merge_test.cpp File Reference
#include <vector>
#include <utility>
#include <iostream>
#include "moab/Core.hpp"
#include "moab/Interface.hpp"
#include "moab/Range.hpp"
+ Include dependency graph for merge_test.cpp:
Classes
class  EntityCount
Functions
bool points_are_coincident (const double *first, const double *second)
ErrorCode find_coincident_nodes (Range vertices, std::vector< std::pair< EntityHandle, EntityHandle > > &coin_nodes)
ErrorCode find_coincident_edges (Range entities, std::vector< std::pair< EntityHandle, EntityHandle > > &coin_edges)
ErrorCode find_coincident_elements (Range entities, int num_nodes, std::vector< std::pair< EntityHandle, EntityHandle > > &coin)
ErrorCode coincident_counts (EntityCount &curr_count, EntityCount &diff_count)
ErrorCode merge_top_down (EntityCount &init_count, EntityCount &curr_count)
ErrorCode merge_nodes (EntityCount &init_count, EntityCount &curr_count)
ErrorCode merge_edges (EntityCount &init_count, EntityCount &curr_count)
ErrorCode merge_2D_elem (EntityCount &init_count, EntityCount &curr_count)
ErrorCode merge_3D_elem (EntityCount &init_count, EntityCount &curr_count)
ErrorCode read_file (std::string &file_name, EntityCount &counts)
ErrorCode write_file (std::string &file_name)
ErrorCode process_td_auto_merge (std::string &file_name)
ErrorCode process_mo_auto_merge (std::string &file_name)
ErrorCode process_bu_auto_merge (std::string &file_name)
ErrorCode process_merge (std::string &file_name)
int main ()
Variables
InterfacegMB = 0
Function Documentation
ErrorCode coincident_counts ( EntityCount curr_count,
EntityCount diff_count
Definition at line 275 of file merge_test.cpp.
References moab::Range::clear(), EntityCount::edge, entities, find_coincident_edges(), find_coincident_elements(), find_coincident_nodes(), moab::Interface::get_entities_by_type(), gMB, EntityCount::hex, MB_SUCCESS, MBEDGE, MBHEX, MBQUAD, MBTET, MBTRI, MBVERTEX, EntityCount::node, EntityCount::quad, EntityCount::tet, and EntityCount::tri.
Referenced by merge_top_down(), process_bu_auto_merge(), process_mo_auto_merge(), and process_td_auto_merge().
    Range entities;
    std::vector< std::pair< EntityHandle, EntityHandle > > coincident;
    if( curr_count.node > 0 )
        if( gMB->get_entities_by_type( 0, MBVERTEX, entities ) != MB_SUCCESS ) return MB_FAILURE;
        find_coincident_nodes( entities, coincident );
        diff_count.node = coincident.size();
        entities.clear();
        coincident.clear();
    if( curr_count.edge > 0 )
        if( gMB->get_entities_by_type( 0, MBEDGE, entities ) != MB_SUCCESS ) return MB_FAILURE;
        find_coincident_edges( entities, coincident );
        diff_count.edge = coincident.size();
        entities.clear();
        coincident.clear();
    if( curr_count.quad > 0 )
        if( gMB->get_entities_by_type( 0, MBQUAD, entities ) != MB_SUCCESS ) return MB_FAILURE;
        find_coincident_elements( entities, 4, coincident );
        diff_count.quad = coincident.size();
        entities.clear();
        coincident.clear();
    if( curr_count.tri > 0 )
        if( gMB->get_entities_by_type( 0, MBTRI, entities ) != MB_SUCCESS ) return MB_FAILURE;
        find_coincident_elements( entities, 3, coincident );
        diff_count.tri = coincident.size();
        entities.clear();
        coincident.clear();
    if( curr_count.tet > 0 )
        if( gMB->get_entities_by_type( 0, MBTET, entities ) != MB_SUCCESS ) return MB_FAILURE;
        diff_count.tet = coincident.size();
        entities.clear();
        coincident.clear();
    if( curr_count.hex > 0 )
        if( gMB->get_entities_by_type( 0, MBHEX, entities ) != MB_SUCCESS ) return MB_FAILURE;
        find_coincident_elements( entities, 8, coincident );
        diff_count.hex = coincident.size();
        entities.clear();
        coincident.clear();
    return MB_SUCCESS;
ErrorCode find_coincident_edges ( Range  entities,
std::vector< std::pair< EntityHandle, EntityHandle > > &  coin_edges
Definition at line 171 of file merge_test.cpp.
