cgma
00001 //---------------------------------------------------------- 00002 //Class: GeomMeasureTool 00003 //Description: Does Geometric measureing and statistical 00004 // gathering on various topologies. 00005 //Creator: David R. White 00006 //Date: 7/9/2002 00007 //---------------------------------------------------------- 00008 00009 00010 #include "GeomMeasureTool.hpp" 00011 #include "RefEntity.hpp" 00012 #include "RefVertex.hpp" 00013 #include "RefEdge.hpp" 00014 #include "RefFace.hpp" 00015 #include "RefVolume.hpp" 00016 #include "Body.hpp" 00017 #include "RefGroup.hpp" 00018 #include "RefEntityFactory.hpp" 00019 #include "CoEdge.hpp" 00020 #include "Loop.hpp" 00021 #include "Shell.hpp" 00022 #include "Chain.hpp" 00023 #include "CastTo.hpp" 00024 #include "GMem.hpp" 00025 #include "Curve.hpp" 00026 #include "Surface.hpp" 00027 #include "GeometryQueryEngine.hpp" 00028 #include "GeomSeg.hpp" 00029 #include "GeomPoint.hpp" 00030 #include "RTree.hpp" 00031 #include "AbstractTree.hpp" 00032 #include "IntersectionTool.hpp" 00033 #include "CpuTimer.hpp" 00034 #include "GeometryQueryTool.hpp" 00035 #include "GeometryModifyTool.hpp" 00036 #include "MergeTool.hpp" 00037 #include "GeomDataObserver.hpp" 00038 #include "Lump.hpp" 00039 #include "ModelQueryEngine.hpp" 00040 #include "ProgressTool.hpp" 00041 #include "AppUtil.hpp" 00042 00043 #include <set> 00044 #include <map> 00045 #include <stack> 00046 #include <algorithm> 00047 00048 void GeomMeasureTool::get_edges_from_list(DLIList <RefEntity*> &entity_list, 00049 DLIList <RefEdge*> &ref_edges ) 00050 { 00051 //assume the mark is zero. 00052 int ii,jj; 00053 RefEntity *entity_ptr; 00054 RefEdge *ref_edge; 00055 00056 TopologyEntity *topo_ent; 00057 DLIList <RefEdge*> tmp_edges; 00058 for ( ii = entity_list.size(); ii > 0; ii-- ) 00059 { 00060 tmp_edges.clean_out(); 00061 entity_ptr = entity_list.get_and_step(); 00062 topo_ent = CAST_TO(entity_ptr, TopologyEntity); 00063 if ( topo_ent == NULL ) 00064 continue; 00065 topo_ent->ref_edges(tmp_edges); 00066 for ( jj = tmp_edges.size(); jj > 0; jj-- ) 00067 { 00068 ref_edge = tmp_edges.pop(); 00069 if ( !ref_edge->marked() ) 00070 { 00071 ref_edge->marked(1); 00072 ref_edges.append(ref_edge); 00073 } 00074 } 00075 } 00076 for ( ii = ref_edges.size(); ii > 0; ii-- ) 00077 ref_edges.get_and_step()->marked(0); 00078 } 00079 00080 void GeomMeasureTool::get_bodies_from_list(DLIList <RefVolume*> &entity_list, 00081 DLIList <Body*> &ref_bodies ) 00082 { 00083 //assume the mark is zero. 00084 int ii, jj; 00085 RefVolume *entity_ptr; 00086 Body *ref_body; 00087 00088 TopologyEntity *topo_ent; 00089 DLIList <Body*> tmp_bodies; 00090 for ( ii = entity_list.size(); ii > 0; ii-- ) 00091 { 00092 tmp_bodies.clean_out(); 00093 entity_ptr = entity_list.get_and_step(); 00094 topo_ent = CAST_TO(entity_ptr, TopologyEntity); 00095 if ( topo_ent == NULL ) 00096 continue; 00097 topo_ent->bodies(tmp_bodies); 00098 for ( jj = tmp_bodies.size(); jj > 0; jj-- ) 00099 { 00100 ref_body = tmp_bodies.pop(); 00101 if ( !ref_body->marked() ) 00102 { 00103 ref_body->marked(1); 00104 ref_bodies.append(ref_body); 00105 } 00106 } 00107 } 00108 for ( ii = ref_bodies.size(); ii > 0; ii-- ) 00109 ref_bodies.get_and_step()->marked(0); 00110 } 00111 00112 void GeomMeasureTool::get_faces_from_list(DLIList <RefEntity*> &entity_list, 00113 DLIList <RefFace*> &ref_faces ) 00114 { 00115 //assume the mark is zero. 00116 int ii,jj; 00117 RefEntity *entity_ptr; 00118 RefFace *ref_face; 00119 00120 TopologyEntity *topo_ent; 00121 DLIList <RefFace*> tmp_faces; 00122 for ( ii = entity_list.size(); ii > 0; ii-- ) 00123 { 00124 tmp_faces.clean_out(); 00125 entity_ptr = entity_list.get_and_step(); 00126 topo_ent = CAST_TO(entity_ptr, TopologyEntity); 00127 topo_ent->ref_faces(tmp_faces); 00128 for ( jj = tmp_faces.size(); jj > 0; jj-- ) 00129 { 00130 ref_face = tmp_faces.pop(); 00131 if ( !ref_face->marked() ) 00132 { 00133 ref_face->marked(1); 00134 ref_faces.append(ref_face); 00135 } 00136 } 00137 } 00138 for ( ii = ref_faces.size(); ii > 0; ii-- ) 00139 ref_faces.get_and_step()->marked(0); 00140 } 00141 void GeomMeasureTool::get_volumes_from_list(DLIList <RefEntity*> &entity_list, 00142 DLIList <RefVolume*> &ref_volumes ) 00143 { 00144 //assume the mark is zero. 00145 int ii,jj; 00146 RefEntity *entity_ptr; 00147 RefVolume *ref_volume; 00148 00149 TopologyEntity *topo_ent; 00150 DLIList <RefVolume*> tmp_volumes; 00151 for ( ii = entity_list.size(); ii > 0; ii-- ) 00152 { 00153 tmp_volumes.clean_out(); 00154 entity_ptr = entity_list.get_and_step(); 00155 topo_ent = CAST_TO(entity_ptr, TopologyEntity); 00156 topo_ent->ref_volumes(tmp_volumes); 00157 for ( jj = tmp_volumes.size(); jj > 0; jj-- ) 00158 { 00159 ref_volume = tmp_volumes.pop(); 00160 if ( !ref_volume->marked() ) 00161 { 00162 ref_volume->marked(1); 00163 ref_volumes.append(ref_volume); 00164 } 00165 } 00166 } 00167 for ( ii = ref_volumes.size(); ii > 0; ii-- ) 00168 ref_volumes.get_and_step()->marked(0); 00169 } 00170 void GeomMeasureTool::measure_curve_length(DLIList <RefEntity*> &entity_list, 00171 double &smallest, 00172 RefEdge *&smallest_edge, 00173 double &largest, 00174 RefEdge *&largest_edge, 00175 double &average, 00176 double &sum) 00177 { 00178 DLIList<RefEdge*> ref_edges; 00179 get_edges_from_list(entity_list, ref_edges); 00180 measure_curve_length(ref_edges, smallest, smallest_edge, 00181 largest, largest_edge, average, sum); 00182 00183 } 00184 00185 void GeomMeasureTool::measure_curve_length(DLIList <RefEdge*> &ref_edges, 00186 double &smallest, 00187 RefEdge *&smallest_edge, 00188 double &largest, 00189 RefEdge *&largest_edge, 00190 double &average, 00191 double &sum) 00192 { 00193 int ii; 00194 double curr_length, total_length = 0.0; 00195 smallest = CUBIT_DBL_MAX; 00196 largest = 0.0; 00197 RefEdge *curr_edge; 00198 for ( ii = ref_edges.size(); ii > 0; ii-- ) 00199 { 00200 curr_edge = ref_edges.get_and_step(); 00201 if( curr_edge->geometry_type() == POINT_CURVE_TYPE ) 00202 continue; 00203 curr_length = curr_edge->measure(); 00204 if ( curr_length < smallest ) 00205 { 00206 smallest = curr_length; 00207 smallest_edge = curr_edge; 00208 } 00209 if ( curr_length > largest ) 00210 { 00211 largest = curr_length; 00212 largest_edge = curr_edge; 00213 } 00214 total_length += curr_length; 00215 } 00216 if ( ref_edges.size() != 0 ) 00217 average = total_length/ref_edges.size(); 00218 sum = total_length; 00219 00220 } 00221 void GeomMeasureTool::measure_face_curves( RefFace *ref_face, 00222 double &min_curve_length, 00223 double &max_curve_ratio, 00224 RefEdge *&min_ref_edge) 00225 { 00226 DLIList<DLIList<CoEdge*> > co_edge_loops; 00227 ref_face->co_edge_loops(co_edge_loops); 00228 CoEdge *curr_co_edge, *next_co_edge; 00229 min_curve_length = CUBIT_DBL_MAX; 00230 double curve_length, next_curve_length, ratio; 00231 max_curve_ratio = -CUBIT_DBL_MAX; 00232 CubitBoolean ratio_set = CUBIT_FALSE; 00233 int ii, jj; 00234 for ( ii = co_edge_loops.size(); ii > 0; ii-- ) 00235 { 00236 DLIList <CoEdge*> &co_edge_list = co_edge_loops.get_and_step(); 00237 curve_length = co_edge_list.get()->get_ref_edge_ptr()->measure(); 00238 for ( jj = co_edge_list.size(); jj > 0; jj-- ) 00239 { 00240 curr_co_edge = co_edge_list.get_and_step(); 00241 next_co_edge = co_edge_list.get(); 00242 next_curve_length = next_co_edge->get_ref_edge_ptr()->measure(); 00243 //find the smallest curve 00244 if ( curve_length < min_curve_length ) 00245 { 00246 min_curve_length = curve_length; 00247 min_ref_edge = curr_co_edge->get_ref_edge_ptr(); 00248 } 00249 if ( co_edge_list.size() > 1 ) 00250 { 00251 //find the biggest change in curve lengths. 00252 if ( curve_length > next_curve_length ) 00253 { 00254 if ( next_curve_length < CUBIT_RESABS ) 00255 ratio = CUBIT_DBL_MAX; 00256 else 00257 ratio = curve_length / next_curve_length; 00258 } 00259 else 00260 { 00261 if ( curve_length < CUBIT_RESABS ) 00262 ratio = CUBIT_DBL_MAX; 00263 else 00264 ratio = next_curve_length /curve_length; 00265 } 00266 curve_length = next_curve_length; 00267 if ( ratio > max_curve_ratio ) 00268 { 00269 ratio_set = CUBIT_TRUE; 00270 max_curve_ratio = ratio; 00271 } 00272 } 00273 } 00274 } 00275 if ( !ratio_set ) 00276 max_curve_ratio = -1.0; 00277 } 00278 00279 00280 00281 00282 CubitStatus GeomMeasureTool::measure_face_loops( RefFace *face, 00283 double &min_distance_between_loops, 00284 double &min_distance_in_one_loop, 00285 double &min_angle, 00286 double &max_angle, 00287 double tolerance) 00288 { 00289 //This is the most tricky of these functions. 00290 //To do this I'm going to facet the edges, then use an AbstractTree to 00291 //find the minimum distance between the loops and between a single 00292 //loop. 00293 PointLoopList boundary_point_loops; 00294 CubitStatus stat; 00295 stat = get_boundary_points(face, boundary_point_loops, tolerance); 00296 if ( stat != CUBIT_SUCCESS ) 00297 return CUBIT_FAILURE; 00298 00299 SegLoopList boundary_seg_loops; 00300 stat = convert_to_lines( boundary_point_loops, 00301 boundary_seg_loops, 00302 face); 00303 if ( stat != CUBIT_SUCCESS ) 00304 return stat; 00305 00306 //Now add the points to the AbstractTree. 00307 DLIList<AbstractTree<GeomSeg*>*> atree_list; 00308 AbstractTree<GeomSeg*> *curr_tree; 00309 SegList *seg_list; 00310 GeomSeg *curr_seg, *next_seg; 00311 int ii,jj, kk; 00312 double angle; 00313 min_angle = CUBIT_DBL_MAX; 00314 max_angle = 0.0; 00315 double creation_time=0.0; 00316 CpuTimer creation_timer; 00317 const double angle_convert = 180.0/CUBIT_PI; 00318 boundary_seg_loops.reset(); 00319 int num_segs = 0; 00320 for (ii = 0; ii < boundary_seg_loops.size(); ii++ ) 00321 { 00322 seg_list = boundary_seg_loops.get_and_step(); 00323 creation_timer.cpu_secs(); 00324 curr_tree = new RTree<GeomSeg*>(GEOMETRY_RESABS); 00325 creation_time += creation_timer.cpu_secs(); 00326 for ( jj = seg_list->size(); jj > 0; jj-- ) 00327 { 00328 //build the r-tree. 00329 num_segs++; 00330 creation_timer.cpu_secs(); 00331 curr_seg = seg_list->get_and_step(); 00332 curr_tree->add(curr_seg); 00333 creation_time += creation_timer.cpu_secs(); 00334 //calculate the interior angles. 00335 next_seg = seg_list->get(); 00336 00337 RefEntity* temp_ent = curr_seg->get_end()->owner(); 00338 //only measure the angle at vertices. This 00339 //should make things slightly faster. 00340 if ( CAST_TO(temp_ent, RefVertex) ) 00341 { 00342 stat = interior_angle(curr_seg, next_seg, 00343 face, angle); 00344 if ( stat != CUBIT_SUCCESS ) 00345 { 00346 min_angle = 0.0; 00347 max_angle = 360.0; 00348 } 00349 else if ( angle < min_angle ) 00350 { 00351 min_angle = angle; 00352 } 00353 else if ( angle > max_angle ) 00354 { 00355 max_angle = angle; 00356 } 00357 } 00358 } 00359 atree_list.append(curr_tree); 00360 } 00361 min_angle *= angle_convert; 00362 max_angle *= angle_convert; 00363 00364 if ( atree_list.size() <= 1 ) 00365 min_distance_between_loops = -1.0; 00366 else 00367 { 00368 //determine the minimum distance between the loops. 00369 CpuTimer atree_time; 00370 atree_time.cpu_secs(); 00371 PointList *curr_points; 00372 GeomPoint *curr_point; 00373 DLIList <GeomSeg*> nearest_neighbors; 00374 00375 CubitVector curr_loc; 00376 double closest_dist; 00377 min_distance_between_loops = CUBIT_DBL_MAX; 00378 atree_list.reset(); 00379 for ( ii = 0; ii < atree_list.size(); ii++ ) 00380 { 00381 curr_points = boundary_point_loops.get_and_step(); 00382 for ( jj = ii+1; jj < atree_list.size(); jj++ ) 00383 { 00384 curr_tree = atree_list.next(jj); 00385 //now for every point in curr_points, find it's closest_point 00386 //in the curr_tree. 00387 for ( kk = 0; kk < curr_points->size(); kk++ ) 00388 { 00389 curr_point = curr_points->get_and_step(); 00390 curr_loc.set(curr_point->coordinates()); 00391 nearest_neighbors.clean_out(); 00392 curr_tree->k_nearest_neighbor(curr_loc, 00393 1, closest_dist, nearest_neighbors, 00394 dist_sq_point_data); 00395 if ( nearest_neighbors.size() == 0) 00396 { 00397 //hmm, not sure what is wrong here. 00398 PRINT_ERROR("Can't find closest point between loops.\n"); 00399 return CUBIT_FAILURE; 00400 } 00401 if (closest_dist < min_distance_between_loops) 00402 min_distance_between_loops = closest_dist; 00403 } 00404 } 00405 } 00406 double time = atree_time.cpu_secs(); 00407 PRINT_DEBUG_139("Time to create atree: %f\n", creation_time); 00408 PRINT_DEBUG_139("Time for atree nn search: %f\n", time); 00409 } 00410 if ( min_distance_between_loops != -1.0 ) 00411 min_distance_between_loops = sqrt(min_distance_between_loops); 00412 //Now find the min distance inside a loop. This is tricky 00413 //in that we want to find distances that are across some area 00414 //and not just between adjacent curves. 00415 atree_list.reset(); 00416 GeomSeg *tmp_seg; 00417 double dist; 00418 min_distance_in_one_loop = CUBIT_DBL_MAX; 00419 int k=5; 00420 CubitVector curr_loc; 00421 DLIList <GeomSeg*> nearest_neighbors; 00422 RefEntity *ent_1, *ent_2; 00423 TopologyEntity *top_1, *top_2; 00424 00425 00426 for ( ii = atree_list.size(); ii > 0; ii-- ) 00427 { 00428 curr_tree = atree_list.get_and_step(); 00429 seg_list = boundary_seg_loops.get_and_step(); 00430 for ( jj = seg_list->size(); jj > 0; jj-- ) 00431 { 00432 nearest_neighbors.clean_out(); 00433 curr_seg = seg_list->get_and_step(); 00434 //get the k closest segments. 00435 curr_loc.set(curr_seg->get_start()->coordinates()); 00436 curr_tree->k_nearest_neighbor(curr_loc, 00437 k, dist, nearest_neighbors, 00438 dist_sq_point_data); 00439 //go through these nearest_neighbors and through out 00440 //the segments that are attached to curr_seg. 00441 for ( kk = 0; kk < nearest_neighbors.size(); kk++ ) 00442 { 00443 tmp_seg = nearest_neighbors.get(); 00444 if ( tmp_seg == curr_seg || 00445 tmp_seg == curr_seg->get_prev() || 00446 tmp_seg == curr_seg->get_next() ) 00447 nearest_neighbors.remove(); 00448 } 00449 if ( nearest_neighbors.size() == 0 ) 00450 continue; 00451 //The min distance is the distance between the curr_loc 00452 //and the top nearest_neighbor. 00453 nearest_neighbors.reset(); 00454 tmp_seg = nearest_neighbors.get(); 00455 ent_1 = tmp_seg->owner(); 00456 ent_2 = curr_seg->get_start()->owner(); 00457 top_1 = CAST_TO(ent_1, TopologyEntity); 00458 top_2 = CAST_TO(ent_2, TopologyEntity); 00459 00460 if ( top_1->is_directly_related(top_2) ) 00461 continue; 00462 00463 //we'll need to recompute it... 00464 dist = dist_sq_point_data(curr_loc, tmp_seg); 00465 if ( dist < min_distance_in_one_loop ) 00466 min_distance_in_one_loop = dist; 00467 } 00468 } 00469 if ( min_distance_in_one_loop == CUBIT_DBL_MAX ) 00470 { 00471 ent_1 = (RefEntity*)face; 00472 DLIList<RefEntity*> entities; 00473 entities.append(ent_1); 00474 double smallest, largest, ave, sum; 00475 RefEdge *small_e, *large_e; 00476 measure_curve_length(entities, smallest, small_e, 00477 largest, large_e, ave, sum); 00478 min_distance_in_one_loop = smallest; 00479 } 00480 else 00481 min_distance_in_one_loop = sqrt(min_distance_in_one_loop); 00482 //clean up the memory. 00483 int ll,mm; 00484 atree_list.reset(); 00485 boundary_seg_loops.reset(); 00486 for ( ll = boundary_seg_loops.size(); ll > 0; ll-- ) 00487 { 00488 delete atree_list.pop(); 00489 seg_list = boundary_seg_loops.pop(); 00490 for ( mm = seg_list->size(); mm > 0; mm-- ) 00491 delete seg_list->pop(); 00492 delete seg_list; 00493 } 00494 00495 PointList *point_list; 00496 for ( ll = boundary_point_loops.size(); ll > 0; ll-- ) 00497 { 00498 point_list = boundary_point_loops.pop(); 00499 for ( mm = point_list->size(); mm > 0; mm-- ) 00500 { 00501 GeomPoint *tmp_point = point_list->pop(); 00502 //delete the CubitPointData 00503 delete tmp_point; 00504 } 00505 delete point_list; 00506 } 00507 return CUBIT_SUCCESS; 00508 } 00509 //------------------------------------------------------------------- 00510 //Function: dist_point_data 00511 //Computes the distance between the line segment and the vector position. 00512 //This function is used to determine the nearest neigbhor search and 00513 //gets passed to the AbstractTree. 00514 //------------------------------------------------------------------- 00515 double GeomMeasureTool::dist_sq_point_data( CubitVector &curr_point, 00516 GeomSeg *&curr_seg ) 00517 { 00518 double node[3]; 00519 double point_0[3], point_1[3]; 00520 node[0] = curr_point.x(); 00521 node[1] = curr_point.y(); 00522 node[2] = curr_point.z(); 00523 CubitVector start_v = curr_seg->get_start()->coordinates(); 00524 CubitVector end_v = curr_seg->get_end()->coordinates(); 00525 point_0[0] = start_v.x(); 00526 point_0[1] = start_v.y(); 00527 point_0[2] = start_v.z(); 00528 point_1[0] = end_v.x(); 00529 point_1[1] = end_v.y(); 00530 point_1[2] = end_v.z(); 00531 00532 IntersectionTool new_tool(GEOMETRY_RESABS); 00533 double t; 00534 double dist = new_tool.distance_point_line(node, point_0, 00535 point_1, t); 00536 if ( dist < 0.0 ) 00537 { 00538 //This happens if the point is beyond the line segment, in which 00539 //case we just want the closer end point. 00540 if ( t < 0.0 ) 00541 { 00542 dist = (curr_point -start_v).length_squared(); 00543 } 00544 else 00545 { 00546 dist = (curr_point - end_v).length_squared(); 00547 } 00548 } 00549 else 00550 { 00551 //I hate to do this but everything else is in 00552 //terms of distance squared. 00553 dist = dist*dist; 00554 } 00555 return dist; 00556 } 00557 00558 CubitStatus GeomMeasureTool::convert_to_lines( PointLoopList &boundary_point_loops, 00559 SegLoopList &boundary_line_loops, 00560 RefFace *ref_face ) 00561 { 00562 //This does more than just converts the boundary points to line segments. It also 00563 //Sets up a doubily linked list through the ImprintLineSegment data structure. 00564 //Calling codes need to make sure all this data is deleted. 00565 //This function also sets the PointType for each of the boundary points. This 00566 //will depend also on the boundary_1 flag. If we are doing boundary_1 then, 00567 //the flag will be true, otherwise it will be false. 00568 int ii, jj; 00569 PointList *point_list; 00570 SegList *segment_list; 00571 GeomSeg *new_line, *prev = NULL; 00572 SegList allocated_segs; 00573 RefEntity *entity_start, *entity_end, *seg_owner; 00574 boundary_point_loops.reset(); 00575 for ( ii = boundary_point_loops.size(); ii > 0; ii-- ) 00576 { 00577 point_list = boundary_point_loops.get_and_step(); 00578 segment_list = new SegList; 00579 prev = NULL; 00580 new_line = NULL; 00581 seg_owner = NULL; 00582 for ( jj = point_list->size(); jj > 0; jj-- ) 00583 { 00584 entity_start = point_list->get()->owner(); 00585 entity_end = point_list->next()->owner(); 00586 seg_owner = CAST_TO(entity_start, RefEdge); 00587 if ( seg_owner == NULL ) 00588 { 00589 seg_owner = CAST_TO(entity_end, RefEdge); 00590 if ( seg_owner == NULL ) 00591 { 00592 RefVertex *ref_vert_end = CAST_TO(entity_end, RefVertex); 00593 RefVertex *ref_vert_start = CAST_TO(entity_start, RefVertex); 00594 DLIList <RefEdge*> common_edges; 00595 ref_vert_start->common_ref_edges(ref_vert_end, 00596 common_edges, 00597 ref_face); 00598 if ( common_edges.size() == 0 ) 00599 { 00600 PRINT_ERROR("GeomMeasureTool::convert_to_lines having problem finding owner \n" 00601 " of boundary. Could be indicative of corrupt geometry.\n"); 00602 int ll; 00603 for ( ll = boundary_line_loops.size(); ll > 0; ll-- ) 00604 delete boundary_line_loops.pop(); 00605 for ( ll = allocated_segs.size(); ll > 0; ll-- ) 00606 delete allocated_segs.pop(); 00607 delete segment_list; 00608 return CUBIT_FAILURE; 00609 } 00610 if ( common_edges.size() == 1 ) 00611 seg_owner = common_edges.get(); 00612 else 00613 { 00614 //Now we have to decide which of these edges is the one. 00615 //Lets take a mid point on this segment and check the distances. 00616 //First find the mid_point of the line segment. 00617 CubitVector start = point_list->get()->coordinates(); 00618 CubitVector end = point_list->next()->coordinates(); 00619 CubitVector mid = (start+end)/2.0; 00620 CubitVector closest_point; 00621 00622 //Now test the edges to see which is closest. 00623 RefEdge *closest_edge = NULL, *curr_ref_edge; 00624 double min_dist = CUBIT_DBL_MAX, dist; 00625 int kk; 00626 for ( kk = common_edges.size(); kk > 0; kk-- ) 00627 { 00628 curr_ref_edge = common_edges.get_and_step(); 00629 curr_ref_edge->closest_point(mid, closest_point); 00630 dist = (mid - closest_point).length_squared(); 00631 if ( dist < min_dist ) 00632 { 00633 min_dist = dist; 00634 closest_edge = curr_ref_edge; 00635 } 00636 } 00637 if ( closest_edge == NULL ) 00638 { 00639 PRINT_ERROR("Problems determining segment ownwership.\n" 00640 "Internal problem with virtual imprinting.