MeshKit
1.0
00001 //-----------------------------------C++-------------------------------------// 00002 // File: src/algs/meshkit/CoreGen.hpp 00003 // 00004 // Brief: CoreGen class definition: 00005 // Creates reactor core model from input mesh files 00006 // class, CoreGen 00007 //---------------------------------------------------------------------------// 00008 00009 #ifndef MESHKIT_COREGEN_HPP 00010 #define MESHKIT_COREGEN_HPP 00011 00012 00013 #define STRINGIFY_(X) #X 00014 #define STRINGIFY(X) STRINGIFY_(X) 00015 #define COREGEN_DEFAULT_TEST_FILE "coregen_default" 00016 #define CTEST_FILE_NAME "coregen_default" 00017 00018 #include <cassert> 00019 #include <string> 00020 #include <vector> 00021 #include <set> 00022 00023 #include "meshkit/Types.hpp" 00024 #include "meshkit/Error.hpp" 00025 #include "meshkit/MeshScheme.hpp" 00026 #include "meshkit/ModelEnt.hpp" 00027 #include "meshkit/MKCore.hpp" 00028 #include "meshkit/SizingFunction.hpp" 00029 #include "meshkit/RegisterMeshOp.hpp" 00030 00031 #include "meshkit/LocalSet.hpp" 00032 #include "meshkit/LocalTag.hpp" 00033 #include "meshkit/Matrix.hpp" 00034 00035 #include "meshkit/iMesh.hpp" 00036 #include "meshkit/iGeom.hpp" 00037 #include "MBCN.h" 00038 00039 #include "meshkit/vectortemplate.hpp" 00040 #include "meshkit/matrixtemplate.hpp" 00041 #include "meshkit/parser.hpp" 00042 #include "meshkit/SimpleArray.hpp" 00043 #include "meshkit/clock.hpp" 00044 #include "meshkit/mstream.hpp" 00045 00046 #include "iMesh_extensions.h" 00047 #include "MBiMesh.hpp" 00048 #include "moab/Interface.hpp" 00049 #include "moab/Range.hpp" 00050 #include "moab/Skinner.hpp" 00051 #include "MBTagConventions.hpp" 00052 #include "moab/MergeMesh.hpp" 00053 00054 00055 #ifdef USE_MPI 00056 #include "mpi.h" 00057 #include "iMeshP.h" 00058 #include "moab_mpi.h" 00059 #include "moab/ParallelMergeMesh.hpp" 00060 #include "moab/ParallelComm.hpp" 00061 #include "MBParallelConventions.h" 00062 #endif 00063 00064 #include "meshkit/CopyGeom.hpp" 00065 #include "meshkit/CopyMesh.hpp" 00066 #include "meshkit/ExtrudeMesh.hpp" 00067 #include "meshkit/CESets.hpp" 00068 00069 namespace MeshKit { 00070 00071 class MKCore; 00072 00073 class CoreGen : public MeshScheme 00074 { 00075 public: 00076 /* \brief Constructor 00077 * 00078 * Create a new CoreGen instance 00079 * \param impl the iGeom instance handle for the Geom 00080 */ 00081 CoreGen(MKCore *mk, const MEntVector &me_vec); 00082 00083 /* \brief Destructor 00084 */ 00085 virtual ~CoreGen(); 00086 00088 static const char* name(); 00089 00094 static bool can_mesh(iBase_EntityType dim); 00095 00102 static bool can_mesh(ModelEnt *me); 00103 00107 static const moab::EntityType* output_types(); 00108 00112 virtual const moab::EntityType* mesh_types_arr() const; 00113 00117 virtual bool add_modelent(ModelEnt *model_ent); 00118 00120 virtual void setup_this(); 00121 00123 virtual void execute_this(); 00124 00125 enum ErrorStates {INVALIDINPUT, ENEGATIVE}; 00126 int prepareIO (int argc, char *argv[], int nrank, int numprocs, std::string TestDir); 00127 int parse_assembly_names(CParser parse, int argc, char *argv[]); 00128 int load_meshes(); 00129 int load_meshes_more_procs(const int, int); 00130 int load_meshes_parallel(const int, int); 00131 int distribute_mesh(const int, int); 00132 int load_geometries(); 00133 int read_inputs_phase1 (int argc, char *argv[]); 00134 int read_inputs_phase2 (int argc, char *argv[]); 00135 int write_makefile (); 00136 int write_minfofile (); 00137 int find_assm(const int i, int &assm_index); 00138 void banner(); 00139 int copymove(const int nrank, const int numprocs); 00140 int copymove_all(const int nrank, const int numprocs); 00141 int set_copymove_coords(); 00142 int save_mesh(); 00143 int save_mesh(int rank); 00144 #ifdef USE_MPI 00145 int save_mesh_parallel(const int nrank, const int numprocs); 00146 #endif 00147 int save_geometry(); 00148 int shift_mn_ids(iBase_EntitySetHandle orig_set, int index); 00149 