MeshKit
1.0
00001 /* 00002 * MBVolOp.cpp 00003 * 00004 * Created on: Jan 13, 2012 00005 */ 00006 00007 #include "meshkit/MBVolOp.hpp" 00008 #include "meshkit/MBSplitOp.hpp" 00009 #include "meshkit/ModelEnt.hpp" 00010 #include "moab/CartVect.hpp" 00011 00012 //#include "moab/Core.hpp" 00013 //#include "meshkit/FBiGeom.hpp" 00014 00015 00016 namespace MeshKit { 00017 00018 00019 //Entity Type initialization for splitting; no mesh output 00020 moab::EntityType MBVolOp_tps[] = { moab::MBMAXTYPE }; // no mesh, really 00021 const moab::EntityType* MBVolOp::output_types() 00022 { 00023 return MBVolOp_tps; 00024 } 00025 00026 MBVolOp::MBVolOp(MKCore *mk_core, const MEntVector &me_vec) : 00027 MeshScheme(mk_core, me_vec) 00028 { 00029 _direction[0]=_direction[1]=0.; 00030 _direction[2]=1.0; 00031 _pGTT = NULL; 00032 _rootSet = 0; // it means no set yet, although 0 mean root set in moab 00033 _fbe = NULL; 00034 } 00035 00036 MBVolOp::~MBVolOp() { 00037 // TODO Auto-generated destructor stub 00038 } 00039 void MBVolOp::setup_this() 00040 { 00041 // construct an FBEngine object, used more like a container, and to trigger the weaving 00042 // it is not really required; this object is based on gtt object build from top and bottom faces 00043 // ( which are extracted from model entities of dimension 2) 00044 // so, involve FBEngine just because we have something we need there 00045 // collect the top and bottom faces from ment vector 00046 int nTotSurf = this->mentSelection.size(); 00047 std::cout << " total number of faces:" << nTotSurf << "\n"; 00048 00049 // grab all surfaces, and duplicate model using gtt, to get new gsets, that will be 00050 // continued with volume sets in the end 00051 // establish the loops from faces 00052 MEntSelection::iterator mit; 00053 00054 moab::Interface * MBI = mk_core()->moab_instance(); 00055 moab::GeomTopoTool gtt(MBI, true);// to retrieve the gsets 00056 moab::EntityHandle mset; 00057 // these should all be of dimension 2, faces 00058 std::vector<moab::EntityHandle> vSurfaces; 00059 00060 moab::ErrorCode rval; 00061 00062 for (mit = mentSelection.begin(); mit != mentSelection.end(); mit++) { 00063 mset = (mit->first)->mesh_handle(); 00064 // get the globalId tag 00065 vSurfaces.push_back(mset); 00066 } 00067 00068 rval = gtt.duplicate_model(_pGTT, &vSurfaces); 00069 MBERRCHK(rval, MBI); 00070 // now, _pGTT will have the new sets, which will form the basis for the volume creation 00071 // new gsets will be added to this _pGTT, and this will (unfortunately) create an OBB tree too, 00072 // although we do not really need it (actually, 2 obb trees that are not needed!) bummer! 00073 // the result will be the model root set of the new GTT, stored in result range 00074 // that corresponds to the first model ent 00075 ModelEnt * firstMe = (*(mentSelection.begin()) ).first; 00076 moab::Range & resultRange = mentSelection[firstMe]; 00077 _rootSet = _pGTT->get_root_model_set(); 00078 resultRange.insert(_rootSet); 00079 _fbe = new moab::FBEngine(MBI, _pGTT, false);// smooth=false, not needed here (are you sure?) 00080 //we will use FBEngine for querying; although ModelEnt would have helped 00081 // still, the model ent works with geometry adjacency; in this case, there is no geometry 00082 // we need to work directly with MOAB; 00083 // not pretty :( 00084 // we build all this infrastructure and I am not using it 00085 00086 