\n"); 00641 int ll; 00642 for ( ll = boundary_line_loops.size(); ll > 0; ll-- ) 00643 delete boundary_line_loops.pop(); 00644 for ( ll = allocated_segs.size(); ll > 0; ll-- ) 00645 delete allocated_segs.pop(); 00646 delete segment_list; 00647 return CUBIT_FAILURE; 00648 } 00649 seg_owner = closest_edge; 00650 } 00651 } 00652 } 00653 new_line = new GeomSeg( point_list->get(), point_list->next(), seg_owner); 00654 allocated_segs.append(new_line); 00655 point_list->step(); 00656 segment_list->append(new_line); 00657 if ( prev != NULL ) 00658 { 00659 prev->set_next(new_line); 00660 new_line->set_prev(prev); 00661 } 00662 prev = new_line; 00663 } 00664 if ( prev != NULL ) 00665 { 00666 segment_list->reset(); 00667 assert(prev == segment_list->prev()); 00668 segment_list->prev()->set_next(segment_list->get()); 00669 segment_list->get()->set_prev(segment_list->prev()); 00670 assert(segment_list->get()->get_next() != NULL ); 00671 } 00672 if ( segment_list->size() ) 00673 { 00674 boundary_line_loops.append(segment_list); 00675 } 00676 else 00677 delete segment_list; 00678 } 00679 return CUBIT_SUCCESS; 00680 } 00681 00682 CubitStatus GeomMeasureTool::get_boundary_points( RefFace *ref_face, 00683 PointLoopList &boundary_point_loops, 00684 double seg_length_tol) 00685 { 00686 DLIList<DLIList<CoEdge*> > co_edge_loops; 00687 ref_face->co_edge_loops(co_edge_loops); 00688 int ii, jj; 00689 PointList *new_point_loop_ptr, tmp_point_list; 00690 RefEdge *ref_edge_ptr; 00691 CoEdge *co_edge_ptr; 00692 CubitStatus stat; 00693 CubitSense sense; 00694 00695 for ( ii = co_edge_loops.size(); ii > 0; ii-- ) 00696 { 00697 DLIList <CoEdge*> &co_edge_list_ptr = co_edge_loops.get_and_step(); 00698 new_point_loop_ptr = new PointList; 00699 for ( jj = co_edge_list_ptr.size(); jj > 0; jj-- ) 00700 { 00701 co_edge_ptr = co_edge_list_ptr.get_and_step(); 00702 ref_edge_ptr = co_edge_ptr->get_ref_edge_ptr(); 00703 tmp_point_list.clean_out(); 00704 stat = get_curve_facets( ref_edge_ptr, tmp_point_list, 00705 seg_length_tol ); 00706 if ( stat != CUBIT_SUCCESS ) 00707 return CUBIT_FAILURE; 00708 if ( tmp_point_list.size() == 0 ) 00709 continue; 00710 tmp_point_list.reset(); 00711 //the points are in order from start vertex to end vertex. 00712 //append them now according to the loop. 00713 sense = co_edge_ptr->get_sense(); 00714 if ( CUBIT_FORWARD != sense ) 00715 tmp_point_list.reverse(); 00716 //Now take off the last point as it is a duplicate with the 00717 //other list... 00718 tmp_point_list.reset(); 00719 delete tmp_point_list.pop(); 00720 (*new_point_loop_ptr) += tmp_point_list; 00721 } 00722 boundary_point_loops.append(new_point_loop_ptr); 00723 } 00724 00725 return CUBIT_SUCCESS; 00726 } 00727 00728 CubitStatus GeomMeasureTool::get_curve_facets( RefEdge* curve, 00729 PointList &segments, 00730 double seg_length_tol ) 00731 { 00732 // const double COS_ANGLE_TOL = 0.965925826289068312213715; // cos(15) 00733 // const double COS_ANGLE_TOL = 0.984807753012208020315654; // cos(10) 00734 //const double COS_ANGLE_TOL = 0.996194698091745545198705; // cos(5) 00735 GMem curve_graphics; 00736 //make this tol bigger than seg_length_tol, to 00737 //make sure the segments are larger than the tolerance. 00738 const double dist_tol = seg_length_tol;// + .05*seg_length_tol; 00739 //const double dist_tol_sqr = dist_tol*dist_tol; 00740 if ( curve->get_curve_ptr() == NULL ) 00741 { 00742 PRINT_ERROR("Curve %d had no geometry, this is a bug!\n", curve->id()); 00743 return CUBIT_FAILURE; 00744 } 00745 else if ( curve->get_curve_ptr()->get_geometry_query_engine() == NULL ) 00746 { 00747 PRINT_ERROR("Curve %d had no geometry engine, this is a bug!\n", 00748 curve->id()); 00749 return CUBIT_FAILURE; 00750 } 00751 curve->get_graphics( curve_graphics ); 00752 00753 GPoint* gp = curve_graphics.point_list(); 00754 if ( gp == NULL ) 00755 { 00756 if ( curve->measure() < GEOMETRY_RESABS ) 00757 { 00758 if( curve->geometry_type() != POINT_CURVE_TYPE ) 00759 { 00760 PRINT_INFO("Curve %d has a zero length, and won't be used for loop measurements.\n", 00761 curve->id()); 00762 } 00763 } 00764 else 00765 PRINT_ERROR("Curve %d had not faceting. Ignoring this curve.\n", 00766 curve->id()); 00767 return CUBIT_SUCCESS; 00768 } 00769 GeomPoint *last = new GeomPoint( gp[0].x, gp[0].y, gp[0].z, curve ); 00770 CubitVector lastv = last->coordinates(); 00771 int num_points = curve_graphics.pointListCount; 00772 segments.append( last ); 00773 int ii; 00774 CubitBoolean remove_second_to_end = CUBIT_FALSE; 00775 for ( ii = 1; ii < num_points; ii++ ) 00776 { 00777 CubitVector pos( gp[ii].x, gp[ii].y, gp[ii].z ); 00778 CubitVector step1 = (pos - lastv); 00779 double len1 = step1.length(); 00780 if( len1 < dist_tol && ii != num_points - 1) 00781 continue; 00782 else if ( len1 < dist_tol && ii == num_points-1 ) 00783 { 00784 remove_second_to_end = CUBIT_TRUE; 00785 } 00786 last = new GeomPoint(pos,curve); 00787 segments.append( last ); 00788 lastv = last->coordinates(); 00789 } 00790 // Now check if the segment list is reversed wrt the curve direction. 00791 segments.reset(); 00792 if ( remove_second_to_end ) 00793 { 00794 if ( segments.size() == 2 ) 00795 { 00796 //just leave it in, let it be small... 00797 } 00798 else 00799 { 00800 //Remove the second to last one. To do 00801 //this efficiently (don't do remove), pop 00802 //the last one, then save that and 00803 //re-add it after poping the second one. 00804 GeomPoint *temp = segments.pop(); 00805 segments.pop(); 00806 segments.append(temp); 00807 } 00808 } 00809 segments.reset(); 00810 if( curve->start_vertex() != curve->end_vertex() ) 00811 { 00812 CubitVector start_vec, end_vec; 00813 start_vec = curve->start_vertex()->coordinates(); 00814 end_vec = curve->end_vertex()->coordinates(); 00815 CubitVector start_seg = segments.get()->coordinates(); 00816 double dist_1 = (start_seg - start_vec).length_squared(); 00817 double dist_2 = (start_seg - end_vec).length_squared(); 00818 if ( dist_1 > dist_2 ) 00819 segments.reverse(); 00820 } 00821 else 00822 { 00823 double u1, u2; 00824 u1 = curve->u_from_position( (segments.next(1)->coordinates()) ); 00825 u2 = curve->u_from_position( (segments.next(2)->coordinates()) ); 00826 if( (u2 < u1) && (curve->start_param() <= curve->end_param()) ) 00827 segments.reverse(); 00828 } 00829 //clean up the periodic curve case (last seg may be too small.) 00830 if ( curve->start_vertex() == curve->end_vertex() ) 00831 { 00832 segments.reset(); 00833 CubitVector start_v = segments.get()->coordinates(); 00834 CubitVector last_v = segments.prev()->coordinates(); 00835 double dist = (start_v - last_v).length(); 00836 if ( dist < dist_tol ) 00837 { 00838 //remove the last one. 00839 segments.pop(); 00840 } 00841 } 00842 if ( segments.size() < 2 ) 00843 { 00844 PRINT_ERROR("Problem faceting boundary.\n"); 00845 return CUBIT_FAILURE; 00846 } 00847 segments.get()->owner(curve->start_vertex()); 00848 segments.prev()->owner(curve->end_vertex()); 00849 return CUBIT_SUCCESS; 00850 } 00851 CubitStatus GeomMeasureTool::interior_angle(GeomSeg *first_seg, 00852 GeomSeg *next_seg, 00853 RefFace *face, 00854 double &angle ) 00855 { 00856 if ( first_seg->get_end() != next_seg->get_start() ) 00857 { 00858 PRINT_ERROR("GeomMeasureTool::interior_angle expects segments\n" 00859 "to be connected (Users: this is a bug, please submit.\n"); 00860 return CUBIT_FAILURE; 00861 } 00862 CubitVector point = first_seg->get_end()->coordinates(); 00863 CubitVector to_prev = first_seg->get_start()->coordinates(); 00864 to_prev -= point; 00865 CubitVector to_next = next_seg->get_end()->coordinates(); 00866 to_next -= point; 00867 CubitVector surf_norm = face->normal_at(point); 00868 if ( surf_norm.length_squared() < CUBIT_RESABS ) 00869 { 00870 //Try getting it at one of the other nodes... 00871 surf_norm = face->normal_at(first_seg->get_start()->coordinates() ); 00872 if (surf_norm.length_squared() < CUBIT_RESABS ) 00873 { 00874 //Try getting it at one of the other nodes... 00875 surf_norm = face->normal_at(next_seg->get_end()->coordinates() ); 00876 if (surf_norm.length_squared() < CUBIT_RESABS ) 00877 { 00878 PRINT_ERROR("Trying to get normal at surf %d.\n" 00879 " Normal length being returned equals zero.\n", 00880 face->id() ); 00881 angle = CUBIT_DBL_MAX; 00882 return CUBIT_FAILURE; 00883 } 00884 } 00885 } 00886 angle = surf_norm.vector_angle ( to_next, to_prev ); 00887 return CUBIT_SUCCESS; 00888 } 00889 00890 void GeomMeasureTool::measure_face_area (DLIList <RefEntity*> &entity_list, 00891 double &smallest, 00892 RefFace *&smallest_face, 00893 double &largest, 00894 RefFace *&largest_face, 00895 double &average, 00896 double &sum) 00897 { 00898 DLIList<RefFace*> ref_faces; 00899 get_faces_from_list(entity_list, ref_faces); 00900 measure_face_area(ref_faces, smallest, smallest_face, 00901 largest, largest_face, average, sum); 00902 00903 } 00904 00905 void GeomMeasureTool::measure_face_area (DLIList <RefFace*> &ref_faces, 00906 double &smallest, 00907 RefFace *&smallest_face, 00908 double &largest, 00909 RefFace *&largest_face, 00910 double &average, 00911 double &sum) 00912 { 00913 int ii; 00914 double curr_area, total_area = 0.0; 00915 smallest = CUBIT_DBL_MAX; 00916 largest = 0.0; 00917 RefFace *curr_face; 00918 for( ii = ref_faces.size(); ii > 0; ii-- ) 00919 { 00920 curr_face = ref_faces.get_and_step(); 00921 curr_area = measure_area(curr_face); 00922 if ( curr_area < smallest ) 00923 { 00924 smallest = curr_area; 00925 smallest_face = curr_face; 00926 } 00927 if( curr_area > largest ) 00928 { 00929 largest = curr_area; 00930 largest_face = curr_face; 00931 } 00932 total_area += curr_area; 00933 } 00934 if (ref_faces.size() != 0 ) 00935 average = total_area/ref_faces.size(); 00936 sum = total_area; 00937 00938 } 00939 00940 void GeomMeasureTool::measure_volume_volume (DLIList <RefEntity*> &entity_list, 00941 double &smallest, 00942 RefVolume *&smallest_volume, 00943 double &largest, 00944 RefVolume *&largest_volume, 00945 double &average, 00946 double &sum) 00947 { 00948 DLIList<RefVolume*> ref_volumes; 00949 get_volumes_from_list(entity_list, ref_volumes); 00950 measure_volume_volume(ref_volumes, smallest, smallest_volume, 00951 largest, largest_volume, average, sum); 00952 00953 } 00954 00955 void GeomMeasureTool::measure_volume_volume (DLIList <RefVolume*> &ref_volumes, 00956 double &smallest, 00957 RefVolume *&smallest_volume, 00958 double &largest, 00959 RefVolume *&largest_volume, 00960 double &average, 00961 double &sum) 00962 { 00963 int ii; 00964 double curr_volume, total_volume = 0.0; 00965 smallest = CUBIT_DBL_MAX; 00966 largest = 0.0; 00967 RefVolume *curr_solid; 00968 for ( ii = ref_volumes.size(); ii > 0; ii-- ) 00969 { 00970 curr_solid = ref_volumes.get_and_step(); 00971 curr_volume = curr_solid->measure(); 00972 00973 if ( curr_volume < smallest ) 00974 { 00975 smallest = curr_volume; 00976 smallest_volume = curr_solid; 00977 } 00978 if ( curr_volume > largest ) 00979 { 00980 largest = curr_volume; 00981 largest_volume = curr_solid; 00982 } 00983 total_volume += curr_volume; 00984 } 00985 if (ref_volumes.size() != 0 ) 00986 average = total_volume/ref_volumes.size(); 00987 sum = total_volume; 00988 00989 } 00990 00991 void GeomMeasureTool::measure_face_area_and_hydraulic_radius(RefFace *curr_face, 00992 double &face_area, 00993 double &face_hydraulic_radius) 00994 { 00995 int ii; 00996 double total_edge_length = 0.0, curr_edge_length; 00997 RefEdge *curr_edge; 00998 DLIList <CoEdge*> my_co_edges; 00999 01000 face_area = measure_area(curr_face); 01001 curr_face->co_edges(my_co_edges); 01002 for( ii = my_co_edges.size(); ii > 0; ii-- ) 01003 { 01004 curr_edge = my_co_edges.get_and_step()->get_ref_edge_ptr(); 01005 curr_edge_length = curr_edge->measure(); 01006 total_edge_length += curr_edge_length; 01007 } 01008 if (total_edge_length != 0) 01009 face_hydraulic_radius = 4.0*(face_area / total_edge_length); 01010 } 01011 01012 void GeomMeasureTool::measure_volume_volume_and_hydraulic_radius(RefVolume *curr_volume, 01013 double &volume_volume, 01014 double &volume_hydraulic_radius) 01015 { 01016 int ii; 01017 double curr_face_area, total_surface_area = 0.0; 01018 DLIList <RefFace*> ref_face_list; 01019 RefFace *curr_face; 01020 01021 volume_volume = curr_volume->measure(); 01022 curr_volume->ref_faces(ref_face_list); 01023 01024 for ( ii = ref_face_list.size(); ii > 0; ii-- ) 01025 { 01026 curr_face = ref_face_list.get_and_step(); 01027 curr_face_area = measure_area(curr_face); 01028 total_surface_area += curr_face_area; 01029 } 01030 if (total_surface_area != 0) 01031 volume_hydraulic_radius = 6.0*(volume_volume / total_surface_area); 01032 01033 } 01034 01035 void GeomMeasureTool::angles_between_volume_surfaces(RefVolume *curr_volume, 01036 double &min_angle, 01037 double &max_angle, 01038 RefFace *&face_min_1, 01039 RefFace *&face_min_2, 01040 RefFace *&face_max_1, 01041 RefFace *&face_max_2) 01042 { 01043 int ii, jj, shared_angles = 0; 01044 double common_angle, sum_of_angles = 0.0; 01045 double smallest = CUBIT_DBL_MAX, largest = 0.0; 01046 DLIList <RefFace*> face_list_1, face_list_2; 01047 RefFace *curr_face_1, *curr_face_2; 01048 RefEdge *common_edge; 01049 01050 curr_volume->ref_faces(face_list_1); 01051 face_list_2 = face_list_1; 01052 01053 for (ii = face_list_1.size(); ii > 0; ii--) 01054 { 01055 curr_face_1 = face_list_1.get_and_step(); 01056 for(jj = face_list_2.size(); jj > 0; jj--) 01057 { 01058 curr_face_2 = face_list_2.get_and_step(); 01059 01060 if(curr_face_1 == curr_face_2) 01061 continue; 01062 else 01063 { 01064 common_edge = curr_face_1->common_ref_edge(curr_face_2); 01065 if( common_edge == NULL ) 01066 continue; 01067 else 01068 { 01069 shared_angles++; 01070 01071 if ( common_edge->get_curve_ptr()->geometry_type() != STRAIGHT_CURVE_TYPE ) 01072 { 01073 int kk; 01074 double frac_pos = 0.00; 01075 for ( kk = 0; kk < 4; kk++ ) 01076 { 01077 common_angle = GeometryQueryTool::instance()->surface_angle(curr_face_1, curr_face_2, 01078 common_edge, curr_volume, 01079 frac_pos); 01080 frac_pos += .25; 01081 if( common_angle < smallest ) 01082 { 01083 min_angle = common_angle * (180 / CUBIT_PI); 01084 smallest = common_angle; 01085 face_min_1 = curr_face_1; 01086 face_min_2 = curr_face_2; 01087 } 01088 if( common_angle > largest ) 01089 { 01090 max_angle = common_angle * (180 / CUBIT_PI); 01091 largest = common_angle; 01092 face_max_1 = curr_face_1; 01093 face_max_2 = curr_face_2; 01094 } 01095 } 01096 } 01097 else 01098 { 01099 01100 common_angle = GeometryQueryTool::instance()->surface_angle(curr_face_1, curr_face_2, 01101 common_edge, curr_volume ); 01102 if( common_angle < smallest ) 01103 { 01104 min_angle = common_angle * (180 / CUBIT_PI); 01105 smallest = common_angle; 01106 face_min_1 = curr_face_1; 01107 face_min_2 = curr_face_2; 01108 } 01109 if( common_angle > largest ) 01110 { 01111 max_angle = common_angle * (180 / CUBIT_PI); 01112 largest = common_angle; 01113 face_max_1 = curr_face_1; 01114 face_max_2 = curr_face_2; 01115 } 01116 } 01117 01118 sum_of_angles += common_angle; 01119 } 01120 } 01121 } 01122 } 01123 } 01124 01125 void GeomMeasureTool::merged_unmerged_surface_ratio(DLIList <RefVolume*> &ref_volumes, 01126 int &merged, int &unmerged, 01127 double &ratio) 01128 01129 { 01130 int ii, jj; 01131 RefVolume *curr_volume_1; 01132 DLIList <RefFace*> surface_list_1, surface_list_2; 01133 RefFace *curr_face_1; 01134 int merged_surfaces = 0, unmerged_surfaces = 0; 01135 01136 for( ii = ref_volumes.size(); ii > 0; ii-- ) 01137 { 01138 curr_volume_1 = ref_volumes.get_and_step(); 01139 surface_list_1.clean_out(); 01140 01141 curr_volume_1->ref_faces(surface_list_1); 01142 for( jj = surface_list_1.size(); jj > 0; jj-- ) 01143 { 01144 curr_face_1 = surface_list_1.get_and_step(); 01145 if ( curr_face_1->marked() ) 01146 continue; 01147 else 01148 { 01149 curr_face_1->marked(1); 01150 surface_list_2.append(curr_face_1); 01151 } 01152 if ( curr_face_1->num_ref_volumes() == 2 ) 01153 merged_surfaces++; 01154 else 01155 unmerged_surfaces++; 01156 } 01157 } 01158 for ( ii = surface_list_2.size(); ii > 0; ii-- ) 01159 { 01160 surface_list_2.get_and_step()->marked(0); 01161 } 01162 merged = merged_surfaces; 01163 unmerged = unmerged_surfaces; 01164 if ( unmerged_surfaces == 0 ) 01165 { 01166 ratio = 100.0; 01167 } 01168 else 01169 ratio = (double) ((double)merged_surfaces / (double)unmerged_surfaces); 01170 } 01171 01172 void GeomMeasureTool::report_intersected_volumes(DLIList <RefVolume*> &ref_vols, 01173 DLIList <RefVolume*> &intersection_list) 01174 { 01175 DLIList <RefVolume*> results; 01176 RefVolume *curr_vol; 01177 int i, j; 01178 ProgressTool *progress_ptr = NULL; 01179 int total_volumes = ref_vols.size(); 01180 if (total_volumes > 5) 01181 { 01182 progress_ptr = AppUtil::instance()->progress_tool(); 01183 assert(progress_ptr != NULL); 01184 progress_ptr->start(0, 100, "Overlapping Volumes Progress", 01185 NULL, CUBIT_TRUE, CUBIT_TRUE); 01186 } 01187 double curr_percent = 0.0; 01188 01189 for( i = 0; i < ref_vols.size(); i++ ) 01190 { 01191 curr_vol = ref_vols.next(i); 01192 01193 //is this body a multi-volume-body? 01194 Body *single_volume_body = curr_vol->body(); 01195 DLIList<RefVolume*> body_vols; 01196 single_volume_body->ref_volumes( body_vols ); 01197 if( body_vols.size() > 1 ) 01198 single_volume_body = NULL; 01199 01200 for( j = (i + 1); j < ref_vols.size(); j++ ) 01201 { 01202 RefVolume *curr_vol2 = ref_vols.next(j); 01203 if ( AppUtil::instance()->interrupt() ) 01204 { 01205 //interrpt. We need to exit. 01206 if ( progress_ptr != NULL ) 01207 { 01208 progress_ptr->end(); 01209 } 01210 //just leave what has been calculated... 01211 return; 01212 } 01213 01214 Body *single_volume_body2 = curr_vol2->body(); 01215 DLIList<RefVolume*> body_vols2; 01216 single_volume_body2->ref_volumes( body_vols2 ); 01217 if( body_vols2.size() > 1 ) 01218 single_volume_body2 = NULL; 01219 01220 //update the progress.. 01221 if ( progress_ptr != NULL ) 01222 { 01223 curr_percent = ((double)(i+1))/((double)(total_volumes)); 01224 progress_ptr->percent(curr_percent); 01225 } 01226 01227 //if both are single-volume-bodies 01228 if( single_volume_body && single_volume_body2 ) 01229 { 01230 if( GeometryQueryTool::instance()->bodies_overlap( single_volume_body, 01231 single_volume_body2 ) ) 01232 { 01233 intersection_list.append( curr_vol ); 01234 intersection_list.append( curr_vol2 ); 01235 } 01236 } 01237 else if( GeometryQueryTool::instance()->volumes_overlap( curr_vol, curr_vol2 ) ) 01238 { 01239 intersection_list.append( curr_vol ); 01240 intersection_list.append( curr_vol2 ); 01241 } 01242 } 01243 } 01244 01245 if ( progress_ptr != NULL ) 01246 { 01247 progress_ptr->end(); 01248 } 01249 } 01250 01251 void GeomMeasureTool::report_intersected_bodies(DLIList <Body*> &ref_bodies, 01252 DLIList <Body*> &intersection_list) 01253 { 01254 Body *curr_body, *curr_body_2; 01255 int ii, jj; 01256 ProgressTool *progress_ptr = NULL; 01257 int total_bodies = ref_bodies.size(); 01258 if (total_bodies > 5) 01259 { 01260 progress_ptr = AppUtil::instance()->progress_tool(); 01261 assert(progress_ptr != NULL); 01262 progress_ptr->start(0, 100, "Overlapping Volumes Progress", 01263 NULL, CUBIT_TRUE, CUBIT_TRUE); 01264 } 01265 double curr_percent = 0.0; 01266 01267 01268 for( ii = 0; ii < ref_bodies.size(); ii++ ) 01269 { 01270 curr_body = ref_bodies.next(ii); 01271 01272 for( jj = (ii + 1); jj < ref_bodies.size(); jj++ ) 01273 { 01274 curr_body_2 = ref_bodies.next(jj); 01275 if ( AppUtil::instance()->interrupt() ) 01276 { 01277 //interrpt. We need to exit. 01278 if ( progress_ptr != NULL ) 01279 { 01280 progress_ptr->end(); 01281 } 01282 //just leave what has been calculated... 01283 return; 01284 } 01285 01286 if (GeometryQueryTool::instance()->bodies_overlap(curr_body, 01287 curr_body_2) ) 01288 { 01289 intersection_list.append(curr_body); 01290 intersection_list.append(curr_body_2); 01291 } 01292 } 01293 //update the progress.. 