MOAB: Mesh Oriented datABase  (version 5.1.1)
test_entsetFB.cpp File Reference
#include "moab/MOABConfig.h"
#include "FBiGeom.h"
#include "iMesh.h"
#include "iRel.h"
#include "stdio.h"
#include "stdlib.h"
#include "string.h"
+ Include dependency graph for test_entsetFB.cpp:
Defines
#define DEFAULT_TEST_FILE   shell.h5m
#define DEFAULT_TEST_FILE1   shellQuad.h5m
#define STRINGIFY_(X)   #X
#define STRINGIFY(X)   STRINGIFY_(X)
#define CHECK_SIZE_C(type, array, allocated_size, size)
Typedefs
typedef void * iRel_EntityHandle
Functions
void handle_error_code (const int result, int *number_failed, int *number_not_implemented, int *number_successful)
int print_geom_info (FBiGeom_Instance geom, iBase_EntityHandle gent)
int print_mesh_info (iMesh_Instance mesh, iBase_EntityHandle ment)
int load_geom_mesh_test (const char *geom_filename, const char *mesh_filename, FBiGeom_Instance geom, iMesh_Instance mesh)
int create_relation_test (iRel_Instance assoc, FBiGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle *pair)
int relate_geom_mesh_test (iRel_Instance assoc, FBiGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle pair)
int query_relations_test (iRel_Instance assoc, FBiGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle pair)
int main (int argc, char *argv[])
Define Documentation
#define CHECK_SIZE_C (   type,
  array,
  allocated_size,
  size
Value:
if (NULL == *array || *allocated_size == 0) {\
            *array = (type *) malloc(sizeof(type) * size); \
            *allocated_size = size;} \
          else if (*allocated_size < size) { \
             printf("   Array passed in is non-zero but too short.\n"); }
Definition at line 22 of file test_entsetFB.cpp.
Definition at line 10 of file test_entsetFB.cpp.
Definition at line 11 of file test_entsetFB.cpp.
#define STRINGIFY (   X)    STRINGIFY_(X)
Definition at line 14 of file test_entsetFB.cpp.
#define STRINGIFY_ (   X)    #X
Definition at line 13 of file test_entsetFB.cpp.
Typedef Documentation
typedef void* iRel_EntityHandle
Definition at line 29 of file test_entsetFB.cpp.
Function Documentation
Test:
TSTTLasso create relation Test
  • Create relation between geom and mesh
Definition at line 204 of file test_entsetFB.cpp.
References iBase_SUCCESS, iRel_ACTIVE, iRel_createPair, iRel_ENTITY, iRel_FBIGEOM_IFACE, iRel_findPairs, iRel_getPairInfo, iRel_IMESH_IFACE, and iRel_SET.
  int result;
  iBase_Instance iface1, iface2;
  int type1, type2;
  int ent_or_set1, ent_or_set2;
  int status1, status2;
  iRel_PairHandle tmp_pair;
  iRel_PairHandle *pair_ptr = &tmp_pair;
  int pairs_alloc = 1, pairs_size;
    /* create an relation, entity to set */
  iRel_createPair(assoc,
                  geom, iRel_ENTITY, iRel_FBIGEOM_IFACE, iRel_ACTIVE,
                  mesh, iRel_SET,    iRel_IMESH_IFACE, iRel_ACTIVE,
                  pair, &result);
  if (iBase_SUCCESS != result) {
    printf("Couldn't create a new relation.\n");
    return 0;
  iRel_getPairInfo(assoc, *pair,
                   &iface1, &ent_or_set1, &type1, &status1,
                   &iface2, &ent_or_set2, &type2, &status2, &result);
    printf("Couldn't retrieve relation info.\n");
    return 0;
  if (iface1 != geom || ent_or_set1 != iRel_ENTITY ||
      type1 != iRel_FBIGEOM_IFACE || iface2 != mesh || ent_or_set2 != iRel_SET ||
      type2 != iRel_IMESH_IFACE) {
    printf("Unexpected relation info returned.\n");
    return 0;
  iRel_findPairs(assoc, geom, &pair_ptr, &pairs_alloc, &pairs_size, &result);
    printf("Couldn't find relation pair when querying geom.\n");
    return 0;
  if (pairs_size != 1 || tmp_pair != *pair) {
    printf("Unexpected relation pairs returned when querying geom.\n");
    return 0;
  iRel_findPairs(assoc, mesh, &pair_ptr, &pairs_alloc, &pairs_size, &result);
    printf("Couldn't find relation pair when querying mesh.\n");
    return 0;
    printf("Unexpected relation pairs returned when querying mesh.\n");
    return 0;
  return 1;
void handle_error_code ( const int  result,
int *  number_failed,
int *  number_not_implemented,
int *  number_successful
prints out a result string based on the value of error_code
Definition at line 34 of file test_entsetFB.cpp.