References moab::Range::begin(), conn, moab::Range::end(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), gMB, MB_SUCCESS, and points_are_coincident().
Referenced by coincident_counts(), merge_edges(), merge_top_down(), process_mo_auto_merge(), and process_td_auto_merge().
    double coords1[3], coords2[3], coords3[3];
    Range::iterator iter, jter;
    std::vector< EntityHandle > conn( 2 );
    std::pair< EntityHandle, EntityHandle > coincident_pair;
    for( iter = entities.begin(); iter != entities.end(); ++iter )
        if( gMB->get_connectivity( &*iter, 1, conn ) != MB_SUCCESS ) return MB_FAILURE;
        // Get the coordinates for the edge endpoints.
        if( gMB->get_coords( &conn[0], 1, coords1 ) != MB_SUCCESS ) return MB_FAILURE;
        if( gMB->get_coords( &conn[1], 1, coords2 ) != MB_SUCCESS ) return MB_FAILURE;
        for( jter = iter; jter != entities.end(); ++jter )
            if( *iter != *jter )
                // Edges should be the same sense to merge.
                if( gMB->get_connectivity( &*jter, 1, conn ) != MB_SUCCESS ) return MB_FAILURE;
                if( gMB->get_coords( &conn[0], 1, coords3 ) != MB_SUCCESS ) return MB_FAILURE;
                if( points_are_coincident( coords1, coords3 ) )
                    if( gMB->get_coords( &conn[1], 1, coords3 ) != MB_SUCCESS ) return MB_FAILURE;
                    if( points_are_coincident( coords2, coords3 ) )
                        coincident_pair.first  = *iter;
                        coincident_pair.second = *jter;
                        coin_edges.push_back( coincident_pair );
    return MB_SUCCESS;
ErrorCode find_coincident_elements ( Range  entities,
int  num_nodes,
Definition at line 214 of file merge_test.cpp.
    double coords1[8][3], coords2[8][3];
    std::vector< EntityHandle > conn( 8 );
    int i = 0, j = 0, ii = 0;
        // Get the coordinates for the element corners.
        for( ii = 0; ii < num_nodes; ii++ )
            if( gMB->get_coords( &conn[ii], 1, coords1[ii] ) != MB_SUCCESS ) return MB_FAILURE;
                // Elements should be the same sense to merge.
                if( gMB->get_coords( &conn[0], 1, coords2[0] ) != MB_SUCCESS ) return MB_FAILURE;
                // Find if first node is coincident before testing the rest.
                for( i = 0; i < num_nodes; i++ )
                    if( points_are_coincident( coords1[i], coords2[0] ) ) break;
                if( i < num_nodes )
                    for( ii = 1; ii < num_nodes; ii++ )
                        if( gMB->get_coords( &conn[ii], 1, coords2[ii] ) != MB_SUCCESS ) return MB_FAILURE;
                    for( j = 1; j < num_nodes; j++ )
                        if( !points_are_coincident( coords1[j], coords2[( j + i ) % num_nodes] ) ) break;
                    if( j == num_nodes )
                        coin.push_back( coincident_pair );
    return MB_SUCCESS;
ErrorCode find_coincident_nodes ( Range  vertices,
std::vector< std::pair< EntityHandle, EntityHandle > > &  coin_nodes
Definition at line 140 of file merge_test.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_coords(), gMB, MB_SUCCESS, and points_are_coincident().