01294 if ( progress_ptr != NULL ) 01295 { 01296 curr_percent = ((double)(ii+1))/((double)(total_bodies)); 01297 progress_ptr->percent(curr_percent); 01298 } 01299 } 01300 if ( progress_ptr != NULL ) 01301 { 01302 progress_ptr->end(); 01303 } 01304 } 01305 01306 void GeomMeasureTool::face_list_from_volume_list( DLIList <RefVolume*> &input_vols, 01307 DLIList <RefFace*> &all_faces ) 01308 { 01309 DLIList <RefFace*> curr_faces; 01310 RefVolume *curr_vol; 01311 RefFace *curr_face; 01312 int ii, jj; 01313 01314 //get the all RefFaces from input_vols. 01315 //put them into all_faces list. 01316 01317 for ( ii = 0; ii < input_vols.size(); ii++ ) 01318 { 01319 curr_vol = input_vols.get_and_step(); 01320 curr_faces.clean_out(); 01321 curr_vol->ref_faces(curr_faces); 01322 01323 for( jj = 0; jj < curr_faces.size(); jj++ ) 01324 { 01325 curr_face = curr_faces.get_and_step(); 01326 if( curr_face->marked() ) 01327 continue; 01328 else 01329 { 01330 curr_face->marked(1); 01331 all_faces.append(curr_face); 01332 } 01333 } 01334 } 01335 for ( ii = all_faces.size();ii >0; ii-- ) 01336 all_faces.get_and_step()->marked(0); 01337 } 01338 01339 RefFace* GeomMeasureTool::valid_start( DLIList <RefFace*> &all_faces ) 01340 { 01341 int ii; 01342 RefFace *start_face; 01343 01344 for( ii = 0; ii < all_faces.size(); ii++ ) 01345 { 01346 start_face = all_faces.get_and_step(); 01347 01348 if( !start_face->marked() && start_face->num_ref_volumes()== 1 ) 01349 return start_face; 01350 } 01351 01352 return NULL; 01353 01354 } 01355 01356 void GeomMeasureTool::find_shells( DLIList <RefVolume*> &input_vols, 01357 RefGroup *&owner_groups, 01358 int &number_of_shells) 01359 { 01360 DLIList <DLIList<RefEntity*>*> list_of_lists; 01361 DLIList <RefEntity*> *new_list; 01362 DLIList <RefFace*> all_faces, stack, related_faces; 01363 DLIList <RefEdge*> curr_edges; 01364 RefFace *start_face, *curr_face, *related_face; 01365 RefEdge *curr_edge; 01366 int ii, jj; 01367 RefEntity *tmp_ent; 01368 number_of_shells = 0; 01369 DLIList <RefFace*> marked_faces; 01370 01371 face_list_from_volume_list( input_vols, all_faces ); 01372 01373 // all_faces all marked - need unmarked 01374 for (ii = 0; ii < all_faces.size(); ii++ ) 01375 { 01376 curr_face = all_faces.get_and_step(); 01377 curr_face->marked(0); 01378 } 01379 while ( (start_face = valid_start(all_faces) ) != NULL ) 01380 { 01381 //create a list. 01382 stack.clean_out(); 01383 new_list = new DLIList<RefEntity*>; 01384 stack.append(start_face); 01385 start_face->marked(1); 01386 marked_faces.append(start_face); 01387 01388 while (stack.size() > 0 ) 01389 { 01390 curr_edges.clean_out(); 01391 01392 curr_face = stack.pop(); // get last face added 01393 tmp_ent = CAST_TO(curr_face, RefEntity); 01394 new_list->append(tmp_ent); // append that face to the newest list 01395 curr_face->ref_edges(curr_edges); // gets list of face's edges 01396 01397 for( ii = 0; ii < curr_edges.size(); ii++ ) // loops edges 01398 { 01399 related_faces.clean_out(); 01400 01401 curr_edge = curr_edges.get_and_step(); // chooses next edge 01402 curr_edge->ref_faces(related_faces); // finds edge's related faces 01403 for( jj = 0; jj < related_faces.size(); jj++ ) // loops faces 01404 { 01405 related_face = related_faces.get_and_step(); // gets face 01406 if(!related_face->marked() && related_face->num_ref_volumes() == 1) 01407 { 01408 stack.append(related_face); 01409 related_face->marked(1); 01410 marked_faces.append(related_face); 01411 } 01412 } 01413 } 01414 } 01415 list_of_lists.append(new_list); 01416 number_of_shells++; 01417 } 01418 01419 for (ii = 0; ii < marked_faces.size(); ii++ ) 01420 { 01421 curr_face = marked_faces.get_and_step(); 01422 curr_face->marked(0); 01423 } 01424 01425 RefGroup *curr_group; 01426 owner_groups = RefEntityFactory::instance()->construct_RefGroup("volume_shells"); 01427 for( ii = list_of_lists.size(); ii > 0; ii-- ) 01428 { 01429 new_list = list_of_lists.pop(); 01430 curr_group = RefEntityFactory::instance()->construct_RefGroup(*new_list); 01431 tmp_ent = CAST_TO(curr_group, RefEntity); 01432 owner_groups->add_ref_entity(tmp_ent); 01433 delete new_list; 01434 } 01435 } 01436 01437 void GeomMeasureTool::print_surface_measure_summary( DLIList <RefFace*> &ref_faces ) 01438 01439 { 01440 01441 double min_dist_loops=CUBIT_DBL_MAX, min_dist_loop=CUBIT_DBL_MAX; 01442 double curr_min_dist_loops=CUBIT_DBL_MAX, curr_min_dist_loop=CUBIT_DBL_MAX; 01443 double min_angle=CUBIT_DBL_MAX, max_angle=-CUBIT_DBL_MAX; 01444 double curr_min_angle=CUBIT_DBL_MAX, curr_max_angle=-CUBIT_DBL_MAX; 01445 double curr_face_area, curr_face_hydraulic_radius; 01446 double min_face_area=CUBIT_DBL_MAX, min_face_hydraulic_radius=CUBIT_DBL_MAX; 01447 double max_face_area=-CUBIT_DBL_MAX; 01448 int counter = 0; 01449 double total_area= 0.0; 01450 double min_curve_length = CUBIT_DBL_MAX; 01451 double max_curve_ratio = -CUBIT_DBL_MAX; 01452 double curve_length, curve_ratio; 01453 int ii; 01454 01455 RefFace *curr_face; 01456 RefFace *face_min_dist_loops=NULL, *face_min_dist_loop=NULL; 01457 RefFace *face_min_angle=NULL, *face_max_angle=NULL; 01458 RefFace *face_min_area=NULL, *face_min_hydraulic_radius=NULL; 01459 RefFace *face_max_area=NULL; 01460 RefFace *face_min_curve_length=NULL, *face_max_curve_ratio=NULL; 01461 RefEdge *smallest_edge=NULL, *curr_small_edge=NULL; 01462 01463 01464 for( ii = 0; ii < ref_faces.size(); ii++ ) 01465 { 01466 curr_face = ref_faces.get_and_step(); 01467 if ( curr_face->num_ref_edges() > 0 ) 01468 { 01469 GeomMeasureTool::measure_face_loops(curr_face, 01470 curr_min_dist_loops, 01471 curr_min_dist_loop, 01472 curr_min_angle, 01473 curr_max_angle, 01474 GEOMETRY_RESABS*500); 01475 GeomMeasureTool::measure_face_area_and_hydraulic_radius(curr_face, 01476 curr_face_area, 01477 curr_face_hydraulic_radius); 01478 GeomMeasureTool::measure_face_curves(curr_face, curve_length, 01479 curve_ratio, curr_small_edge); 01480 } 01481 else 01482 curr_face_area = curr_face->measure(); 01483 01484 total_area += curr_face_area; 01485 counter++; 01486 if ( curr_face->num_ref_edges() > 0 ) 01487 { 01488 if ( curve_length < min_curve_length ) 01489 { 01490 min_curve_length = curve_length; 01491 smallest_edge = curr_small_edge; 01492 face_min_curve_length = curr_face; 01493 } 01494 if ( curve_ratio != -1.0 && curve_ratio > max_curve_ratio ) 01495 { 01496 max_curve_ratio = curve_ratio; 01497 face_max_curve_ratio = curr_face; 01498 } 01499 if ( curr_min_dist_loops != -1.0 && curr_min_dist_loops < min_dist_loops ) 01500 { 01501 face_min_dist_loops = curr_face; 01502 min_dist_loops = curr_min_dist_loops; 01503 } 01504 if ( curr_min_dist_loop < min_dist_loop ) 01505 { 01506 face_min_dist_loop = curr_face; 01507 min_dist_loop = curr_min_dist_loop; 01508 } 01509 if ( curr_min_angle < min_angle ) 01510 { 01511 face_min_angle = curr_face; 01512 min_angle = curr_min_angle; 01513 } 01514 if ( curr_max_angle > max_angle ) 01515 { 01516 face_max_angle = curr_face; 01517 max_angle = curr_max_angle; 01518 } 01519 01520 if ( curr_face_hydraulic_radius < min_face_hydraulic_radius ) 01521 { 01522 min_face_hydraulic_radius = curr_face_hydraulic_radius; 01523 face_min_hydraulic_radius = curr_face; 01524 } 01525 01526 } 01527 if ( curr_face_area < min_face_area ) 01528 { 01529 min_face_area = curr_face_area; 01530 face_min_area = curr_face; 01531 } 01532 if ( curr_face_area > max_face_area ) 01533 { 01534 max_face_area = curr_face_area; 01535 face_max_area = curr_face; 01536 } 01537 } 01538 if ( counter > 0 ) 01539 { 01540 PRINT_INFO("\n******Summary of Surface Measure Info*******\n\n"); 01541 PRINT_INFO("Measured %d surfaces: Average Area: %f \n\n", counter, total_area/counter ); 01542 PRINT_INFO("Minimum Surface Area is: %f on surface %d\n\n", 01543 min_face_area, face_min_area->id()); 01544 PRINT_INFO("Maximum Surface Area is: %f on surface %d\n\n", 01545 max_face_area, face_max_area->id()); 01546 if ( face_min_hydraulic_radius ) 01547 PRINT_INFO("Minimum Hydraulic Radius (Area/Perimeter) is: %f on surface %d\n\n", 01548 min_face_hydraulic_radius, face_min_hydraulic_radius->id()); 01549 if ( smallest_edge ) 01550 PRINT_INFO("Minimum Curve Length is: %f for curve %d on surface %d\n\n", 01551 min_curve_length, smallest_edge->id(), face_min_curve_length->id()); 01552 if ( face_max_curve_ratio ) 01553 PRINT_INFO("Maximum Ratio of Adjacent Curve Lengths is: %f on surface %d\n\n", 01554 max_curve_ratio, face_max_curve_ratio->id()); 01555 if ( face_min_dist_loops && face_min_dist_loops->num_loops() > 1 ) 01556 { 01557 PRINT_INFO("Minimum Distance Between Loops is: %f on surface %d\n\n", 01558 min_dist_loops, face_min_dist_loops->id()); 01559 } 01560 if ( face_min_dist_loop ) 01561 PRINT_INFO("Minimum Distance Between a Single Loop is: %f on surface %d\n\n", 01562 min_dist_loop, face_min_dist_loop->id()); 01563 if ( face_min_angle ) 01564 PRINT_INFO("Minimum Interior Angle Between Curves is: %f Degrees on surface %d\n\n", 01565 min_angle, face_min_angle->id()); 01566 if ( face_max_angle ) 01567 PRINT_INFO("Maximum Interior Angle Between Curves is: %f Degrees on surface %d\n\n", 01568 max_angle, face_max_angle->id()); 01569 center(ref_faces); 01570 PRINT_INFO("************End of Summary***********\n\n"); 01571 } 01572 01573 } 01574 void GeomMeasureTool::find_adjacent_face_ratios(RefVolume *curr_volume, double &max_face_ratio, 01575 RefFace *&big_face, 01576 RefFace *&small_face) 01577 { 01578 //Loop over all the faces in the model. Find the maximum face area ratio. 01579 //(larger face area / smaller face area) 01580 01581 DLIList <Shell*> shells; 01582 curr_volume->shells(shells); 01583 DLIList <RefFace*> ref_face_stack, adj_faces; 01584 Shell* curr_shell; 01585 RefFace *curr_ref_face, *adj_face; 01586 //AreaHashTuple is defined in the .hpp file. 01587 DLIList <AreaHashTuple*> *hash_table; 01588 max_face_ratio = -CUBIT_DBL_MAX; 01589 01590 01591 int ii, jj, table_size; 01592 int hash_val; 01593 double tmp_area; 01594 double tmp_ratio; 01595 01596 AreaHashTuple* curr_tuple, *adj_tuple; 01597 01598 for ( ii = shells.size(); ii > 0; ii-- ) 01599 { 01600 curr_shell = shells.get_and_step(); 01601 ref_face_stack.clean_out(); 01602 curr_shell->ref_faces(ref_face_stack); 01603 table_size = ref_face_stack.size(); 01604 //build a hash table with the most simple form 01605 //of hashing based on the ref face id. 01606 //To get this more reliable, make table size a prime 01607 //number... 01608 //Do this so that we don't have to calculate the 01609 //areas more than once... 01610 hash_table = new DLIList<AreaHashTuple*> [table_size]; 01611 for ( jj = 0; jj < ref_face_stack.size(); jj++ ) 01612 { 01613 curr_ref_face = ref_face_stack.get_and_step(); 01614 tmp_area = curr_ref_face->measure(); 01615 curr_tuple = new AreaHashTuple(); 01616 curr_tuple->myFace = curr_ref_face; 01617 curr_tuple->myArea = tmp_area; 01618 hash_val = curr_ref_face->id() % table_size; 01619 hash_table[hash_val].append(curr_tuple); 01620 } 01621 01622 while ( ref_face_stack.size() ) 01623 { 01624 curr_ref_face = ref_face_stack.pop(); 01625 //Now get the adjacent faces. 01626 get_adjacent_faces(curr_ref_face, adj_faces); 01627 find_index(hash_table, table_size, curr_ref_face, curr_tuple); 01628 assert(curr_tuple != NULL); 01629 if ( curr_tuple == NULL ) 01630 return; 01631 CubitBoolean curr_is_big = CUBIT_TRUE; 01632 for ( jj = 0; jj < adj_faces.size(); jj++ ) 01633 { 01634 adj_face = adj_faces.get_and_step(); 01635 find_index(hash_table, table_size, adj_face, adj_tuple); 01636 if ( adj_tuple == NULL ) 01637 continue; 01638 curr_is_big = CUBIT_TRUE; 01639 if ( curr_tuple->myArea < adj_tuple->myArea ) 01640 { 01641 tmp_ratio = adj_tuple->myArea / curr_tuple->myArea; 01642 curr_is_big = CUBIT_FALSE; 01643 } 01644 else 01645 tmp_ratio = curr_tuple->myArea / adj_tuple->myArea; 01646 if ( tmp_ratio > max_face_ratio ) 01647 { 01648 max_face_ratio = tmp_ratio; 01649 if ( curr_is_big ) 01650 { 01651 big_face = curr_ref_face; 01652 small_face = adj_face; 01653 } 01654 else 01655 { 01656 big_face = adj_face; 01657 small_face = curr_ref_face; 01658 } 01659 } 01660 } 01661 } 01662 for ( jj = 0; jj < table_size; jj++ ) 01663 { 01664 //delete the area tuples. 01665 while ( hash_table[jj].size() > 0 ) 01666 delete hash_table[jj].pop(); 01667 } 01668 //delete the hash_table. 01669 delete [] hash_table; 01670 } 01671 } 01672 void GeomMeasureTool::find_index(DLIList<AreaHashTuple*> *hash_table, 01673 int table_size, 01674 RefFace *ref_face, 01675 AreaHashTuple *&curr_tuple ) 01676 { 01677 int ii; 01678 int hash_val = ref_face->id() % table_size; 01679 if ( hash_table[hash_val].size() == 0 ) 01680 { 01681 //this ref face isn't store here. 01682 curr_tuple = NULL; 01683 return; 01684 } 01685 int curr_size = hash_table[hash_val].size(); 01686 //resolve collisions by separate chaining method... 01687 for ( ii = 0;ii < curr_size; ii++ ) 01688 { 01689 if ( hash_table[hash_val].next(ii)->myFace == ref_face ) 01690 { 01691 curr_tuple = hash_table[hash_val].next(ii); 01692 return; 01693 } 01694 } 01695 curr_tuple = NULL; 01696 return; 01697 } 01698 01699 void GeomMeasureTool::get_adjacent_faces(RefFace* curr_face, 01700 DLIList<RefFace*> &adjacent_faces) 01701 { 01702 DLIList <RefEdge*> ref_edges; 01703 DLIList <RefFace*> tmp_ref_faces; 01704 curr_face->ref_edges(ref_edges); 01705 RefEdge *ref_edge; 01706 RefFace *tmp_ref_face; 01707 int ii, jj; 01708 for ( ii = 0; ii < ref_edges.size(); ii++ ) 01709 { 01710 ref_edge = ref_edges.get_and_step(); 01711 tmp_ref_faces.clean_out(); 01712 ref_edge->ref_faces(tmp_ref_faces); 01713 for ( jj = 0; jj < tmp_ref_faces.size(); jj++ ) 01714 { 01715 tmp_ref_face = tmp_ref_faces.get_and_step(); 01716 if ( !tmp_ref_face->marked() && tmp_ref_face != curr_face ) 01717 { 01718 tmp_ref_face->marked(1); 01719 adjacent_faces.append(tmp_ref_face); 01720 } 01721 else 01722 continue; 01723 } 01724 } 01725 for ( ii = adjacent_faces.size(); ii > 0; ii-- ) 01726 adjacent_faces.get_and_step()->marked(0); 01727 } 01728 void GeomMeasureTool::print_volume_measure_summary(DLIList <RefVolume*> &ref_volumes) 01729 { 01730 int ii; 01731 RefVolume *curr_volume; 01732 RefFace *curr_face; 01733 DLIList <RefFace*> ref_faces, tmp_faces; 01734 //First get a list of all the ref_faces. 01735 //Get them uniquely. 01736 for ( ii = 0; ii< ref_volumes.size(); ii++ ) 01737 { 01738 curr_volume = ref_volumes.get_and_step(); 01739 tmp_faces.clean_out(); 01740 curr_volume->ref_faces(tmp_faces); 01741 int jj; 01742 for ( jj = 0; jj < tmp_faces.size(); jj++ ) 01743 { 01744 curr_face = tmp_faces.get_and_step(); 01745 if ( curr_face->marked() ) 01746 continue; 01747 else 01748 { 01749 curr_face->marked(1); 01750 ref_faces.append(curr_face); 01751 } 01752 } 01753 } 01754 //reset the mark. 01755 for ( ii = 0; ii< ref_faces.size(); ii++ ) 01756 ref_faces.get_and_step()->marked(0); 01757 01758 double volume_volume, volume_hydraulic_radius; 01759 double min_angle=CUBIT_DBL_MAX, max_angle=-CUBIT_DBL_MAX; 01760 double total_volume = 0.0, min_volume_hydraulic_radius = CUBIT_DBL_MAX; 01761 double min_volume=CUBIT_DBL_MAX; //, max_volume=-CUBIT_DBL_MAX; 01762 double curr_min_angle = 361.0, curr_max_angle =361.; 01763 double max_face_ratio = -CUBIT_DBL_MAX, curr_face_ratio=CUBIT_DBL_MAX; 01764 01765 01766 RefVolume *volume_min_volume = NULL, *volume_min_hydraulic_radius=NULL; 01767 RefVolume *volume_min_angle=NULL, *volume_max_angle=NULL; 01768 RefVolume *volume_face_ratio= NULL; 01769 RefFace *max_small_face=NULL, *max_big_face=NULL; 01770 RefFace *small_face=NULL, *big_face=NULL; 01771 RefFace *face_min_1=NULL, *face_min_2=NULL; 01772 RefFace *face_max_1=NULL, *face_max_2=NULL; 01773 RefFace *face_min_angle_1=NULL, *face_min_angle_2=NULL; 01774 RefFace *face_max_angle_1=NULL, *face_max_angle_2=NULL; 01775 01776 01777 int counter = 0; 01778 01779 for( ii = 0; ii< ref_volumes.size(); ii++ ) 01780 { 01781 curr_volume = ref_volumes.get_and_step(); 01782 GeomMeasureTool::measure_volume_volume_and_hydraulic_radius(curr_volume, 01783 volume_volume, 01784 volume_hydraulic_radius); 01785 if ( curr_volume->num_ref_faces() > 1 ) 01786 { 01787 GeomMeasureTool::angles_between_volume_surfaces(curr_volume, 01788 curr_min_angle, 01789 curr_max_angle, 01790 face_min_1, face_min_2, 01791 face_max_1, face_max_2); 01792 GeomMeasureTool::find_adjacent_face_ratios(curr_volume, 01793 curr_face_ratio, 01794 big_face, small_face); 01795 } 01796 total_volume += volume_volume; 01797 counter++; 01798 if ( volume_volume < min_volume ) 01799 { 01800 volume_min_volume = curr_volume; 01801 min_volume = volume_volume; 01802 } 01803 if ( volume_hydraulic_radius < min_volume_hydraulic_radius ) 01804 { 01805 volume_min_hydraulic_radius = curr_volume; 01806 min_volume_hydraulic_radius = volume_hydraulic_radius; 01807 } 01808 if ( curr_volume->num_ref_faces() > 1 && curr_min_angle < min_angle ) 01809 { 01810 volume_min_angle = curr_volume; 01811 face_min_angle_1 = face_min_1; 01812 face_min_angle_2 = face_min_2; 01813 min_angle = curr_min_angle; 01814 } 01815 if ( curr_volume->num_ref_faces() > 1 && curr_max_angle > max_angle ) 01816 { 01817 volume_max_angle = curr_volume; 01818 max_angle = curr_max_angle; 01819 face_max_angle_1 = face_max_1; 01820 face_max_angle_2 = face_max_2; 01821 } 01822 if ( curr_volume->num_ref_faces() > 1 && curr_face_ratio > max_face_ratio ) 01823 { 01824 volume_face_ratio = curr_volume; 01825 max_face_ratio = curr_face_ratio; 01826 max_small_face = small_face; 01827 max_big_face = big_face; 01828 } 01829 } 01830 if ( counter > 0 ) 01831 { 01832 PRINT_INFO("*************Volume Summary************\n\n"); 01833 PRINT_INFO("Measured %d Volumes: Average Volume was %f.\n\n", 01834 counter, total_volume/counter); 01835 PRINT_INFO("Minimum Volume was %f in volume %d\n\n", 01836 min_volume, volume_min_volume->id()); 01837 PRINT_INFO("Minimum Volume Hydraulic Radius (volume/surface area) was %f in volume %d\n\n", 01838 min_volume_hydraulic_radius, volume_min_hydraulic_radius->id()); 01839 if ( volume_min_angle ) 01840 PRINT_INFO("Minimum Interior Angle Between Two Surfaces was %f,\n" 01841 "\tsurfaces %d and %d in volume %d\n\n", 01842 min_angle, face_min_angle_1->id(), face_min_angle_2->id(), volume_min_angle->id()); 01843 if ( volume_max_angle ) 01844 PRINT_INFO("Maximum Interior Angle Between Two Surfaces was %f,\n" 01845 "\tsurfaces %d and %d in volume %d\n\n", 01846 max_angle, face_max_angle_1->id(), face_max_angle_2->id(), volume_max_angle->id()); 01847 if ( volume_face_ratio ) 01848 PRINT_INFO("Maximum Area Ratios Between Adjacent Faces was %f,\n" 01849 "\tsurfaces %d and %d in volume %d.\n\n", 01850 max_face_ratio, max_big_face->id(), max_small_face->id(), volume_face_ratio->id()); 01851 int merged, unmerged; 01852 double ratio; 01853 GeomMeasureTool::merged_unmerged_surface_ratio(ref_volumes, merged, unmerged, ratio); 01854 PRINT_INFO("Total number of merged surfaces:\t%d\n" 01855 "Total number of unmerged surfaces:\t%d\n" 01856 "Ratio of merged to unmerged surfaces:\t%f\n\n", merged, unmerged, ratio); 01857 RefGroup *group_of_shells; 01858 int number_shells; 01859 GeomMeasureTool::find_shells(ref_volumes, group_of_shells, number_shells); 01860 if ( number_shells > 0 ) 01861 { 01862 if ( number_shells == 1 ) 01863 { 01864 PRINT_INFO("Found %d shell of connected surfaces.\n", number_shells); 01865 PRINT_INFO("These shell is contained in the group %s\n", 01866 group_of_shells->entity_name().c_str()); 01867 } 01868 else 01869 { 01870 PRINT_INFO("Found %d shells of connected surfaces.\n", number_shells); 01871 PRINT_INFO("These shells are contained in the group %s\n", 01872 group_of_shells->entity_name().c_str()); 01873 } 01874 } 01875 PRINT_INFO("\n\n"); 01876 PRINT_INFO("Now Printing Summaries of Surfaces contained by these volumes.\n"); 01877 GeomMeasureTool::print_surface_measure_summary(ref_faces); 01878 } 01879 return; 01880 01881 } 01882 01883 // Find all of the surfaces in the given volumes that have narrow regions. 01884 void GeomMeasureTool::find_surfs_with_narrow_regions(DLIList <RefVolume*> &ref_vols, 01885 double tol, 01886 DLIList <RefFace*> &surfs_with_narrow_regions) 01887 { 01888 int j; 01889 01890 int ii, jj; 01891 DLIList <RefFace*> ref_faces, temp_faces; 01892 RefVolume *ref_vol; 01893 RefFace *curr_face; 01894 for ( ii = 0; ii < ref_vols.size(); ii++ ) 01895 { 01896 DLIList<RefFace*> faces; 01897 ref_vol = ref_vols.get_and_step(); 01898 ref_vol->ref_faces(faces); 01899 for ( jj = faces.size(); jj > 0; jj-- ) 01900 { 01901 curr_face = faces.get_and_step(); 01902 curr_face->marked(0); 01903 temp_faces.append(curr_face); 01904 } 01905 } 01906 01907 //uniquely add the faces. 01908 for ( jj = temp_faces.size(); jj > 0; jj-- ) 01909 { 01910 curr_face = temp_faces.get_and_step(); 01911 if ( curr_face->marked()== 0 ) 01912 { 01913 curr_face->marked(1); 01914 ref_faces.append(curr_face); 01915 } 01916 } 01917 01918 int num_faces = ref_faces.size(); 01919 01920 ProgressTool *progress_ptr = NULL; 01921 if (num_faces > 20) 01922 { 01923 progress_ptr = AppUtil::instance()->progress_tool(); 01924 assert(progress_ptr != NULL); 01925 progress_ptr->start(0, 100, "Finding Surfaces with Narrow Regions", 01926 NULL, CUBIT_TRUE, CUBIT_TRUE); 01927 } 01928 01929 int total_faces = 0; 01930 double curr_percent = 0.0; 01931 01932 for(j=0; j<num_faces; j++) 01933 { 01934 DLIList<CubitVector> split_pos1_list; 01935 DLIList<CubitVector> split_pos2_list; 01936 RefFace *cur_face = ref_faces.get_and_step(); 01937 total_faces++; 01938 if ( progress_ptr != NULL ) 01939 { 01940 curr_percent = ((double)(total_faces))/((double)(num_faces)); 01941 progress_ptr->percent(curr_percent); 01942 } 01943 01944 if ( AppUtil::instance()->interrupt() ) 01945 { 01946 //interrpt. We need to exit. 01947 if ( progress_ptr != NULL ) 01948 progress_ptr->end(); 01949 //just leave what has been calculated... 01950 return; 01951 } 01952 find_split_points_for_narrow_regions(cur_face, 01953 tol, split_pos1_list, split_pos2_list); 01954 if(split_pos1_list.size() > 0) 01955 surfs_with_narrow_regions.append_unique(cur_face); 01956 } 01957 01958 if ( progress_ptr != NULL ) 01959 progress_ptr->end(); 01960 } 01961 01962 void GeomMeasureTool::get_narrow_regions(DLIList <RefVolume*> &ref_vols, 01963 double tol, 01964 DLIList <RefFace*> &surfs_with_narrow_regions) 01965 { 01966 int ii, jj; 01967 DLIList <RefFace*> ref_faces, temp_faces; 01968 RefVolume *ref_vol; 01969 RefFace *curr_face; 01970 for ( ii = 0; ii < ref_vols.size(); ii++ ) 01971 { 01972 DLIList<RefFace*> faces; 01973 ref_vol = ref_vols.get_and_step(); 01974 ref_vol->ref_faces(faces); 01975 for ( jj = faces.size(); jj > 0; jj-- ) 01976 { 01977 curr_face = faces.get_and_step(); 01978 curr_face->marked(0); 01979 temp_faces.append(curr_face); 01980 } 01981 } 01982 01983 //uniquely add the faces. 01984 for ( jj = temp_faces.size(); jj > 0; jj-- ) 01985 { 01986 curr_face = temp_faces.get_and_step(); 01987 if ( curr_face->marked()== 0 ) 01988 { 01989 curr_face->marked(1); 01990 ref_faces.append(curr_face); 01991 } 01992 } 01993 01994 int num_faces = ref_faces.size(); 01995 01996 ProgressTool *progress_ptr = NULL; 01997 if (num_faces > 20) 01998 { 01999 progress_ptr = AppUtil::instance()->progress_tool(); 02000 assert(progress_ptr != NULL); 02001 progress_ptr->start(0, 100, "Finding Surfaces with Narrow Regions", 02002 NULL, CUBIT_TRUE, CUBIT_TRUE); 02003 } 02004 02005 int total_faces = 0; 02006 double curr_percent = 0.0; 02007 02008 for(jj=0; jj<num_faces; jj++) 02009 { 02010 RefFace *cur_face = ref_faces.get_and_step(); 02011 total_faces++; 02012 if ( progress_ptr != NULL ) 02013 { 02014 curr_percent = ((double)(total_faces))/((double)(num_faces)); 02015 progress_ptr->percent(curr_percent); 02016 } 02017 02018 if ( AppUtil::instance()->interrupt() ) 02019 { 02020 //interrpt. We need to exit. 02021 if ( progress_ptr != NULL ) 02022 progress_ptr->end(); 02023 //just leave what has been calculated... 