MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Lawrence Livermore National Laboratory. Under 00005 the terms of Contract B545069 with the University of Wisconsin -- 00006 Madison, Lawrence Livermore National Laboratory retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file TagVertexMeshTest.cpp 00028 * \brief unit tests for TagVertexMesh class 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "TagVertexMesh.hpp" 00034 #include "MsqError.hpp" 00035 #include "UnitUtil.hpp" 00036 #include "MeshImpl.hpp" 00037 #include "MsqVertex.hpp" 00038 #include "InstructionQueue.hpp" 00039 #include <cppunit/extensions/HelperMacros.h> 00040 #include <stdio.h> 00041 00042 using namespace MBMesquite; 00043 00044 const char TEMP_FILE_NAME[] = "TagVertexMesh.vtk"; 00045 00046 class TagVertexMeshTest : public CppUnit::TestFixture 00047 { 00048 private: 00049 CPPUNIT_TEST_SUITE( TagVertexMeshTest ); 00050 CPPUNIT_TEST( test_vertex_coordinates ); 00051 CPPUNIT_TEST( test_save_coordinates ); 00052 CPPUNIT_TEST( test_cleanup ); 00053 CPPUNIT_TEST( test_alternate_name ); 00054 CPPUNIT_TEST( test_reference_mesh ); 00055 CPPUNIT_TEST_SUITE_END(); 00056 00057 MeshImpl* realMesh; 00058 00059 public: 00060 TagVertexMeshTest() : realMesh( 0 ) {} 00061 00062 void setUp(); 00063 void tearDown(); 00064 00065 void test_vertex_coordinates(); 00066 void test_save_coordinates(); 00067 void test_cleanup(); 00068 void test_alternate_name(); 00069 void test_reference_mesh(); 00070 }; 00071 00072 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( TagVertexMeshTest, "TagVertexMeshTest" ); 00073 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( TagVertexMeshTest, "Unit" ); 00074 00075 void TagVertexMeshTest::setUp() 00076 { 00077 const char vtk_data[] = "# vtk DataFile Version 2.0\n" 00078 "test mesh\n" 00079 "ASCII\n" 00080 "DATASET UNSTRUCTURED_GRID\n" 00081 "POINTS 3 float\n" 00082 "0 0 0\n" 00083 "1 0 0\n" 00084 "0 1 0\n" 00085 "CELLS 1 4\n" 00086 "3 0 1 2\n" 00087 "CELL_TYPES 1\n" 00088 "5\n"; 00089 00090 FILE* file = fopen( TEMP_FILE_NAME, "w" ); 00091 CPPUNIT_ASSERT( !!file ); 00092 size_t r = fwrite( vtk_data, sizeof( vtk_data ) - 1, 1, file ); 00093 fclose( file ); 00094 CPPUNIT_ASSERT( r == 1 ); 00095 00096 MsqPrintError err( std::cerr ); 00097 realMesh = new MeshImpl; 00098 realMesh->read_vtk( TEMP_FILE_NAME, err ); 00099 remove( TEMP_FILE_NAME ); 00100 ASSERT_NO_ERROR( err ); 00101 } 00102 00103 void TagVertexMeshTest::tearDown() 00104 { 00105 delete realMesh; 00106 realMesh = 0; 00107 } 00108 00109 void TagVertexMeshTest::test_vertex_coordinates() 00110 { 00111 MsqPrintError err( std::cerr ); 00112 TagVertexMesh tag_mesh( err, realMesh, true ); 00113 ASSERT_NO_ERROR( err ); 00114 00115 std::vector< Mesh::VertexHandle > vertices; 00116 realMesh->get_all_vertices( vertices, err ); 00117 ASSERT_NO_ERROR( err ); 00118 00119 // Check that initial position for vertex matches that of real mesh 00120 Mesh::VertexHandle vertex = vertices[0]; 00121 MsqVertex get_coords; 00122 Vector3D orig_coords, real_coords, tag_coords; 00123 