MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"
#include "moab/SpatialLocator.hpp"
#include "moab/Tree.hpp"
#include "moab/HomXform.hpp"
#include "moab/ScdInterface.hpp"
#include "moab/CartVect.hpp"
#include "moab/AdaptiveKDTree.hpp"
#include "moab/BVHTree.hpp"
#include "moab/ProgOptions.hpp"
#include "moab/CpuTimer.hpp"
#include "moab/ElemEvaluator.hpp"
#include <cstdlib>
#include <sstream>
Functions | |
ErrorCode | test_locator (SpatialLocator &sl, int npoints, double rtol, double &cpu_time, double &percent_outside) |
ErrorCode | create_hex_mesh (Interface &mb, Range &elems, int n, int dim) |
int | main (int argc, char **argv) |
ErrorCode create_hex_mesh | ( | Interface & | mb, |
Range & | elems, | ||
int | n, | ||
int | dim | ||
int main | ( | int | argc, |
char ** | argv | ||
Definition at line 25 of file sploc_searching_perf.cpp.
References ProgOptions::addOpt(), moab::Range::begin(), create_hex_mesh(), dim, ErrorCode, eval(), moab::fail(), ints, mb, MB_SUCCESS, npoints, moab::TreeStats::output_all_stats(), moab::Tree::parse_options(), ProgOptions::parseCommandLine(), moab::ElemEvaluator::set_eval_set(), test_locator(), tree, and moab::Tree::tree_stats().
{ #ifdef MOAB_HAVE_MPI int fail = MPI_Init( &argc, &argv ); if( fail ) return fail; #else // silence the warning of parameters not used, in serial; there should be a smarter way :( argv[0] = argv[argc - argc]; #endif int npoints = 100, dim = 3; int dints = 1, dleafs = 1, ddeps = 1; bool eval = false; double rtol = 1.0e-10; ProgOptions po( "tree_searching_perf options" ); po.addOpt< void >( ",e", "Use ElemEvaluator in tree search", &eval ); po.addOpt< int >( "ints,i", "Number of doublings of intervals on each side of scd mesh", &dints ); po.addOpt< int >( "leaf,l", "Number of doublings of maximum number of elements per leaf", &dleafs ); po.addOpt< int >( "max_depth,m", "Number of 5-intervals on maximum depth of tree", &ddeps ); po.addOpt< int >( "npoints,n", "Number of query points", &npoints ); po.addOpt< int >( "dim,d", "Dimension of the mesh", &dim ); po.addOpt< double >( "tol,t", "Relative tolerance of point search", &rtol ); // po.addOpt<void>( "print,p", "Print tree details", &print_tree); po.parseCommandLine( argc, argv ); std::vector< int > ints, deps, leafs; ints.push_back( 10 ); for( int i = 1; i < dints; i++ ) ints.push_back( 2 * ints[i - 1] ); deps.push_back( 30 ); for( int i = 1; i < ddeps; i++ ) deps.push_back( deps[i - 1] - 5 ); leafs.push_back( 6 ); for( int i = 1; i < dleafs; i++ ) leafs.push_back( 2 * leafs[i - 1] ); ErrorCode rval = MB_SUCCESS; std::cout << "Tree_type" << " " << "Elems_per_leaf" << " " << "Tree_depth" << " " << "Ints_per_side" << " " << "N_elements" << " " << "search_time" << " " << "perc_outside" << " " << "initTime" << " " << "nodesVisited" << " " << "leavesVisited" << " " << "numTraversals" << " " << "leafObjectTests" << std::endl; // outermost iteration: # elements for( std::vector< int >::iterator int_it = ints.begin(); int_it != ints.end(); ++int_it ) { Core mb; Range elems; rval = create_hex_mesh( mb, elems, *int_it, dim ); if( MB_SUCCESS != rval ) return rval; // iteration: tree depth for( std::vector< int >::iterator dep_it = deps.begin(); dep_it != deps.end(); ++dep_it ) { // iteration: tree max elems/leaf for( std::vector< int >::iterator leafs_it = leafs.begin(); leafs_it != leafs.end(); ++leafs_it ) { // iteration: tree type for( int tree_tp = 0; tree_tp < 2; tree_tp++ ) { // create tree Tree* tree; if( 0 == tree_tp ) tree = new BVHTree( &mb ); else tree = new AdaptiveKDTree( &mb ); ElemEvaluator* eeval = NULL; if( eval ) { // create an element evaluator eeval = new ElemEvaluator( &mb ); rval = eeval->set_eval_set( *elems.begin() ); if( MB_SUCCESS != rval ) return rval; } std::ostringstream opts; opts << "MAX_DEPTH=" << *dep_it << ";MAX_PER_LEAF=" << *leafs_it; FileOptions fo( opts.str().c_str() ); rval = tree->parse_options( fo ); if( MB_SUCCESS != rval ) return rval; SpatialLocator sl( &mb, elems, tree, eeval ); // call evaluation double cpu_time, perc_outside; rval = test_locator( sl, npoints, rtol, cpu_time, perc_outside ); if( MB_SUCCESS != rval ) return rval; std::cout << ( tree_tp == 0 ? "BVH" : "KD" ) << " " << *leafs_it << " " << *dep_it << " " << *int_it << " " << ( *int_it ) * ( *int_it ) * ( *int_it ) << " " << cpu_time << " " << perc_outside << " "; tree->tree_stats().output_all_stats(); if( eeval ) delete eeval; } // tree_tp } // max elems/leaf } // max depth } // # elements #ifdef MOAB_HAVE_MPI fail = MPI_Finalize(); if( fail ) return fail; #endif return 0; }
ErrorCode test_locator | ( | SpatialLocator & | sl, |
int | npoints, | ||
double | rtol, | ||
double & | cpu_time, | ||
double & | percent_outside | ||
Definition at line 158 of file sploc_searching_perf.cpp.
References moab::BoundBox::bMax, moab::BoundBox::bMin, box(), ErrorCode, moab::SpatialLocator::local_box(), moab::SpatialLocator::locate_points(), MB_SUCCESS, npoints, and moab::CpuTimer::time_elapsed().
{ BoundBox box = sl.local_box(); CartVect box_del = box.bMax - box.bMin; std::vector< CartVect > test_pts( npoints ), test_res( npoints ); std::vector< EntityHandle > ents( npoints ); int* is_in = new int[npoints]; double denom = 1.0 / (double)RAND_MAX; for( int i = 0; i < npoints; i++ ) { // generate a small number of random point to test double rx = (double)rand() * denom, ry = (double)rand() * denom, rz = (double)rand() * denom; test_pts[i] = box.bMin + CartVect( rx * box_del[0], ry * box_del[1], rz * box_del[2] ); } CpuTimer ct; // call spatial locator to locate points ErrorCode rval = sl.locate_points( test_pts[0].array(), npoints, &ents[0], test_res[0].array(), &is_in[0], rtol, 0.0 ); if( MB_SUCCESS != rval ) { delete[] is_in; return rval; } cpu_time = ct.time_elapsed(); int num_out = std::count( is_in, is_in + npoints, false ); percent_outside = ( (double)num_out ) / npoints; delete[] is_in; return rval; }