02024 return; 02025 } 02026 if(cur_face->num_loops() == 1) 02027 { 02028 DLIList<CubitVector> split_pos1_list; 02029 DLIList<CubitVector> split_pos2_list; 02030 find_split_points_for_narrow_regions(cur_face, 02031 tol, split_pos1_list, split_pos2_list); 02032 if(split_pos1_list.size() > 0) 02033 surfs_with_narrow_regions.append(cur_face); 02034 } 02035 else if(cur_face->num_loops() > 1) 02036 { 02037 DLIList <RefEdge*> tmp_close_edges; 02038 DLIList <double> tmp_small_lengths; 02039 find_close_loops( cur_face, tmp_close_edges, 02040 tmp_small_lengths, tol); 02041 if ( tmp_close_edges.size() > 0 ) 02042 { 02043 surfs_with_narrow_regions.append(cur_face); 02044 } 02045 } 02046 } 02047 02048 if ( progress_ptr != NULL ) 02049 progress_ptr->end(); 02050 } 02051 02052 bool GeomMeasureTool::is_surface_narrow(RefFace *face, double small_curve_size) 02053 { 02054 bool ret = true; 02055 DLIList<RefEdge*> edges; 02056 face->ref_edges(edges); 02057 RefVolume *vol = face->ref_volume(); 02058 int i, j; 02059 double dist_sq = small_curve_size*small_curve_size; 02060 double proj_dist = 1.2 * small_curve_size; 02061 for(i=edges.size(); i>0 && ret == true; i--) 02062 { 02063 RefEdge *cur_edge = edges.get_and_step(); 02064 double edge_length = cur_edge->measure(); 02065 if(edge_length > small_curve_size) 02066 { 02067 int num_incs = (int)(edge_length/small_curve_size) + 1; 02068 double start, end; 02069 cur_edge->get_param_range(start, end); 02070 double t = start; 02071 bool one_bad = false; 02072 for(j=0; j<num_incs && ret == true; j++) 02073 { 02074 CubitVector pos1, tangent; 02075 cur_edge->position_from_u(t, pos1); 02076 cur_edge->tangent(pos1, tangent, face); 02077 CubitVector norm = face->normal_at(pos1, vol); 02078 CubitVector indir = norm * tangent; 02079 indir.normalize(); 02080 CubitVector new_pos = pos1 + proj_dist * indir; 02081 CubitVector pt_on_surf; 02082 face->get_surface_ptr()->closest_point_trimmed(new_pos, pt_on_surf); 02083 if((pt_on_surf-pos1).length_squared() < dist_sq) 02084 { 02085 one_bad = false; 02086 } 02087 else // we found one out of small_curve range 02088 { 02089 if(one_bad) // if we had already found one out of range this makes two in a row 02090 ret = false; 02091 else // this is the first one out of range 02092 one_bad = true; 02093 } 02094 } 02095 } 02096 } 02097 02098 return ret; 02099 } 02100 02101 void GeomMeasureTool::find_split_points_for_narrow_regions(RefFace *face, 02102 double size, 02103 DLIList<CubitVector> &split_pos1_list, 02104 DLIList<CubitVector> &split_pos2_list) 02105 { 02106 int k, i, j; 02107 double size_sq = size*size; 02108 DLIList<RefEdge*> edges; 02109 face->ref_edges(edges); 02110 while(edges.size() > 1) 02111 { 02112 RefEdge *cur_edge = edges.extract(); 02113 for(k=edges.size(); k--;) 02114 { 02115 RefEdge *other_edge = edges.get_and_step(); 02116 DLIList<CubitVector*> e1_pos_list, e2_pos_list; 02117 DLIList<RefVertex*> e1_vert_list, e2_vert_list; 02118 if(narrow_region_exists(cur_edge, other_edge, face, size, 02119 e1_pos_list, e2_pos_list, e1_vert_list, e2_vert_list)) 02120 { 02121 e1_pos_list.reset(); 02122 e2_pos_list.reset(); 02123 e1_vert_list.reset(); 02124 e2_vert_list.reset(); 02125 02126 // Loop through each pair of positions defining a split. 02127 for(i=e1_pos_list.size(); i--;) 02128 { 02129 RefVertex *e1_vert = e1_vert_list.get_and_step(); 02130 RefVertex *e2_vert = e2_vert_list.get_and_step(); 02131 CubitVector *e1_pos = e1_pos_list.get_and_step(); 02132 CubitVector *e2_pos = e2_pos_list.get_and_step(); 02133 02134 // Snap to existing vertices if we are not already at at vertex. 02135 if(!e1_vert) 02136 { 02137 if((cur_edge->start_vertex()->coordinates() - *e1_pos).length_squared() < size_sq) 02138 e1_vert = cur_edge->start_vertex(); 02139 else if((cur_edge->end_vertex()->coordinates() - *e1_pos).length_squared() < size_sq) 02140 e1_vert = cur_edge->end_vertex(); 02141 } 02142 if(!e2_vert) 02143 { 02144 if((other_edge->start_vertex()->coordinates() - *e2_pos).length_squared() < size_sq) 02145 e2_vert = other_edge->start_vertex(); 02146 else if((other_edge->end_vertex()->coordinates() - *e2_pos).length_squared() < size_sq) 02147 e2_vert = other_edge->end_vertex(); 02148 } 02149 02150 // We may have multiple edges separating these two vertices but the accumulated 02151 // length of them may still be within our narrow size so check this. If this 02152 // is the case we will not want to consider this as a place to split and 02153 // will as a result discard these positions. 02154 if(e1_vert && e2_vert) 02155 { 02156 double dist = size*sqrt(2.0); 02157 RefVertex *cur_vert = e1_vert; 02158 RefEdge *edge = cur_edge; 02159 double length = 0.0; 02160 while(edge && cur_vert != e2_vert && length <= dist) 02161 { 02162 edge = edge->get_other_curve(cur_vert, face); 02163 if(edge) 02164 { 02165 length += edge->get_arc_length(); 02166 cur_vert = edge->other_vertex(cur_vert); 02167 } 02168 } 02169 if(length > dist) 02170 { 02171 // We want to keep this split. 02172 split_pos1_list.append(e1_vert->coordinates()); 02173 split_pos2_list.append(e2_vert->coordinates()); 02174 } 02175 } 02176 else 02177 { 02178 // We want to keep this split. 02179 split_pos1_list.append(*e1_pos); 02180 split_pos2_list.append(*e2_pos); 02181 } 02182 } 02183 } 02184 while(e1_pos_list.size()) 02185 delete e1_pos_list.pop(); 02186 while(e2_pos_list.size()) 02187 delete e2_pos_list.pop(); 02188 } 02189 } 02190 02191 // Make splits unique 02192 DLIList<CubitVector> unique_list1, unique_list2; 02193 split_pos1_list.reset(); 02194 split_pos2_list.reset(); 02195 for(i=split_pos1_list.size(); i--;) 02196 { 02197 CubitVector p1 = split_pos1_list.get_and_step(); 02198 CubitVector p2 = split_pos2_list.get_and_step(); 02199 int unique = 1; 02200 for(j=unique_list1.size(); j>0 && unique; j--) 02201 { 02202 CubitVector u1 = unique_list1.get_and_step(); 02203 CubitVector u2 = unique_list2.get_and_step(); 02204 if((p1.about_equal(u1) && p2.about_equal(u2)) || 02205 (p1.about_equal(u2) && p2.about_equal(u1))) 02206 { 02207 unique = 0; 02208 } 02209 } 02210 if(unique) 02211 { 02212 unique_list1.append(p1); 02213 unique_list2.append(p2); 02214 } 02215 } 02216 split_pos1_list = unique_list1; 02217 split_pos2_list = unique_list2; 02218 } 02219 02220 // Checks to see if at the given position the two edges are close together and 02221 // have the same tangent. 02222 int GeomMeasureTool::is_narrow_region_at_point(RefEdge *e1, 02223 RefFace *face, 02224 const CubitVector &pt_on_e1, 02225 RefEdge *e2, 02226 const double &tol_sq, 02227 CubitVector &closest) 02228 { 02229 int ret = 0; 02230 02231 CubitVector tan_1, tan_2; 02232 e2->closest_point_trimmed(pt_on_e1, closest); 02233 02234 double dist_sq = CUBIT_DBL_MAX; 02235 02236 // If the surface is not a plane lets project 02237 // the midpoint to the surface and fit a circular 02238 // arc through the 3 points and get the arc length 02239 // to approximate the acutal distance on the surface 02240 // between the 2 original points. 02241 if(PLANE_SURFACE_TYPE != face->geometry_type()) 02242 { 02243 CubitVector closest_mid; 02244 CubitVector vec1 = closest-pt_on_e1; 02245 double straight_length_sq = vec1.length_squared(); 02246 CubitVector mid = pt_on_e1 + 0.5 * vec1; 02247 face->get_surface_ptr()->closest_point(mid, &closest_mid); 02248 CubitVector mid_vec = mid-closest_mid; 02249 double mid_length_sq = mid_vec.length_squared(); 02250 // If we are dealing with very small distances or 02251 // it doesn't look like there is much curvature just use 02252 // the straight line distance. 02253 if(straight_length_sq < 1e-10 || mid_length_sq < 0.01*straight_length_sq) 02254 { 02255 dist_sq = straight_length_sq; 02256 } 02257 else 02258 { 02259 double mid_length = sqrt(mid_length_sq); 02260 double half_length = sqrt(straight_length_sq)/2.0; 02261 // theta is the angle between the vector from the orig point to its projection 02262 // on the other edge and the vector from the orig point to the projected mid point. 02263 double theta = atan(mid_length/half_length); 02264 // beta is the angle between the vector going from the circle center to 02265 // the orig point and the vector going from the circle center to the 02266 // projected mid point. 02267 double beta = 2.0*theta; 02268 // Some trig to get the radius of the circle that goes through all 3 points 02269 double radius = half_length/sin(beta); 02270 dist_sq = 2.0*radius*beta; 02271 dist_sq *= dist_sq; 02272 } 02273 } 02274 else 02275 { 02276 dist_sq = (pt_on_e1-closest).length_squared(); 02277 } 02278 02279 if(dist_sq < tol_sq) 02280 { 02281 DLIList<CoEdge*> coes; 02282 e1->tangent(pt_on_e1, tan_1); 02283 e2->tangent(closest, tan_2); 02284 e1->get_co_edges(coes, face); 02285 if(coes.size() == 1) 02286 { 02287 if(coes.get()->get_sense() == CUBIT_REVERSED) 02288 tan_1 *= -1.0; 02289 coes.clean_out(); 02290 e2->get_co_edges(coes, face); 02291 if(coes.size() == 1) 02292 { 02293 if(coes.get()->get_sense() == CUBIT_REVERSED) 02294 tan_2 *= -1.0; 02295 tan_1.normalize(); 02296 tan_2.normalize(); 02297 if(tan_1 % tan_2 < -0.9) 02298 ret = 1; 02299 } 02300 } 02301 } 02302 return ret; 02303 } 02304 02305 int GeomMeasureTool::narrow_region_exists(RefFace *face, 02306 const double &tol) 02307 { 02308 int k, ret = 0; 02309 DLIList<RefEdge*> edges; 02310 face->ref_edges(edges); 02311 int num_curves = edges.size(); 02312 02313 // if the surface has no bounding edges then we won't consider 02314 // it narrow. This can happen with complete sphere surfaces. 02315 if (0 == num_curves) 02316 return 0; 02317 02318 int num_small_curves = 0; 02319 while(edges.size() > 1 && !ret) 02320 { 02321 // Remove the current edge each time so that we aren't 02322 // doing redundant comparisons. 02323 RefEdge *cur_edge = edges.extract(); 02324 if(cur_edge->get_arc_length() < tol) 02325 num_small_curves++; 02326 02327 // Compare this edge with the remaining edges on the face. 02328 for(k=edges.size(); k && !ret; k--) 02329 { 02330 RefEdge *other_edge = edges.get_and_step(); 02331 02332 DLIList<CubitVector*> e1_pos_list, e2_pos_list; 02333 DLIList<RefVertex*> e1_vert_list, e2_vert_list; 02334 ret = narrow_region_exists(cur_edge, other_edge, face, tol, 02335 e1_pos_list, e2_pos_list, e1_vert_list, e2_vert_list); 02336 while(e1_pos_list.size()) 02337 delete e1_pos_list.pop(); 02338 while(e2_pos_list.size()) 02339 delete e2_pos_list.pop(); 02340 } 02341 } 02342 if(!ret) 02343 { 02344 if(edges.size() == 1 && edges.get()->get_arc_length() < tol) 02345 num_small_curves++; 02346 } 02347 02348 ret = ret || (num_small_curves == num_curves); 02349 02350 return ret; 02351 } 02352 02353 int GeomMeasureTool::narrow_region_exists(RefFace *face, 02354 RefEdge *edge, 02355 const double &tol) 02356 { 02357 int k, ret = 0; 02358 DLIList<RefEdge*> edges; 02359 face->ref_edges(edges); 02360 if(edges.move_to(edge)) 02361 { 02362 edges.extract(); 02363 02364 // Compare this edge with the remaining edges on the face. 02365 for(k=edges.size(); k && !ret; k--) 02366 { 02367 RefEdge *other_edge = edges.get_and_step(); 02368 02369 DLIList<CubitVector*> e1_pos_list, e2_pos_list; 02370 DLIList<RefVertex*> e1_vert_list, e2_vert_list; 02371 ret = narrow_region_exists(edge, other_edge, face, tol, 02372 e1_pos_list, e2_pos_list, e1_vert_list, e2_vert_list); 02373 while(e1_pos_list.size()) 02374 delete e1_pos_list.pop(); 02375 while(e2_pos_list.size()) 02376 delete e2_pos_list.pop(); 02377 } 02378 } 02379 return ret; 02380 } 02381 02382 // Finds the start and stop locations between two "close" curves 02383 // that meet the narrow criteria. The lists that are returned 02384 // mark the beginning and ends of the narrow regions. 02385 int GeomMeasureTool::narrow_region_exists( 02386 RefEdge *e1, 02387 RefEdge *e2, 02388 RefFace *face, 02389 const double &tol, 02390 DLIList<CubitVector*> &e1_pos_list, 02391 DLIList<CubitVector*> &e2_pos_list, 02392 DLIList<RefVertex*> &e1_vert_list, 02393 DLIList<RefVertex*> &e2_vert_list) 02394 { 02395 int ret = 0; 02396 double tol_sq = tol*tol; 02397 double max_dist_sq = 0.0; 02398 RefVertex *e1_start_vert = e1->start_vertex(); 02399 RefVertex *e1_end_vert = e1->end_vertex(); 02400 02401 CubitVector closest; 02402 DLIList<RefVertex*> e1_verts, e2_verts; 02403 02404 e1->ref_vertices(e1_verts); 02405 e2->ref_vertices(e2_verts); 02406 e1_verts.intersect_unordered(e2_verts); 02407 int num_shared_verts = e1_verts.size(); 02408 RefVertex *shared_vert = NULL; 02409 RefEdge *edge1 = NULL; 02410 RefEdge *edge2 = NULL; 02411 if(num_shared_verts == 1) 02412 { 02413 shared_vert = e1_verts.get(); 02414 DLIList<CoEdge*> coes; 02415 e1->get_co_edges(coes, face); 02416 if(coes.size() == 1) 02417 { 02418 RefVolume *vol = face->ref_volume(); 02419 CubitSense facevol_sense = face->sense(vol); 02420 if((coes.get()->start_vertex() == shared_vert) == 02421 (facevol_sense == CUBIT_FORWARD)) 02422 { 02423 edge1 = e1; 02424 edge2 = e2; 02425 } 02426 else 02427 { 02428 edge1 = e2; 02429 edge2 = e1; 02430 } 02431 } 02432 } 02433 02434 // Project cur endpoints onto other. 02435 02436 // First check the endpoints of e1 agaisnt e2 02437 int do_narrow_region_check = 1; 02438 if(num_shared_verts == 1 && shared_vert == e1_start_vert) 02439 { 02440 // Edges are next to each other. Check the angle between them 02441 // before doing anything else. 02442 double interior_angle = edge1->angle_between(edge2, face); 02443 if(interior_angle > CUBIT_PI/4.0) 02444 do_narrow_region_check = 0; 02445 } 02446 if(do_narrow_region_check && 02447 is_narrow_region_at_point(e1, face, e1_start_vert->coordinates(), e2, tol_sq, closest)) 02448 { 02449 max_dist_sq = (closest - e1_start_vert->coordinates()).length_squared(); 02450 e1_pos_list.append(new CubitVector(e1_start_vert->coordinates())); 02451 e2_pos_list.append(new CubitVector(closest)); 02452 e1_vert_list.append(e1_start_vert); 02453 e2_vert_list.append(NULL); 02454 } 02455 do_narrow_region_check = 1; 02456 if(num_shared_verts == 1 && shared_vert == e1_end_vert) 02457 { 02458 // Edges are next to each other. Check the angle between them 02459 // before doing anything else. 02460 double interior_angle = edge1->angle_between(edge2, face); 02461 if(interior_angle > CUBIT_PI/4.0) 02462 do_narrow_region_check = 0; 02463 } 02464 if(do_narrow_region_check && 02465 is_narrow_region_at_point(e1, face, e1_end_vert->coordinates(), e2, tol_sq, closest)) 02466 { 02467 double cur_dist_sq = (closest - e1_end_vert->coordinates()).length_squared(); 02468 max_dist_sq = max_dist_sq > cur_dist_sq ? max_dist_sq : cur_dist_sq; 02469 e1_pos_list.append(new CubitVector(e1_end_vert->coordinates())); 02470 e2_pos_list.append(new CubitVector(closest)); 02471 e1_vert_list.append(e1_end_vert); 02472 e2_vert_list.append(NULL); 02473 } 02474 02475 if(e1_pos_list.size() < 2) 02476 { 02477 RefVertex *e2_start_vert = e2->start_vertex(); 02478 RefVertex *e2_end_vert = e2->end_vertex(); 02479 do_narrow_region_check = 1; 02480 // Now check the end points of e2 against e1 02481 if(num_shared_verts == 1 && shared_vert == e2_start_vert) 02482 { 02483 // Edges are next to each other. Check the angle between them 02484 // before doing anything else. 02485 double interior_angle = edge1->angle_between(edge2, face); 02486 if(interior_angle > CUBIT_PI/4.0) 02487 do_narrow_region_check = 0; 02488 } 02489 if(do_narrow_region_check && 02490 is_narrow_region_at_point(e2, face, e2_start_vert->coordinates(), e1, tol_sq, closest)) 02491 { 02492 if(e1_pos_list.size() == 0 || !closest.about_equal(*e1_pos_list.get())) 02493 { 02494 double cur_dist_sq = (closest - e2_start_vert->coordinates()).length_squared(); 02495 max_dist_sq = max_dist_sq > cur_dist_sq ? max_dist_sq : cur_dist_sq; 02496 e2_pos_list.append(new CubitVector(e2_start_vert->coordinates())); 02497 e1_pos_list.append(new CubitVector(closest)); 02498 e2_vert_list.append(e2_start_vert); 02499 e1_vert_list.append(NULL); 02500 } 02501 } 02502 if(e1_pos_list.size() < 2) 02503 { 02504 do_narrow_region_check = 1; 02505 if(num_shared_verts == 1 && shared_vert == e2_end_vert) 02506 { 02507 // Edges are next to each other. Check the angle between them 02508 // before doing anything else. 02509 double interior_angle = edge1->angle_between(edge2, face); 02510 if(interior_angle > CUBIT_PI/4.0) 02511 do_narrow_region_check = 0; 02512 } 02513 if(do_narrow_region_check && 02514 is_narrow_region_at_point(e2, face, e2_end_vert->coordinates(), e1, tol_sq, closest)) 02515 { 02516 if(e1_pos_list.size() == 0 || !closest.about_equal(*e1_pos_list.get())) 02517 { 02518 double cur_dist_sq = (closest - e2_end_vert->coordinates()).length_squared(); 02519 max_dist_sq = max_dist_sq > cur_dist_sq ? max_dist_sq : cur_dist_sq; 02520 e2_pos_list.append(new CubitVector(e2_end_vert->coordinates())); 02521 e1_pos_list.append(new CubitVector(closest)); 02522 e2_vert_list.append(e2_end_vert); 02523 e1_vert_list.append(NULL); 02524 } 02525 } 02526 } 02527 } 02528 02529 // At this point we have projected each curves endpoints onto the other curve 02530 // and if the projection was "close" we have recorded these as in the lists 02531 // as close positions. 02532 02533 // If we have two sets of narrow points check to see if the region 02534 // between them is all narrow. 02535 if(e1_pos_list.size() == 2) 02536 { 02537 int w; 02538 int all_good = 1; 02539 // double dist_tol = sqrt(max_dist_sq)*5.0; 02540 e1_pos_list.reset(); 02541 e2_pos_list.reset(); 02542 CubitVector *cur1 = e1_pos_list.get_and_step(); 02543 CubitVector *cur2 = e1_pos_list.get(); 02544 CubitVector *other1 = e2_pos_list.get_and_step(); 02545 CubitVector *other2 = e2_pos_list.get(); 02546 02547 double len1 = e1->get_arc_length(*cur1, *cur2); 02548 //We have to check for periodic edges because the narrow points 02549 //will be the same when one or both of the edges is periodic. 02550 if(len1 > tol || (e1->is_periodic()|| e2->is_periodic())) 02551 { 02552 double len2 = e2->get_arc_length(*other1, *other2); 02553 if(len2 > tol || (e1->is_periodic()|| e2->is_periodic())) 02554 { 02555 double cur_param1 = e1->u_from_position(*cur1); 02556 double cur_param2 = e1->u_from_position(*cur2); 02557 int num_divisions = 2; 02558 CubitVector cur_pos; 02559 double param_step = (cur_param2-cur_param1)/num_divisions; 02560 double cur_param = cur_param1 + param_step; 02561 for(w=1; w<num_divisions && all_good; w++) 02562 { 02563 e1->position_from_u(cur_param, cur_pos); 02564 cur_param += param_step; 02565 if(is_narrow_region_at_point(e1, face, cur_pos, e2, tol_sq, closest)) 02566 { 02567 // Sanity check to make sure we aren't splitting off negative space. 02568 CubitVector mid = (cur_pos + closest)/2.0; 02569 CubitVector tmp_pt; 02570 face->get_surface_ptr()->closest_point_trimmed(mid, tmp_pt); 02571 // If it didn't move we are fine but if it did we need to check 02572 // a little more. 02573 if(!mid.about_equal(tmp_pt)) 02574 { 02575 // It is possible that the midpoint between the two curves does not lie on the 02576 // surface. This would be the case in a blend surface. Check to see that 02577 // the projected point is just an offset along the normal of the surface 02578 // rather than a laterl movement because the space between the two 02579 // curves was actually negative space and not part of the surface. 02580 CubitVector norm = face->normal_at(tmp_pt); 02581 CubitVector dir(tmp_pt - mid); 02582 dir.normalize(); 02583 if(fabs(norm % dir) < .9) 02584 all_good = 0; 02585 } 02586 } 02587 } 02588 } 02589 else 02590 all_good = 0; 02591 } 02592 else 02593 all_good = 0; 02594 02595 if(all_good) 02596 ret = 1; 02597 else 02598 { 02599 e1_pos_list.remove(cur1); 02600 e1_pos_list.remove(cur2); 02601 e2_pos_list.remove(other1); 02602 e2_pos_list.remove(other2); 02603 delete cur1; 02604 delete cur2; 02605 delete other1; 02606 delete other2; 02607 } 02608 } 02609 02610 // If we didn't find a continous region that was narrow we may curves 02611 // that start narrow at one or more of the ends and then move away from each other. 02612 // We need to find if there is a significant region that is narrow and identify 02613 // where the two curves start diverging. Add additional points to the lists 02614 // at the points where things start diverging. 02615 if(!ret && e1_pos_list.size() > 0) 02616 { 02617 int i; 02618 e1_pos_list.reset(); 02619 e2_pos_list.reset(); 02620 e1_vert_list.reset(); 02621 e2_vert_list.reset(); 02622 for(i=e1_pos_list.size(); i--;) 02623 { 02624 RefVertex *e1_vert = e1_vert_list.get_and_step(); 02625 RefVertex *e2_vert = e2_vert_list.get_and_step(); 02626 02627 RefVertex *cur_vert = NULL; 02628 RefEdge *cur_edge = NULL, *other_edge = NULL; 02629 if(e1_vert) 02630 { 02631 cur_edge = e1; 02632 other_edge = e2; 02633 cur_vert = e1_vert; 02634 } 02635 else if(e2_vert) 02636 { 02637 cur_edge = e2; 02638 other_edge = e1; 02639 cur_vert = e2_vert; 02640 } 02641 if(cur_vert) 02642 { 02643 CubitVector next_pos; 02644 CubitVector prev_pos = cur_vert->coordinates(); 02645 int num_incs = 20; 02646 double step = cur_edge->get_arc_length()/(double)num_incs; 02647 int still_good = 1; 02648 int cntr = 0; 02649 double direction = (cur_vert == cur_edge->start_vertex() ? 1.0 : -1.0); 02650 // Do coarse traversal along curve to see where we start deviating from 02651 // narrow. 02652 while(still_good) 02653 { 02654 cur_edge->point_from_arc_length(prev_pos, step*direction, next_pos); 02655 if(is_narrow_region_at_point(cur_edge, face, next_pos, other_edge, tol_sq, closest) && 02656 cntr < num_incs) 02657 { 02658 prev_pos = next_pos; 02659 cntr++; 02660 } 02661 else 02662 still_good = 0; 02663 } 02664 if(cntr < num_incs) 02665 { 02666 cntr = 0; 02667 double cur_arc_length = cur_edge->get_arc_length(prev_pos, next_pos); 02668 // Do bisection on remaining interval to zero in on point where 02669 // we go from narrow to non-narrow. 