00087 establish_mapping(); 00088 return; 00089 } 00090 void MBVolOp::establish_mapping() 00091 { 00092 // the first half of the surfaces are bottom, next are top 00093 // establish the connection between top and bottom entities 00094 // use the direction for vertices, and tangent direction for edges 00095 00096 // these are all vertices from current gtt 00097 moab::Interface * MBI = mk_core()->moab_instance(); 00098 moab::Range verticeSets= _pGTT->geoRanges()[0]; 00099 int num_vertices = verticeSets.size(); 00100 std::vector<moab::CartVect> coordVert; 00101 coordVert.resize(num_vertices); 00102 std::vector<int> corrV; 00103 corrV.resize(num_vertices); 00104 moab::ErrorCode rval = moab::MB_SUCCESS; 00105 std::map<moab::EntityHandle, int> indexVertex; 00106 for (int i=0; i<num_vertices; i++) 00107 { 00108 rval = _fbe->getVtxCoord(verticeSets[i], &(coordVert[i][0]), 00109 &(coordVert[i][1]), &(coordVert[i][2])); 00110 MBERRCHK(rval, MBI); 00111 corrV[i]=-1;// no correspondence yet 00112 indexVertex[verticeSets[i]] = i; 00113 } 00114 00115 // decide with an expensive linear search, what vertices correspond to what 00116 moab::CartVect dirr(_direction); 00117 dirr.normalize(); 00118 int j=-1; 00119 for ( j=0; j<num_vertices; j++) 00120 { 00121 if (corrV[j]!=-1) 00122 continue; // we already know about this one 00123 moab::CartVect & v1 = coordVert[j]; 00124 int minIndex = -1; 00125 double minVal = 1.e38; // HUGE 00126 for (int k=0; k<num_vertices; k++) 00127 { 00128 if (j==k || corrV[k]>-1) 00129 continue; 00130 moab::CartVect product = (v1-coordVert[k])*dirr; 00131 double valProd = product.length_squared(); 00132 if (valProd<minVal) 00133 { 00134 minVal = valProd; 00135 minIndex=k; 00136 } 00137 } 00138 std::cout<<"j: "<< j <<" val min:" << minVal << " min index:" << minIndex << "\n"; 00139 if (minIndex==-1) 00140 { 00141 std::cout<< "Error Stop it. j: " << j << "\n"; 00142 continue; 00143 } 00144 // make sure that the lower index is on bottom 00145 double dotProd = (coordVert[minIndex]-coordVert[j])%dirr; 00146 if (dotProd < 0) 00147 { 00148 std::cout<<"wrong orientation, bottom vertices should be of lower index\n"; 00149 MBERRCHK(moab::MB_FAILURE, MBI);// bail out from here, stop it! 00150 } 00151 00152 corrV[j] = minIndex; 00153 corrV[minIndex] = j; 00154 } 00155 // check that we do not have any left vertices 00156 for (j=0; j<num_vertices; j++) 00157 { 00158 if (corrV[j]==-1) 00159 { 00160 std::cout<<"Error in finding a corresponding vertex to j:"<<j <<"\n"; 00161 MBERRCHK(moab::MB_FAILURE, MBI);// bail out from here, stop it! 00162 } 00163 vertexMap[verticeSets[j]]= verticeSets[corrV[j]]; 00164 } 00165 00166 // so now we have mappings between vertices 00167 // we need to build mappings between edges and faces. 00168 // we usually start with bottom and continue to the top 00169 moab::Range edgeSets= _pGTT->geoRanges()[1]; 00170 int numEdges = edgeSets.size(); 00171 std::vector<moab::CartVect> edgeTangents; 00172 edgeTangents.resize(numEdges*2);// we need 2 tangents per edge 00173 // for each vertex, compute the tangents at ends, projected on a plan perpendicular to the direction 00174 // (usually, xy plan...) 00175 // tangents at both ends!