    double first_coords[3], second_coords[3];
    ErrorCode result;
    for( iter = vertices.begin(); iter != vertices.end(); ++iter )
        result = gMB->get_coords( &*iter, 1, first_coords );
        if( result != MB_SUCCESS ) return result;
        for( jter = iter; jter != vertices.end(); ++jter )
                result = gMB->get_coords( &*jter, 1, second_coords );
                if( points_are_coincident( first_coords, second_coords ) )
                    coin_nodes.push_back( coincident_pair );
    return MB_SUCCESS;
int main ( )
Definition at line 945 of file merge_test.cpp.
References ErrorCode, gMB, MB_SUCCESS, process_bu_auto_merge(), process_merge(), process_mo_auto_merge(), and process_td_auto_merge().
    ErrorCode result;
    std::string test_files[] = {
        std::string( "test/2barcase1.g" ),  std::string( "test/2barcase2.g" ),  std::string( "test/2hexcase1.g" ),
        std::string( "test/2hexcase2.g" ),  std::string( "test/2hexcase3.g" ),  std::string( "test/2hexcase4.g" ),
        std::string( "test/2hexcase5.g" ),  std::string( "test/2quadcase1.g" ), std::string( "test/2quadcase2.g" ),
        std::string( "test/2quadcase3.g" ), std::string( "test/2quadcase4.g" ), std::string( "test/2tetcase1.g" ),
        std::string( "test/2tetcase2.g" ),  std::string( "test/2tetcase3.g" ),  std::string( "test/2tetcase4.g" ),
        std::string( "test/2tricase1.g" ),  std::string( "test/2tricase2.g" ),  std::string( "test/2tricase3.g" ) };
    // Create the MB database instance.
    gMB = new Core();
    // Loop through the list of test files.
    unsigned int i;
    cout << "---Starting Top Down Auto Merge Tests---" << endl << endl;
    for( i = 0; i < ( sizeof( test_files ) / sizeof( std::string ) ); i++ )
        cout << "---Testing:\"" << test_files[i] << "\"---" << endl;
        result = process_td_auto_merge( test_files[i] );
        if( result == MB_SUCCESS )
            cout << "---Success---";
        else
            cout << "---Failure---";
        cout << endl << endl;
    cout << "---Starting Bottom Up Auto Merge Tests---" << endl << endl;
        result = process_bu_auto_merge( test_files[i] );
        else
    cout << "---Starting Middle Out Auto Merge Tests---" << endl << endl;
        result = process_mo_auto_merge( test_files[i] );
        else
    cout << "---Starting Merge Tests---" << endl << endl;
        result = process_merge( test_files[i] );
        else
    // Destroy the MB database instance.
    delete gMB;
    gMB = NULL;
ErrorCode merge_2D_elem ( EntityCount init_count,
Definition at line 481 of file merge_test.cpp.
References moab::Range::clear(), EntityCount::edge, entities, ErrorCode, find_coincident_elements(), EntityCount::get_counts(), moab::Interface::get_entities_by_type(), gMB, EntityCount::hex, moab::Interface::id_from_handle(), MB_SUCCESS, MBQUAD, MBTRI, moab::Interface::merge_entities(), EntityCount::node, EntityCount::quad, EntityCount::tet, and EntityCount::tri.
Referenced by process_merge().
    cout << "Merging Coincident 2D Elements:" << endl;
    // Get the list of tris from the database.
