h5mtoscrip.cpp File Reference
#include <iostream>
#include <exception>
#include <cmath>
#include <cassert>
#include <vector>
#include <string>
#include <fstream>
#include <iomanip>
#include "moab/ProgOptions.hpp"
#include "moab/Core.hpp"
#include "OfflineMap.h"
#include "netcdfcpp.h"
#include "NetCDFUtilities.h"
#include "DataArray2D.h"
+ Include dependency graph for h5mtoscrip.cpp:
Defines
#define DTYPE(a)
Functions
template<typename T >
ErrorCode get_vartag_data (moab::Interface *mbCore, Tag tag, moab::Range &sets, int &out_data_size, std::vector< T > &data)
void ReadFileMetaData (std::string &metaFilename, std::map< std::string, std::string > &metadataVals)
int main (int argc, char *argv[])
Define Documentation
#define DTYPE (   a)
Value:
        ( ( ( a ) == 0 ) ? "FV" : ( ( ( a ) == 1 ) ? "cGLL" : "dGLL" ) ) \
Referenced by main().
Function Documentation
ErrorCode get_vartag_data ( moab::Interface mbCore,
Tag  tag,
moab::Range sets,
int &  out_data_size,
std::vector< T > &  data
Definition at line 33 of file h5mtoscrip.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, moab::Range::size(), T, and moab::Interface::tag_get_by_ptr().
    int* tag_sizes        = new int[sets.size()];
    const void** tag_data = (const void**)new void*[sets.size()];
    ErrorCode rval = mbCore->tag_get_by_ptr( tag, sets, tag_data, tag_sizes );MB_CHK_SET_ERR( rval, "Getting matrix rows failed" );
    out_data_size = 0;
    for( unsigned is = 0; is < sets.size(); ++is )
        out_data_size += tag_sizes[is];
    data.resize( out_data_size );
    int ioffset = 0;
    for( unsigned index = 0; index < sets.size(); index++ )
        T* m_vals = (T*)tag_data[index];
        for( int k = 0; k < tag_sizes[index]; k++ )
            data[ioffset++] = m_vals[k];
    return moab::MB_SUCCESS;
int main ( int  argc,
char *  argv[]
Definition at line 81 of file h5mtoscrip.cpp.
References ProgOptions::addOpt(), DTYPE, ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), get_vartag_data(), moab::Interface::globalId_tag(), moab::Interface::load_mesh(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, ProgOptions::parseCommandLine(), ProgOptions::printHelp(), ReadFileMetaData(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::UNION.
    moab::ErrorCode rval;
    int dimension = 2;
    NcError error2( NcError::verbose_nonfatal );
    std::stringstream sstr;
    ProgOptions opts;
    std::string h5mfilename, scripfile;
    bool noMap         = false;
    bool writeXYCoords = false;
#ifdef MOAB_HAVE_MPI
    MPI_Init( &argc, &argv );
#endif
    opts.addOpt< std::string >( "weights,w", "h5m remapping weights filename", &h5mfilename );
    opts.addOpt< std::string >( "scrip,s", "Output SCRIP map filename", &scripfile );
    opts.addOpt< int >( "dim,d", "Dimension of entities to use for partitioning", &dimension );
    opts.addOpt< void >( "mesh,m", "Only convert the mesh and exclude the remap weight details", &noMap );
    opts.addOpt< void >( "coords,c", "Write the center and vertex coordinates in lat/lon format", &writeXYCoords );
    opts.parseCommandLine( argc, argv );
    if( h5mfilename.empty() || scripfile.empty() )
        opts.printHelp();
        exit( 1 );
    moab::Interface* mbCore = new( std::nothrow ) moab::Core;
    if( NULL == mbCore )
        return 1;
    // Set the read options for parallel file loading
    const std::string partition_set_name = "PARALLEL_PARTITION";
