MOAB: Mesh Oriented datABase
(version 5.2.1)
Definition at line 56 of file MeshInterfaceTest.cpp.
MeshInterfaceTest::MeshInterfaceTest | ( | ) | [inline] |
Definition at line 83 of file MeshInterfaceTest.cpp.
: mMesh( 0 ) {}
MeshInterfaceTest::CPPUNIT_TEST | ( | test_get_geometric_dimension | ) | [private] |
MeshInterfaceTest::CPPUNIT_TEST | ( | test_vertices | ) | [private] |
MeshInterfaceTest::CPPUNIT_TEST | ( | test_vertex_byte | ) | [private] |
MeshInterfaceTest::CPPUNIT_TEST | ( | test_elements | ) | [private] |
MeshInterfaceTest::CPPUNIT_TEST | ( | test_elements_get_topology | ) | [private] |
MeshInterfaceTest::CPPUNIT_TEST_SUITE | ( | MeshInterfaceTest | ) | [private] |
MeshInterfaceTest::CPPUNIT_TEST_SUITE_END | ( | ) | [private] |
void MeshInterfaceTest::setUp | ( | ) | [inline] |
Definition at line 86 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, MBMesquite::MeshImpl::elements_get_attached_vertices(), MBMesquite::MeshImpl::get_all_elements(), mConnectivity, mElements, mErr, mMesh, mOffsets, mVertices, and MBMesquite::MeshImpl::read_vtk().
{ // Read a VTK file -- 1 triangle flanked by 1 quad on each side (1 tri + 3 quads) mMesh = new MBMesquite::MeshImpl; mMesh->read_vtk( MESH_FILES_DIR "2D/vtk/mixed/untangled/hybrid_3quad_1tri.vtk", mErr ); CPPUNIT_ASSERT( !mErr ); // Get mesh data mMesh->get_all_elements( mElements, mErr ); CPPUNIT_ASSERT( !mErr ); mMesh->elements_get_attached_vertices( arrptr( mElements ), mElements.size(), mConnectivity, mOffsets, mErr ); CPPUNIT_ASSERT( !mErr ); // Construct list of vertices w/out duplicates from // connectivity list. std::vector< MBMesquite::Mesh::VertexHandle >::iterator new_end; mVertices = mConnectivity; std::sort( mVertices.begin(), mVertices.end() ); new_end = std::unique( mVertices.begin(), mVertices.end() ); mVertices.resize( new_end - mVertices.begin() ); }
void MeshInterfaceTest::tearDown | ( | ) | [inline] |
Definition at line 109 of file MeshInterfaceTest.cpp.
References MBMesquite::MsqError::clear(), mErr, and mMesh.
void MeshInterfaceTest::test_element_get_attached_vertex_indices | ( | ) | [inline] |
Definition at line 341 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, MBMesquite::MeshImpl::elements_get_topologies(), mConnectivity, mElements, mErr, MBMesquite::MIXED, mMesh, mOffsets, tri_coords(), MBMesquite::TRIANGLE, and MBMesquite::MeshImpl::vertices_get_coordinates().
{ // Find the index of the triangle MBMesquite::EntityTopology topo = Mesquite::MIXED; int tri_index = -1; while( topo != MBMesquite::TRIANGLE ) { ++tri_index; CPPUNIT_ASSERT( (unsigned)tri_index < mElements.size() ); MBMesquite::Mesh::ElementHandle handle = mElements[tri_index]; mMesh->elements_get_topologies( &handle, &topo, 1, mErr ); CPPUNIT_ASSERT( !mErr ); } // creates list with correct vertices coordinates for the triangle std::vector< Mesquite::Vector3D > correct_coords; correct_coords.push_back( Mesquite::Vector3D( 1., 0., 0. ) ); correct_coords.push_back( Mesquite::Vector3D( 0., 1.732050807, 0. ) ); correct_coords.push_back( Mesquite::Vector3D( -1., 0., 0. ) ); // Creates same list from the mesh implementation std::vector< MBMesquite::MsqVertex > tri_coords( 3 ); mMesh->vertices_get_coordinates( &mConnectivity[mOffsets[tri_index]], arrptr( tri_coords ), 3, mErr ); CPPUNIT_ASSERT( !mErr ); // Makes sure both list contain the same elements (not necessarily in the same order). std::vector< Mesquite::Vector3D >::iterator correct_iter; std::vector< MBMesquite::MsqVertex >::iterator tri_iter; for( tri_iter = tri_coords.begin(); tri_iter != tri_coords.end(); ++tri_iter ) { for( correct_iter = correct_coords.begin(); correct_iter != correct_coords.end(); ++correct_iter ) { if( Mesquite::Vector3D::distance_between( *tri_iter, *correct_iter ) < 10e-4 ) break; } // check if a match was found CPPUNIT_ASSERT( correct_iter != correct_coords.end() ); // remove match from list correct_coords.erase( correct_iter ); } CPPUNIT_ASSERT( correct_coords.empty() ); }
void MeshInterfaceTest::test_elements | ( | ) | [inline] |
Definition at line 268 of file MeshInterfaceTest.cpp.
