ExtractClose.cpp File Reference
#include <iostream>
#include <cstdlib>
#include <cstdio>
#include "moab/Core.hpp"
#include "moab/Interface.hpp"
#include "moab/Range.hpp"
#include "moab/ProgOptions.hpp"
#include "moab/CartVect.hpp"
#include "moab/IntxMesh/IntxUtils.hpp"
+ Include dependency graph for ExtractClose.cpp:
Functions
int main (int argc, char **argv)
Function Documentation
int main ( int  argc,
char **  argv
Definition at line 30 of file ExtractClose.cpp.
References moab::Core::add_entities(), ProgOptions::addOpt(), moab::Range::begin(), center(), moab::Core::create_meshset(), moab::Range::end(), ErrorCode, moab::Core::get_coords(), moab::Core::get_entities_by_dimension(), moab::Range::insert(), moab::IntxUtils::SphereCoords::lat, length(), moab::Core::load_file(), moab::IntxUtils::SphereCoords::lon, mb, MB_CHK_ERR, MB_CHK_SET_ERR, MESHSET_SET, ProgOptions::parseCommandLine(), moab::IntxUtils::SphereCoords::R, moab::Range::size(), moab::IntxUtils::spherical_to_cart(), test_file_name, and moab::Core::write_file().
    ProgOptions opts;
    // vertex 25 in filt out  (-0.784768, 0.594952, -0.173698)
    double x = -0.784768, y = 0.594952, z = -0.173698;
    double lat = 28.6551, lon = 61.0204;  // from Charlie Zender's page
    // https://acme-climate.atlassian.net/wiki/spaces/ED/pages/1347092547/Assessing+and+Addressing+Regridding+Weights+in+Map-Files
    string inputFile = test_file_name;
    opts.addOpt< string >( "inFile,i", "Specify the input file name string ", &inputFile );
    string outFile = "out.h5m";
    opts.addOpt< string >( "outFile,o", "Specify the output file name string ", &outFile );
    opts.addOpt< double >( string( "xpos,x" ), string( "x position" ), &x );
    opts.addOpt< double >( string( "ypos,y" ), string( "y position" ), &y );
    opts.addOpt< double >( string( "zpos,z" ), string( "z position" ), &z );
    opts.addOpt< double >( string( "latitude,t" ), string( "north latitude in degrees" ), &lat );
    opts.addOpt< double >( string( "longitude,w" ), string( "east longitude in degrees" ), &lon );
    bool spherical = false;
    opts.addOpt< void >( "spherical,s", "use spherical coords input (default false) ", &spherical );
    double distance = 0.01;
    opts.addOpt< double >( string( "distance,d" ), string( "distance " ), &distance );
    opts.parseCommandLine( argc, argv );
    int rank         = 0;
    int numProcesses = 1;
    std::string readopts;
#ifdef MOAB_HAVE_MPI
    if( MPI_Init( &argc, &argv ) ) return 1;
    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
    MPI_Comm_size( MPI_COMM_WORLD, &numProcesses );
    readopts = string( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" );  // we do not have to
        // resolve shared ents
#endif
    // Instantiate
    Core mb;
    // Load the file into a new file set
    EntityHandle fileSet;
    ErrorCode rval = mb.create_meshset( MESHSET_SET, fileSet );MB_CHK_SET_ERR( rval, "Error creating file set" );
    rval = mb.load_file( inputFile.c_str(), &fileSet, readopts.c_str() );MB_CHK_SET_ERR( rval, "Error loading file" );
    if( !rank )
        cout << " reading file " << inputFile << " on " << numProcesses << " task";
        if( numProcesses > 1 ) cout << "s";
        cout << "\n";
    // Get all 2d elements in the file set
    Range elems;
    rval = mb.get_entities_by_dimension( fileSet, 2, elems );MB_CHK_SET_ERR( rval, "Error getting 2d elements" );
    // create a meshset with close elements
    EntityHandle outSet;
    // create meshset
    rval = mb.create_meshset( MESHSET_SET, outSet );MB_CHK_ERR( rval );
    // double sphere radius is 1
    CartVect point( x, y, z );
    if( spherical )
        std::cout << " use spherical coordinates on the sphere of radius 1.\n";
        IntxUtils::SphereCoords pos;
        pos.R   = 1;                 // always on the
        pos.lat = lat * M_PI / 180;  // defined in math.h
        pos.lon = lon * M_PI / 180;
        point   = IntxUtils::spherical_to_cart( pos );
    Range closeByCells;
    for( Range::iterator it = elems.begin(); it != elems.end(); it++ )
        EntityHandle cell = *it;
        CartVect center;
        rval = mb.get_coords( &cell, 1, &( center[0] ) );MB_CHK_SET_ERR( rval, "Can't get cell center coords" );
        double dist = ( center - point ).length();
        if( dist <= distance )
            closeByCells.insert( cell );
    rval = mb.add_entities( outSet, closeByCells );MB_CHK_SET_ERR( rval, "Can't add to entity set" );
    int numCells = (int)closeByCells.size();
    // Reduce all of the local sums into the global sum
    int globalCells;
    MPI_Reduce( &numCells, &globalCells, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD );
    numCells = globalCells;
#endif
    if( numCells == 0 )
        if( !rank )
            std::cout << " no close cells to the point " << point << " at distance less than " << distance << "\n";
    else
        if( !rank )
            std::cout << " write file " << outFile << " with cells closer than " << distance << " from " << point
                      << "\n";
        string writeOpts;
        if( numProcesses > 1 ) writeOpts = string( "PARALLEL=WRITE_PART;" );
        rval = mb.write_file( outFile.c_str(), 0, writeOpts.c_str(), &outSet, 1 );MB_CHK_SET_ERR( rval, "Can't write file" );
    if( MPI_Finalize() ) return 1;
#endif
    return 0;