    Range entities;
    ErrorCode result = gMB->get_entities_by_type( 0, MBTRI, entities );
    // find the coincident tri pairs
    // merge the coincident tris
    unsigned long id1, id2;
    unsigned int tri_diff = coincident.size();
    std::vector< std::pair< EntityHandle, EntityHandle > >::iterator iter;
    for( iter = coincident.begin(); iter != coincident.end(); ++iter )
        id1 = gMB->id_from_handle( ( *iter ).first );
        id2 = gMB->id_from_handle( ( *iter ).second );
        cout << "   Coincident tris: " << id1 << "-" << id2 << endl;
        result = gMB->merge_entities( ( *iter ).first, ( *iter ).second, false, true );
    // Get the list of quads from the database.
    entities.clear();
    result = gMB->get_entities_by_type( 0, MBQUAD, entities );
    coincident.clear();
    unsigned int quad_diff = coincident.size();
        cout << "   Coincident quads: " << id1 << "-" << id2 << endl;
    // Get the reduced list of faces.
    curr_count.get_counts();
    // Make sure the coincident faces were all merged.
    if( init_count.tri - curr_count.tri != tri_diff )
        cout << "***ERROR: Not all coincident tris were merged.***" << endl;
        return MB_FAILURE;
    if( init_count.quad - curr_count.quad != quad_diff )
        cout << "***ERROR: Not all coincident quads were merged.***" << endl;
        return MB_FAILURE;
    init_count.tri  = curr_count.tri;
    init_count.quad = curr_count.quad;
    // Make sure we didn't merge anything else.
    if( init_count.node != curr_count.node || init_count.edge != curr_count.edge || init_count.hex != curr_count.hex ||
        init_count.tet != curr_count.tet )
        cout << "***ERROR: Merged other objects when merging faces.***" << endl;
        return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode merge_3D_elem ( EntityCount init_count,
Definition at line 557 of file merge_test.cpp.
References moab::Range::clear(), EntityCount::edge, entities, ErrorCode, find_coincident_elements(), EntityCount::get_counts(), moab::Interface::get_entities_by_type(), gMB, EntityCount::hex, moab::Interface::id_from_handle(), MB_SUCCESS, MBHEX, MBTET, moab::Interface::merge_entities(), EntityCount::node, EntityCount::quad, EntityCount::tet, and EntityCount::tri.
    cout << "Merging Coincident 3D Elements:" << endl;
    // Get the list of tets from the database.
    Range entities;
    ErrorCode result = gMB->get_entities_by_type( 0, MBTET, entities );
    // find the coincident tet pairs
    // merge the coincident tets
    unsigned int tet_diff = coincident.size();
        cout << "   Coincident tets: " << id1 << "-" << id2 << endl;
    // Get the list of hexs from the database.
    entities.clear();
    result = gMB->get_entities_by_type( 0, MBHEX, entities );
    // find the coincident hex pairs
    coincident.clear();
    unsigned int hex_diff = coincident.size();
        cout << "   Coincident hexs: " << id1 << "-" << id2 << endl;
    // Get the reduced list of elements.
    // Make sure the coincident elements were all merged.
    if( init_count.tet - curr_count.tet != tet_diff )
        cout << "***ERROR: Not all coincident tets were merged.***" << endl;
        return MB_FAILURE;
    if( init_count.hex - curr_count.hex != hex_diff )
        cout << "***ERROR: Not all coincident hexs were merged.***" << endl;
        return MB_FAILURE;
    init_count.tet = curr_count.tet;
    init_count.hex = curr_count.hex;
        init_count.quad != curr_count.quad || init_count.tri != curr_count.tri )
        cout << "***ERROR: Merged other objects when merging elements.***" << endl;
        return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode merge_edges ( EntityCount init_count,
Definition at line 433 of file merge_test.cpp.
References EntityCount::edge, entities, ErrorCode, find_coincident_edges(), EntityCount::get_counts(), moab::Interface::get_entities_by_type(), gMB, EntityCount::hex, moab::Interface::id_from_handle(), MB_SUCCESS, MBEDGE, moab::Interface::merge_entities(), EntityCount::node, EntityCount::quad, EntityCount::tet, and EntityCount::tri.
    cout << "Merging Coincident Edges:" << endl;
    // Get the list of entities from the database.