// we know that the u range is from 0 to 1 00176 std::vector<int> corrE; 00177 corrE.resize(numEdges); 00178 std::map<moab::EntityHandle, int> indexEdge; 00179 for (j=0; j<numEdges; j++) 00180 { 00181 corrE[j] = -1;// no correspondence yet 00182 indexEdge[edgeSets[j]] = j; 00183 // careful about the FBEngine, it is not smooth 00184 std::vector<moab::EntityHandle> meshEdges; 00185 rval = MBI->get_entities_by_type(edgeSets[j], moab::MBEDGE, meshEdges); 00186 MBERRCHK(rval, MBI); 00187 // get first and last edges, connectivity and compute tangent 00188 // it will be used to map edges 00189 // first edge, last edge 00190 moab::EntityHandle firstMeshEdge = meshEdges[0]; 00191 moab::EntityHandle lastMeshEdge = meshEdges[meshEdges.size()-1]; 00192 const moab::EntityHandle * conn=NULL; 00193 int nnodes; 00194 rval = MBI->get_connectivity(firstMeshEdge, conn, nnodes); 00195 MBERRCHK(rval, MBI); 00196 moab::CartVect posi[2]; 00197 rval = MBI->get_coords(conn, 2, &(posi[0][0])); 00198 MBERRCHK(rval, MBI); 00199 posi[0] = posi[1]-posi[0]; // 00200 posi[0] = posi[0]*dirr; 00201 edgeTangents[2*j] = posi[0]*dirr;// this is in the plane 00202 edgeTangents[2*j].normalize();// it should be non null, but accidents happen :) 00203 rval = MBI->get_connectivity(lastMeshEdge, conn, nnodes); 00204 MBERRCHK(rval, MBI); 00205 rval = MBI->get_coords(conn, 2, &(posi[0][0])); 00206 MBERRCHK(rval, MBI); 00207 posi[0] = posi[1]-posi[0]; // 00208 posi[0] = posi[0]*dirr; 00209 edgeTangents[2*j+1] = posi[0]*dirr;// this is in the plane 00210 edgeTangents[2*j+1].normalize(); 00211 } 00212 // now try to match edges based on their vertices matching, and start and end tangents matching 00213 for (j = 0; j<numEdges; j++) 00214 { 00215 if (corrE[j]>=0) 00216 continue; // we already have a correspondent edge for it 00217 moab::Range adjVertices; 00218 rval = _fbe-> getEntAdj(edgeSets[j], /*vertex type*/0, adjVertices); 00219 MBERRCHK(rval, MBI); 00220 if (adjVertices.size()==2) 00221 { 00222 int sense=0; 00223 rval = _fbe->getEgVtxSense(edgeSets[j], adjVertices[0], adjVertices[1], sense); 00224 MBERRCHK(rval, MBI); 00225 // find the edges that are adjacent to map(v0) and map(v1) 00226 moab::EntityHandle mapV0 = vertexMap [adjVertices[0]]; 00227 moab::EntityHandle mapV1 = vertexMap [adjVertices[1]]; 00228 // get all edges adjacent to both vertices 00229 moab::Range adjEdges0, adjEdges1; 00230 rval = _fbe-> getEntAdj(mapV0, /*edge type*/1, adjEdges0); 00231 MBERRCHK(rval, MBI); 00232 rval = _fbe-> getEntAdj(mapV1, /*edge type*/1, adjEdges1); 00233 adjEdges0 = intersect(adjEdges0, adjEdges1); 00234 // the mapped edge should be in this range 00235 moab::CartVect & t0=edgeTangents[2*j]; 00236 moab::CartVect & t1=edgeTangents[2*j+1]; 00237 for (moab::Range::iterator rit= adjEdges0.begin(); rit!=adjEdges0.end(); rit++) 00238 { 00239 moab::EntityHandle candidateMapEdge = *rit; 00240 int sense1=0; 00241 int indexCandEdge = indexEdge[candidateMapEdge]; 00242 if (indexCandEdge == j) 00243 // error 00244 MBERRCHK(moab::MB_FAILURE, MBI); 00245 moab::CartVect & tm0=edgeTangents[2*indexCandEdge]; 00246 moab::CartVect & tm1=edgeTangents[2*indexCandEdge+1]; 00247 rval = _fbe->getEgVtxSense(candidateMapEdge, mapV0, mapV1, sense1); 00248 MBERRCHK(rval, MBI); 00249 00250 if (sense*sense1>0)// same sense 00251 { 00252 if ( (t0%tm0 >= 0.99 ) && (t1%tm1>=0.99))// same sense, almost.. 00253 { 00254 corrE[j]=indexCandEdge; 00255 corrE[indexCandEdge] = j; 00256 } 00257 } 00258 else 00259 { 00260 // different senses, check the opposite tangents 00261 if ( (t0%tm0 <=-0.99) && (t1%tm1<=-0.99) ) 00262 { 00263 // how do we store the opposite senses? 