    const std::string global_id_name     = "GLOBAL_ID";
    // Load file
    rval = mbCore->load_mesh( h5mfilename.c_str() );MB_CHK_ERR( rval );
    try
        // Temporarily change rval reporting
        NcError error_temp( NcError::verbose_fatal );
        // Open an output file
        NcFile ncMap( scripfile.c_str(), NcFile::Replace, NULL, 0, NcFile::Offset64Bits );
        if( !ncMap.is_valid() )
            _EXCEPTION1( "Unable to open output map file \"%s\"", scripfile.c_str() );
            // NetCDF-SCRIP Global Attributes
            std::map< std::string, std::string > mapAttributes;
            size_t lastindex = h5mfilename.find_last_of( "." );
            sstr << h5mfilename.substr( 0, lastindex ) << ".meta";
            std::string metaFilename = sstr.str();
            ReadFileMetaData( metaFilename, mapAttributes );
            mapAttributes["Command"] =
                "Converted with MOAB:h5mtoscrip with --w=" + h5mfilename + " and --s=" + scripfile;
            // Add global attributes
            std::map< std::string, std::string >::const_iterator iterAttributes = mapAttributes.begin();
            for( ; iterAttributes != mapAttributes.end(); iterAttributes++ )
                std::cout << iterAttributes->first << " -- " << iterAttributes->second << std::endl;
                ncMap.add_att( iterAttributes->first.c_str(), iterAttributes->second.c_str() );
            std::cout << "\n";
        Tag globalIDTag, materialSetTag;
        globalIDTag = mbCore->globalId_tag();
        // materialSetTag = mbCore->material_tag();
        rval = mbCore->tag_get_handle( "MATERIAL_SET", 1, MB_TYPE_INTEGER, materialSetTag, MB_TAG_SPARSE );MB_CHK_ERR( rval );
        // Get sets entities, by type
        moab::Range meshsets;
        rval = mbCore->get_entities_by_type_and_tag( 0, MBENTITYSET, &globalIDTag, NULL, 1, meshsets,
                                                     moab::Interface::UNION, true );MB_CHK_ERR( rval );
        moab::EntityHandle rootset = 0;
        // The metadata in H5M file contains the following data:
        //   1. n_a: Total source entities: (number of elements in source mesh)
        //   2. n_b: Total target entities: (number of elements in target mesh)
        //   3. nv_a: Max edge size of elements in source mesh
        //   4. nv_b: Max edge size of elements in target mesh
        //   5. maxrows: Number of rows in remap weight matrix
        //   6. maxcols: Number of cols in remap weight matrix
        //   7. nnz: Number of total nnz in sparse remap weight matrix
        //   8. np_a: The order of the field description on the source mesh: >= 1
        //   9. np_b: The order of the field description on the target mesh: >= 1
        //   10. method_a: The type of discretization for field on source mesh: [0 = FV, 1 = cGLL, 2
        //   = dGLL]
        //   11. method_b: The type of discretization for field on target mesh: [0 = FV, 1 = cGLL, 2
        //   = dGLL]
        //   12. conserved: Flag to specify whether the remap operator has conservation constraints:
        //   [0, 1]
        //   13. monotonicity: Flags to specify whether the remap operator has monotonicity
        //   constraints: [0, 1, 2]
        Tag smatMetadataTag;
        int smat_metadata_glb[13];
        rval = mbCore->tag_get_handle( "SMAT_DATA", 13, MB_TYPE_INTEGER, smatMetadataTag, MB_TAG_SPARSE );MB_CHK_ERR( rval );
        rval = mbCore->tag_get_data( smatMetadataTag, &rootset, 1, smat_metadata_glb );MB_CHK_ERR( rval );