02670 CubitVector mid_pos; 02671 double close_enough = tol/20.0; 02672 while(cur_arc_length > close_enough && cntr < 100) 02673 { 02674 cntr++; // prevent infinite looping 02675 cur_edge->point_from_arc_length(prev_pos, cur_arc_length*direction/2.0, mid_pos); 02676 if(is_narrow_region_at_point(cur_edge, face, mid_pos, other_edge, tol_sq, closest)) 02677 prev_pos = mid_pos; 02678 else 02679 next_pos = mid_pos; 02680 cur_arc_length = cur_edge->get_arc_length(prev_pos, next_pos); 02681 } 02682 if(cur_edge->get_arc_length(cur_vert->coordinates(), prev_pos) > tol) 02683 { 02684 // end up with the position that guarantees a new split curve that 02685 // is smaller than the small curve size. 02686 other_edge->closest_point_trimmed(prev_pos, closest); 02687 if(cur_edge == e1) 02688 { 02689 e1_pos_list.append(new CubitVector(prev_pos)); 02690 e2_pos_list.append(new CubitVector(closest)); 02691 } 02692 else 02693 { 02694 e2_pos_list.append(new CubitVector(prev_pos)); 02695 e1_pos_list.append(new CubitVector(closest)); 02696 } 02697 e1_vert_list.append(NULL); 02698 e2_vert_list.append(NULL); 02699 ret = 1; 02700 } 02701 } 02702 } 02703 } 02704 } 02705 02706 // Now remove and regions of close curves between which 02707 // there is negative space (not actually part of the surface). 02708 if(ret) 02709 { 02710 int i, j; 02711 e1_pos_list.reset(); 02712 e2_pos_list.reset(); 02713 e1_vert_list.reset(); 02714 e2_vert_list.reset(); 02715 for(i=e1_pos_list.size(); i--;) 02716 { 02717 CubitVector *e1_pos = e1_pos_list.get(); 02718 CubitVector *e2_pos = e2_pos_list.get(); 02719 int num_divisions = 6; 02720 CubitVector step = (*e2_pos - *e1_pos)/num_divisions; 02721 CubitVector cur_pos = *e1_pos + step; 02722 int removed = 0; 02723 for(j=1; j<num_divisions; j++) 02724 { 02725 CubitVector tmp_pt; 02726 face->get_surface_ptr()->closest_point_trimmed(cur_pos, tmp_pt); 02727 if(!cur_pos.about_equal(tmp_pt)) 02728 { 02729 CubitVector norm = face->normal_at(tmp_pt); 02730 CubitVector dir(tmp_pt - cur_pos); 02731 dir.normalize(); 02732 if(fabs(norm % dir) < .9) 02733 { 02734 removed = 1; 02735 j=num_divisions; 02736 delete e1_pos_list.remove(); 02737 delete e2_pos_list.remove(); 02738 e1_vert_list.remove(); 02739 e2_vert_list.remove(); 02740 } 02741 } 02742 else 02743 cur_pos += step; 02744 } 02745 if(!removed) 02746 { 02747 e1_pos_list.step(); 02748 e2_pos_list.step(); 02749 e1_vert_list.step(); 02750 e2_vert_list.step(); 02751 } 02752 } 02753 02754 if(e1_pos_list.size() == 0) 02755 ret = 0; 02756 } 02757 02758 return ret; 02759 } 02760 02761 void GeomMeasureTool::find_small_curves( DLIList <RefVolume*> &ref_vols, 02762 double tol, 02763 DLIList <RefEdge*> &small_curves, 02764 DLIList <double> &small_lengths) 02765 { 02766 int ii, jj; 02767 DLIList <RefEdge*> ref_edges, temp_edges; 02768 RefVolume *ref_vol; 02769 RefEdge *curr_edge; 02770 for ( ii = 0; ii < ref_vols.size(); ii++ ) 02771 { 02772 ref_vol = ref_vols.get_and_step(); 02773 ref_vol->ref_edges(temp_edges); 02774 //uniquely add the edges. 02775 for ( jj = temp_edges.size(); jj > 0; jj-- ) 02776 { 02777 curr_edge = temp_edges.pop(); 02778 if ( curr_edge->marked()== 0 ) 02779 { 02780 curr_edge->marked(1); 02781 ref_edges.append(curr_edge); 02782 } 02783 } 02784 } 02785 02786 int num_curves = ref_edges.size(); 02787 ProgressTool *progress_ptr = NULL; 02788 if (num_curves> 20) 02789 { 02790 progress_ptr = AppUtil::instance()->progress_tool(); 02791 assert(progress_ptr != NULL); 02792 progress_ptr->start(0, 100, "Finding Small Curves", 02793 NULL, CUBIT_TRUE, CUBIT_TRUE); 02794 } 02795 02796 int total_curves = 0; 02797 double curr_percent = 0.0; 02798 double length; 02799 //find the small curves and reset the marked flag. 02800 for ( ii = ref_edges.size(); ii > 0; ii-- ) 02801 { 02802 total_curves++; 02803 if ( progress_ptr != NULL ) 02804 { 02805 curr_percent = ((double)(total_curves))/((double)(num_curves)); 02806 progress_ptr->percent(curr_percent); 02807 } 02808 if ( AppUtil::instance()->interrupt() ) 02809 { 02810 //interrpt. We need to exit. 02811 if ( progress_ptr != NULL ) 02812 progress_ptr->end(); 02813 //just leave what has been calculated... 02814 return; 02815 } 02816 02817 curr_edge = ref_edges.get_and_step(); 02818 curr_edge->marked(0); 02819 02820 //skip point curves 02821 if( curr_edge->geometry_type() == POINT_CURVE_TYPE ) 02822 continue; 02823 02824 length = curr_edge->measure(); 02825 if ( length <= tol ) 02826 { 02827 small_curves.append(curr_edge); 02828 small_lengths.append(length); 02829 } 02830 } 02831 02832 if ( progress_ptr != NULL ) 02833 progress_ptr->end(); 02834 02835 return; 02836 } 02837 02838 RefEdge* GeomMeasureTool::find_first_small_curve(RefVolume* vol, 02839 double tol) 02840 { 02841 RefEdge *ret = NULL; 02842 int j; 02843 DLIList <RefEdge*> ref_edges; 02844 vol->ref_edges(ref_edges); 02845 for(j=ref_edges.size(); j > 0 && !ret; j--) 02846 { 02847 RefEdge *curr_edge = ref_edges.get_and_step(); 02848 if(curr_edge->measure() <= tol) 02849 ret = curr_edge; 02850 } 02851 return ret; 02852 } 02853 02854 void GeomMeasureTool::find_narrow_faces(DLIList<RefVolume*> &ref_vols, 02855 double small_curve_size, 02856 DLIList<RefFace*> &narrow_faces, 02857 DLIList<RefFace*> &surfs_to_ignore) 02858 { 02859 int ii, jj; 02860 DLIList <RefFace*> ref_faces, temp_faces; 02861 RefVolume *ref_vol; 02862 RefFace *curr_face; 02863 02864 for ( ii = 0; ii < ref_vols.size(); ii++ ) 02865 { 02866 DLIList<RefFace*> faces; 02867 ref_vol = ref_vols.get_and_step(); 02868 ref_vol->ref_faces(faces); 02869 for ( jj = faces.size(); jj > 0; jj-- ) 02870 { 02871 curr_face = faces.get_and_step(); 02872 curr_face->marked(0); 02873 temp_faces.append(curr_face); 02874 } 02875 } 02876 02877 //uniquely add the faces. 02878 for ( jj = temp_faces.size(); jj > 0; jj-- ) 02879 { 02880 curr_face = temp_faces.get_and_step(); 02881 if ( curr_face->marked()== 0 ) 02882 { 02883 curr_face->marked(1); 02884 ref_faces.append(curr_face); 02885 } 02886 } 02887 02888 int num_faces = ref_faces.size(); 02889 ProgressTool *progress_ptr = NULL; 02890 if (num_faces > 20) 02891 { 02892 progress_ptr = AppUtil::instance()->progress_tool(); 02893 assert(progress_ptr != NULL); 02894 progress_ptr->start(0, 100, "Finding Narrow Surfaces", 02895 NULL, CUBIT_TRUE, CUBIT_TRUE); 02896 } 02897 02898 int total_faces = 0; 02899 double curr_percent = 0.0; 02900 02901 for ( ii = ref_faces.size(); ii > 0; ii-- ) 02902 { 02903 total_faces++; 02904 if ( progress_ptr != NULL ) 02905 { 02906 curr_percent = ((double)(total_faces))/((double)(num_faces)); 02907 progress_ptr->percent(curr_percent); 02908 } 02909 02910 if ( AppUtil::instance()->interrupt() ) 02911 { 02912 //interrpt. We need to exit. 02913 if ( progress_ptr != NULL ) 02914 progress_ptr->end(); 02915 //just leave what has been calculated... 02916 return; 02917 } 02918 02919 curr_face = ref_faces.get_and_step(); 02920 if(!surfs_to_ignore.is_in_list(curr_face)) 02921 { 02922 if(narrow_region_exists(curr_face, small_curve_size)) 02923 { 02924 DLIList<CubitVector> split_pos1_list; 02925 DLIList<CubitVector> split_pos2_list; 02926 find_split_points_for_narrow_regions(curr_face, 02927 small_curve_size, split_pos1_list, split_pos2_list); 02928 if(split_pos1_list.size() == 0) 02929 narrow_faces.append_unique(curr_face); 02930 } 02931 } 02932 } 02933 02934 if ( progress_ptr != NULL ) 02935 progress_ptr->end(); 02936 02937 return; 02938 } 02939 02940 void GeomMeasureTool::find_small_faces( DLIList <RefVolume*> &ref_vols, 02941 double tol, 02942 DLIList <RefFace*> &small_faces) 02943 { 02944 int ii, jj; 02945 DLIList <RefFace*> ref_faces, temp_faces; 02946 RefVolume *ref_vol; 02947 RefFace *curr_face; 02948 for ( ii = 0; ii < ref_vols.size(); ii++ ) 02949 { 02950 DLIList<RefFace*> faces; 02951 ref_vol = ref_vols.get_and_step(); 02952 ref_vol->ref_faces(faces); 02953 for ( jj = faces.size(); jj > 0; jj-- ) 02954 { 02955 curr_face = faces.get_and_step(); 02956 curr_face->marked(0); 02957 temp_faces.append(curr_face); 02958 } 02959 } 02960 02961 //uniquely add the faces. 02962 for ( jj = temp_faces.size(); jj > 0; jj-- ) 02963 { 02964 curr_face = temp_faces.get_and_step(); 02965 if ( curr_face->marked()== 0 ) 02966 { 02967 curr_face->marked(1); 02968 ref_faces.append(curr_face); 02969 } 02970 } 02971 02972 int num_faces = ref_faces.size(); 02973 ProgressTool *progress_ptr = NULL; 02974 if (num_faces > 20) 02975 { 02976 progress_ptr = AppUtil::instance()->progress_tool(); 02977 assert(progress_ptr != NULL); 02978 progress_ptr->start(0, 100, "Finding Small Surfaces", 02979 NULL, CUBIT_TRUE, CUBIT_TRUE); 02980 } 02981 02982 int total_faces = 0; 02983 double curr_percent = 0.0; 02984 double area; 02985 //find the small curves and reset the marked flag. 02986 for ( ii = ref_faces.size(); ii > 0; ii-- ) 02987 { 02988 total_faces++; 02989 if ( progress_ptr != NULL ) 02990 { 02991 curr_percent = ((double)(total_faces))/((double)(num_faces)); 02992 progress_ptr->percent(curr_percent); 02993 } 02994 02995 if ( AppUtil::instance()->interrupt() ) 02996 { 02997 //interrpt. We need to exit. 02998 if ( progress_ptr != NULL ) 02999 progress_ptr->end(); 03000 //just leave what has been calculated... 03001 return; 03002 } 03003 03004 curr_face = ref_faces.get_and_step(); 03005 area = measure_area(curr_face); 03006 if ( area <= tol ) 03007 small_faces.append(curr_face); 03008 } 03009 03010 if ( progress_ptr != NULL ) 03011 progress_ptr->end(); 03012 03013 return; 03014 } 03015 03016 void GeomMeasureTool::find_closed_narrow_faces( DLIList <RefVolume*> &ref_vols, 03017 double tol, 03018 DLIList <RefFace*> &face_list) 03019 { 03020 int ii, jj; 03021 DLIList <RefFace*> ref_faces, temp_faces; 03022 RefVolume *ref_vol; 03023 RefFace *curr_face; 03024 for ( ii = 0; ii < ref_vols.size(); ii++ ) 03025 { 03026 DLIList<RefFace*> faces; 03027 ref_vol = ref_vols.get_and_step(); 03028 ref_vol->ref_faces(faces); 03029 for ( jj = faces.size(); jj > 0; jj-- ) 03030 { 03031 curr_face = faces.get_and_step(); 03032 curr_face->marked(0); 03033 temp_faces.append(curr_face); 03034 } 03035 } 03036 03037 //uniquely add the faces. 03038 for ( jj = temp_faces.size(); jj > 0; jj-- ) 03039 { 03040 curr_face = temp_faces.get_and_step(); 03041 if ( curr_face->marked()== 0 ) 03042 { 03043 curr_face->marked(1); 03044 ref_faces.append(curr_face); 03045 } 03046 } 03047 03048 int num_faces = ref_faces.size(); 03049 ProgressTool *progress_ptr = NULL; 03050 if (num_faces > 20) 03051 { 03052 progress_ptr = AppUtil::instance()->progress_tool(); 03053 assert(progress_ptr != NULL); 03054 progress_ptr->start(0, 100, "Finding Small Surfaces", 03055 NULL, CUBIT_TRUE, CUBIT_TRUE); 03056 } 03057 03058 int total_faces = 0; 03059 double curr_percent = 0.0; 03060 for ( ii = ref_faces.size(); ii > 0; ii-- ) 03061 { 03062 total_faces++; 03063 if ( progress_ptr != NULL ) 03064 { 03065 curr_percent = ((double)(total_faces))/((double)(num_faces)); 03066 progress_ptr->percent(curr_percent); 03067 } 03068 03069 if ( AppUtil::instance()->interrupt() ) 03070 { 03071 //interrpt. We need to exit. 03072 if ( progress_ptr != NULL ) 03073 progress_ptr->end(); 03074 //just leave what has been calculated... 03075 return; 03076 } 03077 03078 curr_face = ref_faces.get_and_step(); 03079 if(curr_face->get_surface_ptr()->is_closed_in_U() || curr_face->get_surface_ptr()->is_closed_in_V()) 03080 { 03081 if(curr_face->num_loops() == 2) 03082 { 03083 DLIList<RefEdge*> ref_edge_list; 03084 curr_face->ref_edges(ref_edge_list); 03085 if(ref_edge_list.size() == 2) 03086 { 03087 int num_pts = 5; 03088 double start, end; 03089 RefEdge *e1 = ref_edge_list.get_and_step(); 03090 RefEdge *e2 = ref_edge_list.get(); 03091 e1->get_param_range(start, end); 03092 double dt = (end-start)/(double)(num_pts-1); 03093 double t = start; 03094 bool one_bad = false; 03095 double dist_sq = tol*tol; 03096 for(jj=0; jj<num_pts && one_bad == false; jj++) 03097 { 03098 CubitVector pos1, pos2; 03099 e1->position_from_u(t, pos1); 03100 e2->closest_point_trimmed(pos1, pos2); 03101 if((pos1-pos2).length_squared() > dist_sq) 03102 one_bad = true; 03103 t += dt; 03104 } 03105 if(one_bad == false) 03106 { 03107 face_list.append(curr_face); 03108 } 03109 } 03110 } 03111 } 03112 } 03113 03114 if ( progress_ptr != NULL ) 03115 progress_ptr->end(); 03116 03117 return; 03118 } 03119 03120 void GeomMeasureTool::find_small_faces_hydraulic_radius( DLIList <RefVolume*> &ref_vols, 03121 double tol, 03122 DLIList <RefFace*> &small_faces, 03123 DLIList <double> &small_hyd_rad, 03124 double &percent_planar, 03125 double &percent_pl_co) 03126 { 03127 int ii, jj; 03128 DLIList <RefFace*> ref_faces, temp_faces; 03129 RefVolume *ref_vol; 03130 RefFace *curr_face; 03131 for ( ii = 0; ii < ref_vols.size(); ii++ ) 03132 { 03133 ref_vol = ref_vols.get_and_step(); 03134 ref_vol->ref_faces(temp_faces); 03135 //uniquely add the faces. 03136 for ( jj = temp_faces.size(); jj > 0; jj-- ) 03137 { 03138 curr_face = temp_faces.pop(); 03139 if ( curr_face->marked()== 0 ) 03140 { 03141 curr_face->marked(1); 03142 ref_faces.append(curr_face); 03143 } 03144 } 03145 } 03146 double area; 03147 double length; 03148 int total_faces = 0; 03149 int total_plane = 0; 03150 int total_cone = 0; 03151 double area_plane = 0.0; 03152 double total_area = 0.0; 03153 //find the small curves and reset the marked flag. 03154 DLIList <CoEdge*> co_edges; 03155 int num_faces = ref_faces.size(); 03156 ProgressTool *progress_ptr = NULL; 03157 if (num_faces > 20) 03158 { 03159 progress_ptr = AppUtil::instance()->progress_tool(); 03160 assert(progress_ptr != NULL); 03161 progress_ptr->start(0, 100, "Small Surface Progress", 03162 NULL, CUBIT_TRUE, CUBIT_TRUE); 03163 } 03164 double curr_percent = 0.0; 03165 for ( ii = ref_faces.size(); ii > 0; ii-- ) 03166 { 03167 curr_face = ref_faces.get_and_step(); 03168 curr_face->marked(0); 03169 area = measure_area(curr_face); 03170 total_area += area; 03171 total_faces++; 03172 //update the progress.. 03173 if ( progress_ptr != NULL ) 03174 { 03175 curr_percent = ((double)(total_faces))/((double)(num_faces)); 03176 progress_ptr->percent(curr_percent); 03177 } 03178 if ( AppUtil::instance()->interrupt() ) 03179 { 03180 //interrpt. We need to exit. 03181 if ( progress_ptr != NULL ) 03182 progress_ptr->end(); 03183 //just leave what has been calculated... 03184 return; 03185 } 03186 if ( curr_face->geometry_type() == PLANE_SURFACE_TYPE ) 03187 { 03188 total_plane++; 03189 area_plane += area; 03190 } 03191 else if ( curr_face->geometry_type() == CONE_SURFACE_TYPE ) 03192 total_cone++; 03193 co_edges.clean_out(); 03194 curr_face->co_edges(co_edges); 03195 length = 0.0; 03196 for ( jj = co_edges.size(); jj > 0; jj-- ) 03197 { 03198 length += co_edges.get_and_step()->get_ref_edge_ptr()->measure(); 03199 } 03200 //reset the mark. 03201 curr_face->marked(0); 03202 //compute the hydraulic radius 4*(A/P). 03203 if ( length <= CUBIT_RESABS ) 03204 { 03205 PRINT_INFO("Total Perimeter Length of Surface %d is less than tolerance.\n", 03206 curr_face->id()); 03207 03208 continue; 03209 } 03210 area = 4.0*(area/length); 03211 if ( area <= tol ) 03212 { 03213 small_faces.append(curr_face); 03214 small_hyd_rad.append(area); 03215 } 03216 } 03217 if ( total_faces > 0 ) 03218 { 03219 percent_planar = 100.0*area_plane/total_area; 03220 percent_pl_co = 100.0*((double)total_plane+(double)total_cone)/(double)total_faces; 03221 } 03222 else 03223 { 03224 percent_planar = 0.; 03225 percent_pl_co = 0.; 03226 } 03227 if ( progress_ptr != NULL ) 03228 { 03229 progress_ptr->end(); 03230 } 03231 03232 return; 03233 } 03234 void GeomMeasureTool::find_small_volumes( DLIList <RefVolume*> &ref_vols, 03235 double tol, 03236 DLIList <RefVolume*> &small_volumes) 03237 { 03238 int ii; 03239 RefVolume *ref_vol; 03240 double volume; 03241 03242 for ( ii = 0; ii < ref_vols.size(); ii++ ) 03243 { 03244 ref_vol = ref_vols.get_and_step(); 03245 volume = ref_vol->measure(); 03246 if ( volume <= tol ) 03247 small_volumes.append(ref_vol); 03248 } 03249 return; 03250 } 03251 void GeomMeasureTool::find_small_volumes_hydraulic_radius( DLIList <RefVolume*> &ref_vols, 03252 double tol, 03253 DLIList <RefVolume*> &small_volumes, 03254 DLIList <double> &small_hyd_rad) 03255 { 03256 int ii, jj; 03257 DLIList <RefFace*> ref_faces, temp_faces; 03258 RefVolume *ref_vol; 03259 RefFace *curr_face; 03260 double area; 03261 double hyd_volume; 03262 03263 for ( ii = 0; ii < ref_vols.size(); ii++ ) 03264 { 03265 ref_vol = ref_vols.get_and_step(); 03266 ref_vol->ref_faces(temp_faces); 03267 area = 0.0; 03268 for ( jj = temp_faces.size(); jj > 0; jj-- ) 03269 { 03270 curr_face = temp_faces.pop(); 03271 area += measure_area(curr_face); 03272 } 03273 if ( area <= CUBIT_RESABS ) 03274 continue; 03275 hyd_volume = 6.0*(ref_vol->measure() / area); 03276 if ( hyd_volume <= tol ) 03277 { 03278 small_hyd_rad.append(hyd_volume); 03279 small_volumes.append(ref_vol); 03280 } 03281 } 03282 return; 03283 } 03298 void GeomMeasureTool::find_sharp_tangential_meets( RefVolume *ref_volume, 03299 DLIList <RefEdge*> &small_angle_edge_pairs, 03300 DLIList <RefFace*> &tangential_surface_pairs ) 03301 { 03302 //Okay, given the small angle edge pairs. See if there are surfaces that meet tangentially. 03303 //I'm really looking for something spefic. 03304 RefEdge *ref_edge_1, *ref_edge_2; 03305 int ii, jj; 03306 DLIList <Loop*> loops_1, loops_2; 03307 Loop *common_loop; 03308 const double rad_to_deg = 180.0/CUBIT_PI; 03309 RefFace *ref_face; 03310 03311 //loop over for each edge pair. 03312 for ( ii = 0; ii < small_angle_edge_pairs.size(); ii += 2 ) 03313 { 03314 ref_edge_1 = small_angle_edge_pairs.get_and_step(); 03315 ref_edge_2 = small_angle_edge_pairs.get_and_step(); 03316 //find the loop that these edges are both on. 03317 loops_1.clean_out(); 03318 loops_2.clean_out(); 03319 ref_edge_1->loops(loops_1); 03320 ref_edge_2->loops(loops_2); 03321 common_loop = NULL; 03322 for ( jj = loops_1.size(); jj > 0; jj-- ) 03323 { 03324 if ( !loops_2.move_to(loops_1.get()) ) 03325 loops_1.remove(); 03326 else 03327 loops_1.step(); 03328 } 03329 if ( loops_1.size() == 1 ) 03330 common_loop = loops_1.get(); 03331 else 03332 { 03333 //find the loop that has a co_edge from ref_edge_1 03334 //then a co_edge from ref_edge_2. 03335 DLIList <CoEdge*> co_edges; 03336 Loop *tmp_loop; 03337 int kk; 03338 CoEdge *co_edge; 03339 for ( jj = loops_1.size(); jj > 0; jj-- ) 03340 { 03341 tmp_loop = loops_1.get_and_step(); 03342 co_edges.clean_out(); 03343 tmp_loop->ordered_co_edges(co_edges); 03344 for ( kk = co_edges.size(); kk > 0; kk-- ) 03345 { 03346 co_edge = co_edges.get_and_step(); 03347 if ( co_edge->get_ref_edge_ptr() == ref_edge_1 ) 03348 { 03349 if ( co_edges.get()->get_ref_edge_ptr() == ref_edge_2 ) 03350 { 03351 common_loop = tmp_loop; 03352 break; 03353 } 03354 else 03355 //not this loop.. 03356 break; 03357 } 03358 } 03359 if ( common_loop != NULL ) 03360 break; 03361 } 03362 } 03363 assert ( common_loop != NULL ); 03364 //now find surface. 03365 //Then see if there are surfaces that meet at 180 degrees that 03366 //are 90* rotated from here. 03367 ref_face = common_loop->get_ref_face_ptr(); 03368 //Okay, refface is the surface on which we have the bad angle. 03369 //One of these curves will have a concave angle and the other a 03370 //convex angle. The surface on the other side of the convex angle 03371 //we need to check to see if it comes tangentially into another 03372 //surface (dihedral angle of 180.) 03373 RefFace *ref_face_1 = ref_edge_1->other_face(ref_face, ref_volume); 03374 if( ref_face_1 == NULL ) 03375 continue; 03376 03377 double surf_angle_1, surf_angle_2; 03378 RefFace *tangential_face = NULL; 03379 RefEdge *edge_next_to = NULL; 03380 surf_angle_1 = GeometryQueryTool::instance()->surface_angle(ref_face, 03381 ref_face_1, 03382 ref_edge_1, 03383 ref_volume); 03384 surf_angle_1 *= rad_to_deg; 03385 RefFace *ref_face_2; 03386 ref_face_2 = ref_edge_2->other_face(ref_face, ref_volume); 03387 if( ref_face_2 == NULL ) 03388 continue; 03389 surf_angle_2 = GeometryQueryTool::instance()->surface_angle(ref_face, 03390 ref_face_2, 03391 ref_edge_2, 03392 ref_volume); 03393 surf_angle_2 *= rad_to_deg; 03394 if ( surf_angle_1 < 180.0 && surf_angle_2 > 180.0 ) 03395 { 03396 tangential_face = ref_face_1; 03397 edge_next_to = ref_edge_1; 03398 } 03399 else if ( surf_angle_2 < 180.0 && surf_angle_1 > 180.0 ) 03400 { 03401 tangential_face = ref_face_2; 03402 edge_next_to = ref_edge_2; 03403 } 03404 if ( tangential_face == NULL ) // This isn't the config we seek. 03405 continue; 03406 03407 //Now, on this face, there is an edge, next to edge_next_to, 03408 //that will have an interior angle of 180.0. If that is the 03409 //case then this is what we seek. 03410 RefVertex* ref_vert = ref_edge_1->common_ref_vertex(ref_edge_2, 03411 ref_face); 03412 DLIList <RefEdge*> tmp_ref_edges; 03413 ref_vert->ref_edges(tmp_ref_edges); 03414 //Find the edge that is on tangential face and is not edge_next_to. 03415 RefEdge *tangential_edge=NULL, *tmp_edge; 03416 for ( jj = tmp_ref_edges.size(); jj > 0; jj-- ) 03417 { 03418 tmp_edge = tmp_ref_edges.get_and_step(); 03419 if ( tmp_edge != edge_next_to && 03420 tmp_edge->is_directly_related(tangential_face) ) 03421 { 03422 tangential_edge = tmp_edge; 03423 break; 03424 } 03425 } 03426 if ( tangential_edge == NULL ) 03427 //not what we are looking for. 03428 continue; 03429 //Now get the other face and measure the dihedral angle. 