realMesh->vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00124 ASSERT_NO_ERROR( err ); 00125 orig_coords = get_coords; 00126 tag_mesh.vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00127 ASSERT_NO_ERROR( err ); 00128 tag_coords = get_coords; 00129 CPPUNIT_ASSERT_VECTORS_EQUAL( orig_coords, tag_coords, DBL_EPSILON ); 00130 00131 // Check that modified vertex coords show up in tag mesh but not 00132 // real mesh. 00133 Vector3D new_coords( 5, 5, 5 ); 00134 tag_mesh.vertex_set_coordinates( vertex, new_coords, err ); 00135 ASSERT_NO_ERROR( err ); 00136 tag_mesh.vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00137 ASSERT_NO_ERROR( err ); 00138 tag_coords = get_coords; 00139 CPPUNIT_ASSERT_VECTORS_EQUAL( new_coords, tag_coords, DBL_EPSILON ); 00140 realMesh->vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00141 ASSERT_NO_ERROR( err ); 00142 real_coords = get_coords; 00143 CPPUNIT_ASSERT_VECTORS_EQUAL( orig_coords, real_coords, DBL_EPSILON ); 00144 } 00145 00146 void TagVertexMeshTest::test_save_coordinates() 00147 { 00148 MsqPrintError err( std::cerr ); 00149 Vector3D new_coords( 5, 5, 5 ); 00150 MsqVertex get_coords; 00151 00152 std::vector< Mesh::VertexHandle > vertices; 00153 realMesh->get_all_vertices( vertices, err ); 00154 ASSERT_NO_ERROR( err ); 00155 Mesh::VertexHandle vertex = vertices[0]; 00156 00157 realMesh->vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00158 ASSERT_NO_ERROR( err ); 00159 Vector3D orig_coords = get_coords; 00160 00161 // modify a vertex in the tag interface 00162 { 00163 TagVertexMesh tag_mesh( err, realMesh, false ); 00164 ASSERT_NO_ERROR( err ); 00165 tag_mesh.vertex_set_coordinates( vertex, new_coords, err ); 00166 ASSERT_NO_ERROR( err ); 00167 } 00168 00169 // check that it exists in a new TagVertexMesh 00170 { 00171 TagVertexMesh tag_mesh( err, realMesh, false ); 00172 ASSERT_NO_ERROR( err ); 00173 tag_mesh.vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00174 ASSERT_NO_ERROR( err ); 00175 CPPUNIT_ASSERT_VECTORS_EQUAL( new_coords, get_coords, DBL_EPSILON ); 00176 } 00177 } 00178 00179 void TagVertexMeshTest::test_cleanup() 00180 { 00181 MsqPrintError err( std::cerr ); 00182 Vector3D new_coords( 5, 5, 5 ); 00183 MsqVertex get_coords; 00184 00185 std::vector< Mesh::VertexHandle > vertices; 00186 realMesh->get_all_vertices( vertices, err ); 00187 ASSERT_NO_ERROR( err ); 00188 Mesh::VertexHandle vertex = vertices[0]; 00189 00190 realMesh->vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00191 ASSERT_NO_ERROR( err ); 00192 Vector3D orig_coords = get_coords; 00193 00194 // modify a vertex in the tag interface 00195 { 00196 TagVertexMesh tag_mesh( err, realMesh, true ); 00197 ASSERT_NO_ERROR( err ); 00198 tag_mesh.vertex_set_coordinates( vertex, new_coords, err ); 00199 ASSERT_NO_ERROR( err ); 00200 } 00201 00202 // check that values were cleaned up when previous instance was destroyed 00203 { 00204 TagVertexMesh tag_mesh( err, realMesh, false ); 00205 ASSERT_NO_ERROR( err ); 00206 tag_mesh.vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00207 