    Range entities;
    ErrorCode result = gMB->get_entities_by_type( 0, MBEDGE, entities );
    // find the coincident edge pairs
    std::vector< std::pair< EntityHandle, EntityHandle > > coincident_edges;
    find_coincident_edges( entities, coincident_edges );
    // merge the coincident edges
    for( iter = coincident_edges.begin(); iter != coincident_edges.end(); ++iter )
        cout << "   Coincident edges: " << id1 << "-" << id2 << endl;
    // Get the reduced list of edges.
    // Make sure the coincident edges were all merged.
    if( init_count.edge - curr_count.edge != coincident_edges.size() )
        cout << "***ERROR: Not all coincident edges were merged.***" << endl;
        return MB_FAILURE;
    init_count.edge = curr_count.edge;
    if( init_count.node != curr_count.node || init_count.quad != curr_count.quad || init_count.tri != curr_count.tri ||
        init_count.hex != curr_count.hex || init_count.tet != curr_count.tet )
        cout << "***ERROR: Merged other objects when merging edges.***" << endl;
        return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode merge_nodes ( EntityCount init_count,
Definition at line 388 of file merge_test.cpp.
References EntityCount::edge, ErrorCode, find_coincident_nodes(), EntityCount::get_counts(), moab::Interface::get_entities_by_type(), gMB, EntityCount::hex, MB_SUCCESS, MBVERTEX, moab::Interface::merge_entities(), EntityCount::node, EntityCount::quad, EntityCount::tet, and EntityCount::tri.
    cout << "Merging Coincident Nodes:" << endl;
    // Get the list of vertices from the database.
    Range vertices;
    ErrorCode result = gMB->get_entities_by_type( 0, MBVERTEX, vertices );
    // find the coincident node pairs
    std::vector< std::pair< EntityHandle, EntityHandle > > coincident_nodes;
    find_coincident_nodes( vertices, coincident_nodes );
    // merge the coincident nodes
    for( iter = coincident_nodes.begin(); iter != coincident_nodes.end(); ++iter )
        cout << "   Coincident nodes: " << ( *iter ).first << "-" << ( *iter ).second << endl;
    // Get the reduced list of vertices.
    // Make sure the coincident nodes were all merged.
    if( init_count.node - curr_count.node != coincident_nodes.size() )
        cout << "***ERROR: Not all coincident nodes were merged.***" << endl;
        return MB_FAILURE;
    init_count.node = curr_count.node;
    if( init_count.edge != curr_count.edge || init_count.quad != curr_count.quad || init_count.tri != curr_count.tri ||
        cout << "***ERROR: Merged other objects when merging nodes.***" << endl;
        return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode merge_top_down ( EntityCount init_count,
Definition at line 332 of file merge_test.cpp.
References coincident_counts(), EntityCount::edge, entities, find_coincident_edges(), find_coincident_elements(), EntityCount::get_counts(), moab::Interface::get_entities_by_type(), gMB, EntityCount::hex, MB_SUCCESS, MBEDGE, MBHEX, MBQUAD, MBTET, MBTRI, moab::Interface::merge_entities(), EntityCount::node, EntityCount::quad, EntityCount::tet, and EntityCount::tri.
    Range entities;
    EntityCount diff_count;
    // Find how many objects of each type need to be merged.
    if( coincident_counts( curr_count, diff_count ) != MB_SUCCESS ) return MB_FAILURE;
    // Find the top level object to merge.
    if( diff_count.hex > 0 )
    else if( diff_count.quad > 0 )
    else if( diff_count.tet > 0 )
    else if( diff_count.tri > 0 )
    else if( diff_count.edge > 0 )
    // Get the new entity totals.
    // Make sure we didn't merge anything.
        init_count.quad != curr_count.quad || init_count.tri != curr_count.tri || init_count.hex != curr_count.hex ||
        cout << "***ERROR: Merged top down when not using auto merge.***" << endl;
        return MB_FAILURE;
    return MB_SUCCESS;
bool points_are_coincident ( const double *  first,
const double *  second
Definition at line 126 of file merge_test.cpp.