        // std::cout << "Number of mesh sets is " << meshsets.size() << std::endl;
#define DTYPE( a )                                                       \
        // Map dimensions
        int nA              = smat_metadata_glb[0];
        int nB              = smat_metadata_glb[1];
        int nVA             = smat_metadata_glb[2];
        int nVB             = smat_metadata_glb[3];
        int nDofB           = smat_metadata_glb[4];
        int nDofA           = smat_metadata_glb[5];
        int NNZ             = smat_metadata_glb[6];
        int nOrdA           = smat_metadata_glb[7];
        int nOrdB           = smat_metadata_glb[8];
        int nBasA           = smat_metadata_glb[9];
        std::string methodA = DTYPE( nBasA );
        int nBasB           = smat_metadata_glb[10];
        std::string methodB = DTYPE( nBasB );
        int bConserved      = smat_metadata_glb[11];
        int bMonotonicity   = smat_metadata_glb[12];
        EntityHandle source_mesh = 0, target_mesh = 0, overlap_mesh = 0;
        for( unsigned im = 0; im < meshsets.size(); ++im )
            moab::Range elems;
            rval = mbCore->get_entities_by_dimension( meshsets[im], 2, elems );MB_CHK_ERR( rval );
            if( elems.size() - nA == 0 && source_mesh == 0 )
                source_mesh = meshsets[im];
            else if( elems.size() - nB == 0 && target_mesh == 0 )
                target_mesh = meshsets[im];
            else if( overlap_mesh == 0 )
                overlap_mesh = meshsets[im];
            else
                continue;
        Tag srcIDTag, srcAreaTag, tgtIDTag, tgtAreaTag;
        rval = mbCore->tag_get_handle( "SourceGIDS", srcIDTag );MB_CHK_ERR( rval );
        rval = mbCore->tag_get_handle( "SourceAreas", srcAreaTag );MB_CHK_ERR( rval );
        rval = mbCore->tag_get_handle( "TargetGIDS", tgtIDTag );MB_CHK_ERR( rval );
        rval = mbCore->tag_get_handle( "TargetAreas", tgtAreaTag );MB_CHK_ERR( rval );
        Tag smatRowdataTag, smatColdataTag, smatValsdataTag;
        rval = mbCore->tag_get_handle( "SMAT_ROWS", smatRowdataTag );MB_CHK_ERR( rval );
        rval = mbCore->tag_get_handle( "SMAT_COLS", smatColdataTag );MB_CHK_ERR( rval );
        rval = mbCore->tag_get_handle( "SMAT_VALS", smatValsdataTag );MB_CHK_ERR( rval );
        Tag srcCenterLon, srcCenterLat, tgtCenterLon, tgtCenterLat;
        rval = mbCore->tag_get_handle( "SourceCoordCenterLon", srcCenterLon );MB_CHK_ERR( rval );
        rval = mbCore->tag_get_handle( "SourceCoordCenterLat", srcCenterLat );MB_CHK_ERR( rval );
        rval = mbCore->tag_get_handle( "TargetCoordCenterLon", tgtCenterLon );MB_CHK_ERR( rval );
        rval = mbCore->tag_get_handle( "TargetCoordCenterLat", tgtCenterLat );MB_CHK_ERR( rval );
        Tag srcVertexLon, srcVertexLat, tgtVertexLon, tgtVertexLat;
        rval = mbCore->tag_get_handle( "SourceCoordVertexLon", srcVertexLon );MB_CHK_ERR( rval );
        rval = mbCore->tag_get_handle( "SourceCoordVertexLat", srcVertexLat );MB_CHK_ERR( rval );
        rval = mbCore->tag_get_handle( "TargetCoordVertexLon", tgtVertexLon );MB_CHK_ERR( rval );
        rval = mbCore->tag_get_handle( "TargetCoordVertexLat", tgtVertexLat );MB_CHK_ERR( rval );
        moab::Range sets;
        // rval = mbCore->get_entities_by_type(0, MBENTITYSET, sets);MB_CHK_ERR(rval);
        rval = mbCore->get_entities_by_type_and_tag( 0, MBENTITYSET, &smatRowdataTag, NULL, 1, sets,
