namespace Eigen 00222 00223 #endif // SPARSELU_PANEL_BMOD_H
