FixPolys.cpp File Reference
#include <iostream>
#include <cstdlib>
#include <cstdio>
#include "moab/Core.hpp"
#include "moab/Interface.hpp"
#include "moab/Range.hpp"
#include "moab/ProgOptions.hpp"
+ Include dependency graph for FixPolys.cpp:
Functions
int main (int argc, char **argv)
Function Documentation
int main ( int  argc,
char **  argv
Definition at line 23 of file FixPolys.cpp.
References ProgOptions::addOpt(), moab::Range::begin(), moab::Core::create_element(), moab::Core::delete_entities(), moab::Range::end(), ErrorCode, moab::Core::get_connectivity(), moab::Core::get_entities_by_dimension(), moab::Core::globalId_tag(), moab::Range::insert(), moab::Core::load_file(), mb, MB_CHK_SET_ERR, MBPOLYGON, ProgOptions::parseCommandLine(), moab::Range::size(), moab::Core::tag_get_data(), moab::Core::tag_set_data(), test_file_name, and moab::Core::write_file().
    ProgOptions opts;
    string inputFile = test_file_name;
    opts.addOpt< string >( "inFile,i", "Specify the input file name string ", &inputFile );
    string outFile = "out.h5m";
    opts.addOpt< string >( "outFile,o", "Specify the output file name string ", &outFile );
    opts.parseCommandLine( argc, argv );
    // Instantiate
    Core mb;
    ErrorCode rval = mb.load_file( inputFile.c_str() );MB_CHK_SET_ERR( rval, "Error loading file" );
    cout << " reading file " << inputFile << "\n";
    // Get all 2d elements in the file set
    Range elems;
    rval = mb.get_entities_by_dimension( 0, 2, elems );MB_CHK_SET_ERR( rval, "Error getting 2d elements" );
    cout << "number of cells: " << elems.size() << "\n";
    Tag gidTag = mb.globalId_tag();
    Range OldCells;
    for( Range::iterator it = elems.begin(); it != elems.end(); ++it )
        EntityHandle cell = *it;
        const EntityHandle* conn;
        int number_nodes;
        rval = mb.get_connectivity( cell, conn, number_nodes );MB_CHK_SET_ERR( rval, "Error getting connectivity" );
        // now check if we have consecutive duplicated vertices, and if so, create a new cell
        std::vector< EntityHandle > new_verts;
        // push to it, if we do not have duplicates
        EntityHandle current = conn[0];
        // new_verts.push_back(current);
        for( int i = 1; i <= number_nodes; i++ )
            EntityHandle nextV;
            if( i < number_nodes )
                nextV = conn[i];
            else
                nextV = conn[0];  // first vertex
            if( current != nextV )
                new_verts.push_back( current );
                current = nextV;
        if( number_nodes > (int)new_verts.size() )
            // create a new poly, and put this in a list to be removed
            int gid;
            rval = mb.tag_get_data( gidTag, &cell, 1, &gid );MB_CHK_SET_ERR( rval, "Error getting global id tag" );
            EntityHandle newCell;
            rval = mb.create_element( MBPOLYGON, &new_verts[0], (int)new_verts.size(), newCell );MB_CHK_SET_ERR( rval, "Error creating new polygon " );
            rval = mb.tag_set_data( gidTag, &newCell, 1, &gid );MB_CHK_SET_ERR( rval, "Error setting global id tag" );
            cout << "delete old cell " << cell << " with num_nodes vertices: " << number_nodes
                 << " and with global id: " << gid << "\n";
            for( int i = 0; i < number_nodes; i++ )
                cout << " " << conn[i];
            cout << "\n";
            OldCells.insert( cell );
        mb.delete_entities( OldCells );
    rval = mb.write_file( outFile.c_str() );MB_CHK_SET_ERR( rval, "Error writing file" );
    return 0;