        std::vector< int > src_gids, tgt_gids;
        std::vector< double > src_areas, tgt_areas;
        int srcID_size, tgtID_size, srcArea_size, tgtArea_size;
        rval = get_vartag_data( mbCore, srcIDTag, sets, srcID_size, src_gids );MB_CHK_SET_ERR( rval, "Getting source mesh IDs failed" );
        rval = get_vartag_data( mbCore, tgtIDTag, sets, tgtID_size, tgt_gids );MB_CHK_SET_ERR( rval, "Getting target mesh IDs failed" );
        rval = get_vartag_data( mbCore, srcAreaTag, sets, srcArea_size, src_areas );MB_CHK_SET_ERR( rval, "Getting source mesh areas failed" );
        rval = get_vartag_data( mbCore, tgtAreaTag, sets, tgtArea_size, tgt_areas );MB_CHK_SET_ERR( rval, "Getting target mesh areas failed" );
        assert( srcArea_size == srcID_size );
        assert( tgtArea_size == tgtID_size );
        std::vector< double > src_glob_areas( nDofA, 0.0 ), tgt_glob_areas( nDofB, 0.0 );
        for( int i = 0; i < srcArea_size; ++i )
            // printf("%d/%d: %d = Found ID %d and area %5.6e\n", i, srcArea_size, nDofA,
            // src_gids[i], src_areas[i]);
            assert( i < srcID_size );
            assert( src_gids[i] < nDofA );
            if( src_areas[i] > src_glob_areas[src_gids[i]] ) src_glob_areas[src_gids[i]] = src_areas[i];
        for( int i = 0; i < tgtArea_size; ++i )
            // printf("%d/%d: %d = Found ID %d and area %5.6e\n", i, tgtArea_size, nDofB,
            // tgt_gids[i], tgt_areas[i]);
            assert( i < tgtID_size );
            assert( tgt_gids[i] < nDofB );
            if( tgt_areas[i] > tgt_glob_areas[tgt_gids[i]] ) tgt_glob_areas[tgt_gids[i]] = tgt_areas[i];
        // Write output dimensions entries
        int nSrcGridDims = 1;
        int nDstGridDims = 1;
        NcDim* dimSrcGridRank = ncMap.add_dim( "src_grid_rank", nSrcGridDims );
        NcDim* dimDstGridRank = ncMap.add_dim( "dst_grid_rank", nDstGridDims );
        NcVar* varSrcGridDims = ncMap.add_var( "src_grid_dims", ncInt, dimSrcGridRank );
        NcVar* varDstGridDims = ncMap.add_var( "dst_grid_dims", ncInt, dimDstGridRank );
        if( nA == nDofA )
            varSrcGridDims->put( &nA, 1 );
            varSrcGridDims->add_att( "name0", "num_elem" );
        else
            varSrcGridDims->put( &nDofA, 1 );
            varSrcGridDims->add_att( "name1", "num_dof" );
        if( nB == nDofB )
            varDstGridDims->put( &nB, 1 );
            varDstGridDims->add_att( "name0", "num_elem" );
        else
            varDstGridDims->put( &nDofB, 1 );
            varDstGridDims->add_att( "name1", "num_dof" );
        // Source and Target mesh resolutions
        NcDim* dimNA = ncMap.add_dim( "n_a", nDofA );
        NcDim* dimNB = ncMap.add_dim( "n_b", nDofB );
        // Source and Target verticecs per elements
        const int nva = ( nA == nDofA ? nVA : 1 );
        const int nvb = ( nB == nDofB ? nVB : 1 );
        NcDim* dimNVA = ncMap.add_dim( "nv_a", nva );
        NcDim* dimNVB = ncMap.add_dim( "nv_b", nvb );
        // NcDim * dimNEA = ncMap.add_dim("ne_a", nA);
        // NcDim * dimNEB = ncMap.add_dim("ne_b", nB);
        if( writeXYCoords )
            // Write coordinates
            NcVar* varYCA = ncMap.add_var( "yc_a", ncDouble, dimNA /*dimNA*/ );
            NcVar* varYCB = ncMap.add_var( "yc_b", ncDouble, dimNB /*dimNB*/ );
            NcVar* varXCA = ncMap.add_var( "xc_a", ncDouble, dimNA /*dimNA*/ );
