MOAB: Mesh Oriented datABase
(version 5.2.1)
Computes the edge length range metric for a given vertex. More...
#include <EdgeLengthRangeQualityMetric.hpp>
Public Member Functions | |
EdgeLengthRangeQualityMetric (double low_a, double high_a) | |
virtual | ~EdgeLengthRangeQualityMetric () |
virtual std::string | get_name () const |
virtual int | get_negate_flag () const |
1 if metric should be minimized, -1 if metric should be maximized. | |
virtual bool | evaluate (PatchData &pd, size_t vertex, double &value, MsqError &err) |
Get metric value at a logical location in the patch. | |
virtual bool | evaluate_with_indices (PatchData &pd, size_t vertex, double &value, std::vector< size_t > &indices, MsqError &err) |
Private Member Functions | |
bool | evaluate_common (PatchData &pd, size_t vertex, double &value, std::vector< size_t > &vertices, MsqError &err) |
Private Attributes | |
double | highVal |
double | lowVal |
EdgeLengthRangeQualityMetric is a vertex based metric which computes the lengths of the edges connected to a given vertex and then uses those values to form a metric. The metric is created using two doubles A and B. The value of the metric is zero (ideal) if the edge lengths are in the range [A,B]. Otherwise, the metric value is some positive number. For a given vertex, v_i, with connected edges of lengths l_j for j=1...k, the metric value is the average (where the default average type is SUM) of u_j = ( | l_j - A | - (l_j - A) )^2 + ( | B - l_j | - (B - l_j) )^2.
Definition at line 60 of file EdgeLengthRangeQualityMetric.hpp.
EdgeLengthRangeQualityMetric::EdgeLengthRangeQualityMetric | ( | double | low_a, |
double | high_a | ||
Definition at line 53 of file EdgeLengthRangeQualityMetric.cpp.
bool EdgeLengthRangeQualityMetric::evaluate | ( | PatchData & | pd, |
size_t | handle, | ||
double & | value, | ||
MsqError & | err | ||
) | [virtual] |
Evaluate the metric at one location in the PatchData.
pd | The patch. |
handle | The location in the patch (as passed back from get_evaluations). |
value | The output metric value. |
Implements MBMesquite::QualityMetric.
Definition at line 114 of file EdgeLengthRangeQualityMetric.cpp.
References evaluate_common(), and MSQ_CHKERR.
{ std::vector< size_t > verts; bool rval = evaluate_common( pd, vertex, value, verts, err ); return !MSQ_CHKERR( err ) && rval; }
bool EdgeLengthRangeQualityMetric::evaluate_common | ( | PatchData & | pd, |
size_t | this_vert, | ||
double & | fval, | ||
std::vector< size_t > & | adj_verts, | ||
) | [private] |
For the given vertex, vert, with connected edges of lengths l_j for j=1...k, the metric value is the average (where the default average type is SUM) of u_j = ( | l_j - lowVal | - (l_j - lowVal) )^2 + ( | highVal - l_j | - (highVal - l_j) )^2.
Definition at line 71 of file EdgeLengthRangeQualityMetric.cpp.
References MBMesquite::AveragingQM::average_metrics(), MBMesquite::PatchData::get_adjacent_vertex_indices(), MBMesquite::PatchData::get_vertex_array(), highVal, MBMesquite::Vector3D::length(), lowVal, MSQ_CHKERR, and MSQ_ERRZERO.
Referenced by evaluate(), and evaluate_with_indices().
{ fval = 0.0; Vector3D edg; pd.get_adjacent_vertex_indices( this_vert, adj_verts, err ); MSQ_ERRZERO( err ); int num_sample_points = adj_verts.size(); double* metric_values = new double[num_sample_points]; const MsqVertex* verts = pd.get_vertex_array( err ); MSQ_ERRZERO( err ); // store the length of the edge, and the first and second component of // metric values, respectively. double temp_length = 0.0; double temp_first = 0.0; double temp_second = 0.0; // PRINT_INFO("INSIDE ELR, vertex = // %f,%f,%f\n",verts[this_vert][0],verts[this_vert][1],verts[this_vert][2]); loop while there are // still more adjacent vertices. for( unsigned i = 0; i < adj_verts.size(); ++i ) { edg = verts[this_vert] - verts[adj_verts[i]]; // compute the edge length temp_length = edg.length(); // get the first component temp_first = temp_length - lowVal; temp_first = fabs( temp_first ) - ( temp_first ); temp_first *= temp_first; // get the second component temp_second = highVal - temp_length; temp_second = fabs( temp_second ) - ( temp_second ); temp_second *= temp_second; // combine the two components metric_values[i] = temp_first + temp_second; } // average the metric values of the edges fval = average_metrics( metric_values, num_sample_points, err ); // clean up delete[] metric_values; // always return true because mesh is always valid wrt this metric. return !MSQ_CHKERR( err ); }
bool EdgeLengthRangeQualityMetric::evaluate_with_indices | ( | PatchData & | pd, |
std::vector< size_t > & | indices, | ||
) | [virtual] |
pd | The patch. |
indices | The free vertices that the evaluation is a function of, specified as vertex indices in the PatchData. |
Definition at line 121 of file EdgeLengthRangeQualityMetric.cpp.
References evaluate_common(), MSQ_CHKERR, and MBMesquite::PatchData::num_free_vertices().
{ indices.clear(); bool rval = evaluate_common( pd, vertex, value, indices, err ); std::vector< size_t >::iterator r, w; for( r = w = indices.begin(); r != indices.end(); ++r ) { if( *r < pd.num_free_vertices() ) { *w = *r; ++w; } } indices.erase( w, indices.end() ); if( vertex < pd.num_free_vertices() ) indices.push_back( vertex ); return !MSQ_CHKERR( err ) && rval; }
std::string EdgeLengthRangeQualityMetric::get_name | ( | ) | const [virtual] |
Definition at line 55 of file EdgeLengthRangeQualityMetric.cpp.
{ return "Edge Length Range Metric"; }
int EdgeLengthRangeQualityMetric::get_negate_flag | ( | ) | const [virtual] |
Definition at line 60 of file EdgeLengthRangeQualityMetric.cpp.
return 1;
double MBMesquite::EdgeLengthRangeQualityMetric::highVal [private] |
Definition at line 79 of file EdgeLengthRangeQualityMetric.hpp.
Referenced by EdgeLengthRangeQualityMetric(), and evaluate_common().
double MBMesquite::EdgeLengthRangeQualityMetric::lowVal [private] |
Definition at line 80 of file EdgeLengthRangeQualityMetric.hpp.