int extrude(); 00150 int move_verts(iBase_EntitySetHandle set, const double *dx); 00151 int move_geoms(iBase_EntitySetHandle set, const double *dx); 00152 int create_neumannset(); 00153 int refine_coremodel(); 00154 int load_and_compute_meshtogeom(iBase_EntitySetHandle set, std::string filenam); 00155 00156 bool extrude_flag, umr_flag; 00157 bool compute_meshtogeom; 00158 std::vector <int> bsameas, deg; 00159 bool mem_tflag; 00160 std::string prob_type, savefiles, info, minfo, same_as, reloading_mf; 00161 std::vector<std::string> files, all_meshfiles, mk_files; 00162 std::vector<int> assm_meshfiles, size_mf, times_loaded; 00163 std::vector<int> rank_load; 00164 std::vector<double> load_per_assm; 00165 std::vector< std::vector<int> > assm_location; 00166 std::vector<std::vector<int> > position_core; 00167 std::vector<int> meshfile_proc; 00168 std::vector<double> x_coord; 00169 std::vector<double> y_coord; 00170 bool nst_flag, nsb_flag, nss_flag, nssall_flag; 00171 std::vector<std::string> core_alias; 00172 std::vector<double> nsx, nsy, nsc; 00173 int num_nsside, ms_startid, ns_startid, nDegree; 00174 00175 private: 00177 iGeom *igeom; 00178 00180 iMesh *imesh; 00181 00183 moab::Interface *mb; 00184 00185 std::vector <CopyMesh*> cm; 00186 std::vector <CopyGeom*> cg; 00187 ExtrudeMesh *em; 00188 00189 iBase_EntitySetHandle root_set; 00190 std::vector<iBase_EntitySetHandle> assys; 00191 std::vector<int> assys_index; 00192 // declare variables read in the inputs 00193 int rank, procs, err; 00194 int UNITCELL_DUCT, ASSY_TYPES ; 00195 int nrings, nringsx, nringsy, pack_type, symm; 00196 double pitch, pitchx, pitchy; 00197 bool global_ids, back_mesh, have_hex27; 00198 std::string outfile, mesh_info; 00199 int nassys; // the number of mesh files 00200 int tot_assys; // total no. of assms forming core 00201 int set_DIM; // default is 3D 00202 double PII; 00203 double z_height; // z_height for extruding surfaces mesh 00204 int z_divisions; // z_divisions for extruding surface mesh 00205 int nst_Id, nsb_Id, nssall_Id; 00206 std::vector<int> nss_Id; 00207 std::string testdir; 00208 00209 // file related 00210 std::ifstream file_input; // File Input 00211 std::ofstream make_file, info_file, minfo_file; // File Output 00212 std::string iname, ifile, mfile, geometry, back_meshfile, geom_engine, nsLoc, meshtogeomfile, infofile, minfofile, logfilename; 00213 int linenumber; 00214 std::string card,geom_type, meshfile, mf_alias, temp_alias, etype; 00215 std::vector<std::string> assm_alias; 00216 std::vector<int> all_ms_starts, all_ns_starts; 00217 00218 mstream logfile, meshtogeom_file; 00219 00220 // parsing related 00221 std::string input_string; 00222 std::string comment; 00223 int MAXCHARS ; 00224 00225 // merge related 00226 double merge_tol; 00227 int do_merge; 00228 int update_sets; 00229 iBase_TagHandle merge_tag; 00230 00231 // MKUtils obj, assigning gid's etc. 00232 // MKUtils *mu; 00233 // error handler 00234 void IOErrorHandler (ErrorStates) const; 00235 CClock Timer; 00236 std::string szDateTime; 00237 int run_flag; 00238 clock_t sTime; 00239 #ifdef USE_MPI 00240 moab::ParallelComm *pc; 00241 #endif 00242 00243 // timing related variables 00244 double ctload, ctcopymove, ctmerge, ctextrude, ctns, ctgid, ctsave; 00245 clock_t tload, tcopymove, tmerge, textrude, tns, tgid, tsave; 00246 00247 // more memory/time related variables 00248 int ld_t, ld_tload, ld_tcopymove, ld_tsave, ld_tgid, ld_tmerge, ld_tns; 00249 unsigned long long mem1, mem2, mem3, mem4, mem5, mem6, mem7; 00250 }; 00251 00252 inline const char* CoreGen::name() 00253 { 00254 return "CoreGen"; 00255 } 00256 00257 inline bool CoreGen::can_mesh(iBase_EntityType) 00258 { 00259 return false; 00260 } 00261 00262 inline bool CoreGen::can_mesh(ModelEnt *) 00263 { 00264 return true; 00265 } 00266 00267 inline const moab::EntityType* CoreGen::mesh_types_arr() const 00268 { 00269 return output_types(); 00270 } 00271 00272 } // namespace MeshKit 00273 #endif