  if (result) {
    printf("Success");
    (*number_successful)++;
  else {
    printf("Failure");
    (*number_failed)++;
int load_geom_mesh_test ( const char *  geom_filename,
const char *  mesh_filename,
iMesh_Instance  mesh
Test:
Load Mesh
  • Load a geom and a mesh file
Definition at line 176 of file test_entsetFB.cpp.
References FBiGeom_load, iBase_SUCCESS, and iMesh_load.
    /* load a geom */
  int result;
  FBiGeom_load(geom, geom_filename, 0, &result, strlen(geom_filename), 0);
    printf("ERROR : can not load a geometry\n");
    return 0;
    /* load a mesh */
  iMesh_load(mesh, 0, mesh_filename, 0, &result, strlen(mesh_filename), 0);
    printf("ERROR : can not load a mesh\n");
    return 0;
  return 1;
int main ( int  argc,
char *  argv[]
Definition at line 548 of file test_entsetFB.cpp.
References create_relation_test(), DEFAULT_INPUT_FILE, FBiGeom_dtor, FBiGeom_newGeom, geom, handle_error_code(), iMesh_dtor, iMesh_newMesh, iRel_create, iRel_destroy, load_geom_mesh_test(), mesh, number_tests, number_tests_failed, number_tests_successful, query_relations_test(), and relate_geom_mesh_test().
    /* Check command line arg */
  const char *geom_filename = DEFAULT_INPUT_FILE;
  const char *mesh_filename = DEFAULT_INPUT_FILE1;
  int result;
  int number_tests = 0;
  int number_tests_successful = 0;
  int number_tests_not_implemented = 0;
  int number_tests_failed = 0;
  FBiGeom_Instance geom;
  iMesh_Instance mesh;
  iRel_Instance assoc;
  iRel_PairHandle pair;
  if (argc == 2 && !strcmp(argv[1], "-h")) {
    printf("Usage: %s <geom_filename> <mesh_filename>\n",
           argv[0]);
    return 1;
  else if (argc == 2) {
    geom_filename = argv[1];
    mesh_filename = argv[1];
  else if (argc == 3) {
    mesh_filename = argv[2];
    /* initialize the Geometry */
  FBiGeom_newGeom(0, &geom, &result, 0);
    /* initialize the Mesh */
  iMesh_newMesh(0, &mesh, &result, 0);
    /* initialize the Associate */
  iRel_create(0, &assoc, &result, 0);
    /* Print out Header information */
  printf("\n\niRel TEST PROGRAM:\n\n");
    /* load_geom_mesh test */
  printf("   load_geom_mesh: ");
  result = load_geom_mesh_test(geom_filename, mesh_filename,
                               geom, mesh);
  handle_error_code(result, &number_tests_failed,
                    &number_tests_not_implemented,
                    &number_tests_successful);
  number_tests++;
  printf("\n");
    /* create_relation test */
  printf("   create_relation: ");
  result = create_relation_test(assoc, geom, mesh, &pair);
  number_tests++;
  printf("\n");
    /* relate_geom_mesh test */
  printf("   relate_geom_mesh: ");
  result = relate_geom_mesh_test(assoc, geom, mesh, pair);
  number_tests++;
  printf("\n");
    /* query_relations test */
  printf("   query_relations: ");
  result = query_relations_test(assoc, geom, mesh, pair);
  number_tests++;
  printf("\n");
    /* summary */
  printf("\niRel TEST SUMMARY: \n");
  printf("   Number Tests:           %d\n", number_tests);
  printf("   Number Successful:      %d\n", number_tests_successful);
  printf("   Number Not Implemented: %d\n", number_tests_not_implemented);
  printf("   Number Failed:          %d\n", number_tests_failed);
  printf("\n\n");
  iRel_destroy(assoc, &result);
  iMesh_dtor(mesh, &result);
  FBiGeom_dtor( geom, &result);
  return number_tests_failed != 0;
Definition at line 49 of file test_entsetFB.cpp.
