UniformRefinement.cpp File Reference
#include <iostream>
#include "moab/Core.hpp"
#include "moab/NestedRefine.hpp"
+ Include dependency graph for UniformRefinement.cpp:
Functions
int main (int argc, char *argv[])
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 8 of file UniformRefinement.cpp.
References moab::error(), ErrorCode, moab::NestedRefine::generate_mesh_hierarchy(), moab::Interface::load_file(), mb, MB_CHK_ERR, and moab::Interface::write_file().
    Core mb;
    Interface* mbImpl = &mb;
    ErrorCode error;
    if( argc == 1 )
        std::cerr << "Usage: " << argv[0] << " [filename]" << std::endl;
        return 1;
    const char* filename = argv[1];
    error                = mbImpl->load_file( filename );MB_CHK_ERR( error );
    NestedRefine uref( &mb );
    // Usage: The level degrees array controls number of refinemetns and
    // the degree of refinement at each level.
    // Example: int level_degrees[4] = {2,3,2,3};
    std::vector< int > level_degrees;
    if( argc > 2 )
        level_degrees.resize( argc - 2 );
        for( int i = 2; i < argc; ++i )
            level_degrees[i - 2] = atoi( argv[i] );
    else
        level_degrees.resize( 2 );
    int num_levels = static_cast< int >( level_degrees.size() );
    std::cout << "Starting hierarchy generation" << std::endl;
    std::vector< EntityHandle > set;
    error = uref.generate_mesh_hierarchy( num_levels, level_degrees.data(), set );MB_CHK_ERR( error );
    std::cout << "Finished hierarchy generation" << std::endl;
    std::stringstream file;
    file << "mesh_hierarchy.h5m";
    error = mbImpl->write_file( file.str().c_str() );MB_CHK_ERR( error );
    return 0;
