MOAB: Mesh Oriented datABase
(version 5.2.1)
Definition at line 39 of file EdgeLengthMetricTest.cpp.
EdgeLengthMetricTest::EdgeLengthMetricTest | ( | ) | [inline] |
Definition at line 60 of file EdgeLengthMetricTest.cpp.
: mMetric( 0.0 ), tester( QualityMetricTester::ALL_FE_EXCEPT_SEPTAHEDRON ) {}
Definition at line 61 of file EdgeLengthQualityMetricTest.cpp.
EdgeLengthMetricTest::CPPUNIT_TEST | ( | test_supported_types | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST | ( | test_ideal_element_eval | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST | ( | test_valid_hessian | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST | ( | test_inverted_elements | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST | ( | test_get_evaluations | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST | ( | test_degenerate_elements | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST | ( | test_get_edge_indices | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST | ( | test_get_vertex_indices | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST | ( | test_eval_with_indices | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST | ( | test_eval_with_gradient | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST | ( | test_get_fixed_indices | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST | ( | test_location_invariant | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST | ( | test_orient_invariant | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST_SUITE | ( | EdgeLengthMetricTest | ) | [private] |
EdgeLengthMetricTest::CPPUNIT_TEST_SUITE_END | ( | ) | [private] |
void EdgeLengthMetricTest::test_degenerate_elements | ( | ) | [inline] |
Definition at line 80 of file EdgeLengthQualityMetricTest.cpp.
References mMetric.
{ tester.test_evaluate_degenerate_element( &mMetric, true ); }
void EdgeLengthMetricTest::test_eval_with_gradient | ( | ) | [inline] |
Definition at line 97 of file EdgeLengthMetricTest.cpp.
References mMetric.
void EdgeLengthMetricTest::test_eval_with_indices | ( | ) | [inline] |
Definition at line 92 of file EdgeLengthMetricTest.cpp.
References mMetric.
Definition at line 100 of file EdgeLengthQualityMetricTest.cpp.
References mMetric.
void EdgeLengthMetricTest::test_get_edge_indices | ( | ) | [inline] |
Definition at line 87 of file EdgeLengthMetricTest.cpp.
References mMetric.
{ tester.test_get_edge_indices( &mMetric ); }
void EdgeLengthMetricTest::test_get_evaluations | ( | ) | [inline] |
Definition at line 82 of file EdgeLengthMetricTest.cpp.
References mMetric.
{ tester.test_get_edge_evaluations( &mMetric ); }
Definition at line 85 of file EdgeLengthQualityMetricTest.cpp.
References mMetric.
{ tester.test_get_vertex_evaluations( &mMetric ); }
void EdgeLengthMetricTest::test_get_fixed_indices | ( | ) | [inline] |
Definition at line 95 of file EdgeLengthQualityMetricTest.cpp.
References mMetric.
{ tester.test_get_indices_fixed( &mMetric ); }
void EdgeLengthMetricTest::test_get_vertex_indices | ( | ) | [inline] |
Definition at line 90 of file EdgeLengthQualityMetricTest.cpp.
References mMetric.
{ tester.test_get_vertex_indices( &mMetric ); }
void EdgeLengthMetricTest::test_ideal_element_eval | ( | ) | [inline] |
Definition at line 67 of file EdgeLengthMetricTest.cpp.
References MBMesquite::HEXAHEDRON, mMetric, MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::TETRAHEDRON, and MBMesquite::TRIANGLE.
{ tester.test_evaluate_unit_edge_element( &mMetric, TRIANGLE, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, QUADRILATERAL, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, TETRAHEDRON, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, PYRAMID, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, PRISM, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, HEXAHEDRON, 1.0 ); }
Definition at line 68 of file EdgeLengthQualityMetricTest.cpp.
References mMetric.
{ tester.test_evaluate_unit_edge_tris_about_vertex( &mMetric, 6.0 ); tester.test_evaluate_unit_quads_about_vertex( &mMetric, 4.0 ); tester.test_evaluate_unit_hexes_about_vertex( &mMetric, 6.0 ); }
void EdgeLengthMetricTest::test_inverted_elements | ( | ) | [inline] |
Definition at line 75 of file EdgeLengthQualityMetricTest.cpp.
References mMetric.
{ tester.test_evaluate_inverted_element( &mMetric, true ); }
void EdgeLengthMetricTest::test_location_invariant | ( | ) | [inline] |
Definition at line 103 of file EdgeLengthMetricTest.cpp.
References mMetric.
Definition at line 105 of file EdgeLengthQualityMetricTest.cpp.
References mMetric.
void EdgeLengthMetricTest::test_orient_invariant | ( | ) | [inline] |
Definition at line 109 of file EdgeLengthMetricTest.cpp.
References mMetric.
{ tester.test_orient_invariant( &mMetric ); tester.test_grad_orient_invariant( &mMetric ); }
Definition at line 111 of file EdgeLengthQualityMetricTest.cpp.
References mMetric.
void EdgeLengthMetricTest::test_supported_types | ( | ) | [inline] |
Definition at line 62 of file EdgeLengthMetricTest.cpp.
References mMetric.
{ tester.test_supported_element_types( &mMetric ); }
Definition at line 63 of file EdgeLengthQualityMetricTest.cpp.
References mMetric.
void EdgeLengthMetricTest::test_valid_hessian | ( | ) | [inline] |
Definition at line 77 of file EdgeLengthMetricTest.cpp.
References mMetric.
Definition at line 56 of file EdgeLengthMetricTest.cpp.
Definition at line 57 of file EdgeLengthQualityMetricTest.cpp.
Definition at line 57 of file EdgeLengthMetricTest.cpp.
