MOAB
4.9.3pre
#include <AssignEvaluator.h>
Public Types | |
| enum | { DstFlags = DstEvaluator::Flags, SrcFlags = SrcEvaluator::Flags, RequiredAlignment = unpacket_traits<PacketType>::alignment } |
| enum | { DstAlignment = DstEvaluator::Alignment, SrcAlignment = SrcEvaluator::Alignment, DstHasDirectAccess = DstFlags & DirectAccessBit, JointAlignment = EIGEN_PLAIN_ENUM_MIN(DstAlignment,SrcAlignment) } |
| enum | { Traversal, Vectorized } |
| enum | { Unrolling } |
| typedef DstEvaluator::XprType | Dst |
| typedef Dst::Scalar | DstScalar |
| typedef find_best_packet < DstScalar, Dst::SizeAtCompileTime >::type | PacketType |
Private Types | |
| enum | { InnerSize, InnerMaxSize, OuterStride = int(outer_stride_at_compile_time<Dst>::ret), MaxSizeAtCompileTime = Dst::SizeAtCompileTime, PacketSize = unpacket_traits<PacketType>::size } |
| enum | { DstIsRowMajor = DstFlags&RowMajorBit, SrcIsRowMajor = SrcFlags&RowMajorBit, StorageOrdersAgree = (int(DstIsRowMajor) == int(SrcIsRowMajor)), MightVectorize } |
| enum | { UnrollingLimit = EIGEN_UNROLLING_LIMIT * (Vectorized ? int(PacketSize) : 1) } |
Definition at line 28 of file AssignEvaluator.h.
| typedef DstEvaluator::XprType Eigen::internal::copy_using_evaluator_traits< DstEvaluator, SrcEvaluator, AssignFunc >::Dst |
Definition at line 30 of file AssignEvaluator.h.
| typedef Dst::Scalar Eigen::internal::copy_using_evaluator_traits< DstEvaluator, SrcEvaluator, AssignFunc >::DstScalar |
Definition at line 31 of file AssignEvaluator.h.
| typedef find_best_packet<DstScalar,Dst::SizeAtCompileTime>::type Eigen::internal::copy_using_evaluator_traits< DstEvaluator, SrcEvaluator, AssignFunc >::PacketType |
Definition at line 33 of file AssignEvaluator.h.
| anonymous enum |
Definition at line 35 of file AssignEvaluator.h.
| anonymous enum |
Definition at line 42 of file AssignEvaluator.h.
anonymous enum [private] |
Definition at line 50 of file AssignEvaluator.h.
InnerSize = int(Dst::IsVectorAtCompileTime) ? int(Dst::SizeAtCompileTime)
: int(DstFlags)&RowMajorBit ? int(Dst::ColsAtCompileTime)
: int(Dst::RowsAtCompileTime),
InnerMaxSize = int(Dst::IsVectorAtCompileTime) ? int(Dst::MaxSizeAtCompileTime)
: int(DstFlags)&RowMajorBit ? int(Dst::MaxColsAtCompileTime)
: int(Dst::MaxRowsAtCompileTime),
Definition at line 62 of file AssignEvaluator.h.
MightVectorize = StorageOrdersAgree
&& (int(DstFlags) & int(SrcFlags) & ActualPacketAccessBit)
&& (functor_traits<AssignFunc>::PacketAccess),
MayInnerVectorize = MightVectorize
&& int(InnerSize)!=Dynamic && int(InnerSize)%int(PacketSize)==0
&& int(OuterStride)!=Dynamic && int(OuterStride)%int(PacketSize)==0
&& int(JointAlignment)>=int(RequiredAlignment),
MayLinearize = StorageOrdersAgree && (int(DstFlags) & int(SrcFlags) & LinearAccessBit),
MayLinearVectorize = MightVectorize && MayLinearize && DstHasDirectAccess
&& ((int(DstAlignment)>=int(RequiredAlignment)) || MaxSizeAtCompileTime == Dynamic),
/* If the destination isn't aligned, we have to do runtime checks and we don't unroll,
so it's only good for large enough sizes. */
MaySliceVectorize = MightVectorize && DstHasDirectAccess
&& (int(InnerMaxSize)==Dynamic || int(InnerMaxSize)>=3*PacketSize)
/* slice vectorization can be slow, so we only want it if the slices are big, which is
indicated by InnerMaxSize rather than InnerSize, think of the case of a dynamic block
in a fixed-size matrix */
| anonymous enum |
Definition at line 86 of file AssignEvaluator.h.
Traversal = int(MayInnerVectorize) ? int(InnerVectorizedTraversal)
: int(MayLinearVectorize) ? int(LinearVectorizedTraversal)
: int(MaySliceVectorize) ? int(SliceVectorizedTraversal)
: int(MayLinearize) ? int(LinearTraversal)
: int(DefaultTraversal),
Vectorized = int(Traversal) == InnerVectorizedTraversal
|| int(Traversal) == LinearVectorizedTraversal
|| int(Traversal) == SliceVectorizedTraversal
Definition at line 98 of file AssignEvaluator.h.
UnrollingLimit = EIGEN_UNROLLING_LIMIT * (Vectorized ? int(PacketSize) : 1),
MayUnrollCompletely = int(Dst::SizeAtCompileTime) != Dynamic
&& int(Dst::SizeAtCompileTime) * int(SrcEvaluator::CoeffReadCost) <= int(UnrollingLimit),
MayUnrollInner = int(InnerSize) != Dynamic
&& int(InnerSize) * int(SrcEvaluator::CoeffReadCost) <= int(UnrollingLimit)
| anonymous enum |
Definition at line 107 of file AssignEvaluator.h.
Unrolling = (int(Traversal) == int(InnerVectorizedTraversal) || int(Traversal) == int(DefaultTraversal))
int(MayUnrollCompletely) ? int(CompleteUnrolling)
: int(MayUnrollInner) ? int(InnerUnrolling)
: int(NoUnrolling)
: int(Traversal) == int(LinearVectorizedTraversal)
? ( bool(MayUnrollCompletely) && (int(DstAlignment)>=int(RequiredAlignment)) ? int(CompleteUnrolling)
: int(NoUnrolling) )
: int(Traversal) == int(LinearTraversal)
? ( bool(MayUnrollCompletely) ? int(CompleteUnrolling)
: int(NoUnrolling)