03430 RefFace *other_face = tangential_edge->other_face(tangential_face, 03431 ref_volume); 03432 double tan_angle; 03433 tan_angle = GeometryQueryTool::instance()->surface_angle(tangential_face, 03434 other_face, 03435 tangential_edge, 03436 ref_volume); 03437 tan_angle *= rad_to_deg; 03438 //If they are within tolerance, then we have it... 03439 if ( tan_angle > 165.0 && tan_angle < 195.0 ) 03440 { 03441 tangential_surface_pairs.append(tangential_face); 03442 tangential_surface_pairs.append(other_face); 03443 } 03444 } 03445 } 03446 03447 03448 03449 void GeomMeasureTool::find_interior_curve_angles( RefVolume *ref_volume, 03450 double upper_bound, 03451 double lower_bound, 03452 DLIList <RefEdge*> &large_edge_angles, 03453 DLIList <RefEdge*> &small_edge_angles, 03454 DLIList <double> &large_angles, 03455 DLIList <double> &small_angles, 03456 int &total_interior, 03457 int &total_fuzzy) 03458 { 03459 int ii, jj, kk; 03460 DLIList <RefFace*> ref_faces; 03461 RefFace *curr_face; 03462 total_interior = 0; 03463 total_fuzzy = 0; 03464 ref_volume->ref_faces(ref_faces); 03465 03466 //Okay now loop over the edge loops of the reffaces 03467 //and find the interior angles. 03468 DLIList<Loop*> loops; 03469 Loop *curr_loop; 03470 DLIList <CoEdge*> co_edges; 03471 CoEdge *curr_edge, *next_edge; 03472 double angle = 0.0; 03473 const double RAD_TO_DEG = 180.0/CUBIT_PI; 03474 for ( ii = ref_faces.size(); ii > 0; ii-- ) 03475 { 03476 curr_face = ref_faces.get_and_step(); 03477 curr_face->loops(loops); 03478 //Now loop over these loops. 03479 for ( jj = loops.size(); jj > 0; jj-- ) 03480 { 03481 curr_loop = loops.pop(); 03482 //now loop over the edges in this 03483 co_edges.clean_out(); 03484 curr_loop->ordered_co_edges(co_edges); 03485 for ( kk = co_edges.size(); kk > 0; kk-- ) 03486 { 03487 curr_edge = co_edges.get_and_step(); 03488 next_edge = co_edges.get(); 03489 03490 if ( curr_edge == next_edge ) 03491 { 03492 //This is a hardpoint 03493 if ( curr_edge->get_ref_edge_ptr()->geometry_type() == POINT_CURVE_TYPE ) 03494 { 03495 angle = 360.0; 03496 //for now ignore this.. 03497 continue; 03498 } 03499 else 03500 { 03501 RefEdge *the_edge = curr_edge->get_ref_edge_ptr(); 03502 //Get points 1% from the ends in both directions. 03503 CubitVector point_start, point_end; 03504 CubitStatus stat = the_edge->position_from_fraction(0.01, 03505 point_start); 03506 if ( stat != CUBIT_SUCCESS ) 03507 angle = 180.0; 03508 else 03509 { 03510 stat = the_edge->position_from_fraction(0.99, 03511 point_end); 03512 if ( stat != CUBIT_SUCCESS ) 03513 angle = 180.0; 03514 else 03515 { 03516 CubitVector normal = curr_face->normal_at(point_start, NULL); 03517 CubitVector tangent_1, tangent_2; 03518 stat = the_edge->tangent( point_start, tangent_1, curr_face); 03519 CubitStatus stat2 = the_edge->tangent( point_end, tangent_2, curr_face); 03520 if ( stat != CUBIT_SUCCESS || stat2 != CUBIT_SUCCESS ) 03521 angle = 180.0; 03522 else 03523 { 03524 //one of the tangents will be pointing the wrong 03525 //direction, so reverse it based on the sense. 03526 if ( curr_edge->get_sense() == CUBIT_REVERSED ) 03527 tangent_1 = -tangent_1; 03528 else 03529 tangent_2 = -tangent_2; 03530 angle = normal.vector_angle(tangent_2, tangent_1); 03531 angle *= RAD_TO_DEG; 03532 } 03533 } 03534 } 03535 } 03536 } 03537 else if ( curr_edge->get_ref_edge_ptr() == next_edge->get_ref_edge_ptr() ) 03538 { 03539 //This is the end of a hard line. Set this angle because 03540 //it is tricky to measure it. 03541 angle = 360.0; 03542 } 03543 else if ( curr_edge != next_edge ) 03544 { 03545 angle = 03546 GeometryQueryTool::instance()->geometric_angle(curr_edge, 03547 next_edge); 03548 angle *= RAD_TO_DEG; 03549 } 03550 total_interior++; 03551 //count the number of angles that are fuzzy. 03552 if ( angle <= GEOM_END_LOWER ) 03553 total_fuzzy++; 03554 else if ( angle >= GEOM_END_UPPER && 03555 angle <= GEOM_SIDE_LOWER ) 03556 total_fuzzy++; 03557 else if ( angle >= GEOM_SIDE_UPPER && 03558 angle <= GEOM_CORNER_LOWER ) 03559 total_fuzzy++; 03560 else if ( angle >= GEOM_CORNER_UPPER ) 03561 total_fuzzy++; 03562 if ( angle <= lower_bound ) 03563 { 03564 small_edge_angles.append(curr_edge->get_ref_edge_ptr()); 03565 small_edge_angles.append(next_edge->get_ref_edge_ptr()); 03566 small_angles.append(angle); 03567 } 03568 if ( angle >= upper_bound ) 03569 { 03570 large_edge_angles.append(curr_edge->get_ref_edge_ptr()); 03571 large_edge_angles.append(next_edge->get_ref_edge_ptr()); 03572 large_angles.append(angle); 03573 } 03574 } 03575 } 03576 } 03577 return; 03578 } 03579 03580 void GeomMeasureTool::find_dihedral_angles( DLIList <RefVolume*> &ref_vols, 03581 double upper_bound, 03582 double lower_bound, 03583 DLIList <RefFace*> &large_face_angles, 03584 DLIList <RefFace*> &small_face_angles, 03585 DLIList <double> &large_angles, 03586 DLIList <double> &small_angles, 03587 int &total_interior, 03588 int &total_fuzzy, 03589 int &total_not_flat) 03590 { 03591 int ii; 03592 RefVolume *ref_vol; 03593 total_interior = 0; 03594 total_fuzzy = 0; 03595 total_not_flat = 0; 03596 for ( ii = 0; ii < ref_vols.size(); ii++ ) 03597 { 03598 ref_vol = ref_vols.get_and_step(); 03599 find_dihedral_angles(ref_vol, upper_bound, 03600 lower_bound, 03601 large_face_angles, 03602 small_face_angles, 03603 large_angles, small_angles, 03604 total_interior, total_fuzzy, total_not_flat); 03605 } 03606 return; 03607 } 03608 void GeomMeasureTool::find_dihedral_angles(RefVolume *curr_volume, 03609 double upper_bound, 03610 double lower_bound, 03611 DLIList <RefFace*> &large_face_angles, 03612 DLIList <RefFace*> &small_face_angles, 03613 DLIList <double> &large_angles, 03614 DLIList <double> &small_angles, 03615 int &total_interior, 03616 int &total_fuzzy, int &total_not_flat) 03617 { 03618 int ii, jj, shared_angles = 0; 03619 double common_angle; 03620 DLIList <RefFace*> face_list; 03621 RefFace *curr_face_1, *curr_face_2; 03622 RefFace *tmp_face; 03623 RefEdge *common_edge; 03624 DLIList <RefVolume*> ref_vols; 03625 DLIList<RefEdge*> vol_edges; 03626 curr_volume->ref_edges(vol_edges); 03627 03628 //maybe the body is a sheet-body...don't print errors if so 03629 bool is_sheet_body = false; 03630 if( curr_volume->measure() == 0 ) 03631 is_sheet_body = true; 03632 03633 for ( ii = vol_edges.size(); ii > 0; ii-- ) 03634 { 03635 common_edge = vol_edges.get_and_step(); 03636 03637 //skip point curves 03638 if( common_edge->geometry_type() == POINT_CURVE_TYPE ) 03639 continue; 03640 03641 curr_face_1 = NULL; 03642 curr_face_2 = NULL; 03643 face_list.clean_out(); 03644 common_edge->ref_faces(face_list); 03645 //find the two faces that are part of this volume. 03646 for ( jj = face_list.size(); jj > 0; jj-- ) 03647 { 03648 tmp_face = face_list.get_and_step(); 03649 ref_vols.clean_out(); 03650 tmp_face->ref_volumes(ref_vols); 03651 if ( ref_vols.move_to(curr_volume) ) 03652 { 03653 if ( curr_face_1 == NULL ) 03654 curr_face_1 = tmp_face; 03655 else if ( curr_face_2 == NULL ) 03656 { 03657 curr_face_2 = tmp_face; 03658 break; 03659 } 03660 } 03661 } 03662 if ( curr_face_1 == NULL || 03663 curr_face_2 == NULL ) 03664 { 03665 if( is_sheet_body == false ) 03666 PRINT_ERROR("Problems finding connected surfaces to a curve\n" 03667 "\tfor measuring dihedral angles.\n"); 03668 continue; 03669 } 03670 shared_angles++; 03671 common_angle = GeometryQueryTool::instance()->surface_angle(curr_face_1, 03672 curr_face_2, 03673 common_edge, 03674 curr_volume); 03675 common_angle *= 180.0/CUBIT_PI; 03676 total_interior++; 03677 //use hard coded angles because we want these a little looser. 03678 if ( common_angle >= 200.0 || 03679 common_angle <= 160.0 ) 03680 total_not_flat++; 03681 03682 if ( curr_face_1->geometry_type() != PLANE_SURFACE_TYPE || 03683 curr_face_2->geometry_type() != PLANE_SURFACE_TYPE ) 03684 total_fuzzy++; 03685 else if ( common_angle <= GEOM_END_LOWER ) 03686 total_fuzzy++; 03687 else if ( common_angle >= GEOM_END_UPPER && 03688 common_angle <= GEOM_SIDE_LOWER ) 03689 total_fuzzy++; 03690 else if ( common_angle >= GEOM_SIDE_UPPER && 03691 common_angle <= GEOM_CORNER_LOWER ) 03692 total_fuzzy++; 03693 else if ( common_angle >= GEOM_CORNER_UPPER ) 03694 total_fuzzy++; 03695 03696 if( common_angle <= lower_bound ) 03697 { 03698 small_face_angles.append(curr_face_1); 03699 small_face_angles.append(curr_face_2); 03700 small_angles.append(common_angle); 03701 } 03702 if( common_angle >= upper_bound ) 03703 { 03704 large_face_angles.append(curr_face_1); 03705 large_face_angles.append(curr_face_2); 03706 large_angles.append(common_angle); 03707 } 03708 } 03709 //clean up the edge marks. 03710 for ( ii = vol_edges.size(); ii > 0; ii-- ) 03711 vol_edges.get_and_step()->marked(0); 03712 } 03713 void GeomMeasureTool::find_close_loops(DLIList <RefVolume*> &ref_vols, 03714 DLIList <RefEdge*> &close_edges, 03715 DLIList <RefFace*> &close_loop_faces, 03716 DLIList <double> &small_lengths, 03717 double tol) 03718 { 03719 int ii, jj; 03720 DLIList <RefFace*> ref_faces, temp_faces; 03721 RefVolume *ref_vol; 03722 RefFace *curr_face; 03723 for ( ii = 0; ii < ref_vols.size(); ii++ ) 03724 { 03725 ref_vol = ref_vols.get_and_step(); 03726 ref_vol->ref_faces(temp_faces); 03727 //uniquely add the faces. 03728 for ( jj = temp_faces.size(); jj > 0; jj-- ) 03729 { 03730 curr_face = temp_faces.pop(); 03731 ref_faces.append(curr_face); 03732 } 03733 } 03734 DLIList <RefEdge*> tmp_close_edges; 03735 DLIList <double> tmp_small_lengths; 03736 03737 for ( ii = ref_faces.size(); ii > 0; ii-- ) 03738 { 03739 curr_face = ref_faces.get_and_step(); 03740 curr_face->marked(0); 03741 if ( curr_face->num_loops() < 2 ) 03742 continue; 03743 tmp_close_edges.clean_out(); 03744 tmp_small_lengths.clean_out(); 03745 find_close_loops( curr_face, tmp_close_edges, 03746 tmp_small_lengths, tol); 03747 if ( tmp_close_edges.size() > 0 ) 03748 { 03749 assert(tmp_close_edges.size()%2 == 0 ); 03750 tmp_close_edges.reset(); 03751 tmp_small_lengths.reset(); 03752 for ( jj = tmp_close_edges.size()/2; jj > 0; jj-- ) 03753 { 03754 close_edges.append(tmp_close_edges.get_and_step()); 03755 close_edges.append(tmp_close_edges.get_and_step()); 03756 small_lengths.append(tmp_small_lengths.get_and_step()); 03757 close_loop_faces.append(curr_face); 03758 } 03759 } 03760 } 03761 return; 03762 } 03763 03764 03765 void GeomMeasureTool::find_close_loops(RefFace *face, 03766 DLIList <RefEdge*> &close_edges, 03767 DLIList <double> &small_lengths, 03768 double tol) 03769 { 03770 //only do faces with multiple loops since we are measuring the 03771 //distances between these loops. 03772 if ( face->num_loops() < 2 ) 03773 return; 03774 //This is the most tricky of these functions. 03775 //To do this I'm going to facet the edges, then use an AbstractTree to 03776 //find the minimum distance between the loops and between a single 03777 //loop. 03778 PointLoopList boundary_point_loops; 03779 CubitStatus stat; 03780 stat = get_boundary_points(face, boundary_point_loops, GEOMETRY_RESABS*100); 03781 if ( stat != CUBIT_SUCCESS ) 03782 return; 03783 03784 SegLoopList boundary_seg_loops; 03785 stat = convert_to_lines( boundary_point_loops, 03786 boundary_seg_loops, 03787 face); 03788 if ( stat != CUBIT_SUCCESS ) 03789 return; 03790 03791 //Now add the points to the AbstractTree. 03792 DLIList<AbstractTree<GeomSeg*>*> atree_list; 03793 AbstractTree<GeomSeg*> *curr_tree; 03794 SegList *seg_list; 03795 GeomSeg *curr_seg; 03796 int ii,jj, kk; 03797 //const double angle_convert = 180.0/CUBIT_PI; 03798 boundary_seg_loops.reset(); 03799 int num_segs = 0; 03800 for (ii = 0; ii < boundary_seg_loops.size(); ii++ ) 03801 { 03802 seg_list = boundary_seg_loops.get_and_step(); 03803 curr_tree = new RTree<GeomSeg*>(GEOMETRY_RESABS); 03804 for ( jj = seg_list->size(); jj > 0; jj-- ) 03805 { 03806 //build the r-tree. 03807 num_segs++; 03808 curr_seg = seg_list->get_and_step(); 03809 curr_tree->add(curr_seg); 03810 //calculate the interior angles. 03811 } 03812 atree_list.append(curr_tree); 03813 } 03814 //determine the minimum distance between the loops. 03815 PointList *curr_points; 03816 GeomPoint *curr_point; 03817 DLIList <GeomSeg*> nearest_neighbors; 03818 RefEdge *closest_edge_1, *closest_edge_2; 03819 CubitVector curr_loc; 03820 double closest_dist; 03821 double min_for_loop_squared; 03822 atree_list.reset(); 03823 // This searching was orignally coded to not be an n-squared 03824 // search but I changed it to be n-squared because the 03825 // way the loops are compared comparing loop 1 against loop 2 may 03826 // give a different result than comparing loop 2 against loop 1. 03827 for ( ii = 0; ii < atree_list.size(); ii++ ) 03828 { 03829 curr_points = boundary_point_loops.get_and_step(); 03830 for ( jj = 1; jj < atree_list.size(); jj++ ) 03831 { 03832 min_for_loop_squared = CUBIT_DBL_MAX; 03833 closest_edge_1 = NULL; 03834 closest_edge_2 = NULL; 03835 curr_tree = atree_list.next(ii+jj); 03836 //now for every point in curr_points, find it's closest_point 03837 //in the curr_tree. 03838 for ( kk = 0; kk < curr_points->size(); kk++ ) 03839 { 03840 curr_point = curr_points->get_and_step(); 03841 curr_loc.set(curr_point->coordinates()); 03842 nearest_neighbors.clean_out(); 03843 curr_tree->k_nearest_neighbor(curr_loc, 03844 1, closest_dist, nearest_neighbors, 03845 dist_sq_point_data); 03846 if ( nearest_neighbors.size() == 0) 03847 { 03848 //hmm, not sure what is wrong here. 03849 PRINT_ERROR("Can't find closest point between loops.\n"); 03850 } 03851 if (closest_dist <= tol*tol && closest_dist < min_for_loop_squared ) 03852 { 03853 //just store the smaller ones. Don't store 03854 RefEntity *ref_ent = curr_point->owner(); 03855 GeomSeg *near_seg = nearest_neighbors.get(); 03856 RefEdge *ref_edge_1 = CAST_TO(ref_ent, RefEdge); 03857 if ( ref_edge_1 == NULL ) 03858 { 03859 //assume this is a vertex. 03860 RefVertex *ref_vert = CAST_TO(ref_ent, RefVertex); 03861 if ( ref_vert == NULL ) 03862 { 03863 PRINT_ERROR("problem with point ownership in closest loops.\n"); 03864 continue; 03865 } 03866 DLIList <RefEdge*> ref_edges; 03867 ref_vert->ref_edges(ref_edges); 03868 int ll; 03869 RefEdge *the_edge = NULL; 03870 for ( ll = ref_edges.size(); ll > 0; ll-- ) 03871 { 03872 if ( ref_edges.get()->is_directly_related(face) ) 03873 { 03874 the_edge = ref_edges.get(); 03875 break; 03876 } 03877 ref_edges.step(); 03878 } 03879 if ( the_edge == NULL ) 03880 { 03881 PRINT_ERROR("problem with point ownership in closest loops.\n"); 03882 continue; 03883 } 03884 ref_edge_1 = the_edge; 03885 } 03886 ref_ent = near_seg->owner(); 03887 RefEdge *ref_edge_2 = CAST_TO(ref_ent, RefEdge); 03888 if ( ref_edge_2 == NULL ) 03889 { 03890 PRINT_ERROR("problem with point ownership in closest loops.\n"); 03891 continue; 03892 } 03893 03894 min_for_loop_squared = closest_dist; 03895 closest_edge_1 = ref_edge_1; 03896 closest_edge_2 = ref_edge_2; 03897 } 03898 } 03899 if ( closest_edge_1 != NULL ) 03900 { 03901 close_edges.append(closest_edge_1); 03902 close_edges.append(closest_edge_2); 03903 small_lengths.append(sqrt(min_for_loop_squared)); 03904 } 03905 } 03906 } 03907 //clean up the memory. 03908 int ll,mm; 03909 atree_list.reset(); 03910 boundary_seg_loops.reset(); 03911 for ( ll = boundary_seg_loops.size(); ll > 0; ll-- ) 03912 { 03913 delete atree_list.pop(); 03914 seg_list = boundary_seg_loops.pop(); 03915 for ( mm = seg_list->size(); mm > 0; mm-- ) 03916 delete seg_list->pop(); 03917 delete seg_list; 03918 } 03919 03920 PointList *point_list; 03921 for ( ll = boundary_point_loops.size(); ll > 0; ll-- ) 03922 { 03923 point_list = boundary_point_loops.pop(); 03924 for ( mm = point_list->size(); mm > 0; mm-- ) 03925 { 03926 GeomPoint *tmp_point = point_list->pop(); 03927 //delete the CubitPointData 03928 delete tmp_point; 03929 } 03930 delete point_list; 03931 } 03932 return; 03933 } 03934 double GeomMeasureTool::measure_area(RefFace* curr_face) 03935 { 03936 double area; 03937 GeomDataObserver *g_d_o = GeomDataObserver::get(curr_face); 03938 if ( g_d_o == NULL ) 03939 g_d_o = GeomDataObserver::create(curr_face); 03940 03941 if ( g_d_o == NULL ) 03942 { 03943 assert(g_d_o != NULL ); 03944 return curr_face->measure(); 03945 } 03946 if ( !g_d_o->is_measure_set() ) 03947 { 03948 area = (curr_face->get_surface_ptr())->measure(); 03949 g_d_o->set_measure(area); 03950 } 03951 area = g_d_o->get_measure(); 03952 return area; 03953 } 03954 03960 void GeomMeasureTool::find_bad_geometry(RefVolume *volume, 03961 DLIList <RefEntity*> &bad_ents) 03962 { 03963 Lump *lump_ptr = volume->get_lump_ptr(); 03964 DLIList <TopologyEntity*> bad_top_ents; 03965 lump_ptr->validate(volume->entity_name(), bad_top_ents); 03966 //Now go through and get a RefEnttiy for each entity. 03967 RefEntity *ref_ent; 03968 TopologyEntity *topo_ent; 03969 GroupingEntity *gr_ent; 03970 SenseEntity *se_ent; 03971 03972 int ii; 03973 for (ii = bad_top_ents.size(); ii > 0; ii-- ) 03974 { 03975 topo_ent = bad_top_ents.pop(); 03976 ref_ent = CAST_TO(topo_ent, RefEntity); 03977 if ( ref_ent != NULL ) 03978 { 03979 bad_ents.append(ref_ent); 03980 continue; 03981 } 03982 gr_ent = CAST_TO(topo_ent, GroupingEntity); 03983 if ( gr_ent != NULL ) 03984 { 03985 Chain *ch = CAST_TO(gr_ent, Chain); 03986 if ( ch != NULL ) 03987 { 03988 RefVertex *start_v = ch->start_vertex(); 03989 RefVertex *end_v = ch->end_vertex(); 03990 RefEdge *ref_edge = start_v->common_ref_edge(end_v); 03991 bad_ents.append(ref_edge); 03992 continue; 03993 } 03994 Loop *lo = CAST_TO(gr_ent, Loop); 03995 if ( lo != NULL ) 03996 { 03997 RefFace *rf = lo->get_ref_face_ptr(); 03998 bad_ents.append(rf); 03999 continue; 04000 } 04001 Shell *sh = CAST_TO(gr_ent, Shell); 04002 if (sh != NULL ) 04003 { 04004 RefVolume *rv = sh->get_ref_volume_ptr(); 04005 bad_ents.append(rv); 04006 continue; 04007 } 04008 else 04009 { 04010 //this is incase there is some other entity we don't 04011 //know about, just get the body... 04012 Body *body = topo_ent->body(); 04013 bad_ents.append(body); 04014 continue; 04015 } 04016 } 04017 se_ent = CAST_TO(topo_ent, SenseEntity); 04018 if ( se_ent != NULL ) 04019 { 04020 BasicTopologyEntity *be = se_ent->get_basic_topology_entity_ptr(); 04021 bad_ents.append(be); 04022 continue; 04023 } 04024 //If we are here we didn't get the right entity. Just get 04025 //the body associated with this topology entity. 04026 Body *b = topo_ent->body(); 04027 bad_ents.append(b); 04028 } 04029 return; 04030 } 04031 04037 void GeomMeasureTool::find_irregular_valence( DLIList <RefVolume*> &ref_volumes, 04038 DLIList <RefVertex*> &irregular_vertices) 04039 { 04040 RefVolume *ref_vol; 04041 int ii; 04042 for ( ii = 0; ii < ref_volumes.size(); ii++ ) 04043 { 04044 ref_vol = ref_volumes.get_and_step(); 04045 find_irregular_valence(ref_vol, irregular_vertices); 04046 } 04047 } 04053 void GeomMeasureTool::find_irregular_valence( RefVolume *ref_volume, 04054 DLIList <RefVertex*> &irregular_vertices) 04055 { 04056 RefVertex *ref_vert; 04057 DLIList <RefVertex*> ref_vertices; 04058 ref_volume->ref_vertices(ref_vertices); 04059 int ii; 04060 for ( ii = ref_vertices.size(); ii > 0; ii-- ) 04061 { 04062 ref_vert = ref_vertices.get_and_step(); 04063 if ( ref_vert->num_ref_edges() > 4 ) 04064 irregular_vertices.append(ref_vert); 04065 } 04066 } 04067 04071 #define FACE_BLEND 1 04072 #define VERTEX_BLEND 2 04073 #define BLEND_PROCESSED 3 04074 04075 void GeomMeasureTool::find_blends( RefVolume *ref_volume, 04076 DLIList <RefFace*> &blend_faces, 04077 DLIList <DLIList<RefFace*>*> &blend_groups ) 04078 { 04079 //Assume for now that blends have cartesian angles between 04080 //all the attached faces and itself. 04081 //Also a blend cannot be planar. And directly accross from 04082 //one blend edge, there is usually another blended edge but 04083 //the angle between the two normals must be orthogonal. In other 04084 //words their must be some sort of transition. 04085 04086 //mark all the faces as 0. The mark is used here to find the 04087 // blend groups. The function is_vertex_blend() marks faces 04088 // as being a vertex blend. The group of faces is then traversed 04089 // until the adjacent surface (across the cross curve) is either 04090 // a vertex blend or not a blend. 04091 DLIList <RefFace*> ref_faces; 04092 DLIList <RefFace*> vertex_blends, face_blends; 04093 ref_volume->ref_faces(ref_faces); 04094 int ii, jj; 04095 for ( ii =0; ii < ref_faces.size(); ii++ ) 04096 ref_faces.get_and_step()->marked(0); 04097 04098 //First go through each face and each edge on each face. 04099 DLIList <RefEdge*> ref_edges; 04100 RefFace *ref_face; 04101 RefEdge *ref_edge, *other_edge; 04102 int num_vertex_blends = 0; 04103 int num_face_blends = 0; 04104 for ( ii = ref_faces.size(); ii > 0; ii-- ) 04105 { 04106 ref_face = ref_faces.get_and_step(); 04107 //Test the face to see if it is a face or vertex blend. 04108 other_edge = NULL; 04109 ref_edge = NULL; 04110 if ( is_face_blend(ref_face, ref_volume, 04111 ref_edge, other_edge ) ) 04112 { 04113 face_blends.append(ref_face); 04114 ref_face->marked(1); 04115 num_face_blends++; 04116 } 04117 else if ( is_vertex_blend(ref_face, ref_volume) ) 04118 { 04119 vertex_blends.append(ref_face); 04120 ref_face->marked(2); 04121 num_vertex_blends++; // keep track of the number of vertex blends 04122 } 04123 } 04124 if ( face_blends.size() + vertex_blends.size() == 0 ) 04125 { 04126 return; 04127 } 04128 //Find out how many different groups of surfaces there 04129 //are that share curves. 