References CPPUNIT_ASSERT_EQUAL, and mElements.
{ CPPUNIT_ASSERT_EQUAL( 4, (int)mElements.size() ); }
void MeshInterfaceTest::test_elements_get_attached_vertices | ( | ) | [inline] |
Definition at line 273 of file MeshInterfaceTest.cpp.
References CPPUNIT_ASSERT, mConnectivity, mElements, mOffsets, and mVertices.
{ const size_t nbElem = mElements.size(); // checks we have 3 elements containing 4 vertices // and 1 element containing 3 vertices. int n3 = 0; int n4 = 0; size_t i; for( i = 0; i < nbElem; ++i ) { size_t nve = mOffsets[i + 1] - mOffsets[i]; if( nve == 3 ) ++n3; else if( nve == 4 ) ++n4; else // failure. CPPUNIT_ASSERT( false ); } CPPUNIT_ASSERT( n3 == 1 ); // 1 triangle CPPUNIT_ASSERT( n4 == 3 ); // 3 quads // Make sure CSR data is valid std::map< MBMesquite::Mesh::VertexHandle, int > vtx_repeated_occurence; for( i = 0; i < mVertices.size(); ++i ) vtx_repeated_occurence[mVertices[i]] = 0; for( i = 0; i < mConnectivity.size(); ++i ) ++vtx_repeated_occurence[mConnectivity[i]]; for( i = 0; i < 9; ++i ) { CPPUNIT_ASSERT( vtx_repeated_occurence[mVertices[i]] <= 3 ); } // Makes sure CSR offsets are valid CPPUNIT_ASSERT( mOffsets[0] == 0 ); CPPUNIT_ASSERT( mOffsets[1] >= 3 && mOffsets[1] <= 12 ); CPPUNIT_ASSERT( mOffsets[2] >= 3 && mOffsets[2] <= 12 ); CPPUNIT_ASSERT( mOffsets[3] >= 3 && mOffsets[3] <= 12 ); CPPUNIT_ASSERT( mOffsets[4] == 15 ); }
void MeshInterfaceTest::test_elements_get_topology | ( | ) | [inline] |
Definition at line 314 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::MeshImpl::elements_get_topologies(), mElements, mErr, mMesh, MBMesquite::QUADRILATERAL, and MBMesquite::TRIANGLE.
{ const size_t nbElem = mElements.size(); int nb_quads = 0; int nb_tri = 0; MBMesquite::EntityTopology* topos = new MBMesquite::EntityTopology[nbElem]; mMesh->elements_get_topologies( arrptr( mElements ), topos, nbElem, mErr ); CPPUNIT_ASSERT( !mErr ); for( size_t i = 0; i < nbElem; ++i ) { switch( topos[i] ) { case MBMesquite::TRIANGLE: ++nb_tri; break; case MBMesquite::QUADRILATERAL: ++nb_quads; break; default: CPPUNIT_FAIL( "Topology should be quad or Hex only." ); } } CPPUNIT_ASSERT_EQUAL( 1, nb_tri ); CPPUNIT_ASSERT_EQUAL( 3, nb_quads ); delete[] topos; }
void MeshInterfaceTest::test_get_geometric_dimension | ( | ) | [inline] |
Definition at line 118 of file MeshInterfaceTest.cpp.
