QuadTriConv.cpp File Reference
#include <iostream>
#include <vector>
#include "moab/Core.hpp"
#include "MBTagConventions.hpp"
+ Include dependency graph for QuadTriConv.cpp:
Functions
int main (int argc, char **argv)
Function Documentation
int main ( int  argc,
char **  argv
Definition at line 20 of file QuadTriConv.cpp.
References moab::Range::begin(), moab::Interface::create_element(), moab::Interface::delete_entities(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_dimension(), moab::Range::insert(), moab::Interface::load_file(), mb, MB_CHK_SET_ERR, MBPOLYGON, MBQUAD, MBTRI, moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::Interface::write_file().
    // Get MOAB instance
    Interface* mb = new( std::nothrow ) Core;
    if( NULL == mb ) return 1;
    std::string filename, outfile;
    outfile = string( "out.h5m" );
    if( argc == 1 ) return 0;
    if( argc > 1 ) filename = string( argv[1] );
    if( argc > 2 ) outfile = string( argv[2] );
    // This file is in the mesh files directory
    ErrorCode rval = mb->load_file( filename.c_str() );MB_CHK_SET_ERR( rval, "Failed to read" );
    // get all cells of dimension 2;
    Range cells;
    rval = mb->get_entities_by_dimension( 0, 2, cells );MB_CHK_SET_ERR( rval, "Failed to get cells" );
    cout << " number of cells : " << cells.size() << "\n";
    Tag gid;  // global id tag
    rval = mb->tag_get_handle( "GLOBAL_ID", gid );MB_CHK_SET_ERR( rval, "Failed to get Global ID tag" );
    Range modifiedCells;  // will be deleted at the end; keep the gid
    for( Range::iterator cit = cells.begin(); cit != cells.end(); cit++ )
        EntityHandle cell          = *cit;
        const EntityHandle* connec = NULL;
        int num_verts              = 0;
        rval                       = mb->get_connectivity( cell, connec, num_verts );MB_CHK_SET_ERR( rval, "Failed to get connectivity" );
        vector< EntityHandle > newConnec;
        newConnec.push_back( connec[0] );  // at least one vertex
        int index    = 0;
        int new_size = 1;
        while( index < num_verts - 2 )
            int next_index = ( index + 1 );
            if( connec[next_index] != newConnec[new_size - 1] )
                newConnec.push_back( connec[next_index] );
                new_size++;
            index++;
        // add the last one only if different from previous and first node
        if( ( connec[num_verts - 1] != connec[num_verts - 2] ) && ( connec[num_verts - 1] != connec[0] ) )
            newConnec.push_back( connec[num_verts - 1] );
            new_size++;
        if( new_size < num_verts )
            // cout << "new cell from " << cell << " has only " << new_size << " vertices \n";
            modifiedCells.insert( cell );
            // create a new cell with type triangle, quad or polygon
            EntityType type = MBTRI;
            if( new_size == 3 )
                type = MBTRI;
            else if( new_size == 4 )
                type = MBQUAD;
            else if( new_size > 4 )
                type = MBPOLYGON;
            // create new cell
            EntityHandle newCell;
            rval = mb->create_element( type, &newConnec[0], new_size, newCell );MB_CHK_SET_ERR( rval, "Failed to create new cell" );
            // set the old id to the new element
            int id;
            rval = mb->tag_get_data( gid, &cell, 1, &id );MB_CHK_SET_ERR( rval, "Failed to get global id" );
            rval = mb->tag_set_data( gid, &newCell, 1, &id );MB_CHK_SET_ERR( rval, "Failed to set global id on new cell" );
    mb->delete_entities( modifiedCells );
    // in case global ids are not set for vertices, set them, in order;
    // they are needed for migrating later on
    Range verts;
    rval = mb->get_entities_by_dimension( 0, 0, verts );MB_CHK_SET_ERR( rval, "Failed to get vertices" );
    vector< int > gids;
    gids.resize( verts.size() );
    rval = mb->tag_get_data( gid, verts, &gids[0] );MB_CHK_SET_ERR( rval, "Failed to get gids on vertices" );
    if( gids[0] <= 0 )
        // gids were never set, assign them
        for( size_t i = 1; i <= verts.size(); i++ )
            gids[i - 1] = (int)i;
        rval = mb->tag_set_data( gid, verts, &gids[0] );MB_CHK_SET_ERR( rval, "Failed to set gids on vertices" );
    rval = mb->write_file( outfile.c_str() );MB_CHK_SET_ERR( rval, "Failed to write new file" );
    cout << " wrote file " << outfile << " with " << modifiedCells.size() << " modified cells\n";
    delete mb;
    return 0;