            NcVar* varXCB = ncMap.add_var( "xc_b", ncDouble, dimNB /*dimNB*/ );
            NcVar* varYVA = ncMap.add_var( "yv_a", ncDouble, dimNA /*dimNA*/, dimNVA );
            NcVar* varYVB = ncMap.add_var( "yv_b", ncDouble, dimNB /*dimNB*/, dimNVB );
            NcVar* varXVA = ncMap.add_var( "xv_a", ncDouble, dimNA /*dimNA*/, dimNVA );
            NcVar* varXVB = ncMap.add_var( "xv_b", ncDouble, dimNB /*dimNB*/, dimNVB );
            varYCA->add_att( "units", "degrees" );
            varYCB->add_att( "units", "degrees" );
            varXCA->add_att( "units", "degrees" );
            varXCB->add_att( "units", "degrees" );
            varYVA->add_att( "units", "degrees" );
            varYVB->add_att( "units", "degrees" );
            varXVA->add_att( "units", "degrees" );
            varXVB->add_att( "units", "degrees" );
            std::vector< double > src_centerlat, src_centerlon;
            int srccenter_size;
            rval = get_vartag_data( mbCore, srcCenterLat, sets, srccenter_size, src_centerlat );MB_CHK_SET_ERR( rval, "Getting source mesh areas failed" );
            rval = get_vartag_data( mbCore, srcCenterLon, sets, srccenter_size, src_centerlon );MB_CHK_SET_ERR( rval, "Getting target mesh areas failed" );
            std::vector< double > src_glob_centerlat( nDofA, 0.0 ), src_glob_centerlon( nDofA, 0.0 );
            for( int i = 0; i < srccenter_size; ++i )
                src_glob_centerlat[src_gids[i]] = src_centerlat[i];
                src_glob_centerlon[src_gids[i]] = src_centerlon[i];
            std::vector< double > tgt_centerlat, tgt_centerlon;
            int tgtcenter_size;
            rval = get_vartag_data( mbCore, tgtCenterLat, sets, tgtcenter_size, tgt_centerlat );MB_CHK_SET_ERR( rval, "Getting source mesh areas failed" );
            rval = get_vartag_data( mbCore, tgtCenterLon, sets, tgtcenter_size, tgt_centerlon );MB_CHK_SET_ERR( rval, "Getting target mesh areas failed" );
            std::vector< double > tgt_glob_centerlat( nDofB, 0.0 ), tgt_glob_centerlon( nDofB, 0.0 );
            for( int i = 0; i < tgtcenter_size; ++i )
                tgt_glob_centerlat[tgt_gids[i]] = tgt_centerlat[i];
                tgt_glob_centerlon[tgt_gids[i]] = tgt_centerlon[i];
            varYCA->put( &( src_glob_centerlat[0] ), nDofA );
            varYCB->put( &( tgt_glob_centerlat[0] ), nDofB );
            varXCA->put( &( src_glob_centerlon[0] ), nDofA );
            varXCB->put( &( tgt_glob_centerlon[0] ), nDofB );
            src_centerlat.clear();
            src_centerlon.clear();
            tgt_centerlat.clear();
            tgt_centerlon.clear();
            DataArray2D< double > src_glob_vertexlat( nDofA, nva ), src_glob_vertexlon( nDofA, nva );
            if( nva > 1 )
                std::vector< double > src_vertexlat, src_vertexlon;
                int srcvertex_size;
                rval = get_vartag_data( mbCore, srcVertexLat, sets, srcvertex_size, src_vertexlat );MB_CHK_SET_ERR( rval, "Getting source mesh areas failed" );
                rval = get_vartag_data( mbCore, srcVertexLon, sets, srcvertex_size, src_vertexlon );MB_CHK_SET_ERR( rval, "Getting target mesh areas failed" );
                int offset = 0;
                for( unsigned vIndex = 0; vIndex < src_gids.size(); ++vIndex )
                    for( int vNV = 0; vNV < nva; ++vNV )
                        assert( offset < srcvertex_size );
                        src_glob_vertexlat[src_gids[vIndex]][vNV] = src_vertexlat[offset];