References CPPUNIT_ASSERT_EQUAL, MBMesquite::MeshImpl::get_geometric_dimension(), mErr, and mMesh.
{ int d = mMesh->get_geometric_dimension( mErr ); CPPUNIT_ASSERT_EQUAL( d, 3 ); }
void MeshInterfaceTest::test_vertex_byte | ( | ) | [inline] |
Definition at line 183 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, mErr, mMesh, mVertices, MBMesquite::MeshImpl::vertex_get_byte(), MBMesquite::MeshImpl::vertex_set_byte(), MBMesquite::MeshImpl::vertices_get_byte(), and MBMesquite::MeshImpl::vertices_set_byte().
{ size_t nbVert = mVertices.size(); size_t i; unsigned char* bytes = new unsigned char[nbVert]; mMesh->vertices_get_byte( arrptr( mVertices ), bytes, nbVert, mErr ); CPPUNIT_ASSERT( !mErr ); // Asserts all vertex bytes are initialised to 0. for( i = 0; i < nbVert; ++i ) CPPUNIT_ASSERT( bytes[i] == 0 ); // Test various vertex byte read / write routines. bytes[3] |= 4; mMesh->vertices_set_byte( arrptr( mVertices ), bytes, nbVert, mErr ); CPPUNIT_ASSERT( !mErr ); mMesh->vertex_set_byte( mVertices[5], 8, mErr ); CPPUNIT_ASSERT( !mErr ); unsigned char byte; mMesh->vertex_get_byte( mVertices[3], &byte, mErr ); CPPUNIT_ASSERT( !mErr ); CPPUNIT_ASSERT( byte == 4 ); mMesh->vertices_get_byte( arrptr( mVertices ), bytes, nbVert, mErr ); CPPUNIT_ASSERT( !mErr ); for( i = 0; i < nbVert; ++i ) { if( i == 3 ) CPPUNIT_ASSERT( bytes[i] == 4 ); else if( i == 5 ) CPPUNIT_ASSERT( bytes[i] == 8 ); else CPPUNIT_ASSERT( bytes[i] == 0 ); } delete[] bytes; }
void MeshInterfaceTest::test_vertex_get_attached_elements | ( | ) | [inline] |
Definition at line 220 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, mErr, mMesh, mVertices, and MBMesquite::MeshImpl::vertices_get_attached_elements().
{ size_t i; const size_t nbVert = mVertices.size(); std::vector< MBMesquite::Mesh::ElementHandle > elements; std::vector< size_t > offsets; mMesh->vertices_get_attached_elements( arrptr( mVertices ), mVertices.size(), elements, offsets, mErr ); CPPUNIT_ASSERT( !mErr ); CPPUNIT_ASSERT_EQUAL( offsets.size(), mVertices.size() + 1 ); // checks we have 6 vertices contained in 1 element only // and 3 vertices contained in 3 elements. int n1 = 0; int n3 = 0; for( i = 1; i <= mVertices.size(); ++i ) { const size_t nev = offsets[i] - offsets[i - 1]; if( nev == 1 ) ++n1; else if( nev == 3 ) ++n3; else // failure. CPPUNIT_ASSERT( false ); } CPPUNIT_ASSERT( n1 == 6 ); CPPUNIT_ASSERT( n3 == 3 ); // gets the index of a vertex in a corner int one_corner_vertex_index = 0; for( i = 0; i < nbVert; ++i ) { const size_t nev = offsets[i + 1] - offsets[i]; if( 1 == nev ) break; } CPPUNIT_ASSERT( i < nbVert ); one_corner_vertex_index = i; // retrieve the attached element. // This is a poor test. We allow an element handle of zero, // and just testing that the function returned something isn't // that useful. - J.K. // MBMesquite::Mesh::ElementHandle elem=0; // mMesh->vertex_get_attached_elements(mVertices[one_corner_vertex_index], &elem, 1, mErr); // CPPUNIT_ASSERT(!mErr); // CPPUNIT_ASSERT(elem!=0); }
void MeshInterfaceTest::test_vertex_is_fixed | ( | ) | [inline] |
Definition at line 169 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, fixed, mErr, mMesh, mVertices, and MBMesquite::MeshImpl::vertices_get_fixed_flag().