00264 corrE[j]=indexCandEdge; 00265 corrE[indexCandEdge] = j; 00266 } 00267 } 00268 } 00269 if (corrE[j]==-1) 00270 MBERRCHK(moab::MB_FAILURE, MBI);// can't find a corresponding edge 00271 00272 } 00273 } 00274 // so we have edge matching for every edge 00275 for (j=0; j<numEdges; j++) 00276 { 00277 if (corrE[j]==-1) 00278 { 00279 std::cout<<"Error in finding a corresponding edge: "<<j <<"\n"; 00280 MBERRCHK(moab::MB_FAILURE, MBI);// bail out from here, stop it! 00281 } 00282 std::cout<< "edge j=" << j << " mapped to edge " << corrE[j] << "\n"; 00283 edgeMap[edgeSets[j]]= edgeSets[corrE[j]]; 00284 } 00285 // now, we still need to separate top and bottom faces, somehow 00286 // we assume faces were stenciled correctly with the same polylines 00287 // start from bottom vertices (first half of the vertices is on bottom) 00288 moab::Range bottomFaces; 00289 for (j=0; j<num_vertices/2; j++)// we know that half are on bottom, we verified that already 00290 { 00291 moab::Range faces; 00292 rval = _fbe-> getEntAdj(verticeSets[j], /*face type*/2, faces); 00293 MBERRCHK(rval, MBI); 00294 bottomFaces.merge(faces); 00295 } 00296 // now find the mapped face for each of these, based on mapped edges 00297 for (j=0; j<(int)bottomFaces.size(); j++) 00298 { 00299 moab::Range edges; 00300 rval = _fbe-> getEntAdj(bottomFaces[j], /*edge type*/1, edges); 00301 MBERRCHK(rval, MBI); 00302 moab::Range mappedEdges; 00303 // get now the face connected to the mapped edges 00304 int i=0; 00305 // find the face with all those edges among the other faces 00306 00307 moab::Range mapFaces; 00308 rval = _fbe-> getEntAdj(edgeMap[edges[0]], /*edge type*/2, mapFaces); 00309 MBERRCHK(rval, MBI); 00310 for (i=1; i<(int)edges.size(); i++) 00311 { 00312 moab::Range faces; 00313 rval = _fbe-> getEntAdj(edgeMap[edges[i]], /*edge type*/2, faces); 00314 mapFaces = intersect(mapFaces, faces); 00315 } 00316 if (mapFaces.size()!=1) 00317 { 00318 std::cout<<"Can't find unique mapped face to face index " << j << "\n"; 00319 MBERRCHK(moab::MB_FAILURE, MBI);// bail out from here, stop it! 00320 } 00321 faceMap[bottomFaces[j]] = mapFaces[0]; 00322 faceMap[mapFaces[0]]=bottomFaces[j]; 00323 std::cout << "face j:" << j << " set:" << MBI->id_from_handle(bottomFaces[j]) << " mapped to " 00324 << MBI->id_from_handle(mapFaces[0]) << "\n"; 00325 } 00326 00327 } 00328 00329 void MBVolOp::execute_this() 00330 { 00331 // now, we have the maps between top and bottom faces established, also for edges and vertices 00332 // first build edges between corresponding vertices, then faces between edges, then 00333 // finally, volumes 00334 // we start from bottom towards top 00335 moab::ErrorCode rval = moab::MB_SUCCESS; 00336 moab::Interface * MBI = mk_core()->moab_instance(); 00337 00338 moab::Range verticeSets=_pGTT->geoRanges()[0]; 00339 int num_vertices = verticeSets.size(); 00340 moab::Range bottomEdges; 00341 int j=0; 00342 for (j=0; j<num_vertices/2; j++)// we know that half are on bottom, we verified that already 00343 { 00344 moab::Range edges; 00345 rval = _fbe-> getEntAdj(verticeSets[j], /*edge type*/1, edges); 00346 MBERRCHK(rval, MBI); 00347 bottomEdges.merge(edges); 00348 } 00349 // we need to decide bottom faces before we create new faces, edges, etc 00350 moab::Range bottomFaces; 00351 for (j=0; j<num_vertices/2; j++)// we know that half are on bottom, we verified that already 00352 { 00353 moab::Range faces; 00354 rval = _fbe-> getEntAdj(verticeSets[j], /*face type*/2, faces); 00355 MBERRCHK(rval, MBI); 00356 bottomFaces.merge(faces); 00357 } 00358 00359 // we have verified that the first half are from bottom surfaces 00360 // for each bottom face we will create a volume; 00361 // start with the edges, create weaving faces between edges (no new vertices!) 