                        src_glob_vertexlon[src_gids[vIndex]][vNV] = src_vertexlon[offset];
                        offset++;
            DataArray2D< double > tgt_glob_vertexlat( nDofB, nvb ), tgt_glob_vertexlon( nDofB, nvb );
            if( nvb > 1 )
                std::vector< double > tgt_vertexlat, tgt_vertexlon;
                int tgtvertex_size;
                rval = get_vartag_data( mbCore, tgtVertexLat, sets, tgtvertex_size, tgt_vertexlat );MB_CHK_SET_ERR( rval, "Getting source mesh areas failed" );
                rval = get_vartag_data( mbCore, tgtVertexLon, sets, tgtvertex_size, tgt_vertexlon );MB_CHK_SET_ERR( rval, "Getting target mesh areas failed" );
                int offset = 0;
                for( unsigned vIndex = 0; vIndex < tgt_gids.size(); ++vIndex )
                    for( int vNV = 0; vNV < nvb; ++vNV )
                        assert( offset < tgtvertex_size );
                        tgt_glob_vertexlat[tgt_gids[vIndex]][vNV] = tgt_vertexlat[offset];
                        tgt_glob_vertexlon[tgt_gids[vIndex]][vNV] = tgt_vertexlon[offset];
                        offset++;
            varYVA->put( &( src_glob_vertexlat[0][0] ), nDofA, nva );
            varYVB->put( &( tgt_glob_vertexlat[0][0] ), nDofB, nvb );
            varXVA->put( &( src_glob_vertexlon[0][0] ), nDofA, nva );
            varXVB->put( &( tgt_glob_vertexlon[0][0] ), nDofB, nvb );
        // Write areas
        NcVar* varAreaA = ncMap.add_var( "area_a", ncDouble, dimNA );
        varAreaA->put( &( src_glob_areas[0] ), nDofA );
        // varAreaA->add_att("units", "steradians");
        NcVar* varAreaB = ncMap.add_var( "area_b", ncDouble, dimNB );
        varAreaB->put( &( tgt_glob_areas[0] ), nDofB );
        // varAreaB->add_att("units", "steradians");
        std::vector< int > mat_rows, mat_cols;
        std::vector< double > mat_vals;
        int row_sizes, col_sizes, val_sizes;
        rval = get_vartag_data( mbCore, smatRowdataTag, sets, row_sizes, mat_rows );MB_CHK_SET_ERR( rval, "Getting matrix row data failed" );
        assert( row_sizes == NNZ );
        rval = get_vartag_data( mbCore, smatColdataTag, sets, col_sizes, mat_cols );MB_CHK_SET_ERR( rval, "Getting matrix col data failed" );
        assert( col_sizes == NNZ );
        rval = get_vartag_data( mbCore, smatValsdataTag, sets, val_sizes, mat_vals );MB_CHK_SET_ERR( rval, "Getting matrix values failed" );
        assert( val_sizes == NNZ );
        // Let us form the matrix in-memory and consolidate shared DoF rows from shared-process
        // contributions
        SparseMatrix< double > mapMatrix;
        for( int innz = 0; innz < NNZ; ++innz )
#ifdef VERBOSE
            if( fabs( mapMatrix( mat_rows[innz], mat_cols[innz] ) ) > 1e-12 )
                printf( "Adding to existing loc: (%d, %d) = %12.8f\n", mat_rows[innz], mat_cols[innz],
                        mapMatrix( mat_rows[innz], mat_cols[innz] ) );
#endif
            mapMatrix( mat_rows[innz], mat_cols[innz] ) += mat_vals[innz];
        // Write SparseMatrix entries
        DataArray1D< int > vecRow;
        DataArray1D< int > vecCol;
        DataArray1D< double > vecS;
        mapMatrix.GetEntries( vecRow, vecCol, vecS );
        int nS = vecS.GetRows();
        // Print more information about what we are converting:
        // Source elements/vertices/type (Discretization ?)
        // Target elements/vertices/type (Discretization ?)