04130 DLIList <RefFace*> *blend_group = NULL; 04131 DLIList <RefFace*> stack; 04132 RefFace *start_face = NULL, *other_face; 04133 04134 // continue while there are blends to process 04135 while ( vertex_blends.size() + face_blends.size() > 0 || 04136 start_face != NULL) 04137 { 04138 // if we don't have a start_face, get a new one. 04139 if (!start_face) 04140 { 04141 // this is the start of a new group 04142 blend_group = new DLIList <RefFace*>; 04143 blend_groups.append(blend_group); 04144 04145 // always prefer to start at a vertex blend if one exists 04146 if (vertex_blends.size() > 0 ) 04147 { 04148 start_face = vertex_blends.pop(); 04149 } 04150 else 04151 { 04152 start_face = face_blends.pop(); 04153 } 04154 } 04155 04156 blend_group->append(start_face); // add ref_face to group 04157 blend_faces.append(start_face); // add the ref_face to the returned list 04158 start_face->marked(BLEND_PROCESSED); 04159 04160 ref_edges.clean_out(); 04161 start_face->ref_edges(ref_edges); 04162 for ( jj = 0; jj < ref_edges.size(); jj++ ) 04163 { 04164 ref_edge = ref_edges.get_and_step(); 04165 other_face = ref_edge->other_face(start_face, ref_volume); 04166 if (other_face == NULL) 04167 { 04168 start_face = NULL; 04169 break; 04170 } 04171 04172 // if this blend has been processed and isn't in the current group 04173 if (other_face->marked() == BLEND_PROCESSED && 04174 !blend_group->is_in_list(other_face) ) 04175 { 04176 start_face = NULL; 04177 break; // reached an end of this loop 04178 } 04179 else if (other_face->marked() == VERTEX_BLEND) 04180 { 04181 blend_group->append(other_face); // add the ref_face to the group 04182 blend_faces.append(other_face); // add the ref_face to the returned list 04183 vertex_blends.remove(other_face); 04184 other_face->marked(BLEND_PROCESSED); 04185 start_face = NULL; 04186 break; // a vertex blend is also end of the line 04187 } 04188 else if (other_face->marked() == FACE_BLEND) 04189 { 04190 start_face = other_face; 04191 face_blends.remove(other_face); 04192 break; // continue using this face as the new start face 04193 } 04194 } 04195 // if we traversed through all the edges of this blend without 04196 // finding another blend attached, this is the end of the chain 04197 // and we need to find another starting place. 04198 if ( jj >= ref_edges.size() ) 04199 { 04200 start_face = NULL; 04201 } 04202 04203 } 04204 04205 //cleanup marks. 04206 for ( ii =0; ii < ref_faces.size(); ii++ ) 04207 ref_faces.get_and_step()->marked(0); 04208 for ( ii =0; ii < blend_faces.size(); ii++ ) 04209 blend_faces.get_and_step()->marked(0); 04210 //Okay we should have it now. 04211 04212 //REMEMBER TO DELETE the dllists in blend_faces. 04213 return; 04214 } 04215 04216 // struct type object private to the next function 04217 class NextBlend 04218 { 04219 public: 04220 RefEdge* ref_edge; 04221 RefFace* ref_face; 04222 }; 04223 04224 void GeomMeasureTool::find_blends_from_edge( RefVolume* ref_volume, 04225 RefFace *start_face, 04226 RefEdge* start_edge, 04227 std::vector <RefFace*> &blend_faces) 04228 { 04229 // initialize the mark on all surfaces in the volume 04230 DLIList <RefFace*> ref_faces; 04231 RefEdge *next_edge, *other_edge; 04232 ref_volume->ref_faces(ref_faces); 04233 int ii; 04234 for ( ii =0; ii < ref_faces.size(); ii++ ) 04235 ref_faces.get_and_step()->marked(0); 04236 04237 std::stack<NextBlend> blend_stack; 04238 04239 NextBlend blend; 04240 blend.ref_edge = start_edge; 04241 blend.ref_face = start_face; 04242 blend_faces.push_back(start_face); 04243 04244 blend_stack.push(blend); 04245 04246 while (blend_stack.size() > 0) 04247 { 04248 // this is an oddity with std::stack. Get the top of the stack 04249 // and then you have to remove it from the stack with pop 04250 NextBlend next_blend = blend_stack.top(); 04251 blend_stack.pop(); 04252 RefEdge* ref_edge = next_blend.ref_edge; 04253 RefFace* ref_face = next_blend.ref_face; 04254 04255 RefFace* next_face; 04256 next_face = ref_edge->other_face(ref_face, ref_volume); 04257 04258 // the the next face exists and it's a face blend, save the current blend, 04259 // create a new blend object and add it to the stack 04260 if ( next_face && is_face_blend(next_face, ref_volume, next_edge, other_edge ) ) 04261 { 04262 // if the next face is already processed, the chain loops back on itself. 04263 if (next_face->marked() == BLEND_PROCESSED) 04264 { 04265 for ( ii =0; ii < ref_faces.size(); ii++ ) 04266 ref_faces.get_and_step()->marked(0); 04267 return; 04268 } 04269 04270 blend_faces.push_back(next_face); 04271 next_face->marked(BLEND_PROCESSED); 04272 04273 // the is_face_blend function assumes (poorly) rectangular surfaces 04274 // without any holes. It returns the spring curves and we want 04275 // the cross curves. So get all four edges and remove the two 04276 // spring curves returned by is_face_blend 04277 DLIList <RefEdge*> ref_edges; 04278 next_face->ref_edges(ref_edges); 04279 ref_edges.remove(next_edge); 04280 ref_edges.remove(other_edge); 04281 04282 if (ref_edges.get() != ref_edge) 04283 { 04284 next_blend.ref_edge = ref_edges.get(); 04285 } 04286 else 04287 { 04288 next_blend.ref_edge = ref_edges.next(1); 04289 } 04290 next_blend.ref_face = next_face; 04291 blend_stack.push(next_blend); 04292 } 04293 else if ( next_face && is_vertex_blend(next_face, ref_volume) ) 04294 { 04295 // we will stop the chain at a vertex blend 04296 blend_faces.push_back(next_face); 04297 next_face->marked(BLEND_PROCESSED); 04298 } 04299 } 04300 04301 // clean up the marks 04302 std::vector<RefFace*>::iterator iter; 04303 for ( iter = blend_faces.begin(); iter != blend_faces.end(); iter++) 04304 (*iter)->marked(0); 04305 } 04306 04307 // given a starting blend surface find a chain of blends from 04308 // that surface. 04309 // 04310 // Note that this function intentionally does _not_ 04311 // clear the blend_face list so that additional chains can be added. 04312 CubitStatus GeomMeasureTool::find_blend_chains( RefFace *start_face, 04313 std::vector<std::vector< RefFace*> > &blend_chains) 04314 { 04315 04316 if (start_face == NULL) 04317 { 04318 return CUBIT_FAILURE; 04319 } 04320 04321 std::vector <RefFace*> blend_faces; 04322 04323 // get the owning volume of this blend 04324 DLIList<RefEntity*> entity_list; 04325 RefVolume* ref_volume; 04326 int ii; 04327 04328 start_face->get_parent_ref_entities(entity_list); 04329 04330 // this indicates merged enitites and potential problems 04331 if (entity_list.size() > 1) 04332 { 04333 return CUBIT_FAILURE; 04334 } 04335 04336 // make sure we're at the beginning of the list and get the first 04337 // and only item on the list and cast it to a RefVolume 04338 entity_list.reset(); 04339 ref_volume = CAST_TO(entity_list.get(), RefVolume); 04340 04341 if (!ref_volume) 04342 { 04343 return CUBIT_FAILURE; 04344 } 04345 04346 // initialize the mark on all surfaces in the volume 04347 DLIList <RefFace*> ref_faces; 04348 ref_volume->ref_faces(ref_faces); 04349 04350 RefEdge *spring_curve1, *spring_curve2; 04351 if ( is_face_blend(start_face, ref_volume, spring_curve1, spring_curve2 ) ) 04352 { 04353 // the is_face_blend function assumes (poorly) rectangular surfaces 04354 // without any holes. It returns the spring curves and we want 04355 // the cross curves. So get all four edges and remove the two 04356 // spring curves returned by is_face_blend 04357 DLIList <RefEdge*> ref_edges; 04358 start_face->ref_edges(ref_edges); 04359 ref_edges.remove(spring_curve1); 04360 ref_edges.remove(spring_curve2); 04361 04362 // there is a special case where the blend is a periodic surface 04363 // meaning that there _are_ no cross curves 04364 if ( ref_edges.size() == 0 ) 04365 { 04366 blend_faces.push_back(start_face); 04367 } 04368 else 04369 { 04370 // now find additional blends extending from either side of the blend 04371 blend_faces.clear(); 04372 find_blends_from_edge( ref_volume, start_face, ref_edges.get(), blend_faces); 04373 find_blends_from_edge( ref_volume, start_face, ref_edges.next(1), blend_faces); 04374 04375 // make sure that we have a unique list (the start surface is probably here twice) 04376 std::vector<RefFace*>::iterator new_end; 04377 std::sort( blend_faces.begin(), blend_faces.end() ); 04378 new_end = std::unique( blend_faces.begin(), blend_faces.end() ); 04379 blend_faces.erase(new_end, blend_faces.end()); 04380 } 04381 04382 blend_chains.push_back(blend_faces); 04383 } 04384 else if ( is_vertex_blend(start_face, ref_volume) ) 04385 { 04386 DLIList<RefEdge*> ref_edges; 04387 start_face->ref_edges(ref_edges); 04388 04389 for (ii = 0; ii < ref_edges.size(); ii++) 04390 { 04391 RefEdge* start_edge = ref_edges.get_and_step(); 04392 blend_faces.clear(); 04393 find_blends_from_edge( ref_volume, start_face, start_edge, blend_faces); 04394 04395 blend_chains.push_back(blend_faces); 04396 } 04397 } 04398 else 04399 { 04400 // the given face is not a blend 04401 return CUBIT_FAILURE; 04402 } 04403 04404 return CUBIT_SUCCESS; 04405 } 04406 04407 //-------------------------------------------------------------------- 04408 //Function: Public, is_face_blend 04409 //Description: Determines if a face is a blend surface, returns the 04410 // ref_edge on one side of the blend and other_edge on the opposite side. 04411 // For this type of blend, only ref_edge must be tangentially meeting 04412 // with another surface. Other_edge must be oriented orthogonally to 04413 // it and may or may not blend with another surface. This assumes 04414 // a rectangular blend surface, without holes. 04415 //--------------------------------------------------------------------- 04416 CubitBoolean GeomMeasureTool::is_face_blend(RefFace *ref_face, 04417 RefVolume *ref_volume, 04418 RefEdge *&ref_edge, 04419 RefEdge *&other_edge) 04420 { 04421 //first we know that blend surfaces are not planar. 04422 //so remove these first. 04423 //Also, don't look at faces with more than 2 loops. 04424 if ( ref_face->geometry_type() == PLANE_SURFACE_TYPE || 04425 ref_face->num_loops() > 2 ) 04426 return CUBIT_FALSE; 04427 04428 CubitBoolean is_cartesian; 04429 DLIList<RefEdge*> ref_edges; 04430 ref_edge = NULL; 04431 other_edge = NULL; 04432 RefFace *other_face; 04433 int jj; 04434 double angle; 04435 ref_face->ref_edges(ref_edges); 04436 for ( jj = ref_edges.size(); jj > 0; jj-- ) 04437 { 04438 ref_edge = ref_edges.get_and_step(); 04439 04440 //Weed-out case where one edge is shared between more 04441 //than 2 surfaces of the same volume 04442 DLIList<RefFace*> tmp_faces; 04443 ref_edge->ref_faces( tmp_faces ); 04444 04445 if( tmp_faces.size() > 2 ) 04446 { 04447 int kk; 04448 for(kk=tmp_faces.size(); kk--;) 04449 { 04450 if( !tmp_faces.get()->is_child( ref_volume ) ) 04451 tmp_faces.change_to(NULL); 04452 tmp_faces.step(); 04453 } 04454 tmp_faces.remove_all_with_value( NULL ); 04455 if( tmp_faces.size() > 2 ) 04456 //this isn't the type of surface we are looking for... 04457 continue; 04458 } 04459 04460 other_face = ref_edge->other_face(ref_face, ref_volume); 04461 if ( other_face == NULL ) 04462 { 04463 //this isn't the type of surface we are looking for... 04464 break; 04465 } 04466 angle = GeometryQueryTool::instance()->surface_angle(ref_face, 04467 other_face, 04468 ref_edge, 04469 ref_volume); 04470 angle *= 180.0/CUBIT_PI; 04471 is_cartesian = CUBIT_TRUE; 04472 if ( angle <= GEOM_SIDE_LOWER || 04473 angle >= GEOM_SIDE_UPPER ) 04474 is_cartesian = CUBIT_FALSE; 04475 //Okay, we have one major criteria achieved, this edge is a cartesian meet. 04476 04477 if ( !is_cartesian ) 04478 continue; 04479 //Now we need to check the radius of curvatures between these 04480 //two surfaces. I'm not totally sure about this but I think we 04481 //don't want the same radius of curvature. 04482 double k1_s1, k2_s1, k1_s2, k2_s2; 04483 CubitVector mid_point; 04484 ref_edge->mid_point(mid_point); 04485 ref_face->get_principal_curvatures( mid_point, k1_s1, k2_s1, ref_volume); 04486 other_face->get_principal_curvatures( mid_point, k1_s2, k2_s2, ref_volume); 04487 if (( is_equal(k1_s1, k1_s2) || is_equal(k1_s1, k2_s2) ) && 04488 ( is_equal(k2_s1, k1_s2) || is_equal(k2_s1, k2_s2) ) ) 04489 //try a different edge. 04490 continue; 04491 04492 //Okay, this looks pretty good. 04493 //Now try and find an edge that is on the "opposite" side of 04494 // this surface. Sort of assume this is like a mapable surface. 04495 //check the oposite side. 04496 other_edge = NULL; 04497 CubitVector opp_point; 04498 if ( !find_opposite_edge( ref_edge, ref_face, other_edge, opp_point) || 04499 other_edge == NULL ) 04500 //if we can't find an opposite edge, we need to not 04501 //continue checking this surface. 04502 return CUBIT_FALSE; 04503 04504 //Okay, we have the point opposite. If this is a blend surface 04505 //the normal of this point should be pointing 90 degrees from 04506 //us. 04507 CubitVector normal_1 = ref_face->normal_at(mid_point, ref_volume); 04508 CubitVector normal_2 = ref_face->normal_at(opp_point, ref_volume); 04509 normal_1.normalize(); 04510 normal_2.normalize(); 04511 double dot_product = normal_1 % normal_2; 04512 if ( dot_product >= .5 || dot_product <= -.5 ) 04513 //try a different edge. 04514 continue; 04515 CubitVector tangent_1, tangent_2; 04516 ref_edge->tangent(mid_point, tangent_1, ref_face); 04517 other_edge->tangent(opp_point, tangent_2, ref_face); 04518 tangent_1.normalize(); 04519 tangent_2.normalize(); 04520 dot_product = tangent_1 % tangent_2; 04521 //basically these edges should be somewhat parallel at 04522 //this point. 04523 if ( dot_product < .5 && dot_product > -.5 ) 04524 continue; 04525 //This was called but never checked, not sure why. 04526 // //check the curvature opposite. 04527 // double k1_s3, k2_s3; 04528 // ref_face->get_principal_curvatures( opp_point, k1_s3, k2_s3, ref_volume); 04529 //we are done with this face. It is a blend face. 04530 return CUBIT_TRUE; 04531 } 04532 return CUBIT_FALSE; 04533 } 04534 04535 //-------------------------------------------------------------------- 04536 //Function: Public, is_vertex_blend 04537 //Description: Determines if a face is a vertex blend surface. 04538 // For this type of blend, all ref_edges must be meet tangentially 04539 // with another surface. This assumes blend surface with no holes. 04540 //--------------------------------------------------------------------- 04541 CubitBoolean GeomMeasureTool::is_vertex_blend(RefFace *ref_face, 04542 RefVolume* ref_volume) 04543 { 04544 //first we know that blend surfaces are not planar. 04545 //so remove these first. 04546 //Also, don't look at faces with more than 2 loops. 04547 if ( ref_face->geometry_type() == PLANE_SURFACE_TYPE || 04548 ref_face->num_loops() > 2 ) 04549 return CUBIT_FALSE; 04550 04551 CubitBoolean is_cartesian; 04552 DLIList<RefEdge*> ref_edges; 04553 RefFace *other_face; 04554 RefEdge *ref_edge = NULL; 04555 int jj; 04556 double angle; 04557 ref_face->ref_edges(ref_edges); 04558 for ( jj = ref_edges.size(); jj > 0; jj-- ) 04559 { 04560 ref_edge = ref_edges.get_and_step(); 04561 04562 //Weed-out case where one edge is shared between more 04563 //than 2 surfaces of the same volume 04564 DLIList<RefFace*> tmp_faces; 04565 ref_edge->ref_faces( tmp_faces ); 04566 04567 if( tmp_faces.size() > 2 ) 04568 { 04569 int kk; 04570 for(kk=tmp_faces.size(); kk--;) 04571 { 04572 if( !tmp_faces.get()->is_child( ref_volume ) ) 04573 tmp_faces.change_to(NULL); 04574 tmp_faces.step(); 04575 } 04576 tmp_faces.remove_all_with_value( NULL ); 04577 if( tmp_faces.size() > 2 ) 04578 //this isn't the type of surface we are looking for... 04579 continue; 04580 } 04581 04582 other_face = ref_edge->other_face(ref_face, ref_volume); 04583 if ( other_face == NULL ) 04584 { 04585 //this isn't the type of surface we are looking for... 04586 break; 04587 } 04588 angle = GeometryQueryTool::instance()->surface_angle(ref_face, 04589 other_face, 04590 ref_edge, 04591 ref_volume); 04592 angle *= 180.0/CUBIT_PI; 04593 is_cartesian = CUBIT_TRUE; 04594 if ( angle <= GEOM_SIDE_LOWER || 04595 angle >= GEOM_SIDE_UPPER ) 04596 is_cartesian = CUBIT_FALSE; 04597 //Okay, we have one major criteria achieved, this edge is a cartesian meet. 04598 04599 if ( !is_cartesian ) 04600 return CUBIT_FALSE; 04601 //Now we need to check the radius of curvatures between these 04602 //two surfaces. I'm not totally sure about this but I think we 04603 // want the same radius of curvature. 04604 double k1_s1, k2_s1, k1_s2, k2_s2; 04605 CubitVector mid_point; 04606 ref_edge->mid_point(mid_point); 04607 ref_face->get_principal_curvatures( mid_point, k1_s1, k2_s1, ref_volume); 04608 other_face->get_principal_curvatures( mid_point, k1_s2, k2_s2, ref_volume); 04609 if (( is_equal(k1_s1, k1_s2) || is_equal(k1_s1, k2_s2) ) && 04610 ( is_equal(k2_s1, k1_s2) || is_equal(k2_s1, k2_s2) ) ) 04611 //try a different edge. 04612 continue; 04613 else 04614 return CUBIT_FALSE; 04615 } 04616 04617 // if all edges are tangent and share curvatures then it must be a 04618 // vertex blend. 04619 return CUBIT_TRUE; 04620 } 04621 04622 CubitBoolean GeomMeasureTool::find_opposite_edge( RefEdge* ref_edge, 04623 RefFace* ref_face, 04624 RefEdge *&other_edge, 04625 CubitVector &closest_point) 04626 { 04627 //Here we want to find the edge that is "opposite" to ref_edge. 04628 //Opposite is defined by assuming the surface is a square or cylinder and 04629 //finding the edge on the other side, so that there is a point closest 04630 //to the mid point on the ref_edge. 04631 //double need_to_turn = CUBIT_PI; 04632 int ii; 04633 DLIList <Loop*> loops; 04634 DLIList <CoEdge*> co_edges; 04635 Loop *curr_loop; 04636 CoEdge *co_edge, *this_co_edge; 04637 ref_edge->get_co_edges(co_edges, ref_face); 04638 if ( co_edges.size() != 1 ) 04639 return CUBIT_FALSE; 04640 this_co_edge = co_edges.get(); 04641 co_edges.clean_out(); 04642 ref_face->loops(loops); 04643 if ( loops.size() > 2 ) 04644 return CUBIT_FALSE; 04645 CubitBoolean found_loop = CUBIT_FALSE; 04646 //find the loop where this_co_edge is on. 04647 for(ii = loops.size(); ii > 0; ii-- ) 04648 { 04649 curr_loop = loops.get_and_step(); 04650 co_edges.clean_out(); 04651 curr_loop->ordered_co_edges(co_edges); 04652 if ( co_edges.move_to(this_co_edge) ) 04653 { 04654 found_loop = CUBIT_TRUE; 04655 break; 04656 } 04657 } 04658 if ( !found_loop ) 04659 return CUBIT_FALSE; 04660 CoEdge *opp_co_edge = NULL; 04661 if ( loops.size() == 1 ) 04662 { 04663 //This is the normal case, I hope. 04664 //this co_edge, go around the interior until 04665 //we turn twice. If there are angles greater than CUBIT_PI, this isn't 04666 //a traditional blend. Everything should be convex. 04667 if ( co_edges.size() == 4 ) 04668 { 04669 //Just get the one opposite... 04670 opp_co_edge = co_edges.next(2); 04671 } 04672 else 04673 { 04674 //double total_angle = 0.0; 04675 int turn_counter = 0; 04676 CoEdge *next_co_edge = NULL; 04677 for ( ii = co_edges.size(); ii > 0; ii-- ) 04678 { 04679 co_edge = co_edges.get_and_step(); 04680 next_co_edge = co_edges.get(); 04681 double angle = GeometryQueryTool::instance()->geometric_angle(co_edge, next_co_edge); 04682 angle *= 180.0/CUBIT_PI; 04683 //we don't deal with small or concave angles. 04684 if ( angle < 10.0 ) 04685 return CUBIT_FALSE; 04686 else if ( angle > 185.0 ) 04687 return CUBIT_FALSE; 04688 else if ( angle < 140.0 ) 04689 turn_counter++; 04690 if ( turn_counter == 2 ) 04691 { 04692 opp_co_edge = next_co_edge; 04693 break; 04694 } 04695 } 04696 } 04697 } 04698 else 04699 { 04700 //Just get the other loop and get one coedge in it. 04701 co_edges.clean_out(); 04702 curr_loop = loops.get(); 04703 curr_loop->ordered_co_edges(co_edges); 04704 opp_co_edge = co_edges.get(); 04705 } 04706 if ( opp_co_edge == NULL ) 04707 return CUBIT_FALSE; 04708 //This is just here to test correctness to this point, it can be taken out 04709 //if need be. 04710 if ( !co_edges.move_to(opp_co_edge) ) 04711 { 04712 PRINT_ERROR("logic messed-up in find_opposite edge\n"); 04713 assert(0); 04714 return CUBIT_FALSE; 04715 } 04716 //okay, we now have the co_edges in the correct position and 04717 //we have a canidate co_edge. 04718 //Search from the co_edge with the point that has closest point 04719 //to the mid point of this_co_edge. 04720 other_edge = NULL; 04721 CubitVector mid_point; 04722 ref_edge->mid_point(mid_point); 04723 CubitVector tmp_closest_point; 04724 double min_dist_sq = CUBIT_DBL_MAX; 04725 double dist_sq; 04726 RefEdge *test_ref_edge; 04727 CoEdge *prev_co_edge; 04728 CubitBoolean first = CUBIT_TRUE; 04729 for ( ii = co_edges.size(); ii > 0; ii-- ) 04730 { 04731 co_edge = co_edges.get_and_step(); 04732 prev_co_edge = co_edges.prev(2); 04733 test_ref_edge = co_edge->get_ref_edge_ptr(); 04734 //We don't want edges that are connected to ref edge. 04735 //If we have them, we have gone to far around the surface. 04736 if ( test_ref_edge->common_ref_vertex(ref_edge) ) 04737 break; 04738 if ( !first ) 04739 { 04740 //break out of the for loop if we turn again. We just want the closest 04741 //point opposite. 