References length().
    double diff[3];
    diff[0]       = first[0] - second[0];
    diff[1]       = first[1] - second[1];
    diff[2]       = first[2] - second[2];
    double length = diff[0] * diff[0] + diff[1] * diff[1] + diff[2] * diff[2];
    if( fabs( length ) < .001 ) return true;
    return false;
ErrorCode process_bu_auto_merge ( std::string &  file_name)
Definition at line 845 of file merge_test.cpp.
References coincident_counts(), EntityCount::copy_counts(), EntityCount::edge, entities, find_coincident_nodes(), EntityCount::get_counts(), moab::Interface::get_entities_by_type(), gMB, EntityCount::hex, MB_SUCCESS, MBVERTEX, moab::Interface::merge_entities(), EntityCount::node, EntityCount::print(), EntityCount::quad, read_file(), EntityCount::tet, and EntityCount::tri.
Referenced by main().
    EntityCount init_count;
    EntityCount curr_count;
    // Read in the mesh and get the number of entities of each type.
    if( read_file( file_name, init_count ) != MB_SUCCESS ) return MB_FAILURE;
    // Copy the initial counts into the current count object.
    curr_count.copy_counts( init_count );
    // Print out the list of initial objects.
    cout << "Initial Entities:" << endl;
    curr_count.print();
    // Try auto merging from the bottom up.
    Range entities;
    // Start merging from the nodes and go up.
    cout << "Merging coincident entities(bottom up)..." << endl;
        gMB->merge_entities( ( *iter ).first, ( *iter ).second, true, true );
    if( curr_count.get_counts() != MB_SUCCESS )
        cout << "***ERROR: Unable to get entity list counts.***" << endl;
        return MB_FAILURE;
    // Make sure we merged everything.
    if( init_count.node - curr_count.node != diff_count.node || init_count.edge - curr_count.edge != diff_count.edge ||
        init_count.quad - curr_count.quad != diff_count.quad || init_count.tri - curr_count.tri != diff_count.tri ||
        init_count.hex - curr_count.hex != diff_count.hex || init_count.tet - curr_count.tet != diff_count.tet )
        cout << "***ERROR: Not all coincident objects merged automatically.***" << endl;
        curr_count.print();
        return MB_FAILURE;
    // Print out the final list of objects.
    cout << "Final Entities:" << endl;
    curr_count.print();
    return MB_SUCCESS;
ErrorCode process_merge ( std::string &  file_name)
Definition at line 902 of file merge_test.cpp.
References EntityCount::copy_counts(), EntityCount::get_counts(), MB_SUCCESS, merge_2D_elem(), merge_3D_elem(), merge_edges(), merge_nodes(), merge_top_down(), EntityCount::print(), read_file(), and write_file().
    curr_count.print();
    // Try to merge elements before nodes (should fail).
    if( merge_top_down( init_count, curr_count ) != MB_SUCCESS ) return MB_FAILURE;
    // Merge the nodes.
    if( merge_nodes( init_count, curr_count ) != MB_SUCCESS ) return MB_FAILURE;
    // Next, merge the edges.
    if( merge_edges( init_count, curr_count ) != MB_SUCCESS ) return MB_FAILURE;
    // Now, merge the 2D elements.
    if( merge_2D_elem( init_count, curr_count ) != MB_SUCCESS ) return MB_FAILURE;
    // Finally, merge the 3D elements.
    if( merge_3D_elem( init_count, curr_count ) != MB_SUCCESS ) return MB_FAILURE;
        return MB_FAILURE;
    curr_count.print();
    // write the file out (modifies name)
    return write_file( file_name );
ErrorCode process_mo_auto_merge ( std::string &  file_name)
Definition at line 780 of file merge_test.cpp.