References FBiGeom_getEntType, and iBase_SUCCESS.
    /* print information about this entity */
  int ent_type;
  int result;
  const char *type_names[] = {"Vertex", "Edge", "Face", "Region"};
  FBiGeom_getEntType(geom, gent, &ent_type, &result);
    printf("Trouble getting entity adjacencies or types.");
    return 0;
  printf("%s 0x%lx\n", type_names[ent_type], (unsigned long)gent);
  return 1;
Definition at line 68 of file test_entsetFB.cpp.
References iBase_ALL_TYPES, iBase_BYTES, iBase_DOUBLE, iBase_ENTITY_HANDLE, iBase_INTEGER, iBase_SUCCESS, iMesh_getAllTags, iMesh_getData, iMesh_getDblData, iMesh_getEHData, iMesh_getEntAdj, iMesh_getEntArrType, iMesh_getIntData, iMesh_getTagName, and iMesh_getTagType.
    /* get adjacencies first; assume not more than 50 */
  iBase_EntityHandle adj_ents[50], *adj_ents_ptr = adj_ents;
   int ent_types[50], *ent_types_ptr = ent_types;
  int adj_ents_alloc = 50, adj_ents_size, ent_types_size,
    ent_types_allocated = 50;
  int result;
  iBase_TagHandle *ment_tags = NULL;
  int ment_tags_size, ment_tags_alloc;
  char **tag_names;
  int i;
  int tag_type;
  char *dum_handle = NULL;
  int dum_handle_alloc = 0, dum_handle_size = 0;
  int int_data;
  double dbl_data;
  iBase_EntityHandle eh_data;
  iMesh_getEntAdj(mesh, ment, iBase_ALL_TYPES,
                  &adj_ents_ptr, &adj_ents_alloc, &adj_ents_size,
                  &result);
  if (iBase_SUCCESS != result) return 0;
    /* put this ent on the end, then get types */
  adj_ents[adj_ents_size] = ment;
  iMesh_getEntArrType(mesh, adj_ents, adj_ents_size+1,
                      &ent_types_ptr, &ent_types_allocated,
                      &ent_types_size, &result);
    return 0;
    /* get tags on ment */
  iMesh_getAllTags(mesh, ment,
                   &ment_tags, &ment_tags_alloc, &ment_tags_size,
                   &result);
  printf("Trouble getting tags on an entity or their names.");
    /* while we're at it, get all the tag names */
  tag_names = (char **) malloc(ment_tags_size * sizeof(char*));
  for (i = 0; i < ment_tags_size; i++) {
    tag_names[i] = (char*)malloc(120*sizeof(char));
    iMesh_getTagName(mesh, ment_tags[i], tag_names[i], &result, 120);
    /* now print the information */
  printf("%s %ld:\n", type_names[ent_types[ent_types_size-1]], (long)ment);
  printf("Adjacencies:");
  for (i = 0; i < adj_ents_size; i++) {
    if (i > 0) printf(", ");
    printf("%s %ld", type_names[ent_types[i]],
           (long)adj_ents[i]);
  printf("\nTags: \n");
    printf("%s ", tag_names[i]);
    iMesh_getTagType(mesh, ment_tags[i], &tag_type, &result);
      printf("(trouble getting type...)\n");
    else {
      dum_handle = NULL;
      switch (tag_type) {
        case iBase_INTEGER:
          iMesh_getIntData(mesh, ment, ment_tags[i], &int_data, &result);
          printf("(Int value=%d)", int_data);
          break;
        case iBase_DOUBLE:
          iMesh_getDblData(mesh, ment, ment_tags[i], &dbl_data, &result);
          printf("(Dbl value=%f)", dbl_data);
          break;
        case iBase_ENTITY_HANDLE:
          iMesh_getEHData(mesh, ment, ment_tags[i], &eh_data, &result);
          printf("(EH value=%ld)", (long)eh_data);
          break;
        case iBase_BYTES:
          iMesh_getData(mesh, ment, ment_tags[i],
                        (void**)&dum_handle, &dum_handle_alloc,
                        &dum_handle_size, &result);
          if (NULL != dum_handle && dum_handle_size > 0)
            printf("(Opaque value=%c)", dum_handle[0]);
          break;
    printf("\n");
  printf("(end tags)\n\n");
  free(ment_tags);
  return 1;
Test:
TSTTAssoc move to test
  • Move meshes onto the given geometry
Definition at line 458 of file test_entsetFB.cpp.