ASSERT_NO_ERROR( err ); 00208 CPPUNIT_ASSERT_VECTORS_EQUAL( orig_coords, get_coords, DBL_EPSILON ); 00209 } 00210 } 00211 00212 void TagVertexMeshTest::test_alternate_name() 00213 { 00214 MsqPrintError err( std::cerr ); 00215 Vector3D new_coords( 5, 5, 5 ); 00216 MsqVertex get_coords; 00217 00218 std::vector< Mesh::VertexHandle > vertices; 00219 realMesh->get_all_vertices( vertices, err ); 00220 ASSERT_NO_ERROR( err ); 00221 Mesh::VertexHandle vertex = vertices[0]; 00222 00223 realMesh->vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00224 ASSERT_NO_ERROR( err ); 00225 Vector3D orig_coords = get_coords; 00226 00227 // modify a vertex in the tag interface and save it 00228 { 00229 TagVertexMesh tag_mesh( err, realMesh, false, "foobar" ); 00230 ASSERT_NO_ERROR( err ); 00231 tag_mesh.vertex_set_coordinates( vertex, new_coords, err ); 00232 ASSERT_NO_ERROR( err ); 00233 } 00234 00235 // verify that it is modified in the new interface 00236 { 00237 TagVertexMesh tag_mesh( err, realMesh, false, "foobar" ); 00238 ASSERT_NO_ERROR( err ); 00239 tag_mesh.vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00240 ASSERT_NO_ERROR( err ); 00241 CPPUNIT_ASSERT_VECTORS_EQUAL( new_coords, get_coords, DBL_EPSILON ); 00242 } 00243 } 00244 00245 void TagVertexMeshTest::test_reference_mesh() 00246 { 00247 MsqPrintError err( std::cerr ); 00248 TagVertexMesh tag_mesh( err, realMesh, true ); 00249 ASSERT_NO_ERROR( err ); 00250 00251 std::vector< Mesh::VertexHandle > vertices; 00252 realMesh->get_all_vertices( vertices, err ); 00253 ASSERT_NO_ERROR( err ); 00254 00255 // copy real mesh coordinates into tag data in TagVertexMesh 00256 InstructionQueue q; 00257 q.add_tag_vertex_mesh( &tag_mesh, err ); 00258 ASSERT_NO_ERROR( err ); 00259 q.run_instructions( realMesh, err ); 00260 ASSERT_NO_ERROR( err ); 00261 00262 // Check that initial position for vertex matches that of real mesh 00263 Mesh::VertexHandle vertex = vertices[0]; 00264 MsqVertex get_coords; 00265 Vector3D orig_coords, real_coords, tag_coords; 00266 realMesh->vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00267 ASSERT_NO_ERROR( err ); 00268 orig_coords = get_coords; 00269 tag_mesh.vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00270 ASSERT_NO_ERROR( err ); 00271 tag_coords = get_coords; 00272 CPPUNIT_ASSERT_VECTORS_EQUAL( orig_coords, tag_coords, DBL_EPSILON ); 00273 00274 // Check that modified vertex coords show up in real mesh but not 00275 // tag mesh. 00276 realMesh->vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00277 ASSERT_NO_ERROR( err ); 00278 orig_coords = get_coords; 00279 Vector3D new_coords( 5, 5, 5 ); 00280 realMesh->vertex_set_coordinates( vertex, new_coords, err ); 00281 ASSERT_NO_ERROR( err ); 00282 tag_mesh.vertices_get_coordinates( &vertex, &get_coords, 1, err ); 00283 ASSERT_NO_ERROR( err ); 00284 tag_coords = get_coords; 00285 CPPUNIT_ASSERT_VECTORS_EQUAL( orig_coords, tag_coords, DBL_EPSILON ); 00286 // restore realMesh to initial state 00287 realMesh->vertex_set_coordinates( vertex, orig_coords, err ); 00288 ASSERT_NO_ERROR( err ); 00289 }