04742 double angle = GeometryQueryTool::instance()-> 04743 geometric_angle(prev_co_edge, co_edge); 04744 angle *= 180.0/CUBIT_PI; 04745 if ( angle > 195.0 || angle < 145.0 ) 04746 break; 04747 } 04748 else 04749 first = CUBIT_FALSE; 04750 //now find the closest point to the mid point of ref_edge. 04751 test_ref_edge->closest_point_trimmed( mid_point, 04752 tmp_closest_point); 04753 dist_sq = (mid_point - closest_point).length_squared(); 04754 //find and keep the closest one. 04755 if ( dist_sq < min_dist_sq ) 04756 { 04757 other_edge = test_ref_edge; 04758 min_dist_sq = dist_sq; 04759 closest_point = tmp_closest_point; 04760 } 04761 } 04762 if ( other_edge == NULL ) 04763 return CUBIT_FALSE; 04764 04765 return CUBIT_TRUE; 04766 } 04767 CubitBoolean GeomMeasureTool::is_equal(double v1, double v2) 04768 { 04769 double smallv = v1-v2; 04770 if ( smallv < 0.0 ) 04771 { 04772 if ( smallv >= -CUBIT_RESABS ) 04773 return CUBIT_TRUE; 04774 else 04775 return CUBIT_FALSE; 04776 } 04777 else 04778 { 04779 if ( smallv <= CUBIT_RESABS ) 04780 return CUBIT_TRUE; 04781 else 04782 return CUBIT_FALSE; 04783 } 04784 } 04785 CubitStatus GeomMeasureTool::get_centroid( RefFace *ref_face, CubitVector ¢roid, double &tot_area ) 04786 { 04787 GMem g_mem; 04788 unsigned short norm_tol = 5; 04789 double dist_tol = -1.0; 04790 04791 ref_face->get_geometry_query_engine()-> 04792 get_graphics(ref_face->get_surface_ptr(), &g_mem, norm_tol, dist_tol ); 04793 04794 if(g_mem.fListCount < 1) 04795 { 04796 // Decrease tolerance and try again (we can get this for small features) 04797 norm_tol /= 2; 04798 ref_face->get_geometry_query_engine()-> 04799 get_graphics(ref_face->get_surface_ptr(), &g_mem, norm_tol, dist_tol ); 04800 } 04801 04802 if(g_mem.fListCount < 1) 04803 { 04804 // Lets give up 04805 PRINT_ERROR( "Unable to find the center of a surface\n" ); 04806 return CUBIT_FAILURE; 04807 } 04808 04809 // Initialize 04810 tot_area = 0.0; 04811 centroid.set( 0.0, 0.0, 0.0 ); 04812 04813 // Loop through the triangles 04814 double tri_area; 04815 GPoint p[3]; 04816 GPoint* plist = g_mem.point_list(); 04817 int* facet_list = g_mem.facet_list(); 04818 int c = 0; 04819 for( ; c < g_mem.fListCount; ) 04820 { 04821 p[0] = plist[facet_list[++c]]; 04822 p[2] = plist[facet_list[++c]]; 04823 p[1] = plist[facet_list[++c]]; 04824 c++; 04825 04826 // Get centroid 04827 CubitVector p1( p[0].x, p[0].y, p[0].z ); 04828 CubitVector p2( p[2].x, p[2].y, p[2].z ); 04829 CubitVector p3( p[1].x, p[1].y, p[1].z ); 04830 04831 CubitVector center = (p1 + p2 + p3)/3.0; 04832 04833 //Calculate area 04834 CubitVector vec1 = (p2 - p1); 04835 CubitVector vec2 = (p3 - p1); 04836 04837 CubitVector cross = vec1 * vec2; 04838 04839 tri_area = 0.5* sqrt(cross.x() * cross.x() + cross.y() * cross.y() + cross.z() * cross.z()); 04840 04841 04842 centroid += (tri_area * center); 04843 04844 tot_area += tri_area; 04845 04846 } 04847 if( tot_area == 0 ) 04848 return CUBIT_FAILURE; 04849 04850 centroid /= tot_area; 04851 return CUBIT_SUCCESS; 04852 } 04853 04854 CubitStatus 04855 GeomMeasureTool::center( DLIList<RefFace*> ref_faces ) 04856 { 04857 int ii,id; 04858 double surf_area; 04859 double tot_area = 0.0; 04860 CubitVector surf_centroid; 04861 CubitVector centroid; 04862 centroid.set( 0.0, 0.0, 0.0 ); 04863 04864 for ( ii = ref_faces.size(); ii > 0; ii-- ) 04865 { 04866 RefFace *ref_face = ref_faces.get_and_step(); 04867 if( GeomMeasureTool::get_centroid( ref_face, surf_centroid, surf_area) != CUBIT_SUCCESS ) 04868 return CUBIT_FAILURE; 04869 centroid += (surf_area * surf_centroid); 04870 tot_area += surf_area; 04871 id = ref_face->id(); 04872 } 04873 04874 centroid /= tot_area; 04875 04876 if( ref_faces.size() > 1 ) 04877 PRINT_INFO("Centroid of Composite surface located at: ( %f , %f , %f )\n\n", 04878 centroid.x(), centroid.y(), centroid.z()); 04879 else 04880 PRINT_INFO("Centroid of Surface %i located at: ( %f , %f , %f )\n\n", 04881 id, centroid.x(), centroid.y(), centroid.z()); 04882 return CUBIT_SUCCESS; 04883 } 04884 04885 CubitStatus GeomMeasureTool::find_near_coincident_vertices( 04886 DLIList<RefVolume*> &ref_volumes, 04887 DLIList<RefVertex*> &ref_vertices_out, 04888 DLIList<double> &distances, 04889 double low_tol, 04890 double high_tol, 04891 bool filter_same_volume_cases) 04892 { 04893 DLIList<RefVertex*> tmp_vert_list; 04894 DLIList<RefVertex*> ref_verts; 04895 int i,j; 04896 for( i=ref_volumes.size(); i--; ) 04897 { 04898 RefVolume *tmp_vol = ref_volumes.get_and_step(); 04899 tmp_vert_list.clean_out(); 04900 tmp_vol->ref_vertices( tmp_vert_list ); 04901 ref_verts += tmp_vert_list; 04902 } 04903 04904 //put all the vertices in a tree 04905 AbstractTree <RefVertex*> *a_tree = new RTree<RefVertex*>( high_tol ); 04906 for (i=ref_verts.size(); i--;) 04907 a_tree->add(ref_verts.get_and_step()); 04908 04909 std::multimap<double, dist_vert_struct> distance_vertex_map; 04910 04911 //for each vertex 04912 for (i=ref_verts.size(); i--;) 04913 { 04914 RefVertex *tmp_vert = ref_verts.get_and_step(); 04915 RefVolume *v1 = tmp_vert->ref_volume(); 04916 CubitVector vert_xyz = tmp_vert->coordinates(); 04917 04918 //get all close vertices 04919 DLIList<RefVertex*> close_verts; 04920 a_tree->find(tmp_vert->bounding_box(), close_verts); 04921 04922 //if any vertex is between low_tol and high_tol 04923 //add it to the list 04924 DLIList<RefVertex*> near_coincident_verts; 04925 for( j=close_verts.size(); j--; ) 04926 { 04927 RefVertex *close_vert = close_verts.get_and_step(); 04928 if( close_vert == tmp_vert ) 04929 continue; 04930 04931 RefVolume *v2 = close_vert->ref_volume(); 04932 bool check_distance = true; 04933 if(filter_same_volume_cases && v1 && v2 && v1 == v2) 04934 check_distance = false; 04935 if(check_distance) 04936 { 04937 double distance = vert_xyz.distance_between( close_vert->coordinates() ); 04938 if( distance >= low_tol && distance <= high_tol ) 04939 { 04940 dist_vert_struct tmp_struct; 04941 tmp_struct.dist = distance; 04942 tmp_struct.v1 = tmp_vert; 04943 tmp_struct.v2 = close_vert; 04944 distance_vertex_map.insert( std::multimap<double, dist_vert_struct>:: 04945 value_type( distance, tmp_struct )); 04946 } 04947 } 04948 } 04949 04950 a_tree->remove( tmp_vert ); 04951 } 04952 04953 std::multimap<double, dist_vert_struct>::reverse_iterator iter; 04954 04955 iter = distance_vertex_map.rbegin(); 04956 for(; iter!=distance_vertex_map.rend(); iter++ ) 04957 { 04958 distances.append( (*iter).second.dist ); 04959 ref_vertices_out.append( (*iter).second.v1 ); 04960 ref_vertices_out.append( (*iter).second.v2 ); 04961 } 04962 04963 delete a_tree; 04964 04965 return CUBIT_SUCCESS; 04966 } 04967 04968 // This function is similar to find_near_coincident_vertices except for the 04969 // fact that it will only find the closest vertex in a given volume for 04970 // a vertex in another volume to be close to. This tries to exclude the case where 04971 // you would attempt to merge one vertex from one volume to two different 04972 // vertices in another volume. 04973 CubitStatus GeomMeasureTool::find_near_coincident_vertices_unique( 04974 DLIList<RefVolume*> &ref_volumes, 04975 double high_tol, 04976 std::map <RefVertex*, DLIList<dist_vert_struct*>*> &vert_dist_map) 04977 { 04978 DLIList<RefVertex*> tmp_vert_list; 04979 DLIList<RefVertex*> ref_verts; 04980 int i,j; 04981 for( i=ref_volumes.size(); i--; ) 04982 { 04983 RefVolume *tmp_vol = ref_volumes.get_and_step(); 04984 tmp_vert_list.clean_out(); 04985 tmp_vol->ref_vertices( tmp_vert_list ); 04986 ref_verts += tmp_vert_list; 04987 } 04988 04989 //put all the vertices in a tree 04990 AbstractTree <RefVertex*> *a_tree = new RTree<RefVertex*>( high_tol ); 04991 for (i=ref_verts.size(); i--;) 04992 a_tree->add(ref_verts.get_and_step()); 04993 04994 //for each vertex 04995 for (i=ref_verts.size(); i--;) 04996 { 04997 RefVertex *tmp_vert = ref_verts.get_and_step(); 04998 RefVolume *vol1 = tmp_vert->ref_volume(); 04999 CubitVector vert_xyz = tmp_vert->coordinates(); 05000 05001 //get all close vertices 05002 DLIList<RefVertex*> close_verts; 05003 a_tree->find(tmp_vert->bounding_box(), close_verts); 05004 05005 //if any vertex is between low_tol and high_tol 05006 //add it to the list 05007 DLIList<dist_vert_struct*> *near_coincident_verts = NULL; 05008 for( j=close_verts.size(); j--; ) 05009 { 05010 RefVertex *close_vert = close_verts.get_and_step(); 05011 if( close_vert == tmp_vert ) 05012 continue; 05013 05014 RefVolume *vol2 = close_vert->ref_volume(); 05015 if(vol1 && vol2 && vol1 != vol2) 05016 { 05017 if(!near_coincident_verts) 05018 { 05019 near_coincident_verts = new DLIList<dist_vert_struct*>; 05020 vert_dist_map[tmp_vert] = near_coincident_verts; 05021 } 05022 double distance = vert_xyz.distance_between( close_vert->coordinates() ); 05023 int h; 05024 bool found_entry_with_same_vol = false; 05025 for(h=near_coincident_verts->size(); h>0 && !found_entry_with_same_vol; h--) 05026 { 05027 dist_vert_struct* vds = near_coincident_verts->get_and_step(); 05028 if(vds->vol2 == vol2) 05029 { 05030 found_entry_with_same_vol = true; 05031 if(distance < vds->dist) 05032 { 05033 vds->dist = distance; 05034 vds->vol2 = vol2; 05035 vds->v2 = close_vert; 05036 } 05037 } 05038 } 05039 if(!found_entry_with_same_vol) 05040 { 05041 dist_vert_struct *new_vds = new dist_vert_struct; 05042 new_vds->dist = distance; 05043 new_vds->v2 = close_vert; 05044 new_vds->vol2 = vol2; 05045 near_coincident_verts->append(new_vds); 05046 } 05047 } 05048 } 05049 a_tree->remove( tmp_vert ); 05050 } 05051 05052 delete a_tree; 05053 05054 return CUBIT_SUCCESS; 05055 } 05056 05057 struct dist_vert_vert_struct 05058 { 05059 double dist; 05060 RefVertex *vert1; 05061 RefVertex *vert2; 05062 }; 05063 05064 struct dist_vert_curve_struct 05065 { 05066 double dist; 05067 RefVertex *vert; 05068 RefEdge *edge; 05069 // bool operator<( const dist_vert_curve_struct& b ) const 05070 // { 05071 // return this->dist < b.dist; 05072 // } 05073 }; 05074 05075 struct vert_curve_dist_sort 05076 { 05077 bool operator()( const dist_vert_curve_struct& a, const dist_vert_curve_struct& b ) const 05078 { 05079 return a.dist < b.dist; 05080 } 05081 }; 05082 05083 struct vert_curve_dist_sort_ptr 05084 { 05085 bool operator()( dist_vert_curve_struct *a, dist_vert_curve_struct *b ) const 05086 { 05087 return a->dist < b->dist; 05088 } 05089 }; 05090 05091 struct vert_vert_dist_sort_ptr 05092 { 05093 bool operator()( dist_vert_vert_struct *a, dist_vert_vert_struct *b ) const 05094 { 05095 return a->dist < b->dist; 05096 } 05097 }; 05098 05099 CubitStatus GeomMeasureTool::find_closest_vertex_curve_pairs( 05100 DLIList<RefVolume*> &vol_list, 05101 int &num_to_return, 05102 DLIList<RefVertex*> &vert_list, 05103 DLIList<RefEdge*> &curve_list, 05104 DLIList<double> &distances) 05105 { 05106 DLIList<RefFace*> surfs; 05107 05108 int i, total_num_entries = 0; 05109 for( i=vol_list.size(); i--; ) 05110 { 05111 RefVolume *tmp_vol = vol_list.get_and_step(); 05112 tmp_vol->ref_faces( surfs ); 05113 } 05114 05115 std::set<dist_vert_curve_struct*,vert_curve_dist_sort_ptr> distance_vertex_curve_set; 05116 05117 for(i=surfs.size(); i>0; i--) 05118 { 05119 RefFace *surf = surfs.get_and_step(); 05120 DLIList<RefVertex*> surf_verts; 05121 surf->ref_vertices(surf_verts); 05122 DLIList<RefEdge*> surf_curves; 05123 surf->ref_edges(surf_curves); 05124 05125 int j; 05126 for(j=surf_verts.size(); j>0; j--) 05127 { 05128 RefVertex *tmp_vert = surf_verts.get_and_step(); 05129 CubitVector vert_xyz = tmp_vert->coordinates(); 05130 CubitVector closest_pt; 05131 int k; 05132 for(k=surf_curves.size(); k>0; k--) 05133 { 05134 RefEdge *cur_edge = surf_curves.get_and_step(); 05135 if(cur_edge->start_vertex() != tmp_vert && 05136 cur_edge->end_vertex() != tmp_vert) 05137 { 05138 cur_edge->closest_point_trimmed(vert_xyz, closest_pt); 05139 if(!closest_pt.about_equal(cur_edge->start_coordinates()) && 05140 !closest_pt.about_equal(cur_edge->end_coordinates())) 05141 { 05142 double dist_sq = vert_xyz.distance_between_squared(closest_pt); 05143 dist_vert_curve_struct *tmp_struct = new dist_vert_curve_struct; 05144 tmp_struct->dist = dist_sq; 05145 tmp_struct->vert = tmp_vert; 05146 tmp_struct->edge = cur_edge; 05147 distance_vertex_curve_set.insert( tmp_struct ); 05148 total_num_entries++; 05149 } 05150 } 05151 } 05152 } 05153 } 05154 05155 std::set<dist_vert_curve_struct*, vert_curve_dist_sort_ptr>::iterator iter, upper_iter; 05156 05157 int local_num_to_return = num_to_return; 05158 if(num_to_return == -1) 05159 { 05160 local_num_to_return = total_num_entries; 05161 } 05162 int cntr = 0; 05163 iter = distance_vertex_curve_set.begin(); 05164 for(; iter!=distance_vertex_curve_set.end() && cntr < local_num_to_return; iter++ ) 05165 { 05166 distances.append( sqrt((*iter)->dist) ); 05167 vert_list.append( (*iter)->vert ); 05168 curve_list.append( (*iter)->edge ); 05169 cntr++; 05170 } 05171 05172 iter = distance_vertex_curve_set.begin(); 05173 for(; iter!=distance_vertex_curve_set.end(); iter++ ) 05174 { 05175 delete *iter; 05176 } 05177 05178 return CUBIT_SUCCESS; 05179 } 05180 05181 CubitStatus GeomMeasureTool::find_closest_vertex_vertex_pairs( 05182 DLIList<RefVolume*> &vol_list, 05183 int &num_to_return, 05184 DLIList<RefVertex*> &vert_list1, 05185 DLIList<RefVertex*> &vert_list2, 05186 DLIList<double> &distances) 05187 { 05188 std::set<dist_vert_vert_struct*,vert_vert_dist_sort_ptr> distance_vertex_vertex_set; 05189 05190 int i, total_num_entries = 0; 05191 for( i=vol_list.size(); i--; ) 05192 { 05193 RefVolume *tmp_vol = vol_list.get_and_step(); 05194 DLIList<RefVertex*> vol_verts; 05195 tmp_vol->ref_vertices(vol_verts); 05196 while(vol_verts.size() > 1) 05197 { 05198 RefVertex *vert1 = vol_verts.pop(); 05199 CubitVector vert1_xyz = vert1->coordinates(); 05200 int j; 05201 for(j=vol_verts.size(); j>0; j--) 05202 { 05203 RefVertex *vert2 = vol_verts.get_and_step(); 05204 double dist_sq = vert2->coordinates().distance_between_squared(vert1_xyz); 05205 dist_vert_vert_struct *tmp_struct = new dist_vert_vert_struct; 05206 tmp_struct->dist = dist_sq; 05207 tmp_struct->vert1 = vert1; 05208 tmp_struct->vert2 = vert2; 05209 distance_vertex_vertex_set.insert( tmp_struct ); 05210 total_num_entries++; 05211 } 05212 } 05213 } 05214 05215 std::set<dist_vert_vert_struct*, vert_vert_dist_sort_ptr>::iterator iter, upper_iter; 05216 05217 int local_num_to_return = num_to_return; 05218 if(num_to_return == -1) 05219 local_num_to_return = total_num_entries; 05220 int cntr = 0; 05221 iter = distance_vertex_vertex_set.begin(); 05222 for(; iter!=distance_vertex_vertex_set.end() && cntr < local_num_to_return; iter++ ) 05223 { 05224 distances.append( sqrt((*iter)->dist) ); 05225 vert_list1.append( (*iter)->vert1 ); 05226 vert_list2.append( (*iter)->vert2 ); 05227 cntr++; 05228 } 05229 05230 iter = distance_vertex_vertex_set.begin(); 05231 for(; iter!=distance_vertex_vertex_set.end(); iter++ ) 05232 { 05233 delete *iter; 05234 } 05235 05236 return CUBIT_SUCCESS; 05237 } 05238 05239 CubitStatus GeomMeasureTool::find_near_coincident_vertex_curve_pairs( 05240 DLIList<RefVolume*> &ref_vols, 05241 DLIList<RefEdge*> &ref_edges, 05242 DLIList<RefVertex*> &ref_verts, 05243 DLIList<double> &distances, 05244 double low_tol, 05245 double high_tol, 05246 bool filter_same_volume_cases) 05247 { 05248 //get all the curves and vertices of volumes in list 05249 DLIList<RefVertex*> verts; 05250 DLIList<RefEdge*> curves; 05251 05252 RTree<RefEdge*> a_tree(high_tol); 05253 05254 int i,j; 05255 for( i=ref_vols.size(); i--; ) 05256 { 05257 RefVolume *tmp_vol = ref_vols.get_and_step(); 05258 tmp_vol->ref_vertices( verts ); 05259 05260 curves.clean_out(); 05261 tmp_vol->ref_edges( curves ); 05262 for( j=curves.size(); j--; ) 05263 { 05264 RefEdge *tmp_edge = curves.get_and_step(); 05265 a_tree.add( tmp_edge ); 05266 } 05267 } 05268 05269 ProgressTool *progress_ptr = NULL; 05270 int total_verts = verts.size(); 05271 if (total_verts > 5) 05272 { 05273 progress_ptr = AppUtil::instance()->progress_tool(); 05274 assert(progress_ptr != NULL); 05275 progress_ptr->start(0, 100, "Finding Near Coincident Vertex-Curve Pairs", 05276 NULL, CUBIT_TRUE, CUBIT_TRUE); 05277 } 05278 05279 double curr_percent = 0.0; 05280 int processed_verts = 0; 05281 std::multimap<double, dist_vert_curve_struct> distance_vertex_curve_map; 05282 05283 //for each vertex 05284 for( i=verts.size(); i--; ) 05285 { 05286 processed_verts++; 05287 if ( progress_ptr != NULL ) 05288 { 05289 curr_percent = ((double)(processed_verts))/((double)(total_verts)); 05290 progress_ptr->percent(curr_percent); 05291 } 05292 05293 RefVertex *tmp_vert = verts.get_and_step(); 05294 RefVolume *v1 = tmp_vert->ref_volume(); 05295 CubitBox vertex_box ( tmp_vert->coordinates(), tmp_vert->coordinates() ); 05296 DLIList<RefEdge*> close_curves; 05297 a_tree.find( vertex_box, close_curves ); 05298 05299 CubitVector vertex_xyz = tmp_vert->coordinates(); 05300 05301 for( j=close_curves.size(); j--; ) 05302 { 05303 RefEdge *tmp_edge = close_curves.get_and_step(); 05304 RefVolume *v2 = tmp_edge->ref_volume(); 05305 05306 bool check_distance = true; 05307 if(filter_same_volume_cases && v1 && v2 && v1 == v2) 05308 check_distance = false; 05309 if(check_distance) 05310 { 05311 CubitVector closest_location; 05312 tmp_edge->closest_point_trimmed( vertex_xyz, closest_location ); 05313 double distance = closest_location.distance_between( vertex_xyz ); 05314 05315 if( distance >= low_tol && distance <= high_tol ) 05316 { 05317 dist_vert_curve_struct tmp_struct; 05318 tmp_struct.dist = distance; 05319 tmp_struct.vert = tmp_vert; 05320 tmp_struct.edge = tmp_edge; 05321 05322 distance_vertex_curve_map.insert( std::multimap<double, dist_vert_curve_struct>:: 05323 value_type( distance, tmp_struct )); 05324 } 05325 } 05326 } 05327 } 05328 05329 if ( progress_ptr != NULL ) 05330 progress_ptr->end(); 05331 05332 //std::set<dist_vert_curve_struct, vert_curve_dist_sort>::iterator iter, upper_iter; 05333 std::multimap<double, dist_vert_curve_struct>::reverse_iterator iter; 05334 05335 iter = distance_vertex_curve_map.rbegin(); 05336 for(; iter!=distance_vertex_curve_map.rend(); iter++ ) 05337 { 05338 distances.append( (*iter).second.dist ); 05339 ref_verts.append( (*iter).second.vert ); 05340 ref_edges.append( (*iter).second.edge ); 05341 } 05342 05343 return CUBIT_SUCCESS; 05344 } 05345 05346 05347 struct dist_vert_surf_struct 05348 { 05349 double dist; 05350 RefVertex *vert; 05351 RefFace *face; 05352 }; 05353 05354 struct vert_surf_dist_sort 05355 { 05356 bool operator()( dist_vert_surf_struct a, dist_vert_surf_struct b ) const 05357 { 05358 if( a.dist < b.dist ) 05359 return true; 05360 else if( a.dist > b.dist ) 05361 return false; 05362 else 05363 { 05364 if( a.vert < b.vert ) 05365 return true; 05366 else if( a.vert > b.vert ) 05367 return false; 05368 else if( a.face < b.face ) 05369 return true; 05370 else if( a.face > b.face ) 05371 return false; 05372 } 05373 return false; 05374 } 05375 }; 05376 05377 05378 CubitStatus GeomMeasureTool::find_near_coincident_vertex_surface_pairs( 05379 DLIList<RefVolume*> &ref_vols, 05380 DLIList<RefFace*> &ref_faces, 05381 DLIList<RefVertex*> &ref_verts, 05382 DLIList<double> &distances, 05383 double low_tol, 05384 double high_tol, 05385 bool filter_same_volume_cases) 05386 { 05387 //get all the curves and vertices of volumes in list 05388 DLIList<RefVertex*> verts; 05389 DLIList<RefFace*> faces; 05390 05391 AbstractTree<RefFace*> *a_tree = new RTree<RefFace*>( high_tol ); 05392 05393 int i,j; 05394 for( i=ref_vols.size(); i--; ) 05395 { 05396 RefVolume *tmp_vol = ref_vols.get_and_step(); 05397 tmp_vol->ref_vertices( verts ); 05398 05399 faces.clean_out(); 05400 tmp_vol->ref_faces( faces ); 05401 // Populate the Surface AbstractTree 05402 for( j=faces.size(); j--; ) 05403 { 05404 RefFace *tmp_face = faces.get_and_step(); 05405 a_tree->add( tmp_face ); 05406 } 05407 } 05408 05409 ProgressTool *progress_ptr = NULL; 05410 int total_verts = verts.size(); 05411 if (total_verts > 50) 05412 { 05413 progress_ptr = AppUtil::instance()->progress_tool(); 05414 assert(progress_ptr != NULL); 05415 progress_ptr->start(0, 100, "Finding Near Coincident Vertex-Surface Pairs", 05416 NULL, CUBIT_TRUE, CUBIT_TRUE); 05417 } 05418 double curr_percent = 0.0; 05419 int processed_verts = 0; 05420 05421 std::multimap<double, dist_vert_surf_struct> distance_vertex_surface_map; 05422 05423 //for each vertex 05424 for( i=verts.size(); i--; ) 05425 { 05426 processed_verts++; 05427 if ( progress_ptr != NULL ) 05428 { 05429 curr_percent = ((double)(processed_verts))/((double)(total_verts)); 05430 progress_ptr->percent(curr_percent); 05431 } 05432 05433 RefVertex *tmp_vert = verts.get_and_step(); 05434 RefVolume *v1 = tmp_vert->ref_volume(); 05435 CubitBox vertex_box ( tmp_vert->coordinates(), tmp_vert->coordinates() ); 05436 DLIList<RefFace*> close_faces; 05437 a_tree->find( vertex_box, close_faces); 05438 05439 CubitVector vertex_xyz = tmp_vert->coordinates(); 05440 05441 for( j=close_faces.size(); j--; ) 05442 { 05443 RefFace *tmp_face = close_faces.get_and_step(); 05444 RefVolume *v2 = tmp_face->ref_volume(); 05445 05446 bool check = true; 05447 if(filter_same_volume_cases && v1 && v2 && v1 == v2) 05448 check = false; 05449 05450 if(check) 05451 { 05452 DLIList<RefVertex*> tmp_verts; 05453 tmp_face->ref_vertices( tmp_verts ); 05454 if( tmp_verts.is_in_list( tmp_vert ) ) 05455 continue; 05456 05457 CubitVector closest_location; 05458 tmp_face->find_closest_point_trimmed( vertex_xyz, closest_location ); 05459 double distance = closest_location.distance_between( vertex_xyz ); 05460 05461 if( distance > low_tol && distance < high_tol ) 05462 { 05463 dist_vert_surf_struct tmp_struct; 05464 tmp_struct.dist = distance; 05465 tmp_struct.vert = tmp_vert; 05466 tmp_struct.face = tmp_face; 05467 distance_vertex_surface_map.insert( std::multimap<double, dist_vert_surf_struct>:: 05468 value_type( distance, tmp_struct )); 05469 } 05470 } 05471 } 05472 } 05473 05474 if ( progress_ptr != NULL ) 05475 progress_ptr->end(); 05476 05477 std::multimap<double, dist_vert_surf_struct>::reverse_iterator iter; 05478 05479 iter = distance_vertex_surface_map.rbegin(); 05480 for(; iter!=distance_vertex_surface_map.rend(); iter++ ) 05481 { 05482 distances.append( (*iter).second.dist ); 05483 ref_verts.append( (*iter).second.vert ); 05484 ref_faces.append( (*iter).second.face); 05485 } 05486 05487 delete a_tree; 05488 05489 return CUBIT_SUCCESS; 05490 } 05491 05492 05493 05494 05495