References FBiGeom_getEntities, iBase_ALL_TYPES, iBase_SUCCESS, iMesh_isList, iRel_getDescription, iRel_getEntArrSetArrRelation, iRel_getSetArrEntArrRelation, and print_geom_info().
    /* get all the geom entities, and find relation to some mesh entity */
  iBase_EntityHandle *gentities = NULL;
  int gentities_size = 0, gentities_alloc = 0;
  int result;
  iBase_EntitySetHandle *out_mentities = NULL;
  int out_mentities_size, out_mentities_alloc = 0;
  char descr[120];
  int i;
  int is_list;
  iBase_EntityHandle *out_gentities = NULL;
  int out_gentities_size, out_gentities_alloc = 0;
  FBiGeom_getEntities(geom, NULL, iBase_ALL_TYPES,
                    &gentities, &gentities_alloc,
                    &gentities_size, &result);
    printf("Problem getting all geom entities.\n" );
    return 0;
  iRel_getEntArrSetArrRelation(assoc, pair,
                               gentities, gentities_size, 0,
                               &out_mentities, &out_mentities_alloc,
                               &out_mentities_size,
                               &result);
    /* might not all be */
    printf("Failed to get mesh entities related to geom entities in query_relations_test.\n");
    iRel_getDescription(assoc, descr, sizeof(descr)-1);
    printf("Entities missing relations: %s\n", descr);
    for (i = 0; i < gentities_size; i++) {
        print_geom_info(geom, gentities[i]);
    return 0;
    /* check that they're all non-null */
  if (out_mentities_size != gentities_size) {
    printf("Number of mesh & related geom entities don't match.\n");
    return 0;
    /* check to make sure they're mesh sets; how to do that? */
  for (i = 0; i < out_mentities_size; i++) {
    iMesh_isList(mesh, (iBase_EntitySetHandle)out_mentities[i], &is_list, &result);
      printf("Entity set returned from classification wasn't valid.\n");
      return 0;
    /* now turn around and check classification of those mesh entities */
  iRel_getSetArrEntArrRelation(assoc, pair,
                               out_mentities, out_mentities_size, 1,
                               &out_gentities, &out_gentities_alloc,
                               &out_gentities_size,
                               &result);
    printf("Failed to get geom entities related to mesh entities in query_relations_test.\n");
    return 0;
  if (out_mentities_size != out_gentities_size) {
    printf("Number of geom & related mesh entities don't match.\n" );
    return 0;
  free(gentities);
  gentities=NULL;
  free(out_mentities);
  out_mentities=NULL;
  free(out_gentities);
  out_gentities=NULL;
    /* ok, we're done */
  return 1;
Test:
TSTTLasso relate geom and mesh Test
  • Check relation between geom and mesh
Definition at line 272 of file test_entsetFB.cpp.
References dim, FBiGeom_getEntities, iBase_ALL_TYPES, iBase_INTEGER, iBase_SUCCESS, iBase_TAG_ALREADY_EXISTS, iBase_VERTEX, iMesh_createTag, iMesh_getEntSetIntData, iMesh_getEntSets, iRel_getEntArrSetArrRelation, iRel_getSetArrEntArrRelation, iRel_inferAllRelations, iRel_inferEntArrRelations, iRel_inferSetArrRelations, iRel_rmvEntArrRelation, and iRel_setEntArrSetArrRelation.