        // Overlap elements/types
        // Rmeapping weights matrix: rows/cols/NNZ
        // Output the number of sets
        printf( "Primary sets: %15zu\n", sets.size() );
        printf( "Original NNZ: %18d\n", NNZ );
        printf( "Consolidated Total NNZ: %8d\n", nS );
        printf( "Conservative weights ? %6d\n", ( bConserved > 0 ) );
        printf( "Monotone weights ? %10d\n", ( bMonotonicity > 0 ) );
        printf( "\n--------------------------------------------------------------\n" );
        printf( "%20s %21s %15s\n", "Description", "Source", "Target" );
        printf( "--------------------------------------------------------------\n" );
        printf( "%25s %15d %15d\n", "Number of elements:", nA, nB );
        printf( "%25s %15d %15d\n", "Number of DoFs:", nDofA, nDofB );
        printf( "%25s %15d %15d\n", "Maximum vertex/element:", nVA, nVB );
        printf( "%25s %15s %15s\n", "Discretization type:", methodA.c_str(), methodB.c_str() );
        printf( "%25s %15d %15d\n", "Discretization order:", nOrdA, nOrdB );
        // Calculate and write fractional coverage arrays
            DataArray1D< double > dFracA( nDofA );
            DataArray1D< double > dFracB( nDofB );
            for( int i = 0; i < nS; i++ )
                // std::cout << i << " - mat_vals = " << mat_vals[i] << " dFracA = " << mat_vals[i]
                // / src_glob_areas[vecCol[i]] * tgt_glob_areas[vecRow[i]] << std::endl;
                dFracA[vecCol[i]] += vecS[i] / src_glob_areas[vecCol[i]] * tgt_glob_areas[vecRow[i]];
                dFracB[vecRow[i]] += vecS[i];
            NcVar* varFracA = ncMap.add_var( "frac_a", ncDouble, dimNA );
            varFracA->put( &( dFracA[0] ), nDofA );
            varFracA->add_att( "name", "fraction of target coverage of source dof" );
            varFracA->add_att( "units", "unitless" );
            NcVar* varFracB = ncMap.add_var( "frac_b", ncDouble, dimNB );
            varFracB->put( &( dFracB[0] ), nDofB );
            varFracB->add_att( "name", "fraction of source coverage of target dof" );
            varFracB->add_att( "units", "unitless" );
        // Write out data
        NcDim* dimNS = ncMap.add_dim( "n_s", nS );
        NcVar* varRow = ncMap.add_var( "row", ncInt, dimNS );
        varRow->add_att( "name", "sparse matrix target dof index" );
        varRow->add_att( "first_index", "1" );
        NcVar* varCol = ncMap.add_var( "col", ncInt, dimNS );
        varCol->add_att( "name", "sparse matrix source dof index" );
        varCol->add_att( "first_index", "1" );
        NcVar* varS = ncMap.add_var( "S", ncDouble, dimNS );
        varS->add_att( "name", "sparse matrix coefficient" );
        // Increment vecRow and vecCol: make it 1-based
            vecRow[i]++;
            vecCol[i]++;
        varRow->set_cur( (long)0 );
        varRow->put( &( vecRow[0] ), nS );
        varCol->set_cur( (long)0 );
        varCol->put( &( vecCol[0] ), nS );
        varS->set_cur( (long)0 );
        varS->put( &( vecS[0] ), nS );
        ncMap.close();
        // rval = mbCore->write_file(scripfile.c_str());MB_CHK_ERR(rval);
    catch( std::exception& e )
        std::cout << " exception caught during tree initialization " << e.what() << std::endl;
    delete mbCore;
    MPI_Finalize();
#endif
    exit( 0 );
void ReadFileMetaData ( std::string &  metaFilename,
std::map< std::string, std::string > &  metadataVals
Definition at line 62 of file h5mtoscrip.cpp.
    std::ifstream metafile;
    std::string line;
    metafile.open( metaFilename.c_str() );
    metadataVals["Title"] = "MOAB-TempestRemap (MBTR) Offline Regridding Weight Converter (h5mtoscrip)";
    std::string key, value;
    while( std::getline( metafile, line ) )
        size_t lastindex = line.find_last_of( "=" );
        key              = line.substr( 0, lastindex - 1 );
        value            = line.substr( lastindex + 2, line.length() );
        metadataVals[std::string( key )] = std::string( value );
    metafile.close();