{ size_t nbVert = mVertices.size(); bool correct_fixed[9] = { false, false, false, true, true, true, true, true, true }; std::vector< bool > fixed; mMesh->vertices_get_fixed_flag( arrptr( mVertices ), fixed, 9, mErr ); CPPUNIT_ASSERT( !mErr ); CPPUNIT_ASSERT_EQUAL( (size_t)8, fixed.size() ); for( size_t i = 0; i < nbVert; ++i ) { CPPUNIT_ASSERT_EQUAL( correct_fixed[i], (bool)fixed[i] ); } }
void MeshInterfaceTest::test_vertices | ( | ) | [inline] |
Definition at line 124 of file MeshInterfaceTest.cpp.
References MBMesquite::arrptr(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, mErr, mMesh, mVertices, MBMesquite::Vector3D::set(), MBMesquite::MeshImpl::vertex_set_coordinates(), and MBMesquite::MeshImpl::vertices_get_coordinates().
{ size_t nbVert = mVertices.size(); CPPUNIT_ASSERT_EQUAL( 9, (int)nbVert ); MBMesquite::MsqVertex correct_coords[9], coords[9]; correct_coords[0].set( 1, 0, 0 ); correct_coords[1].set( 0, 1.732, 0 ); correct_coords[2].set( -1, 0, 0 ); correct_coords[3].set( -1, -2, 0 ); correct_coords[4].set( 1, -2, 0 ); correct_coords[5].set( 2.732, 1, 0 ); correct_coords[6].set( 1.732, 2.732, 0 ); correct_coords[7].set( -1.732, 2.732, 0 ); correct_coords[8].set( -2.732, 1, 0 ); mMesh->vertices_get_coordinates( arrptr( mVertices ), coords, nbVert, mErr ); CPPUNIT_ASSERT( !mErr ); for( size_t i = 0; i < nbVert; ++i ) { for( int j = 0; j < 3; ++j ) CPPUNIT_ASSERT_DOUBLES_EQUAL( coords[i][j], correct_coords[i][j], .01 ); } coords[3].set( 2., 3., 4. ); mMesh->vertex_set_coordinates( mVertices[3], coords[3], mErr ); CPPUNIT_ASSERT( !mErr ); MBMesquite::MsqVertex coords_2; mMesh->vertices_get_coordinates( &mVertices[3], &coords_2, 1, mErr ); CPPUNIT_ASSERT( !mErr ); for( int j = 0; j < 3; ++j ) CPPUNIT_ASSERT_DOUBLES_EQUAL( coords[3][j], coords_2[j], 1e-6 ); }
std::vector< MBMesquite::Mesh::VertexHandle > MeshInterfaceTest::mConnectivity [private] |
Definition at line 76 of file MeshInterfaceTest.cpp.
Referenced by setUp(), test_element_get_attached_vertex_indices(), and test_elements_get_attached_vertices().
std::vector< MBMesquite::Mesh::ElementHandle > MeshInterfaceTest::mElements [private] |
Definition at line 78 of file MeshInterfaceTest.cpp.
Referenced by setUp(), test_element_get_attached_vertex_indices(), test_elements(), test_elements_get_attached_vertices(), and test_elements_get_topology().
MBMesquite::MsqError MeshInterfaceTest::mErr [private] |
Definition at line 80 of file MeshInterfaceTest.cpp.
Referenced by setUp(), tearDown(), test_element_get_attached_vertex_indices(), test_elements_get_topology(), test_get_geometric_dimension(), test_vertex_byte(), test_vertex_get_attached_elements(), test_vertex_is_fixed(), and test_vertices().
MBMesquite::MeshImpl* MeshInterfaceTest::mMesh [private] |
Definition at line 75 of file MeshInterfaceTest.cpp.
std::vector< size_t > MeshInterfaceTest::mOffsets [private] |
Definition at line 79 of file MeshInterfaceTest.cpp.
std::vector< MBMesquite::Mesh::VertexHandle > MeshInterfaceTest::mVertices [private] |
Definition at line 77 of file MeshInterfaceTest.cpp.
Referenced by setUp(), test_elements_get_attached_vertices(), test_vertex_byte(), test_vertex_get_attached_elements(), test_vertex_is_fixed(), and test_vertices().
