copyPartition.cpp File Reference
#include "moab/ProgOptions.hpp"
#include "moab/Core.hpp"
#include <cmath>
#include <sstream>
+ Include dependency graph for copyPartition.cpp:
Functions
int main (int argc, char *argv[])
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 21 of file copyPartition.cpp.
References moab::Core::add_entities(), ProgOptions::addOpt(), moab::Range::begin(), moab::Core::clear_meshset(), moab::Range::end(), ErrorCode, moab::Core::get_entities_by_dimension(), moab::Core::get_entities_by_type_and_tag(), moab::Core::globalId_tag(), moab::Core::load_file(), mb, MB_CHK_ERR, MB_CHK_SET_ERR, MBENTITYSET, ProgOptions::parseCommandLine(), ProgOptions::printHelp(), moab::Range::size(), moab::Core::tag_get_data(), moab::Core::tag_get_handle(), and moab::Core::write_file().
    ProgOptions opts;
    std::string physfile, pg2file, outfile;
    opts.addOpt< std::string >( "physgridfile,p", "phys grid filename", &physfile );
    opts.addOpt< std::string >( "pg2file,g", "pg2 mesh file", &pg2file );
    opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile );
    opts.parseCommandLine( argc, argv );
    std::cout << "phys grid cloud file: " << physfile << "\n";
    std::cout << "pg2 mesh file: " << pg2file << "\n";
    std::cout << "output file: " << outfile << "\n";
    if( physfile.empty() )
        opts.printHelp();
        return 0;
    ErrorCode rval;
    Core* mb = new Core();
    rval = mb->load_file( physfile.c_str() );MB_CHK_SET_ERR( rval, "can't load phys grid file" );
    Core* mb2 = new Core();
    rval      = mb2->load_file( pg2file.c_str() );MB_CHK_SET_ERR( rval, "can't load pg2 mesh file" );
    Tag globalIDTag1 = mb->globalId_tag();
    Tag parti;
    rval = mb->tag_get_handle( "partition", parti );MB_CHK_SET_ERR( rval, "can't get partition tag phys grid mesh " );
    Tag globalIDTag2 = mb2->globalId_tag();
    Range verts1;
    rval = mb->get_entities_by_dimension( 0, 0, verts1 );MB_CHK_SET_ERR( rval, "can't get vertices " );
    std::vector< int > partValues;
    partValues.resize( verts1.size() );
    rval = mb->tag_get_data( parti, verts1, &partValues[0] );MB_CHK_SET_ERR( rval, "can't get parts values on vertices " );
    Range cells;
    rval = mb2->get_entities_by_dimension( 0, 2, cells );MB_CHK_SET_ERR( rval, "can't get 2d cells " );
    std::vector< int > globalIdsCells;
    globalIdsCells.resize( cells.size() );
    rval = mb2->tag_get_data( globalIDTag2, cells, &globalIdsCells[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " );
    std::vector< int > globalIdsVerts;
    globalIdsVerts.resize( verts1.size() );
    rval = mb->tag_get_data( globalIDTag1, verts1, &globalIdsVerts[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " );
    Tag partTag;
    rval = mb2->tag_get_handle( "PARALLEL_PARTITION", partTag );MB_CHK_SET_ERR( rval, "can't partition tag " );
    Range sets;
    rval = mb2->get_entities_by_type_and_tag( 0, MBENTITYSET, &partTag, NULL, 1, sets );MB_CHK_ERR( rval );
    std::vector< int > setValues;
    setValues.resize( sets.size() );
    rval = mb2->tag_get_data( partTag, sets, &setValues[0] );MB_CHK_ERR( rval );
    std::map< int, EntityHandle > valToSet;
    int i = 0;
    for( Range::iterator st = sets.begin(); st != sets.end(); ++st, i++ )
        valToSet[setValues[i]] = *st;
    // now, every cell will be put into one set, by looking at the global id of cell
    std::map< int, EntityHandle > gidToCell;
    i = 0;
    for( Range::iterator it = cells.begin(); it != cells.end(); ++it, i++ )
        gidToCell[globalIdsCells[i]] = *it;
    // empty all sets
    rval = mb2->clear_meshset( sets );MB_CHK_ERR( rval );
    // look now at parti values for vertices, and their global ids
    for( i = 0; i < (int)verts1.size(); i++ )
        int part          = partValues[i];
        int gid           = globalIdsVerts[i];
        EntityHandle set1 = valToSet[part];
        EntityHandle cell = gidToCell[gid];
        rval              = mb2->add_entities( set1, &cell, 1 );MB_CHK_ERR( rval );
    rval = mb2->write_file( outfile.c_str() );MB_CHK_SET_ERR( rval, "can't write file" );
    delete mb;
    delete mb2;
    return 0;