00362 // now, for each bottom edge, create a weaving face 00363 std::vector<moab::EntityHandle> newFaces; 00364 newFaces.resize(bottomEdges.size()); 00365 for (j=0; j<(int)bottomEdges.size(); j++) 00366 { 00367 rval = _fbe->weave_lateral_face_from_edges(bottomEdges[j], edgeMap[bottomEdges[j]], _direction, newFaces[j]); 00368 MBERRCHK(rval, MBI); 00369 } 00370 // now, to create volumes, we need to loop over bottom faces and add volumes one by one, and the 00371 // orientation of faces in them 00372 00373 int volumeMatId = 0;// just give a mat id, for debugging, mostly 00374 moab::Tag matTag; 00375 rval = MBI->tag_get_handle("MATERIAL_SET", 1, moab::MB_TYPE_INTEGER, matTag); 00376 MBERRCHK(rval, MBI); 00377 00378 for (j = 0; j<(int)bottomFaces.size(); j++) 00379 { 00380 // create volume here , finally!!! 00381 moab::EntityHandle volume; 00382 rval = MBI->create_meshset(moab::MESHSET_SET, volume); 00383 MBERRCHK(rval, MBI); 00384 volumeMatId++; 00385 rval= MBI->tag_set_data(matTag, &volume, 1, &volumeMatId); 00386 MBERRCHK(rval, MBI); 00387 moab::EntityHandle botFace = bottomFaces[j]; 00388 moab::EntityHandle topFace = faceMap[botFace]; 00389 // start copy 00390 // get the edges of bot face 00391 rval= MBI->add_parent_child(volume, botFace); 00392 MBERRCHK(rval, MBI); 00393 00394 rval= MBI->add_parent_child(volume, topFace); 00395 MBERRCHK(rval, MBI); 00396 00397 rval = _pGTT->add_geo_set(volume, 3); 00398 MBERRCHK(rval, MBI); 00399 00400 // set senses 00401 // bottom face is negatively oriented, its normal is toward interior of the volume 00402 rval = _pGTT->set_sense(botFace, volume, -1); 00403 MBERRCHK(rval, MBI); 00404 00405 // the top face is positively oriented 00406 rval = _pGTT->set_sense(topFace, volume, 1); 00407 MBERRCHK(rval, MBI); 00408 00409 // the children should be in the same direction 00410 // get the side edges of each face, and form lateral faces, along direction 00411 std::vector<moab::EntityHandle> edges1; 00412 00413 rval = MBI->get_child_meshsets(botFace, edges1); // no hops 00414 MBERRCHK(rval, MBI); 00415 00416 for (unsigned int i = 0; i < edges1.size(); ++i) 00417 { 00418 // the orientation of edge in face will give the sense of face in volume 00419 int indexB = bottomEdges.index(edges1[i]); 00420 if (indexB<=-1) 00421 MBERRCHK(moab::MB_FAILURE, MBI); 00422 int sense = 1; 00423 rval = _pGTT->get_sense(edges1[i], botFace, sense); 00424 MBERRCHK(rval, MBI); 00425 rval=MBI->add_parent_child(volume, newFaces[indexB]); 00426 MBERRCHK(rval, MBI); 00427 00428 // set sense as the one decided from the bottom edge sense within the bottom face 00429 rval = _pGTT->set_sense(newFaces[indexB], volume, sense); 00430 MBERRCHK(rval, MBI); 00431 } 00432 // end copy 00433 } 00434 00435 00436 delete _fbe; 00437 delete _pGTT; // when we are done, remove the _pGTT; 00438 // at this point, the result will be the model root set of the first ment of the model 00439 // ( (*(mentSelection.begin()) ).second ) 00440 } 00441 00442 }