References coincident_counts(), EntityCount::copy_counts(), EntityCount::edge, entities, find_coincident_edges(), find_coincident_nodes(), EntityCount::get_counts(), moab::Interface::get_entities_by_type(), gMB, EntityCount::hex, MB_SUCCESS, MBEDGE, MBVERTEX, moab::Interface::merge_entities(), EntityCount::node, EntityCount::print(), EntityCount::quad, read_file(), EntityCount::tet, and EntityCount::tri.
    curr_count.print();
    // Try auto merging from the middle out.
    Range entities;
    // Start merge at the edge level if present.
    else
    cout << "Merging coincident entities(middle out)..." << endl;
        return MB_FAILURE;
        curr_count.print();
        return MB_FAILURE;
    curr_count.print();
    return MB_SUCCESS;
ErrorCode process_td_auto_merge ( std::string &  file_name)
Definition at line 696 of file merge_test.cpp.
References coincident_counts(), EntityCount::copy_counts(), EntityCount::edge, entities, find_coincident_edges(), find_coincident_elements(), find_coincident_nodes(), EntityCount::get_counts(), moab::Interface::get_entities_by_type(), gMB, EntityCount::hex, MB_SUCCESS, MBEDGE, MBHEX, MBQUAD, MBTET, MBTRI, MBVERTEX, moab::Interface::merge_entities(), EntityCount::node, EntityCount::print(), EntityCount::quad, read_file(), EntityCount::tet, and EntityCount::tri.
    curr_count.print();
    // Try auto merging from the top down.
    Range entities;
    else if( diff_count.node > 0 )
    cout << "Merging coincident entities(top down)..." << endl;
        return MB_FAILURE;
        curr_count.print();
        return MB_FAILURE;
    curr_count.print();
    return MB_SUCCESS;
ErrorCode read_file ( std::string &  file_name,
EntityCount counts
Definition at line 632 of file merge_test.cpp.
References moab::Interface::delete_mesh(), EntityCount::get_counts(), gMB, moab::Interface::load_mesh(), and MB_SUCCESS.
    // Make sure the database is empty.
    gMB->delete_mesh();
    // Read the model from the file.
    if( gMB->load_mesh( file_name.c_str(), 0 ) != MB_SUCCESS )
        cout << "***ERROR: Unable to load mesh file.***" << endl;
        return MB_FAILURE;
    // Get the number of each entity types in the mesh.
    if( counts.get_counts() != MB_SUCCESS )
        return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode write_file ( std::string &  file_name)
Definition at line 654 of file merge_test.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), gMB, MB_SUCCESS, MBENTITYSET, moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::write_mesh().
Referenced by process_merge(), moab::Core::write_file(), and moab::Core::write_mesh().
    // get the block tag
    ErrorCode result;
    Range block_range;
    Tag block_tag;
    if( gMB->tag_get_handle( "MATERIAL_SET", block_tag ) == MB_SUCCESS )
        // get all the blocks
        result = gMB->get_entities_by_type_and_tag( 0, MBENTITYSET, &block_tag, 0, 1, block_range );
    // transfer range contents into vectors
    std::vector< EntityHandle > output_list;
    Range::iterator range_iter, end_iter;
    range_iter = block_range.begin();
    end_iter   = block_range.end();
    for( ; range_iter != end_iter; ++range_iter )
        int id;
        result = gMB->tag_get_handle( "MATERIAL_SET", block_tag );
        result = gMB->tag_get_data( block_tag, &*range_iter, 1, &id );
        // if(id != 2)
        output_list.push_back( *range_iter );
    // write the file
    static std::string mrg_splice( ".mrg" );
    file_name.insert( file_name.size() - 2, mrg_splice );
    result = gMB->write_mesh( file_name.c_str(), &output_list[0], output_list.size() );
    return result;
Variable Documentation
Interface* gMB = 0
Definition at line 11 of file merge_test.cpp.