    /* relate geometry entities with coresponding mesh entity sets */
  int result;
  iBase_EntitySetHandle *mentity_handles = NULL;
  int mentity_handles_size = 0, mentity_handles_alloc = 0;
  const char *dim_tag_name = "GEOM_DIMENSION";
  iBase_TagHandle dim_tag_mesh;
  iBase_EntitySetHandle *mentities_vec;
  int mentities_vec_size;
  int i;
  int out_mentities_size = 0, out_mentities_alloc = 0;
  iBase_EntitySetHandle *out_mentities2 = NULL;
  int out_mentities2_size = 0, out_mentities2_alloc = 0;
  int out_gentities_size = 0, out_gentities_alloc = 0;
                    iBase_VERTEX,
                    &gentities,
                    &gentities_alloc,
    printf("Failed to get gentities by type in relate_geom_mesh_test.\n");
    return 0;
  iRel_inferEntArrRelations(assoc, pair,
                            &result);
    printf("Failed to relate geom entities in relate_geom_mesh_test.\n");
    return 0;
    /* relate coresponding mesh entity sets for geometry entities */
    /* get 1-dimensional mesh entitysets */
  iMesh_getEntSets(mesh, NULL, 1,
                   &mentity_handles, &mentity_handles_alloc,
                   &mentity_handles_size, &result);
    printf("Problem to get all entity sets.\n");
    return 0;
    /* get geom dimension tags for mesh entitysets */
  iMesh_createTag(mesh, dim_tag_name, 1, iBase_INTEGER,
                  &dim_tag_mesh, &result, 15);
  if (iBase_SUCCESS != result && result != iBase_TAG_ALREADY_EXISTS) {
    printf("Couldn't create geom dim tag for mesh entities.\n");
    return 0;
  mentities_vec = (iBase_EntitySetHandle*)malloc(mentity_handles_size*sizeof(iBase_EntitySetHandle));
  mentities_vec_size = 0;
  for (i = 0; i < mentity_handles_size; i++) {
    int dim;
    iMesh_getEntSetIntData(mesh, mentity_handles[i], dim_tag_mesh,
                           &dim, &result);
      continue;
    if (dim == 1)
      mentities_vec[mentities_vec_size++] = mentity_handles[i];
  iRel_inferSetArrRelations(assoc, pair,
                            mentities_vec, mentities_vec_size,
                            1, &result);
    printf("Failed to relate mesh entities in relate_geom_mesh_test.\n");
    return 0;
    /* relate all geometry and mesh entities */
  iRel_inferAllRelations(assoc, pair, &result);
    printf("Failed to relate all geom and mesh entities in relate_geom_mesh_test.\n");
    return 0;
    /* reset geom entities list and get all geom entities (prev
       only vertices) */
  free(gentities);
  gentities = NULL;
                    iBase_ALL_TYPES,
                    &gentities,
                    &gentities_alloc,
    return 0;
    /* get related mesh entity sets for geometry entities */
                               &result);
    printf("Failed to get geom entities in relate_geom_mesh_test.\n");
    return 0;
    printf("Number of input geom entities and output mesh entity sets should be same\n");
    return 0;
    /* now try deleting this relation */
  iRel_rmvEntArrRelation(assoc, pair, gentities, gentities_size, 0, &result);
    printf("Failed to remove relation in relate_geom_mesh_test.\n");
    return 0;
                               &out_mentities2, &out_mentities2_alloc,
                               &out_mentities2_size,
                               &result);
  if (iBase_SUCCESS == result) {
    printf("Shouldn't have gotten mesh sets in relate_geom_mesh_test.\n");
    return 0;
    /* restore the relation, since we need it later */
  iRel_setEntArrSetArrRelation(assoc, pair, gentities, gentities_size,
                               out_mentities, out_mentities_size, &result);
    printf("Failed to restore relation in relate_geom_mesh_test.\n");
    return 0;
    /* get related geometry entities for mesh entity sets */
                               &result);
    printf("Failed to get mesh entities in relate_geom_mesh_test.\n");
    return 0;
    printf("Number of input mesh entity sets and output geom entities should be same\n");
    return 0;
  free(mentity_handles);
  free(gentities);
  gentities=NULL;
  mentity_handles=NULL;
  out_mentities=NULL;
  free(mentities_vec);
  mentities_vec=NULL;
  out_gentities=NULL;
  return 1;
